Gartenbeleuchtung in TabletUI übernehmen
Begonnen von Kusselin, 13 Februar 2017, 13:03:43
redlav
Häng mal deine html-Dateien hier rein, damit ich mir die mal ansehen kann.
Vieleicht fällt mir ja was auf.
Kusselin
#31
so sieht die html datei aus:
<html>
<head>
    <title>Einstellungen</title>
</head>
<body>
<div class="gridster">
<ul>
<!-- Menü -->
<li data-col="1" data-row="1" data-sizex="1" data-sizey="8" data-template="menu.html">
<!-- Gartenbeleuchtung -->
<li data-col="7" data-row="2" data-sizex="5" data-sizey="2">
<header>
<div data-type="label" class="medium">Gartenbeleuchtung</div>
</header>
<div class="top-space small">
<div data-type="switch" data-device="Beleuchtung_Terrasse" data-get="state" data-icons='["fa-lightbulb-o","fa-lightbulb-o"]' data-on-colors='["black","gray"]' data-get-on='["on","off"]' data-background-colors='["#006600","#505050"]' data-set-on="on" data-set-off="off" class="bigger inline" ></div>
<div data-type="switch" data-device="Beleuchtung_Ostseite" data-get="state" data-icons='["fa-lightbulb-o","fa-lightbulb-o"]' data-on-colors='["black","gray"]' data-get-on='["on","off"]' data-background-colors='["#006600","#505050"]' data-set-on="on" data-set-off="off" class="bigger inline" ></div>
<div data-type="switch" data-device="Beleuchtung_Suedseite" data-get="state" data-icons='["fa-lightbulb-o","fa-lightbulb-o"]' data-on-colors='["black","gray"]' data-get-on='["on","off"]' data-background-colors='["#006600","#505050"]' data-set-on="on" data-set-off="off" class="bigger inline" ></div>
<div data-type="switch" data-device="Beleuchtung_Westseite" data-get="state" data-icons='["fa-lightbulb-o","fa-lightbulb-o"]' data-on-colors='["black","gray"]' data-get-on='["on","off"]' data-background-colors='["#006600","#505050"]' data-set-on="on" data-set-off="off" class="bigger inline" ></div>
</div>
</div>
</li>
</ul>
</div>
</body>
</html>
Es ist ein Unterschied gell wenn ich die daten in der HTML hintereinander schreibe gegenüber untereinander?
Wenn Du noch mehr Infos benötigst, sag bitte Bescheid.
Gruss
Kusselin
Anders herum...
wie müsste die Ergänzung aussehen das die Icons nebeneinander sitzen??
im Header soll " Gartenbeleuchtung" stehen:
<ul>
   <li data-col="1" data-row="1" data-sizex="1" data-sizey="8">
      <div data-type="switch" class="big"
        data-device="Terrassen_Beleuchtung"
        data-get="state"
data-set-on="on"
data-set-off="off"
data-background-colors='["#AA6900","#505050"]'>
      </div>
      <div data-type="label" class="darker big">Terrasse</div>
        data-device="Ostseite_Beleuchtung"
        data-get="state"
data-set-on="on"
data-set-off="off"
      </div>
      <div data-type="label" class="darker big">Osten</div>
        data-device="Suedseite_Beleuchtung"
        data-get="state"
data-set-on="on"
data-set-off="off"
      </div>
      <div data-type="label" class="darker big">Suedseite</div>
        data-device="Westseite_Beleuchtung"
        data-get="state"
data-set-on="on"
data-set-off="off"
      </div>
      <div data-type="label" class="darker big">Westseite</div>
</li>
</ul>
Ich bekomms ums verr....nicht gebacken die Icons nebeneinander zu setzen!!
Gruss
n4rrOx
versuch es mal so...:
<ul>
   <li data-col="1" data-row="1" data-sizex="1" data-sizey="2" data-sizex="8">
   <header>Gartenbeleuchtung</header>
      <div class="inline">
        data-get="state"
data-set-on="on"
data-set-off="off"
      </div>
      </div>
        data-get="state"
data-set-on="on"
data-set-off="off"
      </div>
      </div>
        data-get="state"
data-set-on="on"
data-set-off="off"
      </div>
      </div>
        data-get="state"
data-set-on="on"
data-set-off="off"
      </div>
      </div>
   </li>
</ul>
Ggf. noch mit data-sizey und data-sizex experimentieren (benutze kein Gridster), wenn die Symbole trotzdem noch umgebrochen werden (da zu wenig Platz im li-Gridster-Element...).
