seltsames Verhalten bei update (gelöst)
Begonnen von satprofi, 13 Oktober 2016, 16:05:06
satprofi
Hallo.
Wenn ich update 71_ONKYO_AVR_ZONE eingebe wird mir dies dann ausgegeben.
2016.10.13 15:59:53 1: UPD FHEM/71_ONKYO_AVR_ZONE.pm
2016.10.13 15:59:53 1: New entries in the CHANGED file:
2016.10.13 15:59:53 1:   - bugfix:  49_SSCam: Experimental keys on scalar is now forbidden
2016.10.13 15:59:53 1:                        (Perl >= 5.23) Forum: #msg501709
2016.10.13 15:59:53 1:   - added:   37_dash_dhcp.pm: new module for amazon dash buttons
2016.10.13 15:59:53 1:   - feature: 98_Hyperion: removed attribute hyperionAttrRestore
2016.10.13 15:59:53 1:                           default attributes just being added on define
2016.10.13 15:59:53 1:   - added:   73_NUKIBridge,74_NUKIDevice: New Modules to control Nuki Smartlocks
2016.10.13 15:59:53 1:   - feature: 98_Hyperion: new attribute hyperionAttrRestore
2016.10.13 15:59:53 1:                           readings will always be refreshed now
2016.10.13 15:59:53 1:   - feature: 93_DbRep: deviceRename added, new Internal DATABASE,
2016.10.13 15:59:53 1:                        Internal/Attribute ROLE added for Autorename-function
2016.10.13 15:59:53 1:   - bugfix:  93_DbRep: delEntries not running on SQLite
2016.10.13 15:59:53 1:   - added:   74_THINKINGCLEANER: new module to support remote control of
2016.10.13 15:59:53 1:                                Roomba cleaning robots
2016.10.13 15:59:53 1:   - feature: 02_FTUISRV: if and loop constructs added
2016.10.13 15:59:53 1:   - bugfix:  74_AMAD: fix FHEM crash when use AMAD and apptime togehter
2016.10.13 15:59:53 1:   - new:     98_TRAFFIC: provide traffic details with Google Distance API
2016.10.13 15:59:53 1:   - feature: 98_Hyperion: set configFile only available if at least two files
2016.10.13 15:59:53 1:                           are found while get configFiles
2016.10.13 15:59:53 1:                           minor code improvements
2016.10.13 15:59:53 1:   - feature: 50_TelegramBot: urlescaped filenames / location send-receive
2016.10.13 15:59:53 1:                             timeout for send
2016.10.13 15:59:53 1:   - feature: 73_ElectricityCalculator: header and readingFnAttributes added
2016.10.13 15:59:53 1:   - feature: 73_GasCalculator: header and readingFnAttributes added
2016.10.13 15:59:53 1:   - feature: 73_km200: header and readingFnAttributes added
2016.10.13 15:59:53 1:   - feature: 93_DbRep: function minValue added
2016.10.13 15:59:53 1:   - bugfix:  38_netatmo: fix for invalid forecast data crashing FHEM
2016.10.13 15:59:53 1: ... rest of lines skipped.
2016.10.13 15:59:53 1: Calling /usr/bin/perl /opt/fhem/contrib/commandref_join.pl, this may take a while
Schaut so aus als würder damit fhem komplettes update fahren.
2016.10.13 16:02:40 1: *** EN FHEM/95_Alarm.pm: Unbalanced tr (-1, last line ok: 856)
2016.10.13 16:02:40 1: *** EN FHEM/57_Calendar.pm: Unbalanced table (-3, last line ok: 1374)
2016.10.13 16:02:40 1: *** EN FHEM/98_CustomReadings.pm: Unbalanced tr (1, last line ok: 163)
2016.10.13 16:02:40 1: *** EN FHEM/98_CustomReadings.pm: Unbalanced td (3, last line ok: 163)
2016.10.13 16:02:40 1: *** EN FHEM/98_DOIF_ori.pm: No a-tag with name="DOIF_ori"
2016.10.13 16:02:40 1: *** EN FHEM/36_EC3000.pm: Unbalanced tr (1, last line ok: 187)
