FHEM 5.2 released
Begonnen von rudolfkoenig, 31 Dezember 2011, 15:59:51
Mein letzter Tat fuer fhem in diesem Jahr: Ich hab das aktuelle fhem
aus dem SVN zusammengepackt, als 5.2 in SVN getagged, und auf fhem.de
hochgeladen. Auszug aus der CHANGED Datei:
- bugfix:  applying smallscreen attributes to firefox/opera
- feature: CUL_TX added (thanks to Peterp)
- feature: TCM120/TCM310 + EnOcean parser added
- feature: eventMap enhanced
- bugfix:  enabled logging for 59_Weather.pm (Boris)
- feature: language selection for 59_Weather.pm (Erwin)
- feature: .gplot files renamed from type to content
- bugfix:  FS20 on-for-timer error reporting only in the logfile
- bugfix:  FHEM2FHEM should work with CUL again, after syntax change
- feature: CUL directio mode (No Device::SerialPort needed)
- feature: FritzBox 7270 ZIP file
- bugfix:  prevent fhem from stalling if telnet times out in
66_ECMD.pm
- feature: added postproc ability to classdef in 66_ECMD.pm (Boris,
Heinz)
- feature: FHEMWEB longpoll mode, small fixes, tuned smallscreen mode
- feature: average module added
- change:  moved the berliOS CVS repository to a sourceforge SVN
repository
- feature: all FHEM modules have now a subversion id.
- bugfix:  new perl compiled for the FritzBox 7270
- feature: regexp1WontReactivate Attribute added
- bugfix:  XmlList special handling
- bugfix:  CUL_WS rain sensor corr1 fix
- feature: FHEMWEB stylesheet attribute repaced with stylesheetPrefix
- feature: notify attribute forwardReturnValue
- change:  move JsonList from contrib to main-modules
- change:  JsonList output optimized and more structured
- feature: FHEMWEB save button, smallscreen first screen fix
- feature: FHEMWEB encoding is now UTF-8, alias attribute is respected
- change:  HTTPS certs directory moved from cwd into modpath
- feature: shutdown parameter restart added
- feature: usb scan/create command added (part of autocreate).
- feature: SaveAs added to FHEMWEB Edit-Files
- feature: EnOcean ElTako dimmer by Marc.
Viel Spass damit und Gruss,
  Rudi
borsti67
Tolle Sache Rudi, vielen Dank für Deine unermüdliche Arbeit!
Dann komm' gut rein ins Neue Jahr...
Gruss
Torsten
cu/2
Borsti
FHEM 5.8 auf Synology DS211j (bis 11/17) | FHEM 6.0 auf Raspi Zero W (bis 11/20) | FHEM 6.2 als VM in Synology DS1815+ (ab 11/20)
Guest
Hallo Rudolf,
bekomme folgende Fehlermeldung:
AutoLoader.pm did not return a true value at /var/media/ftp/uStor01/
fhem/perl/lib/perl/arch/POSIX.pm line 9.
BEGIN failed--compilation aborted at /var/media/ftp/uStor01/fhem/perl/
Compilation failed in require at fhem.pl line 258.
BEGIN failed--compilation aborted at fhem.pl line 258.
Environment:
FB 7170 mit Freetz
FHEM 5.2 mit Perl für 7270
Vielen Dank für Deine Arbeit und einen guten Rutsch ins neue Jahr
Jörg
> 66_ECMD.pm
> Heinz)
> repository
>   Rudi
Guest
ich bekomme ein "File size for dim06%.png does not correspond to
filetimes.txt entry" wenn ich updatefhem ausführe. Habe ich trotzdem
anschließend die neue Version?
Matthias
On 31 Dez. 2011, 18:08, JoWiemann wrote:
> Hallo Rudolf,
> Environment:
> FB 7170 mit Freetz
> Jörg
> > 66_ECMD.pm
> > Heinz)
> > repository
> >   Rudi
> FB 7170 mit Freetz
Sorry, diese Kombination habe ich nicht getestet. Auf einem "normalen" FB7270
habe ich gerade das neue Paket geprueft: es funktioniert. Und ich habe auch
keine Aenderungen in 5.2, was Deine Probleme verursachen sollten.
Kannst Du bitte im telnet auf dem FB alle Befehle aus startfhem einzeln
ausfuehren, und pruefen ob irgendwas nicht klappt?
Vllt. vor "perl fhem.pl fhem.cfg" noch was einfaches wie
  ./perl -e 'print sin(1)'
ausfuehren.
