(gelöst) Kein Temperaturwert vom HT
Begonnen von stgeran, 21 Februar 2017, 19:59:01
stgeran
Ohne Änderungen habe ich plötzlich nicht mehr die Möglichkeit die IST Temperatur im Plot anzuzeigen. Die Übertragung des Wertes in die Datei hört auf einmal auf.
2017-02-18_11:50:00 Hzg_Sammy mode: manual
2017-02-18_11:50:00 Hzg_Sammy battery: ok
2017-02-18_11:50:00 Hzg_Sammy desiredTemperature: 22.0
2017-02-18_11:50:00 Hzg_Sammy temperature: 23.7
2017-02-18_11:50:00 Hzg_Sammy valveposition: 14
2017-02-18_11:50:00 Hzg_Sammy 22.0 °C
2017-02-18_11:50:00 Hzg_Sammy RSSI: -59.5
2017-02-18_11:52:43 Hzg_Sammy desiredTemperature auto 22.0
2017-02-18_11:52:44 Hzg_Sammy mode: auto
2017-02-18_11:52:44 Hzg_Sammy battery: ok
2017-02-18_11:52:44 Hzg_Sammy desiredTemperature: 22.0
2017-02-18_11:52:44 Hzg_Sammy valveposition: 14
2017-02-18_11:52:44 Hzg_Sammy 22.0 °C
2017-02-18_11:52:44 Hzg_Sammy RSSI: -59.5
2017-02-18_11:54:20 Hzg_Sammy mode: auto
2017-02-18_11:54:20 Hzg_Sammy battery: ok
2017-02-18_11:54:20 Hzg_Sammy desiredTemperature: 22.0
2017-02-18_11:54:20 Hzg_Sammy temperature: 23.7
2017-02-18_11:54:20 Hzg_Sammy valveposition: 14
2017-02-18_11:54:20 Hzg_Sammy 22.0 °C
2017-02-18_11:54:20 Hzg_Sammy RSSI: -58.5
AB HIER
2017-02-18_12:03:03 Hzg_Sammy desiredTemperature 22.0
2017-02-18_12:03:04 Hzg_Sammy mode: manual
2017-02-18_12:03:04 Hzg_Sammy battery: ok
2017-02-18_12:03:04 Hzg_Sammy desiredTemperature: 22.0
2017-02-18_12:03:04 Hzg_Sammy valveposition: 14
2017-02-18_12:03:04 Hzg_Sammy 22.0 °C
2017-02-18_12:03:04 Hzg_Sammy RSSI: -61
2017-02-18_12:07:03 Hzg_Sammy desiredTemperature auto 22.0
2017-02-18_12:07:04 Hzg_Sammy mode: auto
2017-02-18_12:07:04 Hzg_Sammy battery: ok
2017-02-18_12:07:04 Hzg_Sammy desiredTemperature: 22.0
2017-02-18_12:07:04 Hzg_Sammy valveposition: 14
2017-02-18_12:07:04 Hzg_Sammy 22.0 °C
2017-02-18_12:07:04 Hzg_Sammy RSSI: -60
2017-02-18_12:18:03 Hzg_Sammy desiredTemperature 22.0
2017-02-18_12:18:04 Hzg_Sammy mode: manual
2017-02-18_12:18:04 Hzg_Sammy battery: ok
2017-02-18_12:18:04 Hzg_Sammy desiredTemperature: 22.0
2017-02-18_12:18:04 Hzg_Sammy valveposition: 14
2017-02-18_12:18:04 Hzg_Sammy 22.0 °C
2017-02-18_12:18:04 Hzg_Sammy RSSI: -61
2017-02-18_12:21:26 Hzg_Sammy desiredTemperature auto 22.0
2017-02-18_12:21:27 Hzg_Sammy mode: auto
2017-02-18_12:21:27 Hzg_Sammy battery: ok
2017-02-18_12:21:27 Hzg_Sammy desiredTemperature: 22.0
2017-02-18_12:21:27 Hzg_Sammy valveposition: 14
2017-02-18_12:21:27 Hzg_Sammy 22.0 °C
2017-02-18_12:21:27 Hzg_Sammy RSSI: -60.5
Soll ich den HT nochmal neu anlegen?
FHEM auf Raspberry
CSM 866MHz für EM1010 mit Strom und Gaszähler
CUL 866MHz für MAX! Radiator Thermostat
CUL 433MHz für Innen und Aussen Temp
HMLAN für HM-LC-Sw1-PI-2
bartman121
Hallo stgeran,
die Thermostate senden ihre IST-Werte fast nie, steht auch im WIKI:
https://wiki.fhem.de/wiki/MAX#IST-Temperaturwerte
Das kannst du nur mittels Temperatur-Scanner erschlagen, inwiefern das gewünscht ist musst du selbst wissen. Mal davon abgesehen ist die Messung der Temperatur direkt am Thermostat eh sinnlos, da die Werte eher selten der tatsächlichen Raumtemperatur entsprechend werden.
stgeran
Ich habe deswegen bei diesem HT den Scanner mit laufen. Es hat ja auch eine ganze Zeit funktioniert. Der Scanner sagt "processing"
FHEM auf Raspberry
stgeran
HT stand im Cal Modus, daher keine Werte. Batteriewechsel hat geholfen. Trotz "Batterie OK" Spannung war 1,1 V pro Batterie.
FHEM auf Raspberry