2016.10.13 16:02:40 1: *** EN FHEM/36_EC3000.pm: Unbalanced td (1, last line ok: 187)
2016.10.13 16:02:40 1: *** EN FHEM/10_EIB.pm: Unbalanced div (-10, last line ok: 1285)
2016.10.13 16:02:40 1: *** EN FHEM/36_EMT7110.pm: Unbalanced tr (1, last line ok: 232)
2016.10.13 16:02:40 1: *** EN FHEM/36_EMT7110.pm: Unbalanced td (1, last line ok: 232)
2016.10.13 16:02:40 1: *** EN FHEM/72_FB_CALLLIST.pm: Unbalanced tr (1, last line ok: 1024)
2016.10.13 16:02:40 1: *** EN FHEM/72_FB_CALLLIST.pm: Unbalanced td (-3, last line ok: 1044)
2016.10.13 16:02:40 1: *** EN FHEM/72_FB_CALLMONITOR.pm: Unbalanced tr (1, last line ok: 1758)
2016.10.13 16:02:40 1: *** EN FHEM/72_FB_CALLMONITOR.pm: Unbalanced td (1, last line ok: 1758)
2016.10.13 16:02:40 1: *** EN FHEM/72_FRITZBOX.pm: Unbalanced div (-1, last line ok: 4754)
2016.10.13 16:02:40 1: *** EN FHEM/98_GEOFANCY.pm: Unbalanced div (-4, last line ok: 514)
2016.10.13 16:02:40 1: *** EN FHEM/98_HourCounter.pm: Unbalanced div (-25, last line ok: 841)
2016.10.13 16:02:40 1: *** EN FHEM/70_JSONMETER.pm: Unbalanced div (-1, last line ok: 1035)
2016.10.13 16:02:40 1: *** EN FHEM/23_LUXTRONIK2.pm: Unbalanced div (-1, last line ok: 1888)
2016.10.13 16:02:40 1: *** EN FHEM/36_LaCrosse.pm: Unbalanced tr (1, last line ok: 534)
2016.10.13 16:02:40 1: *** EN FHEM/36_LaCrosse.pm: Unbalanced td (1, last line ok: 534)
2016.10.13 16:02:40 1: *** EN FHEM/36_Level.pm: Unbalanced tr (1, last line ok: 208)
2016.10.13 16:02:40 1: *** EN FHEM/36_Level.pm: Unbalanced td (1, last line ok: 208)
2016.10.13 16:02:40 1: *** EN FHEM/00_MAXLAN.pm: Unbalanced tr (1, last line ok: 868)
2016.10.13 16:02:40 1: *** EN FHEM/00_MAXLAN.pm: Unbalanced td (1, last line ok: 868)
2016.10.13 16:02:40 1: *** EN FHEM/59_OPENWEATHER.pm: Unbalanced div (-1, last line ok: 638)
2016.10.13 16:02:40 1: *** EN FHEM/36_PCA301.pm: Unbalanced tr (1, last line ok: 290)
2016.10.13 16:02:40 1: *** EN FHEM/36_PCA301.pm: Unbalanced td (1, last line ok: 290)
2016.10.13 16:02:40 1: *** EN FHEM/70_PHTV.pm: Unbalanced div (-6, last line ok: 3715)
2016.10.13 16:02:40 1: *** EN FHEM/73_PRESENCE.pm: Unbalanced tr (1, last line ok: 1032)
2016.10.13 16:02:40 1: *** EN FHEM/73_PRESENCE.pm: Unbalanced td (1, last line ok: 1032)
2016.10.13 16:02:40 1: *** EN FHEM/59_PROPLANTA.pm: Unbalanced div (-1, last line ok: 922)
2016.10.13 16:02:40 1: *** EN FHEM/40_RFXCOM.pm: Unbalanced tr (1, last line ok: 381)
2016.10.13 16:02:40 1: *** EN FHEM/40_RFXCOM.pm: Unbalanced td (1, last line ok: 381)
2016.10.13 16:02:40 1: *** EN FHEM/51_RPI_GPIO.pm: Unbalanced table (-4, last line ok: 687)
2016.10.13 16:02:40 1: *** EN FHEM/74_S0COUNTER.pm: No document text found
2016.10.13 16:02:40 1: *** EN FHEM/34_SWAP.pm: Unbalanced tr (1, last line ok: 1261)
2016.10.13 16:02:40 1: *** EN FHEM/34_SWAP.pm: Unbalanced td (1, last line ok: 1261)
2016.10.13 16:02:40 1: *** EN FHEM/35_SWAP_0000002200000003.pm: Unbalanced tr (1, last line ok: 385)
2016.10.13 16:02:40 1: *** EN FHEM/35_SWAP_0000002200000003.pm: Unbalanced td (1, last line ok: 385)
2016.10.13 16:02:40 1: *** EN FHEM/35_SWAP_0000002200000008.pm: Unbalanced tr (1, last line ok: 78)
2016.10.13 16:02:40 1: *** EN FHEM/35_SWAP_0000002200000008.pm: Unbalanced td (1, last line ok: 78)
