Fibaro Wall Plug FGWPF
Begonnen von Eisix, 16 Dezember 2016, 10:52:43
Eisix
2016.12.17 14:17:02 3: Opening ZWDongle_1 device /dev/serial/by-id/usb-0658_0200-if00
2016.12.17 14:17:02 3: Setting ZWDongle_1 serial parameters to 115200,8,N,1
2016.12.17 14:17:03 3: ZWDongle_1 device opened
2016.12.17 14:17:11 2: ZWave set ZWave_SWITCH_BINARY_2 off
2016.12.17 14:17:11 5: ZWDongle_Write 1302032501002502 (00)
2016.12.17 14:17:11 5: SW: 01091302032501002502e7
2016.12.17 14:17:12 2: ZWDongle_ProcessSendStack: no ACK, resending message 01091302032501002502e7
2016.12.17 14:17:12 5: SW: 01091302032501002502e7
2016.12.17 14:17:12 2: ZWave set ZWave_SWITCH_BINARY_2 on
2016.12.17 14:17:13 2: ZWDongle_ProcessSendStack: no ACK, resending message 01091302032501002502e7
2016.12.17 14:17:13 5: SW: 01091302032501002502e7
2016.12.17 14:17:14 2: ZWDongle_ProcessSendStack: no ACK, resending message 01091302032501002502e7
2016.12.17 14:17:14 5: SW: 01091302032501002502e7
2016.12.17 14:17:15 2: ZWDongle_ProcessSendStack: no ACK, resending message 01091302032501002502e7
2016.12.17 14:17:15 1: ERROR: max send retries reached, removing 01091302032501002502e7 from dongle sendstack
Ändert nichts  :(
Eisix
2016.12.17 14:26:35 2: ZWave set ZWave_SWITCH_BINARY_2 associationAdd 3 1
2016.12.17 14:26:35 5: ZWDongle_Write 130204850103012502 (00)
2016.12.17 14:26:35 5: SW: 010a13020485010301250241
2016.12.17 14:26:35 4: ZWDongle_Read ZWDongle_1: NACK received
2016.12.17 14:26:35 1: ERROR: max send retries reached, removing 010a13020485010301250241 from dongle sendstack
2016.12.17 14:26:45 1: PERL WARNING: Use of uninitialized value in string eq at (eval 1928) line 1.
2016.12.17 14:26:47 2: ZWave: No ACK from ZWave_SWITCH_BINARY_2 after 10s for sent:130204850103012502
2016.12.17 14:27:03 1: PERL WARNING: Use of uninitialized value in string eq at (eval 1955) line 1.
2016.12.17 14:27:20 1: PERL WARNING: Use of uninitialized value in string eq at (eval 1987) line 1.
2016.12.17 14:27:37 1: PERL WARNING: Use of uninitialized value in string eq at (eval 2010) line 1.
2016.12.17 14:27:48 2: ZWave set ZWave_SWITCH_BINARY_2 associationAdd 1 1
2016.12.17 14:27:48 5: ZWDongle_Write 130204850101012502 (00)
2016.12.17 14:27:48 5: SW: 010a13020485010101250243
2016.12.17 14:27:49 2: ZWDongle_ProcessSendStack: no ACK, resending message 010a13020485010101250243
2016.12.17 14:27:49 5: SW: 010a13020485010101250243
2016.12.17 14:27:50 2: ZWDongle_ProcessSendStack: no ACK, resending message 010a13020485010101250243
2016.12.17 14:27:50 5: SW: 010a13020485010101250243
2016.12.17 14:27:51 2: ZWDongle_ProcessSendStack: no ACK, resending message 010a13020485010101250243
2016.12.17 14:27:51 5: SW: 010a13020485010101250243
2016.12.17 14:27:52 2: ZWDongle_ProcessSendStack: no ACK, resending message 010a13020485010101250243
2016.12.17 14:27:52 1: ERROR: max send retries reached, removing 010a13020485010101250243 from dongle sendstack
2016.12.17 14:27:54 1: PERL WARNING: Use of uninitialized value in string eq at (eval 2087) line 1.
jeep
#17
Zitat von: Eisix am 17 Dezember 2016, 12:31:33
factory default auf den Dongle gemacht. Factory default auf einem wallplug mit Zwave und einem mit Zwave+
Dongle neu definiert, Stecker angelernt, nach Wiki Anleitung.
Da Fibaro
associationAdd 3 1
Ergebnis
gleiches Verhalten nodes sind da aber keine Kommunikation mit möglich.
