heyu oretemp to fhem
Begonnen von Guest, 25 Oktober 2010, 20:11:08
Guest
I noticed that somebody made something to give the digitemp values to
fhem as hms device.
I'm using heyu for my oregon sensors, and wants also to give them to
fhem also as hms device.
I know I can do it with a device I can do this
/usr/local/bin/fhem.pl localhost:7072 'setstate lamp off'
if I run
heyu oretemp l15
I get the  result: 17.7
and heyu orerh l15
I get the result: 56
How can I get these results in fhem as hms device, then I can also
view it with graphs on fhemobile
regards Richard
Sie haben diese Nachricht erhalten, da Sie der Google Groups-Gruppe FHEM users beigetreten sind.
Wenn Sie Nachrichten in dieser Gruppe posten möchten, senden Sie eine E-Mail an fhem-users@googlegroups.com.
Wenn Sie aus dieser Gruppe austreten möchten, senden Sie eine E-Mail an fhem-users+unsubscribe@googlegroups.com.
Besuchen Sie die Gruppe unter http://groups.google.com/group/fhem-users?hl=de, um weitere Optionen zu erhalten.
If you send them via
 fhem.pl localhost:7072 'trigger myhms T: 12.1 H: 50.1 Bat: ok'
(myhms must be defined), then you can configure e.g. a FileLog to write it to a
buffer.
Another possibility to write the logfile outside of fhem in the "correct"
format, and define a fake fhem FileLog with the filename.
An hms log entry looks like this:
  2010-10-26_08:47:06 myhms T: 12.1  H: 50.1 Bat: ok
The perfect solution would be to use the brand-new RFXCOM fhem module. But as I
do not own any RFXCOM devices, I cannot tell you if yours is supported.
Guest
Rduolf,
I'm gone try it, it should work.
how do I define the hms?
define myhms HSM 1234
attr myhms model hms100-tf
is this correct?
Richard
> buffer.
> is this correct?
Yes
Guest
Rudolf
I get
FHZ> l myhms
   CODE       1000
   DEF        1000
   IODev      FHZ1
   NAME       myhms
   NR         14
   STATE      ???
   TYPE       HMS
   model      hms100-tf
   room       Woonkamer
when I run fhem.pl localhost:7072 'trigger myhms T: 12.1 H: 50.1 Bat:
ok'
It doesn't change anything, shouldn't the state be 12.1? or the values
to be seen?
> to be seen?
No. trigger is only evaluated by FileLog/notify/etc. You can additionally
update the STATE of myhms with:
  fhem.pl localhost:7072 'trigger myhms T: 12.1 H: 50.1 Bat: ok;\
        {$defs{myhms}{STATE}="T: 12.1 H: 50.1 Bat: ok"}'
Guest
Is it also possible to put readings in to it??
pgm3 is waiting for first message from the hms device, and fhemobile
gives nothing, so I think they will have readings??
Now I got
FHZ> l myhms
   CODE       1000
   DEF        1000
   IODev      FHZ1
   NAME       myhms
   NR         14
   STATE      T: 16.0 H: 50.1 Bat: ok
   TYPE       HMS
   model      hms100-tf
   room       Woonkamer
> > to be seen?
Guest
Are you using an RFXCOM receiver to get the oregon sensor data from
heyu?
If yes, you may consider to use your RFXCOM receiver with FHEM. I
wrote the modules for FHEM. They work fine with my RFXCOM receiver.
Just get the latest FHEM 40_RFXCOM.pm and 41_OREGON.pm modules from
CVS or just use FHEM 5.0. See commandref.html on how to configure it.
The modules supports lots of Oregon sensors. If your sensor is not
supported, it should be normally no problem to add it. However X10 is
not supported.
Guest
Wili,
I know that there is some suppoort in fhem, but I use also the
rfxpower (gas, power, water) , and raingauge and security modules for
x10 and they are not yet implented
Also fhemobile supports only HMS yet, so if i can fake it, I can see
graphs and temp on my iphone.
> heyu?
> not supported.
