FB_CALLMONITOR: change connection setup to non-blocking connect procedure, close connection when disabled (Forum: #59380)
Begonnen von System, 21 Oktober 2016, 17:45:03
System
FB_CALLMONITOR: change connection setup to non-blocking connect procedure, close connection when disabled (Forum: #59380)View Changes
Source: FB_CALLMONITOR: change connection setup to non-blocking connect procedure, close connection when disabled (Forum: #59380)
