fhem 5.2-7390 server outage while learning switches
Begonnen von Guest, 05 Januar 2012, 16:14:11
Guest
I have installed fhem 5.2-7390 server from scratch. Everything works
nicely, except, when learning two switches (e-Q3 4 channel HomeMatic)
the server quits and has to be restarted via telnet.
In a Fritz!Box telnet session running in parallel some messages showed
up:
Use of uninitialized value in concatenation (.) or string at ./FHEM/
10_CUL_HM. pm line 1147.
10_CUL_HM.pm  line 1147.
Use of uninitialized value $a[3] in string eq at ./FHEM/00_CUL.pm line
958.
00_CUL.pm line 975.
Argument "" isn't numeric in numeric ge (>=) at ./FHEM/00_CUL.pm line
264.
Not sure what to make of it.
After restarting following each learning session, the switches are
created and work as expected.
Guest
After another clean install & updatefhem I get another dropout of fhem
& log filled with:
# Use of uninitialized value in hash element at fhem.pl line 1059.
Use of uninitialized value in hash element at fhem.pl line 1523.
Use of uninitialized value $t in string eq at ./FHEM/01_FHEMWEB.pm
line 672.
line 680.
Use of uninitialized value $t in concatenation (.) or string at ./FHEM/
01_FHEMWE
B.pm line 683.
line 574.
Use of uninitialized value $t in hash element at ./FHEM/01_FHEMWEB.pm
line 575.
line 574.
line 575.
line 574.
line 575.
line 574.
line 575.
line 574.
line 575.
line 574.
line 575.
line 574.
line 575.
line 574.
line 575.
line 574.
line 575.
line 574.
line 575.
line 574.
line 575.
line 574.
line 575.
Use of uninitialized value in numeric comparison (<=>) at fhem.pl line
1004.
1004.
1004.
1004.
Use of uninitialized value in concatenation (.) or string at fhem.pl
line 1014.
line 574.
line 575.
line 574.
line 575.
line 574.
line 575.
line 574.
line 575.
1240.
1240.
1240.
1240.
1240.
1240.
1240.
1240.
1240.
1240.
1240.
1240.
1240.
1240.
1004.
1004.
1004.
1004.
1004.
line 1014.
1240.
1240.
1240.
1240.
1240.
1240.
1240.
1004.
1004.
1004.
1004.
1004.
line 1014.
1240.
1240.
1240.
1240.
1240.
1240.
1240.
1004.
1004.
1004.
1004.
1004.
line 1014.
1004.
1004.
1004.
1004.
1004.
line 1014.
Can't use an undefined value as an ARRAY reference at ./FHEM/
91_notify.pm line 5
7.
# ps | grep perl
15118 root      1416 S    grep perl
> up:
> 958.
> 00_CUL.pm line 975.
> 264.
Guest
And just
# Can't use an undefined value as an ARRAY reference at ./FHEM/91_notify.pm
line
 57.
Followed by fhem halting on learning the second switch.
After restarting all switches are configured and working as expected.
ignisquivir
-----Ursprüngliche Nachricht-----
Von: fhem-users@googlegroups.com [mailto:fhem-users@googlegroups.com (fhem-users@googlegroups.com)] Im
Auftrag von ignisquivir
Gesendet: Freitag, 6. Januar 2012 12:51
An: FHEM users
Betreff: [FHEM] Re: fhem 5.2-7390 server outage while learning switches
After another clean install & updatefhem I get another dropout of fhem & log
filled with:
Use of uninitialized value $t in string eq at ./FHEM/01_FHEMWEB.pm line 672.
Use of uninitialized value $t in string eq at ./FHEM/01_FHEMWEB.pm line 680.
01_FHEMWE B.pm line 683.
Use of uninitialized value $t in string eq at ./FHEM/01_FHEMWEB.pm line 574.
Use of uninitialized value $t in hash element at ./FHEM/01_FHEMWEB.pm line
575.
575.
575.
575.
575.
575.
575.
575.
575.
575.
575.
575.
Use of uninitialized value in numeric comparison (<=>) at fhem.pl line 1004.
Use of uninitialized value in concatenation (.) or string at fhem.pl line
1014.
575.
