homebridge Einrichtung
Begonnen von sepperl4711, 23 November 2016, 11:39:52
sepperl4711
Hallo, bekomme bei einrichten der Homebridge Schnittstelle eine Fehlermeldung beim starten von Homebridge :
*** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** Please fix your application to use the native API of Avahi!
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
*** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister>
/usr/local/lib/node_modules/homebridge-fhem/index.js:53
    for( var subscription of FHEM_subscriptions[inform_id] ) {
[Wed Nov 23 2016 11:34:22 GMT+0100 (CET)] ====================
[Wed Nov 23 2016 11:34:22 GMT+0100 (CET)] ERROR LOADING PLUGIN homebridge-fhem:
[Wed Nov 23 2016 11:34:22 GMT+0100 (CET)] SyntaxError: Unexpected identifier
    at Module._compile (module.js:439:25)
    at Object.Module._extensions..js (module.js:474:10)
    at Module.load (module.js:356:32)
    at Function.Module._load (module.js:312:12)
    at Module.require (module.js:364:17)
    at require (module.js:380:17)
    at Plugin.load (/usr/local/lib/node_modules/homebridge/lib/plugin.js:65:22)
    at Server.<anonymous> (/usr/local/lib/node_modules/homebridge/lib/server.js:112:14)
    at Array.forEach (native)
    at Server._loadPlugins (/usr/local/lib/node_modules/homebridge/lib/server.js:108:22)
[Wed Nov 23 2016 11:34:22 GMT+0100 (CET)] No plugins found. See the README for information on installing plugins.
[Wed Nov 23 2016 11:34:22 GMT+0100 (CET)] Loaded config.json with 0 accessories and 1 platforms.
[Wed Nov 23 2016 11:34:22 GMT+0100 (CET)] ---
[Wed Nov 23 2016 11:34:22 GMT+0100 (CET)] Loading 1 platforms...
Error: The requested platform 'FHEM' was not registered by any plugin.
    at API.platform (/usr/local/lib/node_modules/homebridge/lib/api.js:106:13)
    at Server._loadPlatforms (/usr/local/lib/node_modules/homebridge/lib/server.js:265:45)
    at Server.run (/usr/local/lib/node_modules/homebridge/lib/server.js:71:36)
    at module.exports (/usr/local/lib/node_modules/homebridge/lib/cli.js:40:10)
    at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
    at Module._compile (module.js:456:26)
    at Function.Module.runMain (module.js:497:10)
als Node verwende ich Version 0.10.28
ppm verwendet ich in Version 1.4.9
Bin nach der Anleitung im Wiki vorgegangen.
hier noch die angepasste json Datei
    "bridge": {
        "name": "Homebridge",
        "username": "CC:22:3D:E3:CE:30",
        "port": 51826,
        "pin": "123-45-678"
    "platforms": [
            "platform": "FHEM",
            "name": "FHEM",
            "server": "127.0.0.1",
            "port": "8083",
            "filter": "room=Homekit"
    "accessories": []
und das ist die Version von Chen
Latest Revision: 12625
File              Rev   Last Change
fhem.pl           12596 2016-11-17 16:27:57Z rudolfkoenig
90_at.pm          12028 2016-08-21 12:08:28Z rudolfkoenig
98_autocreate.pm  11984 2016-08-19 12:47:50Z rudolfkoenig
00_CUL.pm         12027 2016-08-21 12:05:23Z rudolfkoenig
10_CUL_HM.pm      12603 2016-11-19 19:51:04Z martinp876
98_dummy.pm       12596 2016-11-17 16:27:57Z rudolfkoenig
91_eventTypes.pm  11984 2016-08-19 12:47:50Z rudolfkoenig
01_FHEMWEB.pm     12613 2016-11-21 10:40:20Z rudolfkoenig
92_FileLog.pm     12378 2016-10-18 19:45:22Z rudolfkoenig
98_HMinfo.pm      12552 2016-11-12 19:20:48Z martinp876
91_notify.pm      11984 2016-08-19 12:47:50Z rudolfkoenig
99_SUNRISE_EL.pm  12485 2016-11-01 15:18:51Z rudolfkoenig
00_TCM.pm         12434 2016-10-26 11:10:15Z klaus-schauer
99_Utils.pm       11984 2016-08-19 12:47:50Z rudolfkoenig
98_version.pm     11987 2016-08-19 17:13:41Z markusbloch
Blocking.pm       12521 2016-11-07 14:29:48Z rudolfkoenig
DevIo.pm          12515 2016-11-06 18:22:36Z rudolfkoenig
HMConfig.pm       12561 2016-11-13 13:19:21Z martinp876
HttpUtils.pm      12174 2016-09-19 05:53:59Z rudolfkoenig
RTypes.pm         10476 2016-01-12 21:03:33Z borisneubert
SetExtensions.pm  11513 2016-05-24 17:56:05Z rudolfkoenig
TcpServerUtils.pm 11908 2016-08-06 15:09:55Z rudolfkoenig
sepperl4711
Achso ... ich verwende ein Raspberry PI ... nur für den Fall das auch das von Interesse wäre
DeeSPe
Ich glaube Deine Node Version ist zu alt!
Du brauchst (soweit ich mich richtig erinnere) mindestens 0.12.....
Am leichtesten geht die Installation so:
cd ~ && wget http://node-arm.herokuapp.com/node_latest_armhf.deb && sudo dpkg -i node_latest_armhf.deb
Dan
Heinzmann
Hallo!
Ich hänge mich hier mal ran, weil ich ebenso Probleme bei der Installation habe. Installiert habe ich es nach der FHEM-Wiki-Anleitung.
Folgende Meldung bekomme ich beim Satrt von Homebridge.
Kann damit jemand etwas anfangen und mir einen Tipp geben?
Vielen Dank!
pi@raspberrypi:~ $ homebridge
/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/mdns/lib/dns_sd.js:35
    throw ex;
Error: Module did not self-register.
    at Error (native)
    at Object.Module._extensions..node (module.js:460:18)
    at Function.Module._load (module.js:311:12)
    at Module.require (module.js:366:17)
    at require (module.js:385:17)
    at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/mdns/lib/dns_sd.js:24:20)
    at Module._compile (module.js:435:26)
    at Object.Module._extensions..js (module.js:442:10)
pi@raspberrypi:~ $