Was ist falsch? Ist der Dongle defekt? Was braucht Ihr für info um mir zu helfen?
Du hast in einem früheren Beitrag erwähnt das Du auch die ZWave+ Version des FGWP hast, da hat der Dongle eigentlich nichts in der assocGroup_3 zu suchen. Da braucht man eventuell ein neues Wiki für die Gen5 Variante. Da wäre, wenn nicht automatisch bei der Inklusion geschehen, ein associationAdd 1 1 richtig.
Dies nur als Hinweis.
Grüße Josef
PS. hatte mich vertippt.
Ein wenig HomeMatic
RPi2  - UZB1, FHEM Testsystem - 8 devices
HC2  - 72 devices  (95 % sind Fibaro devices)
Eisix
@jeep  habe beide Varianten versucht gleiches Ergebnis.
Andere Frage müste der Dongle beim schalten nicht eigentlich kurz blau aufleuchten? Bei add node tut er dies aber beim schalten nicht.
Dongle kaputt oder jemand noch eine Idee?
jeep
Eigentlich ja, habs eben getestet, bei Ein- und Ausschalten zuckt jedesmal das blaue Licht am Dongle.
Seltsam ??? Da ja die Inklusion/Exclusion funktioniert, denke ich nicht dass der Dongle defekt ist, aber ich habe auch keine Idee was es sein kann.  :-[
Ein wenig HomeMatic
jeep
Doch noch was eingefallen (wenn Du es nicht schon selbst probiert hast). Versuche den Wallplug zu exkluden, dann zu resetten (glaube 15 Sek. auf Button) dann neue Inklusion versuchen.
Viel Erfolg.
Ein wenig HomeMatic
Eisix
Hab factory reset am Dongle und am Plug gemacht alle Einträge in Fhem gelöscht. Alles neu angelegt und include gemacht mit dm gleichen Ergebnis.
Die angelernten Geräte antworten nicht.
Eisix
nochmal reset auf alles.
Dongle per autocreate von fhem anlegen lassen.
add node
2016.12.17 17:29:26 2: autocreate: define ZWave_SWITCH_BINARY_2 ZWave d5459244 2 5e22855970565a7a72328e717398312586
2016.12.17 17:29:26 2: autocreate: define FileLog_ZWave_SWITCH_BINARY_2 FileLog ./log/ZWave_SWITCH_BINARY_2-%Y.log ZWave_SWITCH_BINARY_2
2016.12.17 17:29:26 1: PERL WARNING: Use of uninitialized value $CTRLID in concatenation (.) or string at (eval 6650) line 1, <FH> line 762.
2016.12.17 17:29:27 1: ZWAVE INIT: set ZWave_SWITCH_BINARY_2 associationAdd 1 : set associationAdd needs at least 2 parameters
2016.12.17 17:29:27 2: ZWave get ZWave_SWITCH_BINARY_2 model
2016.12.17 17:29:28 1: ZWAVE INIT: get ZWave_SWITCH_BINARY_2 model: Timeout reading answer for get model
2016.12.17 17:29:28 2: ZWDongle_ProcessSendStack: no ACK, resending message 010813020272042502b5
2016.12.17 17:29:31 2: ZWDongle_ProcessSendStack: no ACK, resending message 010813020272042502b5
2016.12.17 17:29:32 2: ZWDongle_ProcessSendStack: no ACK, resending message 010813020272042502b5
2016.12.17 17:29:33 2: ZWDongle_ProcessSendStack: no ACK, resending message 010813020272042502b5
2016.12.17 17:29:33 1: ERROR: max send retries reached, removing 010813020272042502b5 from dongle sendstack
2016.12.17 17:29:37 2: ZWave: No ACK from ZWave_SWITCH_BINARY_2 after 10s for sent:13020272042502
ist da eventuell ein Fehler im autocreate der nodes?
A.Harrenberg
sag mal ist Dein FHEM aktuell?
Da sind eine Menge merkwürdiger Fehlermeldungen in Deinen Logfiles:
Die Warning ist nicht normal...
Hier ist auch was faul...
Sieht auch nicht besser aus...
Kannst Du mal verbose auf 5 setzen (beim Dongle und global) und dann noch mal eine Inklusion machen und das Log posten?
Andreas.
FB 7360, Homematic und ZWave
Support for ZWave-SECURITY
krikan
Habe die Problematik https://wiki.fhem.de/wiki/Z-Wave#Assoziation staerker betont. Bereits vorher war das Thema dort dokumentiert. Man musste nur dem Link zu Fibaro folgen und lesen. Hoffe, es ist jetzt deutlicher.
