[31_PlayBulbCandle.pm] Modul für MiPow PLAYBULB Candle Bluetooth Lampen
Begonnen von CoolTux, 20 Oktober 2016, 22:06:57
herrmannj
so, auch eben nochmal getested (bin wie gesagt auf der Suche nach einem systematischen Angang. Und sieht jut aus :) )
eingabe
[CON][AC:E6:4B:07:AD:7E][LE]> characteristics
handle: 0x0002, char properties: 0x0a, char value handle: 0x0003, uuid: 00002a00-0000-1000-8000-00805f9b34fb
handle: 0x0004, char properties: 0x02, char value handle: 0x0005, uuid: 00002a01-0000-1000-8000-00805f9b34fb
handle: 0x0006, char properties: 0x02, char value handle: 0x0007, uuid: 00002a04-0000-1000-8000-00805f9b34fb
handle: 0x000a, char properties: 0x10, char value handle: 0x000b, uuid: 00002a37-0000-1000-8000-00805f9b34fb
handle: 0x000d, char properties: 0x02, char value handle: 0x000e, uuid: 0000fff8-0000-1000-8000-00805f9b34fb
handle: 0x000f, char properties: 0x0a, char value handle: 0x0010, uuid: 0000fff9-0000-1000-8000-00805f9b34fb
handle: 0x0011, char properties: 0x06, char value handle: 0x0012, uuid: 0000fffa-0000-1000-8000-00805f9b34fb
handle: 0x0013, char properties: 0x06, char value handle: 0x0014, uuid: 0000fffb-0000-1000-8000-00805f9b34fb
handle: 0x0015, char properties: 0x06, char value handle: 0x0016, uuid: 0000fffc-0000-1000-8000-00805f9b34fb
handle: 0x0017, char properties: 0x0a, char value handle: 0x0018, uuid: 0000fffd-0000-1000-8000-00805f9b34fb
handle: 0x0019, char properties: 0x0a, char value handle: 0x001a, uuid: 0000fffe-0000-1000-8000-00805f9b34fb
handle: 0x001b, char properties: 0x0a, char value handle: 0x001c, uuid: 0000ffff-0000-1000-8000-00805f9b34fb
handle: 0x001e, char properties: 0x12, char value handle: 0x001f, uuid: 00002a19-0000-1000-8000-00805f9b34fb
handle: 0x0022, char properties: 0x02, char value handle: 0x0023, uuid: 00002a25-0000-1000-8000-00805f9b34fb
handle: 0x0024, char properties: 0x02, char value handle: 0x0025, uuid: 00002a27-0000-1000-8000-00805f9b34fb
handle: 0x0026, char properties: 0x02, char value handle: 0x0027, uuid: 00002a26-0000-1000-8000-00805f9b34fb
handle: 0x0028, char properties: 0x02, char value handle: 0x0029, uuid: 00002a28-0000-1000-8000-00805f9b34fb
handle: 0x002a, char properties: 0x02, char value handle: 0x002b, uuid: 00002a29-0000-1000-8000-00805f9b34fb
handle: 0x002c, char properties: 0x02, char value handle: 0x002d, uuid: 00002a50-0000-1000-8000-00805f9b34fb
Hinten bei den UUID wieder nur die Ziffern 4-8 beachten. Diese Werte dann hier https://www.bluetooth.com/specifications/gatt/characteristics nachschlagen.
Damit lässt sich ein großer Teil der allgemeinen Werte auslesen. Name, Benutzerdefinierter Name (Balkon ;)), Firmware, Hersteller usw.
Die UUID für Battery ist (lt verlinkt) 0x2a19. Also handle 0x01f. Die Bedeutung der Propertys habe ich auch irgendwo gesehen, erinnere mich aber nicht mehr wo (zu viel gelesen). Aber so gehts, selbst bei total fremden Geräten.
Die UUIDs mit FF.. sind nicht mehr standardisiert sondern Hersteller eigen. Die Anzahl der handles die bleiben ist ja schon überschaubar. Wenn man dann eine idee hat wie die Daten in etwa aussehen (rgb hier bei uns) dann ist das zusammen mit char propertys fast ein Selbstgänger.
Bin ganz zufrieden mit den Ergebnissen  8) 8) 8)
vg
joerg
CoolTux
Danke Jörg für Deine Arbeit. Habe da noch was gefunden
https://github.com/Phhere/Playbulb/blob/master/protocols/color.md
Basierend darauf stelle ich mal folgende Behauptung auf was Firmware an geht
gatttool -b AC:E6:4B:07:93:DD --char-read -a 0x27
Characteristic value/descriptor: 42 54 4c 33 30 30 5f 76 35
Firmware Version. Hier in meinem Fall v5
Characteristic value/descriptor: 42 54 4c 33 30 30 5f 76 36
hier in einem anderen Fall sollte es v6 sein. Kann das bitte mal jemand mit v6 Versionen prüfen
Das TuxNet Wiki:
https://www.cooltux.net
CoolTux
Habe mal schnell diese Seite verwendet und meine erhaltenen Hex Telegramme da ein gegeben. Und siehe da.
