Revision 13146: 98_powerMap: add new set command 'assign' to support pre-defined ...
Begonnen von System, 19 Januar 2017, 00:45:08
System
98_powerMap: add new set command 'assign' to support pre-defined templates for several FHEM modules
Source: Revision 13146: 98_powerMap: add new set command 'assign' to support pre-defined ...
