vcc unknow einträge in log umd device
Begonnen von newan, 16 Februar 2017, 20:27:25
newan
ich hatte mehrere Cul Meldungen im log von "help me" und im wiki gelesen das dort eine vccu helfen soll.
Habe daher alles neu mit der vcc gepaired. Läuft auch soweit außer ein Thermostat. Dieses geht von zeit von Zeit immer voll auf und im Display steht "Ins". Nach klick auf den Button wird eine "Adap" fahrt gemacht und es geht wieder.
Zudem habe ich immer noch diverse Unknow Meldungen:
   CUL0_MSGCNT 34
   CUL0_RAWMSG A0E4FB01128B53B4477AA0202000000::-101:CUL0
   CUL0_RSSI  -101
   CUL0_TIME  2017-02-16 20:26:31
   DEF        C03377
   IODev      CUL0
   LASTInputDev CUL0
   MSGCNT     34
   NAME       VCCU
   NOTIFYDEV  global
   NR         160
   NTFY_ORDER 50-VCCU
   STATE      CUL0:ok,
   TYPE       CUL_HM
   assignedIOs CUL0
   channel_01 VCCU_Btn1
   channel_02 VCCU_Btn2
   Readings:
     2017-02-16 20:17:34   state           CUL0:ok,
     2017-02-11 00:58:12   unknown_1712F4  received
     2017-02-16 20:26:31   unknown_28B53B  received
     2017-02-06 13:10:51   unknown_2CCD26  received
     2017-02-01 19:50:22   unknown_2E2EE0  received
     2017-02-01 19:50:23   unknown_2E2F59  received
     2017-02-16 06:23:43   unknown_2E6E90  received
     2017-02-10 02:05:56   unknown_2E9CE4  received
     2017-02-16 20:24:37   unknown_2F2038  received
     2017-02-16 20:25:10   unknown_2F265D  received
     2017-02-16 20:20:28   unknown_2F2689  received
     2017-02-09 06:25:48   unknown_305F29  received
     2017-02-12 18:20:08   unknown_305F2B  received
     2017-02-01 19:35:07   unknown_32005F  received
     2017-02-10 05:21:29   unknown_3D20A0  received
     2017-02-16 18:59:36   unknown_3D2378  received
     2017-02-16 19:12:16   unknown_3FF71F  received
     2017-02-16 14:37:51   unknown_417A03  received
     2017-02-01 21:59:23   unknown_4449FF  received
     2017-02-04 10:54:42   unknown_44CFFB  received
     2017-02-10 00:54:00   unknown_4751CC  received
     2017-02-10 07:53:20   unknown_4E442F  received
     2017-02-16 20:18:24   unknown_B70B03  received
   Helper:
     HM_CMDNR   44
     mId        FFF0
     rxType     1
     Expert:
       def        1
       det        0
       raw        0
       tpl        0
     Io:
       prefIO
       vccu
       ioList:
         CUL0
     Mrssi:
       mNo
     Prt:
       bErr       0
       sProc      0
     Q:
       qReqConf
       qReqStat
     Role:
       dev        1
       vrt        1
     Tmpl:
   IODev      CUL0
   IOList     CUL0
   model      CCU-FHEM
   room       CUL_HM
   subType    virtual
   webCmd     virtual:update
Wenn noch Infos fehlen bitte einfach melden. Bin für jede Hilfe dankbar.
Vielen dank
marvin78
Warum hast du neu gepairt und wo bitte steht, dass das notwendig ist? Das habe ich nun schon öfter gelesen.
Bitte einmal darüber informieren, was pairen überhaupt bedeutet.
Unknown ist erstmal nichts falsches. Das kann z.B. heißen, dass dein Nachbar auch Homematic verwendet oder es sind deine Devices vor dem (neu) pairen. Du kannst du Readings entfernen und schauen, ob sie wieder auftauchen. Solange du keine Meldungen dazu im Log hast, ist alles gut.
newan
Naja folgendes Scenario:
1. Man hat "Help me" Meldungen im Log
2. Mann will sich informieren und landet im Wiki
3. Man findet den Eintrag: https://wiki.fhem.de/wiki/Virtueller_Controller_VCCU
4. Man liest diesen:
ZitatDurch das Pairen der Geräte mit einer virtuellen CCU ergeben sich folgende Vorteile:
Zitat"Geordnete" Termination von Nachrichten. (Da die üblichen Funkschnittstellen (wie CUL im HM-Mode oder HM-LAN-Konfigurator) relativ "dumm" sind, führen viele Zustände zu den bekannten "Help me" Einträge im Log.)
Ja und dann nimmt man an das man seine Geräte mit der VCCU pairen sollte. Dies habe ich getan.
Welche Meldungen sollen den nicht im Log sein?
ich habe dort immer wieder sowas:
2017.02.16 17:41:29 2: CUL0: unknown message A06358DF5B70B03
martinp876
Die vccu bietet dir an, die readings zu loeschen. Senden sie device weiter in deinem funkbereich sendet wird es wieder kommen.