Aber ich würde dir generell eher erstmal raten sich mit den grundlegenden HTML/CSS Eigenheiten zu beschäftigen....da du einfach noch solche grundlegenden Dinge, wie ... z. B. Tags, die geöffnet werden, nicht schließt ...
<li ......>
Inhalt
</li>
Anschließend kommen die Eigenheiten vom eingesetzten Framework ... Gridster, Flexbox .... usw. usw. und danach kommen die Eigenheiten der Widgets selbst.
Mathias
Kusselin
Hi danke dir...
ja da gebe ich dir recht...habe Bücher zuhause die ich unbedingt mal lesen muss..aber soviel...
<li
Inhalt
</li>
da kommt dann alles rein was angezeigt werden soll....aber wie das dann aussehen muss damit die Buttons nebeneinander stehen sollen....das ist schwer..denke aber es hängt mit
zusammen, wenn ich mich nicht täuche??
Gruss
Wenn ich zuhause bin dann kopiere ich es mal rein und berichte..
Stimmt es das es ein Unterschied ist wenn ich den Inhalt (html) hintereinander schreibe als untereinander??
n4rrOx
das mit dem <li> war nur ein Beispiel.
Richtig. Jeder DIV-Container der diese Klasse innerhalb eines "Rang-höheren" Elements hat (z.B. innerhalb eines <li> oder anderen <div>), wird nebeneinander angezeigt.
Meinst du mit untereinander und hintereinander Folgendes?:
<ul>
  <li>
    <div class="right-align">
        <div class="inline">Eins </div>
        <div class="inline">Zwei </div>
        <div class="inline">Drei </div>
    </div>
  </li>
</ul>
bzw.
<ul><li><div class="right-align"><div class="inline">Eins </div><div class="inline">Zwei </div><div class="inline">Drei</div></div></li></ul>
Wenn, ja, dann ist die Antwort, dass es keinen Unterschied macht.
Man erhält bei beiden die gleiche Ausgabe:
Eins Zwei Drei
Kusselin
ja so meinte ich das auch..danke für die Info..
Jetzt habe ich mal kopiert und zwar habe ich noch den "row wert verändert weil das eigentlich das menü ist am Anfang!!
<html>
<head>
</head>
<body>
<ul>
<li data-col="2" data-row="1" data-sizex="1" data-sizey="2" data-sizex="8">
        data-get="state"
data-set-on="on"
data-set-off="off"
      </div>
      </div>
        data-get="state"
data-set-on="on"
data-set-off="off"
      </div>
      </div>
        data-get="state"
data-set-on="on"
data-set-off="off"
      </div>
      </div>
        data-get="state"
data-set-on="on"
data-set-off="off"
      </div>
      </div>
   </li>
</ul>
</div>
</body>
</html>
Und mit Bild so :-(
n4rrOx
Bitte nachlesen wie das mit den Gridster-Einteilungen ist (wie gesagt .... benutze kein Gridster):
.... data-col="2" data-row="1" data-sizex="1" data-sizey="2" data-sizex="8" ....
So wie es auf dem Bild aussieht haben die Elemente nicht genug Platz, um sich nebeneinander aufzureihen und werden deswegen automatisch umgebrochen.
Kusselin
Ahhh ok das ist natürlich noch ne option..bin grad unterwegs..melde mich
Thorsten Pferdekaemper
data-sizex ist außerdem zweimal drin. Da kann sich das System dann was aussuchen. Nach Murphy wird das immer das Falsche sein.
Ich habe den ganzen inline-Kram irgendwann aufgegeben und positioniere meinen Kram mit <table>. Das ist in modernem Webdesign zwar verpönt, es hat aber den Vorteil, dass es funktioniert.
Btw.: selfhtml.org ist meistens meine Referenz. Bücher dazu habe ich keine.