Gruß, Christian
Eisix
Vorgestern neues Debian Jessie hochgezogen. Fhem debian paket installiert Update all gemacht.
update check
fhem
List of new / modified files since last update:
UPD FHEM/39_alexa.pm
fhemabfall
nothing to do...
fhemtabletui
nothing to do...
Eisix
Und hier der Verbose log
2016.12.17 19:12:10 4: Connection closed for WEB_192.168.1.1_51093: EOF
2016.12.17 19:12:10 4: WEB_192.168.1.1_51228 GET /fhem?detail=ZWDongle_0; BUFLEN:0
2016.12.17 19:12:10 4: name: /fhem?detail=ZWDongle_0 / RL:4485 / text/html; charset=UTF-8 / Content-Encoding: gzip
2016.12.17 19:12:10 4: Connection closed for WEB_192.168.1.1_51228: EOF
2016.12.17 19:12:10 4: WEB_192.168.1.1_51227 GET /fhem?detail=ZWDongle_0; BUFLEN:0
2016.12.17 19:12:11 4: WEB_192.168.1.1_51227 GET /fhem?cmd={ReadingsVal(%22ZWDongle_0%22,%22addNode%22,%22%22)}&XHR=1; BUFLEN:0
2016.12.17 19:12:11 5: Cmd: >{ReadingsVal("ZWDongle_0","addNode","")}<
2016.12.17 19:12:11 4: name: /fhem?cmd={ReadingsVal(%22ZWDongle_0%22,%22addNode%22,%22%22)}&XHR=1 / RL:21 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2016.12.17 19:12:11 4: WEB_192.168.1.1_51227 GET /fhem?cmd={AttrVal(%22ZWDongle_0%22,%22room%22,%22%22)}&XHR=1; BUFLEN:0
2016.12.17 19:12:11 5: Cmd: >{AttrVal("ZWDongle_0","room","")}<
2016.12.17 19:12:11 4: name: /fhem?cmd={AttrVal(%22ZWDongle_0%22,%22room%22,%22%22)}&XHR=1 / RL:26 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2016.12.17 19:12:11 4: WEB_192.168.1.1_51227 GET /fhem?XHR=1&inform=type=status;filter=ZWDongle_0;since=1481998329;fmt=JSON&fw_id=undefined×tamp=1481998331236; BUFLEN:0
2016.12.17 19:12:15 4: Connection closed for WEB_192.168.1.1_51227: EOF
2016.12.17 19:12:15 4: Connection accepted from WEB_192.168.1.1_51274
2016.12.17 19:12:15 4: WEB_192.168.1.1_51274 POST /fhem&detail=ZWDongle_0&dev.setZWDongle_0=ZWDongle_0&cmd.setZWDongle_0=set&arg.setZWDongle_0=addNode&val.setZWDongle_0=on; BUFLEN:0
2016.12.17 19:12:15 5: Cmd: >set ZWDongle_0 addNode on<
2016.12.17 19:12:15 4: ZWDongle *** set ZWDongle_0 addNode on
2016.12.17 19:12:15 5: ZWDongle_Write 004a8105 ()
2016.12.17 19:12:15 5: SW: 0105004a810534
2016.12.17 19:12:15 5: Triggering ZWDongle_0 (1 changes)
2016.12.17 19:12:15 5: Starting notify loop for ZWDongle_0, 1 event(s), first is addNode on
2016.12.17 19:12:15 5: statistics Statistik: Notify.266 Notification of 'ZWDongle_0' received. Device not monitored.
