Fehlermeldungen im LOG !!
Begonnen von sash.sc, 04 November 2016, 20:43:36
sash.sc
Habe in letzter Zeit öfters folgende Meldungen
2016.11.04 20:34:22 1: PERL WARNING: Found = in conditional, should be == at (eval 16113) line 1.
2016.11.04 20:33:59 1: PERL WARNING: Found = in conditional, should be == at (eval 16067) line 1.
2016.11.04 20:33:33 1: PERL WARNING: Found = in conditional, should be == at (eval 16007) line 1.
2016.11.04 20:29:23 2: CUL_TX B ts01 127 (X9BFFFFFFFE) unknown type
2016.11.04 20:29:22 1: PERL WARNING: Found = in conditional, should be == at (eval 15501) line 1.
2016.11.04 20:28:59 1: PERL WARNING: Found = in conditional, should be == at (eval 15457) line 1.
2016.11.04 20:28:28 1: PERL WARNING: Found = in conditional, should be == at (eval 15398) line 1.
2016.11.04 20:24:15 1: PERL WARNING: Found = in conditional, should be == at (eval 14841) line 1.
2016.11.04 20:23:54 1: PERL WARNING: Found = in conditional, should be == at (eval 14791) line 1.
2016.11.04 20:23:23 1: PERL WARNING: Found = in conditional, should be == at (eval 14713) line 1.
2016.11.04 20:19:07 1: PERL WARNING: Found = in conditional, should be == at (eval 14204) line 1.
2016.11.04 20:18:49 1: PERL WARNING: Found = in conditional, should be == at (eval 14152) line 1.
2016.11.04 20:18:18 1: PERL WARNING: Found = in conditional, should be == at (eval 14077) line 1.
2016.11.04 20:14:04 1: PERL WARNING: Found = in conditional, should be == at (eval 13570) line 1.
2016.11.04 20:13:37 1: PERL WARNING: Found = in conditional, should be == at (eval 13503) line 1.
2016.11.04 20:13:18 1: PERL WARNING: Found = in conditional, should be == at (eval 13464) line 1.
2016.11.04 20:10:05 1: PERL WARNING: Found = in conditional, should be == at (eval 13063) line 1.
2016.11.04 20:10:05 1: PERL WARNING: Found = in conditional, should be == at (eval 13062) line 1.
2016.11.04 20:10:05 1: PERL WARNING: Found = in conditional, should be == at (eval 13061) line 1.
2016.11.04 20:10:05 1: PERL WARNING: Found = in conditional, should be == at (eval 13060) line 1.
2016.11.04 20:10:05 1: PERL WARNING: Found = in conditional, should be == at (eval 13059) line 1.
2016.11.04 20:10:05 1: PERL WARNING: Found = in conditional, should be == at (eval 13058) line 1.
2016.11.04 20:10:05 1: PERL WARNING: Found = in conditional, should be == at (eval 13057) line 1.
2016.11.04 20:10:04 1: PERL WARNING: Found = in conditional, should be == at (eval 13055) line 1.
2016.11.04 20:10:04 1: PERL WARNING: Found = in conditional, should be == at (eval 13054) line 1.
2016.11.04 20:10:04 1: PERL WARNING: Found = in conditional, should be == at (eval 13053) line 1.
2016.11.04 20:10:04 1: PERL WARNING: Found = in conditional, should be == at (eval 13052) line 1.
2016.11.04 20:10:04 1: PERL WARNING: Found = in conditional, should be == at (eval 13051) line 1.
2016.11.04 20:10:04 1: PERL WARNING: Found = in conditional, should be == at (eval 13050) line 1.
2016.11.04 20:10:04 1: PERL WARNING: Found = in conditional, should be == at (eval 13049) line 1.
2016.11.04 20:09:55 1: PERL WARNING: Found = in conditional, should be == at (eval 13036) line 1.
2016.11.04 20:09:55 1: PERL WARNING: Found = in conditional, should be == at (eval 13035) line 1.
2016.11.04 20:09:55 1: PERL WARNING: Found = in conditional, should be == at (eval 13034) line 1.
2016.11.04 20:09:55 1: PERL WARNING: Found = in conditional, should be == at (eval 13033) line 1.
2016.11.04 20:09:55 1: PERL WARNING: Found = in conditional, should be == at (eval 13032) line 1.
2016.11.04 20:09:55 1: PERL WARNING: Found = in conditional, should be == at (eval 13031) line 1.
2016.11.04 20:09:55 1: PERL WARNING: Found = in conditional, should be == at (eval 13030) line 1.
2016.11.04 20:09:53 1: PERL WARNING: Found = in conditional, should be == at (eval 13026) line 1.
2016.11.04 20:09:53 1: PERL WARNING: Found = in conditional, should be == at (eval 13025) line 1.
2016.11.04 20:09:53 1: PERL WARNING: Found = in conditional, should be == at (eval 13024) line 1.
2016.11.04 20:09:53 1: PERL WARNING: Found = in conditional, should be == at (eval 13023) line 1.
2016.11.04 20:09:53 1: PERL WARNING: Found = in conditional, should be == at (eval 13022) line 1.
2016.11.04 20:09:53 1: PERL WARNING: Found = in conditional, should be == at (eval 13021) line 1.
2016.11.04 20:09:53 1: PERL WARNING: Found = in conditional, should be == at (eval 13020) line 1.
2016.11.04 20:09:00 1: PERL WARNING: Found = in conditional, should be == at (eval 12915) line 1.
2016.11.04 20:08:24 1: PERL WARNING: Found = in conditional, should be == at (eval 12828) line 1.