Das TuxNet Wiki:
Ma_Bo
Bei mir kommt folgendes:
gatttool -b 8B:39:4B:0D:AC:E6 --char-read -a 0x27
Characteristic value/descriptor: 02 28 00 27 2a
NUC mit FHEM, HM Heizungsthermostate, HM Wandthermostate, Intertechno Funksteckdosen, 10" Tablet als Wanddisplay, KeyMatic, Fensterkontakte, Fensterkontakte umgebaut als Wassermelder und Briefkastenmelder, Aussenthermostat, Anwesenheitssteuerung über Fritz Box, Google Home usw. usw.
herrmannj
ja wart mal Ma_Bo
zuerst bitte das
characteristics
dann die UUID 2a26 suchen
dann den dazugehörigen char value handle abfragen
(und den output von characteristics bitte auch gleich posten ;) )
Danke vg
joerg
CoolTux
Mist ich bin davon ausgegangen das die handle immer gleich sind, zu mindest für sowas wie die Firmware oder so.
Das verwirft meinen ganzen Code  :'(
Das TuxNet Wiki:
herrmannj
ja das is cool. Ein allgemein gültiger, automatischer workflow wäre demnach
- zuerst characteristic, dann aus den UUID den Teil filtern, dann gegen die Liste der bekannten Service prüfen. Perfekt für autocreate. Und anhand der service sieht man parallel was das Ding kann.
btw, meine play bulbs können 0x2a37 :) , bissel muss man wohl aufpassen
herrmannj
Yepp, das war mein learning gestern. UUID->Handle. Jetzt müsste man noch die propertys richtig verstehen ...
CoolTux
Interessant. Muß wohl der Impulseffect sein, lach.
Gott ist das ein Aufwand, uuid Filtern, Handle raussuchen um dann den Type und die Funktionen fest zu stellen. Aber wenn das erstmal geht ist das der Hammer. Werden aber wohl nicht drum rum kommen eine eigene Hash Datenquelle dafür in den Code ein zu bauen.
Das TuxNet Wiki:
fxstc
meine Güte.
Kaum war man mal was Essen geht hier die Post ab  ;D
Mein Output von Charateristics
characteristics
handle: 0x0009, char properties: 0x22, char value handle: 0x000a, uuid: 00002a05-0000-1000-8000-00805f9b34fb
handle: 0x000d, char properties: 0x10, char value handle: 0x000e, uuid: 00002a37-0000-1000-8000-00805f9b34fb
handle: 0x0010, char properties: 0x02, char value handle: 0x0011, uuid: 0000fff8-0000-1000-8000-00805f9b34fb
handle: 0x0012, char properties: 0x0a, char value handle: 0x0013, uuid: 0000fff9-0000-1000-8000-00805f9b34fb
handle: 0x0014, char properties: 0x06, char value handle: 0x0015, uuid: 0000fffa-0000-1000-8000-00805f9b34fb
handle: 0x0016, char properties: 0x06, char value handle: 0x0017, uuid: 0000fffb-0000-1000-8000-00805f9b34fb
handle: 0x0018, char properties: 0x06, char value handle: 0x0019, uuid: 0000fffc-0000-1000-8000-00805f9b34fb
handle: 0x001a, char properties: 0x0a, char value handle: 0x001b, uuid: 0000fffd-0000-1000-8000-00805f9b34fb
handle: 0x001c, char properties: 0x0a, char value handle: 0x001d, uuid: 0000fffe-0000-1000-8000-00805f9b34fb
handle: 0x001e, char properties: 0x0a, char value handle: 0x001f, uuid: 0000ffff-0000-1000-8000-00805f9b34fb
handle: 0x0021, char properties: 0x12, char value handle: 0x0022, uuid: 00002a19-0000-1000-8000-00805f9b34fb
handle: 0x0025, char properties: 0x02, char value handle: 0x0026, uuid: 00002a25-0000-1000-8000-00805f9b34fb
handle: 0x0027, char properties: 0x02, char value handle: 0x0028, uuid: 00002a27-0000-1000-8000-00805f9b34fb
handle: 0x0029, char properties: 0x02, char value handle: 0x002a, uuid: 00002a26-0000-1000-8000-00805f9b34fb
handle: 0x002b, char properties: 0x02, char value handle: 0x002c, uuid: 00002a28-0000-1000-8000-00805f9b34fb
handle: 0x002d, char properties: 0x02, char value handle: 0x002e, uuid: 00002a29-0000-1000-8000-00805f9b34fb
handle: 0x002f, char properties: 0x02, char value handle: 0x0030, uuid: 00002a50-0000-1000-8000-00805f9b34fb
handle: 0x0032, char properties: 0x0a, char value handle: 0x0033, uuid: 00001013-d102-11e1-9b23-00025b00a5a5
handle: 0x0034, char properties: 0x08, char value handle: 0x0035, uuid: 00001018-d102-11e1-9b23-00025b00a5a5