2016.12.17 19:12:15 5: ABFALL_Notify(Abfall) - Device: ZWDongle_0
2016.12.17 19:12:15 5: Batterien: not on any display, ignoring notify
2016.12.17 19:12:15 5: Notify from Device: ZWDongle_0 recieved
2016.12.17 19:12:15 5: DbLog: logging of Device: ZWDongle_0 , Type: ZWDONGLE , Event: addNode on , Reading: state , Value: addNode on , Unit:
2016.12.17 19:12:15 5: ACK received, removing 0105004a810534 from dongle sendstack
2016.12.17 19:12:15 4: ZWDongle_Read ZWDongle_0: rcvd 004a05010000 (request ZW_ADD_NODE_TO_NETWORK), sending ACK
2016.12.17 19:12:15 5: SW: 06
2016.12.17 19:12:15 5: ZWDongle_0: dispatch 004a05010000
2016.12.17 19:12:15 4: ZWDongle_0 CMD:ZW_ADD_NODE_TO_NETWORK ID:01 ARG:0000
2016.12.17 19:12:15 5: Starting notify loop for ZWDongle_0, 1 event(s), first is ZW_ADD_NODE_TO_NETWORK learnReady
2016.12.17 19:12:15 5: DbLog: logging of Device: ZWDongle_0 , Type: ZWDONGLE , Event: ZW_ADD_NODE_TO_NETWORK learnReady , Reading: state , Value: ZW_ADD_NODE_TO_NETWORK learnReady , Unit:
2016.12.17 19:12:15 4: ZWDongle_0 ZW_ADD_NODE_TO_NETWORK learnReady
2016.12.17 19:12:15 4: WEB_192.168.1.1_51274 GET /fhem?detail=ZWDongle_0; BUFLEN:0
2016.12.17 19:12:15 4: name: /fhem?detail=ZWDongle_0 / RL:4486 / text/html; charset=UTF-8 / Content-Encoding: gzip
2016.12.17 19:12:15 4: WEB_192.168.1.1_51274 GET /fhem?cmd={ReadingsVal(%22ZWDongle_0%22,%22addNode%22,%22%22)}&XHR=1; BUFLEN:0
2016.12.17 19:12:15 5: Cmd: >{ReadingsVal("ZWDongle_0","addNode","")}<
2016.12.17 19:12:15 4: name: /fhem?cmd={ReadingsVal(%22ZWDongle_0%22,%22addNode%22,%22%22)}&XHR=1 / RL:21 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2016.12.17 19:12:15 4: WEB_192.168.1.1_51274 GET /fhem?cmd={AttrVal(%22ZWDongle_0%22,%22room%22,%22%22)}&XHR=1; BUFLEN:0
2016.12.17 19:12:15 5: Cmd: >{AttrVal("ZWDongle_0","room","")}<
2016.12.17 19:12:15 4: name: /fhem?cmd={AttrVal(%22ZWDongle_0%22,%22room%22,%22%22)}&XHR=1 / RL:26 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2016.12.17 19:12:15 4: WEB_192.168.1.1_51274 GET /fhem?XHR=1&inform=type=status;filter=ZWDongle_0;since=1481998334;fmt=JSON&fw_id=undefined×tamp=1481998335804; BUFLEN:0
Eisix
Nachschlag
2016.12.17 19:12:21 4: ZWDongle_Read ZWDongle_0: rcvd 004a05020000 (request ZW_ADD_NODE_TO_NETWORK), sending ACK
2016.12.17 19:12:21 5: SW: 06
2016.12.17 19:12:21 5: ZWDongle_0: dispatch 004a05020000
2016.12.17 19:12:21 4: ZWDongle_0 CMD:ZW_ADD_NODE_TO_NETWORK ID:02 ARG:0000
2016.12.17 19:12:21 5: Triggering ZWDongle_0 (1 changes)
2016.12.17 19:12:21 5: Starting notify loop for ZWDongle_0, 1 event(s), first is ZW_ADD_NODE_TO_NETWORK nodeFound
2016.12.17 19:12:21 5: statistics Statistik: Notify.266 Notification of 'ZWDongle_0' received. Device not monitored.
2016.12.17 19:12:21 5: ABFALL_Notify(Abfall) - Device: ZWDongle_0
2016.12.17 19:12:21 5: Batterien: not on any display, ignoring notify
2016.12.17 19:12:21 5: Notify from Device: ZWDongle_0 recieved
2016.12.17 19:12:21 5: DbLog: logging of Device: ZWDongle_0 , Type: ZWDONGLE , Event: ZW_ADD_NODE_TO_NETWORK nodeFound , Reading: state , Value: ZW_ADD_NODE_TO_NETWORK nodeFound , Unit:
2016.12.17 19:12:21 4: ZWDongle_0 ZW_ADD_NODE_TO_NETWORK nodeFound
2016.12.17 19:12:21 4: ZWDongle_Read ZWDongle_0: rcvd 004a050302140410015e22855970565a7a72328e717398312586 (request ZW_ADD_NODE_TO_NETWORK), sending ACK
2016.12.17 19:12:21 5: ZWDongle_0: dispatch 004a050302140410015e22855970565a7a72328e717398312586
2016.12.17 19:12:21 4: ZWDongle_0 CMD:ZW_ADD_NODE_TO_NETWORK ID:03 ARG:02140410015e22855970565a7a72328e717398312586
2016.12.17 19:12:21 5: Triggering global (1 changes)
2016.12.17 19:12:21 5: Starting notify loop for global, 1 event(s), first is UNDEFINED ZWave_SWITCH_BINARY_2 ZWave d5459244 2 5e22855970565a7a72328e717398312586
2016.12.17 19:12:21 5: statistics Statistik: Notify.266 Notification of 'global' received. Device not monitored.