2016.11.04 20:08:13 1: PERL WARNING: Found = in conditional, should be == at (eval 12806) line 1.
2016.11.04 20:03:52 1: PERL WARNING: Found = in conditional, should be == at (eval 12271) line 1.
2016.11.04 20:03:08 1: PERL WARNING: Found = in conditional, should be == at (eval 12182) line 1.
2016.11.04 20:03:04 1: PERL WARNING: Found = in conditional, should be == at (eval 12172) line 1.
2016.11.04 19:58:36 1: PERL WARNING: Found = in conditional, should be == at (eval 11613) line 1.
2016.11.04 19:58:03 1: PERL WARNING: Found = in conditional, should be == at (eval 11533) line 1.
2016.11.04 19:58:03 1: PERL WARNING: Found = in conditional, should be == at (eval 11530) line 1.
2016.11.04 19:53:28 1: PERL WARNING: Found = in conditional, should be == at (eval 11010) line 1.
2016.11.04 19:53:02 1: PERL WARNING: Found = in conditional, should be == at (eval 10968) line 1.
2016.11.04 19:52:58 1: PERL WARNING: Found = in conditional, should be == at (eval 10955) line 1.
2016.11.04 19:48:20 1: PERL WARNING: Found = in conditional, should be == at (eval 10414) line 1.
2016.11.04 19:47:58 1: PERL WARNING: Found = in conditional, should be == at (eval 10358) line 1.
2016.11.04 19:47:53 1: PERL WARNING: Found = in conditional, should be == at (eval 10347) line 1.
2016.11.04 19:43:12 1: PERL WARNING: Found = in conditional, should be == at (eval 9794) line 1.
2016.11.04 19:42:48 1: PERL WARNING: Found = in conditional, should be == at (eval 9749) line 1.
2016.11.04 19:42:25 1: PERL WARNING: Found = in conditional, should be == at (eval 9687) line 1.
2016.11.04 19:38:04 1: PERL WARNING: Found = in conditional, should be == at (eval 9142) line 1.
2016.11.04 19:37:43 1: PERL WARNING: Found = in conditional, should be == at (eval 9099) line 1.
2016.11.04 19:37:21 1: PERL WARNING: Found = in conditional, should be == at (eval 9050) line 1.
2016.11.04 19:32:56 1: PERL WARNING: Found = in conditional, should be == at (eval 8491) line 1.
2016.11.04 19:32:38 1: PERL WARNING: Found = in conditional, should be == at (eval 8458) line 1.
2016.11.04 19:32:05 1: PERL WARNING: Found = in conditional, should be == at (eval 8379) line 1.
2016.11.04 19:27:48 1: PERL WARNING: Found = in conditional, should be == at (eval 7833) line 1.
2016.11.04 19:27:33 1: PERL WARNING: Found = in conditional, should be == at (eval 7801) line 1.
2016.11.04 19:27:03 1: PERL WARNING: Found = in conditional, should be == at (eval 7726) line 1.
2016.11.04 19:22:43 1: PERL WARNING: Found = in conditional, should be == at (eval 7155) line 1.
2016.11.04 19:22:28 1: PERL WARNING: Found = in conditional, should be == at (eval 7126) line 1.
2016.11.04 19:21:59 1: PERL WARNING: Found = in conditional, should be == at (eval 7072) line 1.
2016.11.04 19:19:42 1: PERL WARNING: Found = in conditional, should be == at (eval 6758) line 1.
2016.11.04 19:19:42 1: PERL WARNING: Found = in conditional, should be == at (eval 6757) line 1.
2016.11.04 19:19:42 1: PERL WARNING: Found = in conditional, should be == at (eval 6756) line 1.
2016.11.04 19:19:42 1: PERL WARNING: Found = in conditional, should be == at (eval 6755) line 1.
2016.11.04 19:19:42 1: PERL WARNING: Found = in conditional, should be == at (eval 6754) line 1.
2016.11.04 19:19:42 1: PERL WARNING: Found = in conditional, should be == at (eval 6753) line 1.
2016.11.04 19:19:42 1: PERL WARNING: Found = in conditional, should be == at (eval 6752) line 1.
2016.11.04 19:19:41 1: PERL WARNING: Found = in conditional, should be == at (eval 6751) line 1.
2016.11.04 19:19:41 1: PERL WARNING: Found = in conditional, should be == at (eval 6750) line 1.
2016.11.04 19:19:41 1: PERL WARNING: Found = in conditional, should be == at (eval 6749) line 1.
2016.11.04 19:19:41 1: PERL WARNING: Found = in conditional, should be == at (eval 6748) line 1.
2016.11.04 19:19:41 1: PERL WARNING: Found = in conditional, should be == at (eval 6747) line 1.
2016.11.04 19:19:41 1: PERL WARNING: Found = in conditional, should be == at (eval 6746) line 1.
2016.11.04 19:19:41 1: PERL WARNING: Found = in conditional, should be == at (eval 6745) line 1.
Kann damit einer was anfangen ?
Sascha
Raspi 4B+ Bullseye ;LaCrosse; HomeMatic; MapleCUL; ZigBee; Signalduino ESP32 ; Shellys; MQTT2; Grafana mit Influxdb
viegener
Ja - heisst vermutlich, dass Du einen perl-Ausdruck in einem if hast, bei dem nur = statt == steht. Dieser Perlausdruck scheint nicht in einem at statement sondern in einem notify oder dofi zu stehen, wegen der unregelmässigen Ausführung. Vermutlich musst Du mal in Deinen cfg-File schauen.
sash.sc
AT habe ich nicht am laufen, nur ein Paar DOIFs. Dann muss ich wohl mal schauen !
Danke für die Info