   Thorsten
FUIP
redlav
Meine Frage nach den widget_base-Definitionen wurde auch noch nicht beantwortet:
<meta name="widget_base_width" content="xx">
<meta name="widget_base_height" content="xx">
Wie sehen diese in deiner index.html aus?
Ohne diese Informationen wird es schwierig die Größenangaben in den <li></li>-Definitionen
zu bewerten.
Verwendest du einen Editor mit html-Unterstützung?
In einem solchem Editor kannst du da auf die einzelnen Tags klicken der jeweils dazu passende wird hervorgehoben.
Auch eine Formatierungsfunktion, die die Einrückungen sauber vornimmt hilft bei der Suche nach Inkonsistenzen, die
durch copy&paste mal gerne passieren.
Dann nochmal die Frage nach der Version. Wenn du noch nicht viel an Code zusammen hast, würde ich dir den Update
die 2.6 empfehlen. Dann kannst du dir den ganzen Gridsterkram ersparen. Das geht da wohl automatisch. Außerdem
spartst du dir den Update nachher, der manchmal wohl eine Anpassung des Layout notwendig macht.
Kusselin
weiß ich nicht ich poste aber die HTML dateien...
Sorry aber den Code von gestern..da erscheint nur fett "FTUI" mehr nicht!!
Wie update ich denn?
Gruss
Kusselin
Main HTML:
<html>
<head>
    <title>iHaus Heler</title>
</head>
<body>
<ul>
<!-- Menü -->
<li data-col="1" data-row="1" data-sizex="1" data-sizey="8" data-template="menu.html"></li>
<!-- TV Controll -->
<li data-col="2" data-row="1" data-sizex="10" data-sizey="2">
<header>
<div data-type="label" class="medium">Media Control</div>
</header>
<div class="left-align left-space">
<div class="inline" data-type="label">Kinderzimmer</div>
<div class="inline" data-type="button" data-device="tv_kinderzimmer" data-get="STATE" data-colors='["green","red"]' data-limits='["opened","disconnected"]' data-fhem-cmd="set SamsungKinderzimmer POWEROFF" data-icon="fa-power-off"></div>
<div class="inline" data-type="select"
data-items='["","define timerKZ at +00:30:00 set SamsungSchlafzimmer POWEROFF",
"define timerKZ at +00:50:00 set SamsungSchlafzimmer POWEROFF",
"define timerKZ at +01:45:00 set SamsungSchlafzimmer POWEROFF",
"define timerKZ at +02:05:00 set SamsungSchlafzimmer POWEROFF"]'
data-alias='["TimerOFF",
"30 Minuten",
"50 Minuten",
"105 Minuten",
"125 Minuten"]'
data-cmd="delete timerKZ;"></div>
</div>
<div class="inline" data-type="label">Schlafzimmer</div>
<div class="inline" data-type="button" data-device="tv_schlafzimmer" data-get="STATE" data-colors='["green","red"]' data-limits='["opened","disconnected"]' data-fhem-cmd="set SamsungSchlafzimmer POWEROFF" data-icon="fa-power-off"></div>
<div data-type="select"
data-items='["",
"define timerSZ at +00:30:00 set SamsungSchlafzimmer POWEROFF",
"define timerSZ at +00:50:00 set SamsungSchlafzimmer POWEROFF",
"define timerSZ at +01:45:00 set SamsungSchlafzimmer POWEROFF",
"define timerSZ at +02:05:00 set SamsungSchlafzimmer POWEROFF"]'
"30 Minuten",
"50 Minuten",
"105 Minuten",
"125 Minuten"]'
data-cmd="delete timerSZ;"></div>
</div>
</li>
<!-- Familien Kalender-->
<li data-col="2" data-row="3" data-sizex="5" data-sizey="2">
<header>
<div data-type="label" class="medium">Wichtige Termine</div>
</header>
<div class="left-space-2">
<div data-type="label" data-device="vKalender_Familie" data-get="t_001_bdate" data-part="(\d\d\.\d\d\.).*" class="inline left"></div>
<div data-type="label" data-device="vKalender_Familie" data-get="t_001_btime" data-part="(\d\d\:\d\d).*" class="inline left"></div>
<div data-type="label" data-device="vKalender_Familie" data-get="t_001_etime" data-part="(\d\d\:\d\d).*" class="inline left"></div>
<div data-type="label" data-device="vKalender_Familie" data-get="t_001_summary" class="inline w3x right-align"></div>
</div>
