fhem-2011-01.log not getting updated (debian)
Begonnen von Guest, 23 Januar 2011, 18:22:35
Guest
After i had to start FHEM with an & in the /etc/init.d/fhem startup
script i see that the fhem-2011-01.log logfile in /var/log/fhem is not
updated anymore.
If i check the config file all should be fine.
If i remove the & from the startup script it locks up at boot time
any ideas?
Sie haben diese Nachricht erhalten, da Sie der Google Groups-Gruppe FHEM users beigetreten sind.
Wenn Sie Nachrichten in dieser Gruppe posten möchten, senden Sie eine E-Mail an fhem-users@googlegroups.com.
Wenn Sie aus dieser Gruppe austreten möchten, senden Sie eine E-Mail an fhem-users+unsubscribe@googlegroups.com.
Besuchen Sie die Gruppe unter http://groups.google.com/group/fhem-users?hl=de, um weitere Optionen zu erhalten.
Guest
The "&" should work but is not required in an init script.
Go to your logfile directory like /var/tmp and type "lsof *" to see
the current used logfiles of fhem.pl. If your logfile is listed then
it should be updated by fhem.pl
Martin
> updated anymore.
> any ideas?
Guest
Hi Martin,
I did as requested and this is what i see
fhem.pl    683        fhem    9w      REG       8,18   147518     252476
/var/log/fhem/Thermostaat_Huiskamer.log
fhem.pl    683        fhem   10w      REG       8,18   115985     252652
/var/log/fhem/Thermostaat_Steffi.log
fhem.pl    683        fhem   11w      REG       8,18   117281     252218
/var/log/fhem/Thermostaat_Ernst.log
fhem.pl    683        fhem   12w      REG       8,18     1210     252615
/var/log/fhem/Salon_Tafel-2011.log
fhem.pl    683        fhem   13w      REG       8,18      648     252626
/var/log/fhem/LEDStrip_Bank-2011.log
fhem.pl    683        fhem   14w      REG       8,18     1716     252641
/var/log/fhem/Koof-2011.log
fhem.pl    683        fhem   15w      REG       8,18     1471     252682
/var/log/fhem/Kleine_Staande_Lamp-2011.log
So the fhem-2011-01.log logfile in /var/log/fhem is not updated.
The problem is that i cannot test it without the & in the startscript
because my console locks up and ssh is not started yet.
I moved fhem at a later point in ther /etc/c2.d so it would start after ssh
but without any luck it stil starts before ssh and i cannot login
Would you have anothe sugestion?
> Martin
> > updated anymore.
> > any ideas?
> erhalten.
Guest
Do you use Debian or Ubuntu until 10.04?
Do you use the Start/Stop-Script of the current fhem-5.0.deb? There is
no need for the "&". I recommend this .deb (if possible).
You are using fhem.pl as the user fhem, this is great and sounds like
the deb-package.
Is the owner of fhem-2011-01.log the user fhem (not root)? Please make
a "ls -al /var/log/fhem/".
And make a "lsof | grep fhem" to get an overview about the open files.
Martin
On 24 Jan., 12:55, Ernst Cozijnsen wrote:
> Hi Martin,
> > Martin
> > > updated anymore.
> > > any ideas?
> > erhalten.
Guest
Hi Martin,
I use the standard .deb package from the website if i do not put the & in
the start script my console looks like the picture included and will not go
any further.
see picture included
[image: Selection_025.png]
My system data:
root@guruplug:~# uname -a
Linux guruplug 2.6.32-5-kirkwood #1 Wed Jan 12 15:27:07 UTC 2011 armv5tel
GNU/Linux
root@guruplug:~# cat /etc/issue
Debian GNU/Linux 6.0 \n \l
root@guruplug:~# ls -latr /var/log/fhem
total 444
-rw-r--r--  1 root root   2858 Jan 21 13:40 fhem-2011-01.log
drwxr-xr-x  2 fhem root   4096 Jan 23 17:31 .
-rw-r--r--  1 fhem root    648 Jan 23 20:34 LEDStrip_Bank-2011.log
-rw-r--r--  1 fhem root   1210 Jan 23 20:34 Salon_Tafel-2011.log
-rw-r--r--  1 fhem root   1471 Jan 23 20:34 Kleine_Staande_Lamp-2011.log
-rw-r--r--  1 fhem root   1716 Jan 24 11:42 Koof-2011.log
-rw-r--r--  1 fhem root   5836 Jan 24 13:47 fhem.save
drwxr-xr-x 11 root root   4096 Jan 24 13:47 ..