2016.12.17 19:12:21 5: ABFALL_Notify(Abfall) - Device: global
2016.12.17 19:12:21 2: autocreate: define ZWave_SWITCH_BINARY_2 ZWave d5459244 2 5e22855970565a7a72328e717398312586
2016.12.17 19:12:21 5: Triggering global (2 changes)
2016.12.17 19:12:21 2: autocreate: define FileLog_ZWave_SWITCH_BINARY_2 FileLog ./log/ZWave_SWITCH_BINARY_2-%Y.log ZWave_SWITCH_BINARY_2
2016.12.17 19:12:21 5: Triggering global (3 changes)
2016.12.17 19:12:21 5: Triggering global (4 changes)
2016.12.17 19:12:21 5: Notify from Device: global recieved
2016.12.17 19:12:21 5: DbLog: logging of Device: global , Type: GLOBAL , Event: UNDEFINED ZWave_SWITCH_BINARY_2 ZWave d5459244 2 5e22855970565a7a72328e717398312586 , Reading: state , Value: UNDEFINED ZWave_SWITCH_BINARY_2 ZWave d5459244 2 5e22855970565a7a72328e717398312586 , Unit:
2016.12.17 19:12:21 5: DbLog: logging of Device: global , Type: GLOBAL , Event: DEFINED ZWave_SWITCH_BINARY_2 , Reading: state , Value: DEFINED ZWave_SWITCH_BINARY_2 , Unit:
2016.12.17 19:12:21 5: DbLog: logging of Device: global , Type: GLOBAL , Event: DEFINED FileLog_ZWave_SWITCH_BINARY_2 , Reading: state , Value: DEFINED FileLog_ZWave_SWITCH_BINARY_2 , Unit:
2016.12.17 19:12:21 5: DbLog: logging of Device: global , Type: GLOBAL , Event: SAVE , Reading: state , Value: SAVE , Unit:
2016.12.17 19:12:21 5: https://192.168.1.1:8443/api/s/default/stat/health: HTTP response code 200
2016.12.17 19:12:23 5: ZWDongle_0: dispatch 004a05050200
2016.12.17 19:12:23 4: ZWDongle_0 CMD:ZW_ADD_NODE_TO_NETWORK ID:05 ARG:0200
2016.12.17 19:12:23 1: PERL WARNING: Use of uninitialized value $CTRLID in concatenation (.) or string at (eval 18030) line 1.
2016.12.17 19:12:23 4: ZWDongle_Read ZWDongle_0: rcvd 004a05050200 (request ZW_ADD_NODE_TO_NETWORK), sending ACK
2016.12.17 19:12:23 5: SW: 06
2016.12.17 19:12:23 1: PERL WARNING: Use of uninitialized value $CTRLID in concatenation (.) or string at (eval 18032) line 1.
2016.12.17 19:12:23 1: PERL WARNING: Use of uninitialized value $CTRLID in concatenation (.) or string at (eval 18034) line 1.
