ZigBee: Mitlauschen bei Alarmanlage
Begonnen von peterboeckmann, 11 Februar 2017, 11:49:57
mitdra
#45
Hallo Peter,
ich habe es gerade versucht mich anzumelden.
Mein List:
   BUSY       0
   CFGFN
   CHANGED
   DEF        http://Anmeldename:MeinPW@192.168.178.22/action/device.htm 30
   Interval   30
   LASTSEND   1495038057.45247
   MainURL    http://Anmeldename:MeinPW@192.168.178.22/action/device.htm
   ModuleVersion 3.3.11 - 8.5.2017
   NAME       AlarmZentrale
   NR         2631
   STATE      ???
   TRIGGERTIME 1495038087.45069
   TRIGGERTIME_FMT 2017-05-17 18:21:27
   TYPE       HTTPMOD
   addr       http://192.168.178.22:80
   auth       Anmeldename:MeinPW
   buf        HTTP/1.1 401 Unauthorized
Server: MQX HTTP Climax
Cache-Control: no-cache, no-store, max-age=0, must-revalidate
Expires: Fri, 01 Jan 1990 00:00:00 GMT
Pragma: no-cache
Connection: close
Content-Type: text/html
WWW-Authenticate: Basic realm="WebPanel"
<!DOCTYPE HTML>
<html><head><meta http-equiv="content-type" content="text/html; charset=UTF-8" /><title>401 Unauthorized</title><style type="text/css">
*{font-family:Arial,Helvetica;}
table{border:0;}
table.fm{border-collapse:collapse;border:1px solid #aaa;width:95%;margin:4px 2px;}
table.fm tr td{border-collapse:collapse;border:1px solid #aaa;padding:2px;}
td.ct{text-align:center;}
table.ff td:first-child{font-weight:bold;}
input.sbtn{background-color:#D1D1D1;}
ul{list-style-type:none;margin:0;padding:0;overflow:hidden;}
li{float:left;}
li a{display:block;background-color:#dddddd;padding:.3em;margin:.3em;}
</style></head><body>
<ul><li><a href="index.htm">Welcome</a></li>
<li><a href="control.htm">Control</a></li>
<li><a href="panel.htm">Panel</a></li>
<li><a href="device.htm">Device</a></li>
<li><a href="area.htm">Area</a></li>
<li><a href="user.htm">User</a></li>
<li><a href="history.htm">History</a></li>
<li><a href="capevent.htm">Captured Event</a></li>
<li><a href="rptevent.htm">Reported Event</a></li>
<li><a href="network.htm">Network</a></li>
<li><a href="report.htm">Report</a></li>
<li><a href="upload.htm">Upload</a></li>
<li><a href="ha.htm">HA</a></li>
<li><a href="firmware.htm">Firmware</a></li>
</ul><hr/>
<h1>Unauthorized!</h1>
<hr/>
&copy;2016 Climax Tech. Co., Ltd.</body></html>
   code       401
   conn
   data
   displayurl http://Anmeldename:MeinPW@192.168.178.22/action/device.htm
   header
   host       192.168.178.22
   httpheader HTTP/1.1 401 Unauthorized
Pragma: no-cache
Connection: close
   httpversion 1.0
   hu_blocking 0
   hu_filecount 15
   hu_portSfx
   ignoreredirects 0
   loglevel   4
   path       /action/device.htm
   protocol   http
   redirects  0
   timeout    2
   value      0
   QUEUE:
   Readings:
   Request:
     data
     header
     ignoreredirects 0
     retryCount 0
     type       update
     value      0
   Sslargs:
   room       System
Aber der Anmeldename und MeinPW ist das womit ich mich erfolreich auf die https://eu.bphomeconnect.com/BP/ Seite anmelde.
Wenn ich 192.168.178.22/action/device.htm direkt aufrufe nimmt kann ich mich in dem PopUp nicht damit anmelden.
http://192.168.178.22 verlangt einen Benutzernamen und ein Passwort. Ausgabe der Website: "WebPanel"
Ist es ein anderes PW oder was hat die Kiste für ein Problem?
Grüße David
peterboeckmann
Zitat von: mitdra am 17 Mai 2017, 18:27:00
Hallo Peter,
Mein List:
   BUSY       0
   CFGFN
   CHANGED
   Interval   30
   NAME       AlarmZentrale
   NR         2631
   STATE      ???
   TYPE       HTTPMOD
Pragma: no-cache
Connection: close
<!DOCTYPE HTML>
table{border:0;}
li{float:left;}
</ul><hr/>
<hr/>
   code       401
   conn
   data
   header
   host       192.168.178.22
Pragma: no-cache
Connection: close
   httpversion 1.0
   hu_blocking 0
   hu_filecount 15
   hu_portSfx
   ignoreredirects 0
   loglevel   4
   protocol   http
   redirects  0
   timeout    2
   value      0
   QUEUE:
   Readings:
   Request:
     data
     header
     ignoreredirects 0
     retryCount 0
     type       update
     value      0
   Sslargs:
   room       System
Grüße David
es ist ein anderes Passwort.