handle: 0x0036, char properties: 0x12, char value handle: 0x0037, uuid: 00001014-d102-11e1-9b23-00025b00a5a5
handle: 0x0039, char properties: 0x02, char value handle: 0x003a, uuid: 00001011-d102-11e1-9b23-00025b00a5a5
Abfrage von handle bei uuid 00002a26
char-read-hnd 29
Characteristic value/descriptor: 02 2a 00 26 2a
und hier noch das:
gatttool -b AE:D5:4B:10:AC:E6 --char-read -a 0x27
Ma_Bo
Characteristics:
fhem@NUC:~$ gatttool -b 8B:39:4B:0D:AC:E6 --characteristics
handle = 0x0002, char properties = 0x0a, char value handle = 0x0003, uuid = 00002a00-0000-1000-8000-00805f9b34fb
handle = 0x0004, char properties = 0x02, char value handle = 0x0005, uuid = 00002a01-0000-1000-8000-00805f9b34fb
handle = 0x0006, char properties = 0x02, char value handle = 0x0007, uuid = 00002a04-0000-1000-8000-00805f9b34fb
handle = 0x0009, char properties = 0x22, char value handle = 0x000a, uuid = 00002a05-0000-1000-8000-00805f9b34fb
handle = 0x000d, char properties = 0x10, char value handle = 0x000e, uuid = 00002a37-0000-1000-8000-00805f9b34fb
handle = 0x0010, char properties = 0x02, char value handle = 0x0011, uuid = 0000fff8-0000-1000-8000-00805f9b34fb
handle = 0x0012, char properties = 0x0a, char value handle = 0x0013, uuid = 0000fff9-0000-1000-8000-00805f9b34fb
handle = 0x0014, char properties = 0x06, char value handle = 0x0015, uuid = 0000fffa-0000-1000-8000-00805f9b34fb
handle = 0x0016, char properties = 0x06, char value handle = 0x0017, uuid = 0000fffb-0000-1000-8000-00805f9b34fb
handle = 0x0018, char properties = 0x06, char value handle = 0x0019, uuid = 0000fffc-0000-1000-8000-00805f9b34fb
handle = 0x001a, char properties = 0x0a, char value handle = 0x001b, uuid = 0000fffd-0000-1000-8000-00805f9b34fb
handle = 0x001c, char properties = 0x0a, char value handle = 0x001d, uuid = 0000fffe-0000-1000-8000-00805f9b34fb
handle = 0x001e, char properties = 0x0a, char value handle = 0x001f, uuid = 0000ffff-0000-1000-8000-00805f9b34fb
handle = 0x0021, char properties = 0x12, char value handle = 0x0022, uuid = 00002a19-0000-1000-8000-00805f9b34fb
handle = 0x0025, char properties = 0x02, char value handle = 0x0026, uuid = 00002a25-0000-1000-8000-00805f9b34fb
handle = 0x0027, char properties = 0x02, char value handle = 0x0028, uuid = 00002a27-0000-1000-8000-00805f9b34fb
handle = 0x0029, char properties = 0x02, char value handle = 0x002a, uuid = 00002a26-0000-1000-8000-00805f9b34fb
handle = 0x002b, char properties = 0x02, char value handle = 0x002c, uuid = 00002a28-0000-1000-8000-00805f9b34fb
handle = 0x002d, char properties = 0x02, char value handle = 0x002e, uuid = 00002a29-0000-1000-8000-00805f9b34fb
handle = 0x002f, char properties = 0x02, char value handle = 0x0030, uuid = 00002a50-0000-1000-8000-00805f9b34fb
handle = 0x0032, char properties = 0x0a, char value handle = 0x0033, uuid = 00001013-d102-11e1-9b23-00025b00a5a5
handle = 0x0034, char properties = 0x08, char value handle = 0x0035, uuid = 00001018-d102-11e1-9b23-00025b00a5a5
handle = 0x0036, char properties = 0x12, char value handle = 0x0037, uuid = 00001014-d102-11e1-9b23-00025b00a5a5
handle = 0x0039, char properties = 0x02, char value handle = 0x003a, uuid = 00001011-d102-11e1-9b23-00025b00a5a5
gatttool -b 8B:39:4B:0D:AC:E6 --char-read -a 0x29
herrmannj
yepp. Seh ich auch im io device.
Hab im übrigen auch raus bekommen wie man ständig an die advertise inkl RSSI kommt auch wenn ein gatttool connected. Damit ist für presence und ibeacons alles klar. Zum testen hab ich mir Gigaset gtags bestellt. Die liest er sauber. ibeacons müsste ich genauso sehen, da fehlt aber noch der Beweis.  .... und der ibeacon ...  :) :)
herrmannj
Zitat von: fxstc am 31 Oktober 2016, 22:21:27
meine Güte.
characteristics
char-read-hnd 29
und hier noch das:
ne, Du musst 2a abfragen. 29 beschreibt wie der Inhalt formatiert ist
fxstc
Sorry
char-read-hnd 2a
Ma_Bo
Bei mir identisch
gatttool -b 8B:39:4B:0D:AC:E6 --char-read -a 0x2a
