Is my CUL dead?
Begonnen von Guest, 06 Oktober 2011, 13:44:51
Guest
Hi all,
I have a problem with my CUL device and hope someone can help.
I have an Etrayz media server running FHEM with CUL ver3 attached
which controls seven FHT80b thermostats round the house. It has been
working very well all last winter but not used much through the
summer.
When I tested it recently FHEM could recieve data from the thermostats
but would not send data to change temperature. Eventually I re-built
Etrayz and reinstalled FHEM, it would still only recieve data but not
send anything.
The last thing I did was to re-flash the CUL on my windows PC but now
the CUL has dissapeard completley.
When I run cat /proc/bus/usb/devices I get the following.....
T:  Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#=  1 Spd=480 MxCh= 3
B:  Alloc=  0/800 us ( 0%), #Int=  0, #Iso=  0
D:  Ver= 2.00 Cls=09(hub  ) Sub=00 Prot=01 MxPS=64 #Cfgs=  1
P:  Vendor=0000 ProdID=0000 Rev= 2.06
S:  Manufacturer=Linux 2.6.24.4 ehci_hcd
S:  Product=OXNAS EHCI Host Controller
S:  SerialNumber=usb
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=  0mA
I:* If#= 0 Alt= 0 #EPs= 1 Cls=09(hub  ) Sub=00 Prot=00 Driver=hub
E:  Ad=81(I) Atr=03(Int.) MxPS=   4 Ivl=256ms
T:  Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 12 Spd=12  MxCh= 0
D:  Ver= 2.00 Cls=ff(vend.) Sub=01 Prot=00 MxPS=32 #Cfgs=  1
P:  Vendor=03eb ProdID=2ff4 Rev= 0.00
S:  Manufacturer=ATMEL
S:  Product=ATm32U4DFU
S:  SerialNumber=1.0.0
C:* #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=100mA
I:* If#= 0 Alt= 0 #EPs= 0 Cls=00(>ifc ) Sub=00 Prot=00 Driver=(none)
The vendor used to = 03eb  and pordID = 204b
The manufacturer used to = busware.de
and product used to = CUL868
Can someone please help
Thankyou
Alan
tostmann
Am 06.10.2011 um 13:44 schrieb aam:
No, your CUL is alive in dfu-Bootloader mode. Just re-flash the desired firmware and don't panic ...
Guest
Thankyou, can you please tell me how I get it out of bootloader mode.
I have re-flashed it several times both with the small button pressed
and without but it does not seem to make a differance.
tostmann
Am 06.10.2011 um 14:27 schrieb aam:
This just indicates that you either haven't flashed the image successful or you permanently short circuit the bootloader switch therefor the bootloader kicks in.
Guest
Thankyou, I will check and try again when I get home.
Guest
I flashed the CUL again when I got home yesterday, this time it
completed sucessfully and is working again.
Thankyou for your help
Cheers
Alan
