98_Hyperion: change dynamic set list handling, disable now disconnects, dynamic readings and set depending on delivered data, other minor changes, commandref update
Begonnen von System, 25 Oktober 2016, 03:45:09
System
98_Hyperion: change dynamic set list handling, disable now disconnects, dynamic readings and set depending on delivered data, other minor changes, commandref updateView Changes
Source: 98_Hyperion: change dynamic set list handling, disable now disconnects, dynamic readings and set depending on delivered data, other minor changes, commandref update