Die vccu bietet weiter die device zu definieren und auf ignorieren zu setzen. Dann kommen diese readings nicht mehr. Sollten sich neue device melden kannst du wieder so verfahren.
marvin78
Pairen bedeutet, dass die HMID in den Devices hinterlegt wird. Da du der VCCU die gleiche HMID gibst, wie deinem vorhandenen IODEV, ist neu pairen nicht notwendig. Es steht dort auch nicht, dass du neu pairen sollst. Gepairt mit der VCCU (eigentlich mit der Zentrale) passiert über die Vergabe der HMID an die VCCU.
Zum Rest hat Martin alles gesagt.
newan
#5
Ja o.k habe in dem zuge meine hmId geändert.
Das mit dem Ignore lese ich mich dann ein Danke.
Zum Thermostat ggf noch ein Tipp wieso das auf "Ins" ab und an zurückfällt?
Edit: set VCCU defIgnUnknown ?
hschuett
Die Funktion "set VCCU defIgnUnknown" legt autom. neue FHEM-Devices für die unbekannten Geräte an- siehe unten - die zunächst im Room "Unsorted" auftauchen. Dort kann man dann das Attribut ignore 1 setzen. Wobei das bisher bei mir nicht zu einer Besserung geführt hat, das Logfile ist noch immer gut gefüllt.
### Start DEVICES unkown
define unknown_B61C9B CUL_HM B61C9B
attr unknown_B61C9B IODev CUL_0
attr unknown_B61C9B autoReadReg 4_reqStatus
attr unknown_B61C9B expert 2_raw
attr unknown_B61C9B ignore 1
define unknown_8E2541 CUL_HM 8E2541
attr unknown_8E2541 IODev CUL_0
attr unknown_8E2541 autoReadReg 4_reqStatus
attr unknown_8E2541 expert 2_raw
attr unknown_8E2541 ignore 1
newan
Ja beide Probleme bleiben. nervt
A06358DF5B70B03 steht wieder im Log und auch das Thermostat war die ganze Nacht auf "Ins". Habe ich Log gesehen das fhem heute Nacht eine getCofig gesendet hat:
2017.02.18 03:39:53 3: CUL_HM set WZ.Heizung.Links getConfig
Irgendwie ist HomeMatic und ich nicht ganz auf einer Wellenlänge.
hschuett
#8
Bei mir steht in einer der letzten Meldungen dieser Art ein RSSI Wert von -108.5 --> muss also Gerät von Nachbar sein, ich habe deutlich bessere RSSI Werte im Haus für meine Geräte (zw. -50 und -80)
Die HomeMatic ID lt. der Meldung wäre F00001 --> nicht meine ID
Die 20 Zeichen umfassende Homematic Message (ohne führendes A) wäre:
A131200832C6AD5F00001
Internal von VCCU:
CUL_0_RAWMSG
A131200832C6AD5F0000100009190B1798B002F36::-108.5:CUL_0
CUL_0_RSSI
-108.5
Ich habe jedoch den Eindruck, es ist ein Nicht-Homematic-System in der Nachbarschaft, dass mein CUL hier empfängt.
Weiterer Internal Wert der VCCU - diesmal sieht dass so gar nicht mehr nach HM-Message aus:
CUL_0_RAWMSG
A1410008EB61C9B8E25410133F4E4D4EF58F600A2B4::-102:CUL_0
CUL_0_RSSI
-102
20 Zeichen Message (ohne A), HomeMatic ID wäre 8E2541 --> 6-stellige Hexzahl wäre ja noch i.O., aber im Gegensatz zur Meldung 1 oben hat sich die HomeMatic ID verändert --> die Pair-ID ändert sich aber nicht (dauernd) --> Fazit: Nicht-Homematic System, schlechter RSSI Wert spricht auch dafür
Bei Dir könnte das so ähnlich ablaufen, prüfe mal die 20 Zeichen langen Homematic Raw-Messages und schau ob sich die "HomeMatic ID" permanent ändert und RSSI Werte extrem niedrig sind?
Grüße, Harald
newan
Kannst du mir gerade sagen wie ich an die Raw herankommen. Im Event-Monitor oder wo?
hschuett
Du rufst einfach die Geräte Übersicht Deiner VCCU oder Deines CULs auf.
In den Internals des CULs findet sich ein Internal namens RAWMSG darunter auch das Internal RSSI
Die Internals der VCCU heißen wie folgt:
CUL_0_RAWMSG und direkt darunter CUL_0_RSSI
Das diese 4 Internals immer die gleichen Werte enthalten sollten, ist es egal ob Du in der Geräteübersicht CUL Stick oder VCCU nachschaust.
newan
RAWMSG
A0C34865A32005F000000ACD5321D
RSSI
-59.5
STATE
Initialized
Das steht bei mir gerade drin
hschuett
HM Message (fett - 20 Zeichen) wäre dann:
HM ID (PairID) unterstrichen: 000000
Ändern sich die Zeichen von Pos. 16 bis Pos. 20 im String andauernd?
newan
RAWMSG
A195EA0033D2378427EFD92C1B285484F4ED13E97AC20D7C1CDC2CF
RSSI
-98.5
Wir länger und kürzer und ab und an auch mal mit der richtigen HmId
hschuett
Deine Geräte senden halt auch ab und zu auch mal was, somit ist hmid manchmal korrekt
Pos. 16 bis Pos. 20 im letzten String von Dir, sieht mir auf den ersten Blick deutlich anders aus als 000000
