fht8v and pid oregon device
Begonnen von Guest, 04 Oktober 2011, 21:53:46
Guest
I defined a and fht8v and I can control it with the CUL. I set it op
linke this in fhem.cfg
define thermostaat FHT8V 4931
Now I want to use and oregon device as measuring device instead of an
s300th device.
How must I define it?
define temp_thermostaat PID Slaapkamertemp:temperature:([\d\.]*)
thermostaat
I think after the temperature is wrong but I don't know what it should
be?
the oregon sensor is defined:
define Slaapkamertemp OREGON THGR228N_d9
attr Slaapkamertemp fm_order 22
attr Slaapkamertemp room Slaapkamer
define FileLog_Slaapkamertemp FileLog /var/log/fhem/slaapkamer2-%Y.log
Slaapkamertemp
attr FileLog_Slaapkamertemp fm_order 34
attr FileLog_Slaapkamertemp logtype oregon_hms:Temp/Hum,text
attr FileLog_Slaapkamertemp room Slaapkamer
define weblink_Slaapkamertemp weblink fileplot
FileLog_Slaapkamertemp:oregon_hms:CURRENT
attr weblink_Slaapkamertemp label "Slaapkamer Min $data{min1}, Max
$data{max1}, Last $data{currval1}"
attr weblink_Slaapkamertemp room Slaapkamer
logging looks like
2011-10-04_21:49:38 Slaapkamertemp battery: 10
2011-10-04_21:49:38 Slaapkamertemp T: 21  H: 63
2011-10-04_21:50:21 Slaapkamertemp temperature: 21
2011-10-04_21:50:21 Slaapkamertemp humidity: 63
2011-10-04_21:50:21 Slaapkamertemp battery: 10
2011-10-04_21:50:21 Slaapkamertemp T: 21  H: 63
2011-10-04_21:51:04 Slaapkamertemp temperature: 21
2011-10-04_21:51:04 Slaapkamertemp humidity: 63
2011-10-04_21:51:04 Slaapkamertemp battery: 10
2011-10-04_21:51:04 Slaapkamertemp T: 21  H: 63
2011-10-04_21:51:47 Slaapkamertemp temperature: 21
2011-10-04_21:51:47 Slaapkamertemp humidity: 63
2011-10-04_21:51:47 Slaapkamertemp battery: 10
2011-10-04_21:51:47 Slaapkamertemp T: 21  H: 63
fhem> l Slaapkamertemp
   CODE       THGR228N_d9
   DEF        THGR228N_d9
   IODev      RFXCOM
   NAME       Slaapkamertemp
   NR         31
   STATE      T: 21  H: 63
   TIME       2011-10-04 21:51:47
   TYPE       OREGON
   Readings:
     2011-10-04 21:51:47   battery         10
     2011-10-04 21:51:47   humidity        63
     2011-10-04 21:51:47   temperature     21
   fm_order   22
   room       Slaapkamer
> be?
Since your sensor is generating a temperature event too, you should add it to
line 49 in 98_PID.pm (and tell me the diff). Apparently the regexp there is
defined as
        $regexp = '([\\d\\.]*)';
so this is most probably the correct way do define it on the command line.
Please tell me if it works: in surveyresults there are 6 entries, but I never
heard any explicit confirmation, and I do not use the PID module.
Guest
Hi
I edited line this in 98_PID.pm (changed HMS to OREGON)
    my $t = $defs{$sensor}{TYPE};
    if($t eq "OREGON" || $t eq "CUL_WS") {
      $reading = "temperature";
in fhem.cfg
thermostaat
Slaapkamertemp
But I get in logging
2011.10.06 08:31:11 1: configfile: temp_thermostaat: Unknown sensor
device Slaapkamertemp specified
But I think its ok?????
regards Richard
> > be?
> defined as
the regexp is not necessary, if the TYPE is known in the PID.pm file
Are you sure that in the config file the PID definition comes _AFTER_ the
sensor definition?
Guest
Rudolf,
I think that was the issue I got these values, and look ok??
fhem> l temp_thermostaat
   DEF        Slaapkamertemp:temperature:([\d\.]*) thermostaat
   NAME       temp_thermostaat
   NR         34
   STATE      initialized
   TYPE       PID
   actor      thermostaat
   command    valve
   dFactor    5.88235294117647
   iFactor    3.05882352941176
   pFactor    25.4901960784314
   reading    temperature
   regexp     ([\d\.]*)
   satMax     100
   satMin     0
   sensor     Slaapkamertemp
   Readings:
     2011-10-06 16:38:09   actuation       0
     2011-10-06 16:38:09   delta           0
     2011-10-06 16:38:09   integrator      0
fhem> set temp_thermostaat desired 20
   NR         34
   STATE      20.4 (delta -0.399999999999999)
   TYPE       PID
   actor      thermostaat
   command    valve
   reading    temperature
   regexp     ([\d\.]*)
   satMax     100
   satMin     0
   Readings:
     2011-10-06 16:40:32   actuation       0
     2011-10-06 16:40:32   delta           -0.399999999999999
     2011-10-06 16:40:32   desired         20
     2011-10-06 16:40:32   integrator      0
fhem> l thermostaat
   DEF        4931
   IODev      CUL
   NAME       thermostaat
   NR         3
   STATE      0 %
   TYPE       FHT8V
   addr       4931
   idx        03
fhem>
fhem> set temp_thermostaat desired 21
fhem> l thermostaat
   DEF        4931
   IODev      CUL
   NAME       thermostaat
   NR         3
   STATE      23 %
   TYPE       FHT8V
   addr       4931
   idx        03
fhem>
> sensor definition?