2016.10.13 16:02:40 1: *** EN FHEM/42_SYSMON.pm: Unbalanced table (-1, last line ok: 5054)
2016.10.13 16:02:40 1: *** EN FHEM/42_SYSMON.pm: Unbalanced td (-66, last line ok: 4962)
2016.10.13 16:02:40 1: *** EN FHEM/42_SYSMON.pm: Unbalanced div (-23, last line ok: 4962)
2016.10.13 16:02:40 1: *** EN FHEM/45_TRX.pm: Unbalanced tr (1, last line ok: 411)
2016.10.13 16:02:40 1: *** EN FHEM/45_TRX.pm: Unbalanced td (1, last line ok: 411)
2016.10.13 16:02:40 1: *** EN FHEM/70_TellStick.pm: Unbalanced div (1, last line ok: 349)
2016.10.13 16:02:40 1: *** EN FHEM/70_WS3600.pm: Unbalanced div (-1, last line ok: 461)
2016.10.13 16:02:40 1: *** EN FHEM/32_WifiLight_LD686.pm: No a-tag with name="WifiLight_LD686"
2016.10.13 16:02:40 1: *** EN FHEM/73_km200.pm: Unbalanced td (-28, last line ok: 2981)
2016.10.13 16:02:40 1: *** EN FHEM/95_remotecontrol.pm: Unbalanced td (-1, last line ok: 409)
2016.10.13 16:02:40 1: *** EN FHEM/98_statistics.pm: Unbalanced div (-1, last line ok: 1243)
2016.10.13 16:02:40 1: *** EN FHEM/95_webViewControl.pm: No document text found
2016.10.13 16:02:40 1: *** DE FHEM/57_Calendar.pm: Unbalanced table (-3, last line ok: 1580)
2016.10.13 16:02:40 1: *** DE FHEM/72_FB_CALLLIST.pm: Unbalanced tr (1, last line ok: 1220)
2016.10.13 16:02:40 1: *** DE FHEM/72_FB_CALLLIST.pm: Unbalanced td (-3, last line ok: 1241)
2016.10.13 16:02:40 1: *** DE FHEM/72_FB_CALLMONITOR.pm: Unbalanced tr (1, last line ok: 1902)
2016.10.13 16:02:40 1: *** DE FHEM/72_FB_CALLMONITOR.pm: Unbalanced td (1, last line ok: 1902)
2016.10.13 16:02:40 1: *** DE FHEM/72_FRITZBOX.pm: Unbalanced div (-1, last line ok: 5076)
2016.10.13 16:02:40 1: *** DE FHEM/98_GEOFANCY.pm: Unbalanced div (-2, last line ok: 564)
2016.10.13 16:02:40 1: *** DE FHEM/98_HMinfo.pm: Unbalanced tr (1, last line ok: 2501)
2016.10.13 16:02:40 1: *** DE FHEM/98_HMinfo.pm: Unbalanced td (1, last line ok: 2501)
2016.10.13 16:02:40 1: *** DE FHEM/70_JSONMETER.pm: Unbalanced div (-1, last line ok: 1159)
2016.10.13 16:02:40 1: *** DE FHEM/23_LUXTRONIK2.pm: Unbalanced div (-1, last line ok: 2029)
2016.10.13 16:02:40 1: *** DE FHEM/59_OPENWEATHER.pm: Unbalanced div (-1, last line ok: 749)
2016.10.13 16:02:40 1: *** DE FHEM/73_PRESENCE.pm: Unbalanced tr (1, last line ok: 1275)
2016.10.13 16:02:40 1: *** DE FHEM/73_PRESENCE.pm: Unbalanced td (1, last line ok: 1275)
2016.10.13 16:02:40 1: *** DE FHEM/59_PROPLANTA.pm: Unbalanced div (-1, last line ok: 1042)
2016.10.13 16:02:40 1: *** DE FHEM/51_RPI_GPIO.pm: Unbalanced table (-4, last line ok: 876)
2016.10.13 16:02:40 1: *** DE FHEM/42_SYSMON.pm: Unbalanced table (-1, last line ok: 5715)
2016.10.13 16:02:40 1: *** DE FHEM/42_SYSMON.pm: Unbalanced td (-66, last line ok: 5623)
2016.10.13 16:02:40 1: *** DE FHEM/42_SYSMON.pm: Unbalanced div (-23, last line ok: 5623)
2016.10.13 16:02:40 1: *** DE FHEM/70_WS3600.pm: Unbalanced div (-1, last line ok: 645)
2016.10.13 16:02:40 1: *** DE FHEM/73_km200.pm: Unbalanced td (-28, last line ok: 3172)
2016.10.13 16:02:40 1: *** DE FHEM/95_remotecontrol.pm: Unbalanced td (-1, last line ok: 495)
2016.10.13 16:02:40 1: *** DE FHEM/98_statistics.pm: Unbalanced div (-1, last line ok: 1396)
2016.10.13 16:02:40 1: update finished, "shutdown restart" is needed to activate the changes.
oder interpretiere ich da was falsch?
lg
Tasmota,LD382A,Telegram
dev0
