Homebridgemapping Probleme mit Dimmer, RGBW und Thermostat
Begonnen von moppy, 21 Dezember 2016, 17:43:20
moppy
ich bin am verzweifeln, denn egal welches Homebridgemapping ich einstelle - es funktioniert nichts.
Ich versuche folgendes Gerät mit Homekit zu dimmen
Zitat"Name":"ZW_Wz_LED_Fass_white",
    "PossibleSets":"dim:slider,0,1,99 off:noArg on:noArg rgb:colorpicker,RGB stop:noArg wcrgb off-till intervals on-till off-till-overnight blink on-till-overnight on-for-timer off-for-timer toggle",
    "PossibleAttrs":"alias comment:textField-long eventMap group room suppressReading userReadings:textField-long verbose:0,1,2,3,4,5 IODev WNMI_delay noWakeupForApplicationUpdate:1,0 classes do_not_notify:1,0 dummy:1,0 extendedAlarmReadings:0,1,2 ignore:1,0 noExplorerFrames:1,0 eventForRaw secure_classes showtime:1,0 vclasses zwaveRoute neighborListPos event-on-change-reading event-on-update-reading event-aggregator event-min-interval stateFormat:textField-long timestamp-on-change-reading cmdIcon devStateIcon devStateStyle genericDeviceType:security,ignore,switch,outlet,light,blind,thermometer,thermostat,contact,garage,window,lock homebridgeMapping:textField-long icon sortby webCmd widgetOverride userattr",
    "Internals": {
      "DEF": "d0f3b337 8453",
      "LASTInputDev": "ZWDongle_0",
      "MSGCNT": "3",
      "NAME": "ZW_Wz_LED_Fass_white",
      "NR": "192",
      "STATE": "off",
      "TYPE": "ZWave",
      "ZWDongle_0_MSGCNT": "3",
      "ZWDongle_0_RAWMSG": "0004002107600d0505260300",
      "ZWDongle_0_TIME": "2016-12-21 17:39:34",
      "ZWaveSubDevice": "yes",
      "endpointParent": "ZW_Wz_LED_Fass",
      "homeId": "d0f3b337",
      "isWakeUp": "",
      "nodeIdHex": "2105"
    "Readings": {
      "reportedState": { "Value":"off", "Time":"2016-12-21 17:39:34" },
      "state": { "Value":"off", "Time":"2016-12-21 17:39:39" }
    "Attributes": {
      "IODev": "ZWDongle_0",
      "classes": "COLOR_CONTROL SWITCH_MULTILEVEL",
      "room": "Homekit,Wohnzimmer,ZWave",
      "webCmd": "dim:on:off"
  "totalResultsReturned":1
Folgendes habe ich versucht:
attr ZW_Wz_LED_Fass_white genericDeviceType light
attr ZW_Wz_LED_Fass_white homebridgeMapping Brightness=state,part=1,cmd=dim
im FHEM log funktioniert nur An und Aus
Was mache ich falsch? Muss ich evtl noch irgendwo ein "clear" setzen?
Außerdem wird mir in der iOs Home App bei diesem Dimmer die Option angezeigt, die Farbe zu verändern. Es ist allerdings nur der Weiß-Kanal - es gibt also keine Farben.
Wenn in FHEM Dimme ändert sich state auf
Zitatstate
dim 37
Aber wenn ich den Helligkeitsslider in der Home App verändere bleibt:
Zitatstate on
Habe auch bei meinem Homematic Wandthermometer Probleme die Schritte von 1 auf 0,5 zu verändern. Wäre echt super wenn mir jemand das ganze erklären kann
lg,
Emanuel
Intel NUC7i5 - Proxmox
HP Microserver Gen8 3,3ghz Xeon
http://coldcorner.de
