Stacktrace Enocean
Begonnen von Stril, 23 Oktober 2016, 11:22:58
Stril
Hallo!
Die Enocean-Anbindung funktioniert bei mir, aber seit einem der letzten Updates habe ich folgende Fehlermeldung:
2016.10.23 11:21:06 1: PERL WARNING: Use of uninitialized value $rorg in concatenation (.) or string at ./FHEM/10_EnOcean.pm line 14231.
2016.10.23 11:21:06 3: stacktrace:
2016.10.23 11:21:06 3:     main::__ANON__                      called by ./FHEM/10_EnOcean.pm (14231)
2016.10.23 11:21:06 3:     main::EnOcean_SndCdm                called by ./FHEM/10_EnOcean.pm (6451)
2016.10.23 11:21:06 3:     main::EnOcean_Set                   called by fhem.pl (3222)
2016.10.23 11:21:06 3:     main::CallFn                        called by fhem.pl (1592)
2016.10.23 11:21:06 3:     main::DoSet                         called by fhem.pl (1634)
2016.10.23 11:21:06 3:     main::CommandSet                    called by fhem.pl (2375)
2016.10.23 11:21:06 3:     main::getAllSets                    called by ./FHEM/01_FHEMWEB.pm (2734)
2016.10.23 11:21:06 3:     main::FW_devState                   called by ./FHEM/01_FHEMWEB.pm (2643)
2016.10.23 11:21:06 3:     main::FW_Notify                     called by fhem.pl (3222)
2016.10.23 11:21:06 3:     main::CallFn                        called by fhem.pl (3144)
2016.10.23 11:21:06 3:     main::DoTrigger                     called by fhem.pl (3464)
2016.10.23 11:21:06 3:     main::Dispatch                      called by ./FHEM/00_TCM.pm (457)
2016.10.23 11:21:06 3:     main::TCM_Read                      called by fhem.pl (3222)
2016.10.23 11:21:06 3:     main::CallFn                        called by fhem.pl (672)
Sollte mir das Sorgen machen?
Phil