-rw-r--r--  1 fhem root 120008 Jan 24 14:04 Thermostaat_Ernst.log
-rw-r--r--  1 fhem root 150458 Jan 24 14:05 Thermostaat_Huiskamer.log
-rw-r--r--  1 fhem root 118874 Jan 24 14:05 Thermostaat_Steffi.log
root@guruplug:~#
root@guruplug:~#
root@guruplug:~#
root@guruplug:~# lsof | grep fhem
fhem.pl    682        fhem  cwd       DIR       8,18     4096          2 /
fhem.pl    682        fhem  rtd       DIR       8,18     4096          2 /
fhem.pl    682        fhem  txt       REG       8,18     5176       9737
/usr/bin/perl
fhem.pl    682        fhem  mem       REG       8,18   122340     107760
/lib/ld-2.11.2.so
fhem.pl    682        fhem  mem       REG       8,18  1251432       9742
/usr/lib/libperl.so.5.10.1
fhem.pl    682        fhem  mem       REG       8,18     9808     107755
/lib/libdl-2.11.2.so
fhem.pl    682        fhem  mem       REG       8,18   652912     107771
/lib/libm-2.11.2.so
fhem.pl    682        fhem  mem       REG       8,18   120505     107761
/lib/libpthread-2.11.2.so
fhem.pl    682        fhem  mem       REG       8,18  1205684     107758
/lib/libc-2.11.2.so
fhem.pl    682        fhem  mem       REG       8,18    34376     107757
/lib/libcrypt-2.11.2.so
fhem.pl    682        fhem  mem       REG       8,18    47212     105497
/lib/libgcc_s.so.1
fhem.pl    682        fhem  mem       REG       8,18    15932      16953
/usr/lib/perl/5.10.1/auto/IO/IO.so
fhem.pl    682        fhem  mem       REG       8,18    19972      16955
/usr/lib/perl/5.10.1/auto/Socket/Socket.so
fhem.pl    682        fhem  mem       REG       8,18    25748      42125
/usr/lib/perl/5.10.1/auto/Time/HiRes/HiRes.so
fhem.pl    682        fhem  mem       REG       8,18    26632     107756
/lib/librt-2.11.2.so
fhem.pl    682        fhem  mem       REG       8,18    11736      16960
/usr/lib/perl/5.10.1/auto/Fcntl/Fcntl.so
fhem.pl    682        fhem  mem       REG       8,18   102824      16946
/usr/lib/perl/5.10.1/auto/POSIX/POSIX.so
fhem.pl    682        fhem  mem       REG       8,18    34796      16968
/usr/lib/perl/5.10.1/auto/List/Util/Util.so
fhem.pl    682        fhem  mem       REG       8,18    42680     107773
/lib/libnss_files-2.11.2.so
fhem.pl    682        fhem  mem       REG       8,18    26480     107759
/lib/libnss_compat-2.11.2.so
fhem.pl    682        fhem  mem       REG       8,18    75732     107763
/lib/libnsl-2.11.2.so
fhem.pl    682        fhem  mem       REG       8,18    38608     107764
/lib/libnss_nis-2.11.2.so
fhem.pl    682        fhem    0r      CHR        1,3      0t0        456
/dev/null
fhem.pl    682        fhem    1u      CHR      136,2      0t0          5
/dev/pts/2
fhem.pl    682        fhem    2u      CHR      136,2      0t0          5
/dev/pts/2
fhem.pl    682        fhem    3u      CHR      136,2      0t0          5
/dev/pts/2
fhem.pl    682        fhem    5u     IPv4       2658      0t0        TCP
localhost:7072 (LISTEN)
fhem.pl    682        fhem    6u     IPv4       2678      0t0        TCP
*:8083 (LISTEN)
fhem.pl    682        fhem    7u     IPv4       2679      0t0        TCP
*:8084 (LISTEN)
fhem.pl    682        fhem    8u     IPv4       2705      0t0        TCP
192.168.10.111:35696->192.168.10.2:2323 (ESTABLISHED)
fhem.pl    682        fhem    9w      REG       8,18   150458     252476
fhem.pl    682        fhem   10w      REG       8,18   118874     252652
fhem.pl    682        fhem   11w      REG       8,18   120008     252218
fhem.pl    682        fhem   12w      REG       8,18     1210     252615
fhem.pl    682        fhem   13w      REG       8,18      648     252626
fhem.pl    682        fhem   14w      REG       8,18     1716     252641
fhem.pl    682        fhem   15w      REG       8,18     1471     252682
root@guruplug:~#
> the deb-package.
> Martin
> > Hi Martin,
> ssh
> > > Martin
> not
> > > > updated anymore.
> > > > any ideas?
> FHEM
> > > erhalten.
> erhalten.
Guest
That is the reason:
> total 444
fhem.pl is running as user fhem and has not the rights to write into
Give the file the correct rights with "chown fhem.root
fhem-2011-01.log ". Restart fhem and it should run :-)
Have fun,
Martin
Guest
Hi Martin,
[shame mode]
How you can overlook the simpelest issues :-(
[/shame mode]
Well i changed the owner to fhem but without any luck. I tried both with and
without the & in the start script but without any luck.
The file still doesn't get updated
2011/1/24 Martin Haas
> That is the reason:
> > total 444
> Have fun,
> Martin
> erhalten.
Guest
Did you play with the /etc/fhem.cfg? There should be something like
attr global logfile /var/log/fhem/fhem-%Y-%m.log
attr global verbose 3
If fhem.pl is running make a "telnet localhost 7072" After that "list
global" ==> you should see the currentlogfile
Last test: change as root in the /etc/passwd the shell from fhem from
"/bin/false" to "/bin/bash"
Stop fhem and be sure that it is not running "ps -ef | grep fhem"
>> su fhem
>> id
==> uid=999(fhem)
>> /usr/bin/perl /usr/bin/fhem.pl /etc/fhem.cfg
fhem must start with the settings of the /etc/fhem.cfg
Retry the telnet session above.
No more ideas...
Martin
On 24 Jan., 14:40, Ernst Cozijnsen wrote:
> Hi Martin,
> [shame mode]
> [/shame mode]
> > That is the reason:
> > > total 444
> > Have fun,
> > Martin
> > erhalten.