<div data-type="label" data-device="vKalender_Familie" data-get="t_002_bdate" data-part="(\d\d\.\d\d\.).*" class="inline left"></div>
<div data-type="label" data-device="vKalender_Familie" data-get="t_002_btime" data-part="(\d\d\:\d\d).*" class="inline left"></div>
<div data-type="label" data-device="vKalender_Familie" data-get="t_002_etime" data-part="(\d\d\:\d\d).*" class="inline left"></div>
<div data-type="label" data-device="vKalender_Familie" data-get="t_002_summary" class="inline w3x right-align"></div>
</div>
<div data-type="label" data-device="vKalender_Familie" data-get="t_003_bdate" data-part="(\d\d\.\d\d\.).*" class="inline left"></div>
<div data-type="label" data-device="vKalender_Familie" data-get="t_003_btime" data-part="(\d\d\:\d\d).*" class="inline left"></div>
<div data-type="label" data-device="vKalender_Familie" data-get="t_003_etime" data-part="(\d\d\:\d\d).*" class="inline left"></div>
<div data-type="label" data-device="vKalender_Familie" data-get="t_003_summary" class="inline w3x right-align"></div>
</div>
<div data-type="label" data-device="vKalender_Familie" data-get="t_004_bdate" data-part="(\d\d\.\d\d\.).*" class="inline left"></div>
<div data-type="label" data-device="vKalender_Familie" data-get="t_004_btime" data-part="(\d\d\:\d\d).*" class="inline left"></div>
<div data-type="label" data-device="vKalender_Familie" data-get="t_004_etime" data-part="(\d\d\:\d\d).*" class="inline left"></div>
<div data-type="label" data-device="vKalender_Familie" data-get="t_004_summary" class="inline w3x right-align"></div>
</div>
<div data-type="label" data-device="vKalender_Familie" data-get="t_005_bdate" data-part="(\d\d\.\d\d\.).*" class="inline left"></div>
<div data-type="label" data-device="vKalender_Familie" data-get="t_005_btime" data-part="(\d\d\:\d\d).*" class="inline left"></div>
<div data-type="label" data-device="vKalender_Familie" data-get="t_005_etime" data-part="(\d\d\:\d\d).*" class="inline left"></div>
<div data-type="label" data-device="vKalender_Familie" data-get="t_005_summary" class="inline w3x right-align"></div>
</div>
<div data-type="label" data-device="vKalender_Familie" data-get="t_006_bdate" data-part="(\d\d\.\d\d\.).*" class="inline left"></div>
<div data-type="label" data-device="vKalender_Familie" data-get="t_006_btime" data-part="(\d\d\:\d\d).*" class="inline left"></div>
<div data-type="label" data-device="vKalender_Familie" data-get="t_006_etime" data-part="(\d\d\:\d\d).*" class="inline left"></div>
<div data-type="label" data-device="vKalender_Familie" data-get="t_006_summary" class="inline w3x right-align"></div>
</div>
</li>
<!-- Geburtstags Kalender-->
<li data-col="2" data-row="4" data-sizex="5" data-sizey="2">
<header>
<div data-type="label" class="medium">Geburtstage</div>
</header>
<div data-type="label" data-device="vKalender_Geburtstage" data-get="t_001_bdate" data-part="(\d\d\.\d\d\.).*" class="inline left"></div>
<div data-type="label" data-device="vKalender_Geburtstage" data-get="t_001_summary" class="inline w3x right-align"></div>
</div>
<div data-type="label" data-device="vKalender_Geburtstage" data-get="t_002_bdate" data-part="(\d\d\.\d\d\.).*" class="inline left"></div>
<div data-type="label" data-device="vKalender_Geburtstage" data-get="t_002_summary" class="inline w3x right-align"></div>
</div>
<div data-type="label" data-device="vKalender_Geburtstage" data-get="t_003_bdate" data-part="(\d\d\.\d\d\.).*" class="inline left"></div>
<div data-type="label" data-device="vKalender_Geburtstage" data-get="t_003_summary" class="inline w3x right-align"></div>
</div>
<div data-type="label" data-device="vKalender_Geburtstage" data-get="t_004_bdate" data-part="(\d\d\.\d\d\.).*" class="inline left"></div>