2016.12.17 19:12:24 5: Cmd: >set ZWave_SWITCH_BINARY_2 associationAdd 1<
2016.12.17 19:12:24 1: ZWAVE INIT: set ZWave_SWITCH_BINARY_2 associationAdd 1 : set associationAdd needs at least 2 parameters
2016.12.17 19:12:24 5: Cmd: >get ZWave_SWITCH_BINARY_2 model<
2016.12.17 19:12:24 2: ZWave get ZWave_SWITCH_BINARY_2 model
2016.12.17 19:12:24 5: ZWDongle_Write 13020272042502 (00)
2016.12.17 19:12:24 5: SW: 010813020272042502b5
2016.12.17 19:12:24 4: ZWDongle_ReadAnswer arg:model regexp:^00040002..72
2016.12.17 19:12:25 5: ZWDongle_ReadAnswer: select timeout
2016.12.17 19:12:25 1: ZWAVE INIT: get ZWave_SWITCH_BINARY_2 model: Timeout reading answer for get model
2016.12.17 19:12:25 5: Cmd: >get ZWave_SWITCH_BINARY_2 model<
2016.12.17 19:12:25 2: ZWave get ZWave_SWITCH_BINARY_2 model
2016.12.17 19:12:25 4: ZWDongle_ReadAnswer arg:model regexp:^00040002..72
2016.12.17 19:12:26 1: ZWAVE INIT: get ZWave_SWITCH_BINARY_2 model: Timeout reading answer for get model
2016.12.17 19:12:26 5: Cmd: >get ZWave_SWITCH_BINARY_2 model<
2016.12.17 19:12:26 2: ZWave get ZWave_SWITCH_BINARY_2 model
2016.12.17 19:12:26 4: ZWDongle_ReadAnswer arg:model regexp:^00040002..72
2016.12.17 19:12:27 5: ZWDongle_ReadAnswer: select timeout
2016.12.17 19:12:27 1: ZWAVE INIT: get ZWave_SWITCH_BINARY_2 model: Timeout reading answer for get model
2016.12.17 19:12:27 2: ZWDongle_ProcessSendStack: no ACK, resending message 010813020272042502b5
2016.12.17 19:12:27 5: SW: 010813020272042502b5
hoffe das war jetzt alles
Eisix
Das vorher war für die Zwave+ Version jetzt die alte Zwave.
2016.12.17 19:12:23 5: PRESENCE (P_Netatmo) - starting ping scan: P_Netatmo|192.168.1.104|0|4
2016.12.17 19:12:23 5: Cmd: >{BlockingStart('3673')}<
2016.12.17 19:12:27 4: Connection accepted from telnetPort_127.0.0.1_34027
2016.12.17 19:12:29 2: ZWDongle_ProcessSendStack: no ACK, resending message 010813020272042502b5
2016.12.17 19:12:29 5: SW: 010813020272042502b5
2016.12.17 19:12:30 2: ZWDongle_ProcessSendStack: no ACK, resending message 010813020272042502b5
2016.12.17 19:12:30 1: ERROR: max send retries reached, removing 010813020272042502b5 from dongle sendstack
2016.12.17 19:12:34 2: ZWave: No ACK from ZWave_SWITCH_BINARY_2 after 10s for sent:13020272042502
2016.12.17 19:12:34 5: ZWDongle_Write 13020272042502 (00)
2016.12.17 19:12:34 5: SW: 010813020272042502b5
2016.12.17 19:12:35 5: Cmd: >set ZWDongle_0 addNode off<
2016.12.17 19:12:35 4: ZWDongle *** set ZWDongle_0 addNode off
2016.12.17 19:12:35 5: ZWDongle_Write 004a0506 ()
2016.12.17 19:12:35 5: Triggering ZWDongle_0 (1 changes)
2016.12.17 19:12:35 5: Starting notify loop for ZWDongle_0, 1 event(s), first is addNode off
2016.12.17 19:12:35 5: statistics Statistik: Notify.266 Notification of 'ZWDongle_0' received. Device not monitored.
2016.12.17 19:12:35 5: ABFALL_Notify(Abfall) - Device: ZWDongle_0
2016.12.17 19:12:35 5: Batterien: not on any display, ignoring notify
2016.12.17 19:12:35 5: Notify from Device: ZWDongle_0 recieved
2016.12.17 19:12:35 5: DbLog: logging of Device: ZWDongle_0 , Type: ZWDONGLE , Event: addNode off , Reading: state , Value: addNode off , Unit:
2016.12.17 19:12:35 4: WEB_192.168.1.1_51315 GET /fhem?detail=ZWDongle_0; BUFLEN:0
2016.12.17 19:12:35 4: name: /fhem?detail=ZWDongle_0 / RL:4491 / text/html; charset=UTF-8 / Content-Encoding: gzip
2016.12.17 19:12:36 4: WEB_192.168.1.1_51315 GET /fhem?cmd={ReadingsVal(%22ZWDongle_0%22,%22addNode%22,%22%22)}&XHR=1; BUFLEN:0
2016.12.17 19:12:36 5: Cmd: >{ReadingsVal("ZWDongle_0","addNode","")}<
2016.12.17 19:12:36 4: name: /fhem?cmd={ReadingsVal(%22ZWDongle_0%22,%22addNode%22,%22%22)}&XHR=1 / RL:21 / text/plain; charset=UTF-8 / Content-Encoding: gzip
Eisix
Was vielleicht noch interessant ist, habe gestern ein Update aller Perl Module mit cpanm gemacht.
Eisix