Guest
nach  "updatefhem" habe ich im Log folgenden Eintrag  :
*Use of uninitialized value $commandchain[0] in uc at ./FHEM/99_updatefhem.pm line 45.*
und folgende Fehlermeldung auf dem Browser "Schirm"
 File size for commandref.html does not correspond to filetimes.txt entry
und von mir auch vielen Dank für Deine Arbeit und einen gutes und
erfolgreiches neues Jahr.
:-) Thoralf
(FHEM auf der FB 7390)
Guest
Am 31.12.2011 15:59, schrieb Rudolf Koenig:
FTR, muß ja nix heißen, aber nach der Installation des .deb war der erste
Eintrag in /var/log/fhem/fhem-2012-01.log dieser:
2012.01.01 02:29:38 1: reload: Error:Modul 99_SUNRISE_EL deactivated: Illegal division by zero at /usr/share/fhem/FHEM/99_SUNRISE_EL.pm line 28, <$fh> line 5.
Das kam gestern zumindest dann auch bei jedem "restart fhem".
MfG,
-kai
Ich sehe zwar kein Problem da, aber dieser Code ist von Ruebe.  Vllt. hilft als
erstes ein "update 99_updatefhem.pm" gefolgt von "update" (ohne "")
Bei mir klappt es. Erneut versuchen?
> 5.
Zeile 28:
  my $RADEG  = ( 180 / 3.1415926 );
Ich glaube nicht, dass dieses Modul ohne Fliesskomma jemals funktioniert hat.
salvadore
Nach einem Update startet fhem dauernd neu. Im Log erscheint dann der
Eintrag:
2012.01.02 11:35:19 2: Telnet port 7072 opened
2012.01.02 11:35:19 3: Opening CUN01 device 192.168.178.15:2323
2012.01.02 11:35:19 3: CUN01 device opened
2012.01.02 11:35:20 2: FHEMWEB port 8083 opened
2012.01.02 11:35:20 3: Connecting to database mysql:database=fhem;host=localhost;port=3306 with user xxxx
2012.01.02 11:35:20 3: Connection to db mysql:database=fhem;host=localhost;port=3306 established
2012.01.02 11:35:21 0: Server started (version =VERS= from =DATE= ($Id: fhem.pl 1159 2011-12-31 13:31:58Z rudolfkoenig $), pid 5605)
der Eintrag wiederholt sich dann um 11:40, 11:45 .......
FHEM 5.6, APU-Board, CUNO 1.x, RFXtrx433, 8 FHT80B, diverse FS20 Aktoren, Rasperry, div. DS18x-Sensoren, KD101, AB400R, HE877, ESA2000, Beaglebone Black Rev.C, Jeelink, PCA 301, PT8005,
> Eintrag:
Ich hoffe dass Du es einsiehst, dass das zum Feststellen Deines Problemes nicht
ausreicht.
Guest
>> 5.
> Zeile 28:
Errm ... Das war eine FHEM-Erstinstallation auf meinem designierten neuen FHEM-
Entwicklungsrechner. Falls obiges heißen soll, daß Fließkommakrams fehlt, so
fehlen dem .deb Dependencies darauf.
-kai
> Falls obiges heißen soll, daß Fließkommakrams fehlt, so fehlen dem .deb
In welchem .deb sind die Fliesskommazahlen eingepackt? Ich fuege es gerne
hinzu.
salvadore
ok,
also
- keine Änderungen vorgenommen, weder Hardware noch Einstellungen
- update fhem durchgeführt
- "restart fhem"
- ab dann erscheinen die Einträge
- notify's werden nicht mehr ausgeführt
- verbose auf 5  gesetzt um mehr sehen zu können
- festgestellt, das der Neustart im Abstand von 5 Minuten erfolgt
- mich daran erinnert, vor einigen Wochen einen cron-Auftrag erstellt zu
haben, um die plots für FHEMWeb-Grundriss zu aktualisieren
- cron-Auftrag deaktiviert
- Neustart kommt bis jetzt nicht mehr
Jetzt den Cron-Auftrag prüfen und gegebenfalls üerarbeiten
Vorerst vielen Dank
Gruss
HGO
Guest
Hallo Rudolf,
auf der telnet-Konsole erhalte ich beim Aufruf der Befehle aus
startfem mit dem Befehl der dann FHEM startet die selbe Fehlermeldung.
Bin jetzt erst einmal zur "alten" Perl-Version zurück. Was kann ich
noch testen?
  ./perl -e 'print sin(1)'  wird auch korrekt abgearbeitet.
Herzliche Grüße
Jörg
On 1 Jan., 17:30, Rudolf Koenig wrote:
> > FB 7170 mit Freetz
> > FHEM 5.2 mit Perl f r 7270
> ausfuehren.