<div data-type="label" data-device="vKalender_Geburtstage" data-get="t_004_summary" class="inline w3x right-align"></div>
</div>
<div data-type="label" data-device="vKalender_Geburtstage" data-get="t_005_bdate" data-part="(\d\d\.\d\d\.).*" class="inline left"></div>
<div data-type="label" data-device="vKalender_Geburtstage" data-get="t_005_summary" class="inline w3x right-align"></div>
</div>
<div data-type="label" data-device="vKalender_Geburtstage" data-get="t_006_bdate" data-part="(\d\d\.\d\d\.).*" class="inline left"></div>
<div data-type="label" data-device="vKalender_Geburtstage" data-get="t_006_summary" class="inline w3x right-align"></div>
</div>
</li>
<!-- Abfall Kalender -->
<li data-col="7" data-row="5" data-sizex="5" data-sizey="2">
<header>
<div data-type="label" class="medium">Abfall Kalender</div>
</header>
<div data-type="symbol" data-device="MuellterminDummy" data-get="BioTonne" data-icons='["fa-trash warn fa-spin","fa-trash warn"]' data-on-colors='["SaddleBrown","SaddleBrown"]' data-get-on='["0","2"]' class="bigger inline" ></div>
<div data-type="symbol" data-device="MuellterminDummy" data-get="BlaueTonne" data-icons='["fa-trash warn fa-spin","fa-trash warn"]' data-on-colors='["blue","blue"]' data-get-on='["0","2"]' class="bigger inline" ></div>
<div data-type="symbol" data-device="MuellterminDummy" data-get="GrueneTonne" data-icons='["fa-trash warn fa-spin","fa-trash warn"]' data-on-colors='["green","green"]' data-get-on='["0","2"]' class="bigger inline" ></div>
<div data-type="symbol" data-device="MuellterminDummy" data-get="Restmuell" data-icons='["fa-trash warn fa-spin","fa-trash warn"]' data-on-colors='["gray","grey"]' data-get-on='["0","2"]' class="bigger inline" ></div>
</div>
</li>
<!-- Wetter -->
<li data-col="12" data-row="1" data-sizex="2" data-sizey="8">
<header>
<div data-type="label" class="medium">Wetter</div>
</header>
<table>
<tr class="center">
<header>
<div class="inline" data-type="label" data-device="MeinWetter" data-get="fc1_day_of_week"></div>
<div class="inline" data-type="label" data-device="MeinWetter" data-get="fc1_date"></div>
</header>
</tr>
<tr class="center">
<td>
<div class="medium inline" data-type="weather" data-device="MeinWetter" data-get="fc1_condition"></div>
<div class="medium inline" data-type="label" data-device="MeinWetter" data-get="temperature"></div>
<div class="medium inline" data-type="label">C°</div>
</td>
</tr>
<tr class="center"><td><div class="small" data-type="label" data-device="MeinWetter" data-get="condition"></div></td></tr>
</table>
<br class="small">
<table>
<tr class="center">
<header class="small">
<div class="inline" data-type="label" data-device="MeinWetter" data-get="fc2_day_of_week"></div>
<div class="inline" data-type="label" data-device="MeinWetter" data-get="fc2_date"></div>
</header>
</tr>
<tr class="center">
<td>
<div class="medium inline" data-type="weather" data-device="MeinWetter" data-get="fc2_condition"></div>
<div class="medium inline" data-type="label" data-device="MeinWetter" data-get="fc2_high_c"></div>
</td>
</tr>
<tr class="center"><td><div class="small" data-type="label" data-device="MeinWetter" data-get="fc2_condition"></div></td></tr>
</table>
<br class="small">
<table>
<tr class="center">
<div class="inline" data-type="label" data-device="MeinWetter" data-get="fc3_day_of_week"></div>
<div class="inline" data-type="label" data-device="MeinWetter" data-get="fc3_date"></div>
</header>
</tr>
<tr class="center">
<td>
<div class="medium inline" data-type="weather" data-device="MeinWetter" data-get="fc3_condition"></div>
<div class="medium inline" data-type="label" data-device="MeinWetter" data-get="fc3_high_c"></div>
</td>
</tr>