Registriere dich mal hier, wenn du noch nicht hast und frage nach dem Zugang:
http://blaupunkt.freshdesk.com/de/support/home
Viele Grüße,
Peter
Gesendet von meinem SM-G930F mit Tapatalk
MQTT,Modbus,HTTPMod,DbLog,LaCrosse,SolarForecast,TelegramBot,Twilight,vitoconnect,withings
fhem,fhempy,debmatic
Debian
RaspberryPi5,HomeMatic,HomeMaticIP,Shelly,JeeLink,SignalDuino,ZWDongle,SONOS,alexa,Hue,tradfri,MobileAlerts,Siemens Home Connect,Roborock S50,Wallbox,Harmony,Tuya Smartlife
mitdra
Hallo Peter,
vielen Dank vorab für den Tipp. Ich habe von Blaupunkt nun auch die Zugangsdaten bekommen und es funktioniert soweit.
Leider bin ich nicht in der Lage, das liegt aber auch daran das ich mit den readings auf Kriegsfuss stehe, etwa den Haustür Status auszuwerten.
defmod AlarmZentrale HTTPMOD http://admin_ABCDEFGH:123456@192.168.178.22/action/device.htm 30
attr AlarmZentrale reading01Name Haustür
attr AlarmZentrale reading01Regex <td>Haustür</td><td>[^\d]+</td><td></td><td></td><td></td><td></td><td>[\d]</td><td>([^\d]+)</td>
attr AlarmZentrale room System
Kannst Du mir nochmal nachhelfen?
Vielen Dank im Voraus!
Grüße David
peterboeckmann
Hi David,
mit der Haustür hatte ich auch ein Problem. Ich habe dann herausgefunden, dass es an der Ziffer 1 liegt. Ich habe die Haustür als Entry1 markiert. Daher ist mein Regex wie folgt:
<td>Haustür</td><td>Entry1</td><td></td><td></td><td></td><td></td><td>[\d]</td><td>([^\d]+)</td>
Viele Grüße,
Peter
Debian
mitdra
Hallo Peter,
es funktioniert :-)
Ich gebe mich mal an die anderen Kontakte und arbeite mich in die readings ein.
Vielen Dank!!!
Grüße David
PingPong
habe ebenfalls die besagte Blaupunkt Alarmanlage und würde die Sensordaten ebenfalls gerne in fhem verwenden.
Vielleicht steh ich auf dem Schlauch, aber könnt Ihr mirsagen, nach welchen Zugangsdaten ich fragen soll/muss?
Danke und viele Grüße
Marc
peterboeckmann
Zitat von: PingPong am 24 Mai 2017, 15:46:51
Marc
frag den Support mal nach dem Admin-Zugang. Ich glaube, das ist das Schlüsselwort.
Viele Grüße,
Peter
Debian
PingPong
Danke, dann bin ich mal gespannt...
mitdra
Ich hatte auch den Support nach dem Zugangsdaten gefragt und die haben mir bereitwillig und schnell die ZugangsDaten zugeschickt.
User beginnt mit admin_* und PW ist ebenfalls kryptisch.
Viele Erfolg!
PingPong
also User und PWD hätte ich nun auch :-)
Ich kann mich aber leider nicht anmelden.. : 401 Unauthorized :-(
Muss da noch irgendwo was eingestellt werden? oder soll/muss ich nochmal beim support nachfragen?
peterboeckmann
Zitat von: PingPong am 26 Mai 2017, 22:47:53
Hallo Marc,
kommt die 401-Fehlermeldung auch, wenn du die Adresse http://192.168.178.22/action/device.htm im Browser öffnest und anschließend die Zugangsdaten eingibst? (natürlich mit deiner IP)
Wenn ja, muss irgendwo ein Fehler in den Zugangsdaten sein. Vielleicht wurden sie dir schon falsch geschickt. Dann müsstest du nochmal nachfragen.
Viele Grüße,
Peter
Debian
PingPong
Hallo Peter,
ja, Problem tritt auch da schon auf.
Ok, dann kein Trick :-(
Dann frag ich nochmal nach.
Danke.
PingPong
Ok, hab nen neuen User bekommen. Jetzt kann ich mich schonmal anmelden...
Als nächstes muss ich dann mal versuchen, die Readings zu verstehen und an die Sensoren zu kommen.
Vielen Dank nochmal.
PingPong
bekomme folgende Meldung im Log:
"AlarmZentrale: Read response to update didn't match any Reading".
Hat jemand nen Tipp für mich, wo der Fehler liegen könnte?
HTTP Mod wird auch nur mit ??? angezeigt.
peterboeckmann
#59
Hallo Marc,
die Meldung hatte ich noch nicht. Klingt für mich, als wenn dein RegEx auf der Seite nicht gefunden wurde.
Kannst du mal ein list posten?
Edit:
Der Status wurde bei mir auch mit drei Fragezeichen angezeigt, bis ich das attr stateFormat gesetzt habe.
Debian