Yes, but it is getting harder and I find it strange if it helps:
fhem.pl localhost:7072 'trigger myhms T: 12.1 H: 50.1 Bat: ok; {\
  $defs{myhms}{STATE}="T: 12.1 H: 50.1 Bat: ok";;\
  $defs{myhms}{READINGS}{temperature}{VAL}="12.1 (Celsius)";;\
  $defs{myhms}{READINGS}{temperature}{TIME}="2010-10-27 09:55:51";;\
  $defs{myhms}{READINGS}{humidity}{VAL}="50.1 (%)";;\
  $defs{myhms}{READINGS}{humidity}{TIME}="2010-10-27 09:55:51";;\
  $defs{myhms}{READINGS}{battery}{VAL}="ok";;\
  $defs{myhms}{READINGS}{battery}{TIME}="2010-10-27 09:55:51";;\
Guest
Rudolf
This works almost, I get in fhemobile data, graphs not yet, so I tried
pgm3 also nog graphs, I get Waiting for the first message from the HMS-
Device...
What does it want???
I got this
FHZ> l Buitentemp
   CODE       1001
   DEF        1001
   IODev      FHZ1
   NAME       Buitentemp
   NR         11
   STATE      T: 11.5 H: 40 Bat: ok
   TYPE       HMS
   Readings:
     2010-10-28 21:15:02   battery         ok
     2010-10-28 21:15:02   humidity        40 (%)
     2010-10-28 21:15:02   temperature     11.5 (Celsius)
   model      hms100-tf
   room       Buiten
and as logfile
2010-10-28_14:25:01 Buitentemp T: 13.5 H: 40 Bat: ok
2010-10-28_14:25:01 Buitentemp temperature: 13.5 (Celsius)
2010-10-28_14:25:02 Buitentemp humidity: 40 (%)
2010-10-28_14:25:02 Buitentemp battery: ok
2010-10-28_14:30:02 Buitentemp T: 13.6 H: 39 Bat: ok
2010-10-28_14:30:02 Buitentemp temperature: 13.6 (Celsius)
2010-10-28_14:30:02 Buitentemp humidity: 39 (%)
2010-10-28_14:30:02 Buitentemp battery: ok
and in fhem.cfg
define FileLog_Buitentemp FileLog /var/log/fhem/Buitentemp.log
Buitentemp
attr FileLog_Buitentemp logtype fht:.*
and filled the data with cronjob
#!/bin/sh
datum=$(date +%Y-%m-%d)
tijd=$(date +%H:%M:%S)
temp=$(/usr/local/bin/heyu oretemp l10)
hum=$(/usr/local/bin/heyu orerh l10)
/usr/local/bin/fhem.pl localhost:7072 'trigger Buitentemp T: '$temp'
H: '$hum' Bat: ok; {\
  $defs{Buitentemp}{STATE}="T: '$temp' H: '$hum' Bat: ok";;\
  $defs{Buitentemp}{READINGS}{temperature}{VAL}="'$temp' (Celsius)";;\
  $defs{Buitentemp}{READINGS}{temperature}{TIME}="'$datum' '$tijd'";;\
  $defs{Buitentemp}{READINGS}{humidity}{VAL}="'$hum' (%)";;\
  $defs{Buitentemp}{READINGS}{humidity}{TIME}="'$datum' '$tijd'";;\
  $defs{Buitentemp}{READINGS}{battery}{VAL}="ok";;\
  $defs{Buitentemp}{READINGS}{battery}{TIME}="'$datum' '$tijd'"}'
/usr/local/bin/fhem.pl localhost:7072 'trigger Buitentemp temperature:
'$temp' (Celsius)'
/usr/local/bin/fhem.pl localhost:7072 'trigger Buitentemp humidity:
'$hum' (%)'
/usr/local/bin/fhem.pl localhost:7072 'trigger Buitentemp battery: ok'
Guest
Pgm3 works, I restarted everything.... Only fhemobile the graphs...
hopefully Arno can tell me that
regards Richard
On Oct 28, 9:19 pm, kroon040 wrote:
> Rudolf
> Device...
> I got this
> FHZ> l Buitentemp
> Internals:
>    CODE       1001
>    DEF        1001
>    IODev      FHZ1
>    NAME       Buitentemp
>    NR         11
>    TYPE       HMS
>    Readings:
> Attributes:
>    model      hms100-tf
>    room       Buiten
> and as logfile
> and in fhem.cfg
> Buitentemp
> #!/bin/sh
> '$temp' (Celsius)'
> '$hum' (%)'