<tr class="center"><td><div class="small" data-type="label" data-device="MeinWetter" data-get="fc3_condition"></div></td></tr>
</table>
<br class="small">
<table>
<tr class="center">
<div class="inline" data-type="label" data-device="MeinWetter" data-get="fc4_day_of_week"></div>
<div class="inline" data-type="label" data-device="MeinWetter" data-get="fc4_date"></div>
</header>
</tr>
<tr class="center">
<td>
<div class="medium inline" data-type="weather" data-device="MeinWetter" data-get="fc4_condition"></div>
<div class="medium inline" data-type="label" data-device="MeinWetter" data-get="fc4_high_c"></div>
</td>
</tr>
<tr class="center"><td><div class="small" data-type="label" data-device="MeinWetter" data-get="fc4_condition"></div></td></tr>
</table>
<br class="small">
<table>
<tr class="center">
<div class="inline" data-type="label" data-device="MeinWetter" data-get="fc5_day_of_week"></div>
<div class="inline" data-type="label" data-device="MeinWetter" data-get="fc5_date"></div>
</header>
</tr>
<tr class="center">
<td>
<div class="medium inline" data-type="weather" data-device="MeinWetter" data-get="fc5_condition"></div>
<div class="medium inline" data-type="label" data-device="MeinWetter" data-get="fc5_high_c"></div>
</td>
</tr>
<tr class="center"><td><div class="small" data-type="label" data-device="MeinWetter" data-get="fc5_condition"></div></td></tr>
</table>
<br class="small">
<table>
<tr class="center">
<div class="inline" data-type="label" data-device="MeinWetter" data-get="fc6_day_of_week"></div>
<div class="inline" data-type="label" data-device="MeinWetter" data-get="fc6_date"></div>
</header>
</tr>
<tr class="center">
<td>
<div class="medium inline" data-type="weather" data-device="MeinWetter" data-get="fc6_condition"></div>
<div class="medium inline" data-type="label" data-device="MeinWetter" data-get="fc6_high_c"></div>
</td>
</tr>
<tr class="center"><td><div class="small" data-type="label" data-device="MeinWetter" data-get="fc6_condition"></div></td></tr>
</table>
</li>
</ul>
</div>
</body>
</html>
Menü HTML:
<html>
<body>
<div style="color:#bdc3c7; margin-top: 10px;">
   <div data-type="clock" data-format="H:i" class="large"></div>
   <div data-type="clock" data-format="d.n.Y" class="small"></div>
</div>
<div style="margin-top: 15px; border-top:5px solid #000000;"></div>
    <div class="cell centered">
        <div data-type="pagetab" data-url="main.html" data-icon="fa-home" class="top-space"></div>
        <div data-type="pagetab" data-url="control.html"  data-icon="fa-sliders" class="top-space"></div>
<div data-type="pagetab" data-url="media.html" data-icon="fa-music" class="top-space"></div>
        <div data-type="pagetab" data-url="einstellungen.html" data-icon="fa-wrench" class="top-space"></div>
        <div data-type="pagetab" data-url="wetter.html" data-icon="fa-sun-o" class="top-space"></div>
    </div>
</body>
</html>
Einstellungen HZML:
<html>
<head>
</head>
<body>
<ul>
<li data-col="2" data-row="1" data-sizex="1" data-sizey="10" data-sizex="8">
        data-get="state"
data-set-on="on"
data-set-off="off"
      </div>
      </div>
        data-get="state"
data-set-on="on"
data-set-off="off"
      </div>
      </div>
        data-get="state"
data-set-on="on"
data-set-off="off"
      </div>
      </div>
        data-get="state"
data-set-on="on"
data-set-off="off"
      </div>
      </div>
   </li>
</ul>
</div>
</body>
</html>
Ich hoffe ich habe soweit alles gepostet für Euch/Dich?
Gruss
MH
funktioniert ohne diese Zeile hier überhaupt was im Tablet UI:
   <script src="js/fhem-tablet-ui.js" defer></script>
Das würde mich wundern, aber ich bin die letzten Upgrades auch nicht mitgegangen.
   Thorsten
FUIP
