Fhem 5.0 released
Begonnen von rudolfkoenig, 15 August 2010, 15:16:56
I just released fhem 5.0. From the CHANGED file:
feature: KM271
bugfix:  99_SUNRISE_EL endless loop bug
feature: CUL: optional baudrate spec in definition
feature: CUL: sendpool attribute
feature: CUL_HOERMANN module added
bugfix:  DST change: absolute at and relative sunrise fix
feature: FHEMWEB javascript additions for SVG plots (click on lines/
labels)
feature: FHEMWEB smallscreen attribute (for smartphones)
bugfix:  the internal fhem() used in perl oneliners does not return a
value
feature: Dimmer function of X10 module changed to match FS20
feature: allow only meaningful readings (fill level > -5%) in USF1000
feature: device attr links in commandref.html
bugfix:  make BS known to CUL to avoid lost messages if both FHZ1300
and CUL  are connected, adjust matching rule
feature: Copy&Paste in SVG
feature: Debian/Ubuntu Package. Install-path changes to satisfy
lintian
feature: Allnet 3076/4027/4000T
feature: RFXCOMM Module for Oregon Weatherstations
feature: Davis VantagePro2
feature: ELV USB-WDE1
feature: addvaltriggers CUL attribute for adding RSSI as a trigger
feature: CUL_WS sanity check for large temp differences.
Notes:
- **Important**: The default installation path is changed to satisfy
lintian (lint for .deb files)
- 5.0 is just the successor of 4.9 and _NOT_ the  one which implements
the discussed guidelines and interfaces documented on fhemwiki.de.
That release will most probably be named 6.0, and will require changes
in the fhem configuration file.
Sie haben diese Nachricht erhalten, da Sie der Google Groups-Gruppe FHEM users beigetreten sind.
Wenn Sie Nachrichten in dieser Gruppe posten möchten, senden Sie eine E-Mail an fhem-users@googlegroups.com.
Wenn Sie aus dieser Gruppe austreten möchten, senden Sie eine E-Mail an fhem-users+unsubscribe@googlegroups.com.
Besuchen Sie die Gruppe unter http://groups.google.com/group/fhem-users?hl=de, um weitere Optionen zu erhalten.
Zrrronggg!
Also eigentlich 4.10
Das heisst aber auch, das meine 4.9 konfig mit 5.0 unverändert gehen
sollte, richtig?
Guest
Hallo Rudi,
vielen Dank für die neue Version!
Habe sie bei mir installiert und bin von autocreate begeistert -> tut
alles :-)
Beim anlegen eines neuen notify Eintrages bin ich glaub über einen
Doku Fehler in commandref.html gestolpert
Schreib ich  define b3lampV3 notify btn3 set lamp1 %;;set lamp2 % mit
zwei Semikolons geht nix mit einem kann ich dann die FS20 Steckdosen
hintereinander angeben.
Also so geht's: define b3lampV3 notify btn3 set lamp1 %;set lamp2
Domi
> Also so geht's: define b3lampV3 notify btn3 set lamp1 %;set lamp2 %
Gilt nur, wenn man das im modify Fenster von FHEMWEB (pgm2) macht, es nimmt
einem das laestige \ bzw ;; ab.
Elegenter ist:
  define b3lampV3 notify btn3 set lamp1,lamp2 %
Guest
ah Danke!
Stimmt ich habe versucht um ein Edit des Config Files herumzukommen
und konsequent alles mit autocreate zu machen.
Dabei beim ersten mal das save vergessen...