575.
575.
575.
Use of uninitialized value in numeric comparison (<=>) at fhem.pl line 1240.
1014.
1014.
1014.
1014.
Can't use an undefined value as an ARRAY reference at ./FHEM/ 91_notify.pm
line 5 7.
# ps | grep perl
> up:
> 958.
> 00_CUL.pm line 975.
> 264.
> & log filled with:
You've managed to create a device without a TYPE. Please tell me how.
Guest
> > & log filled with:
Install fhem 5.2-7390
fhem autocreates CUL_0
manually set CUL_0 attribute HomeMatic
Initiate learning on the switch and let fhem autocreate it.
btw, the fhem log contains:
2012.01.06 12:41:31 3: CUL_HM Unknown device CUL_HM_switch_147645,
please define it
2012.01.06 12:41:31 2: autocreate: define CUL_HM_switch_147645 CUL_HM
147645 A1A0A84001476450000001900034845513033363538353210040100
2012.01.06 12:41:31 2: CUL_HM pair: CUL_HM_switch_147645 is a switch,
model HM-LC-SW4-SM serialNr HEQ0365852
2012.01.06 12:41:31 2: autocreate: define CUL_HM_switch_147645_CHN_2
CUL_HM 14764502
FileLog_CUL_HM_switch_147645_CHN_2 FileLog ./log/
CUL_HM_switch_147645_CHN_2-%Y.log CUL_HM_switch_147645_CHN_2
2012.01.06 12:41:31 2: autocreate: define CUL_HM_switch_147645_CHN_3
CUL_HM 14764503
FileLog_CUL_HM_switch_147645_CHN_3 FileLog ./log/
CUL_HM_switch_147645_CHN_3-%Y.log CUL_HM_switch_147645_CHN_3
2012.01.06 12:41:31 2: autocreate: define CUL_HM_switch_147645_CHN_4
CUL_HM 14764504
2012.01.06 12:41:32 2: autocreate: define
FileLog_CUL_HM_switch_147645_CHN_4 FileLog ./log/
CUL_HM_switch_147645_CHN_4-%Y.log CUL_HM_switch_147645_CHN_4
2012.01.06 12:41:32 2: CUL_0 pairing (hmPairForSec) not enabled
2012.01.06 12:41:32 2: autocreate: define FileLog_CUL_HM_switch_147645
FileLog ./log/CUL_HM_switch_147645-%Y.log CUL_HM_switch_147645
for switch 1
and
2012.01.06 13:01:27 3: CUL_HM Unknown device CUL_HM_switch_147606,
please define it
2012.01.06 13:01:27 2: autocreate: define CUL_HM_switch_147606 CUL_HM
147606 A1A0B84001476060000001900034845513033363537363810040100
2012.01.06 13:01:27 2: CUL_HM pair: CUL_HM_switch_147606 is a switch,
model HM-LC-SW4-SM serialNr HEQ0365768
2012.01.06 13:01:27 2: autocreate: define CUL_HM_switch_147606_CHN_2
CUL_HM 14760602
FileLog_CUL_HM_switch_147606_CHN_2 FileLog ./log/
CUL_HM_switch_147606_CHN_2-%Y.log CUL_HM_switch_147606_CHN_2
2012.01.06 13:01:27 2: autocreate: define CUL_HM_switch_147606_CHN_3
CUL_HM 14760603
FileLog_CUL_HM_switch_147606_CHN_3 FileLog ./log/
CUL_HM_switch_147606_CHN_3-%Y.log CUL_HM_switch_147606_CHN_3
2012.01.06 13:01:27 2: autocreate: define CUL_HM_switch_147606_CHN_4
CUL_HM 14760604
FileLog_CUL_HM_switch_147606_CHN_4 FileLog ./log/
CUL_HM_switch_147606_CHN_4-%Y.log CUL_HM_switch_147606_CHN_4
2012.01.06 13:01:27 2: CUL_0 pairing (hmPairForSec) not enabled
2012.01.06 13:01:27 2: autocreate: define FileLog_CUL_HM_switch_147606
FileLog ./log/CUL_HM_switch_147606-%Y.log CUL_HM_switch_147606
for switch 2
Guest
Another detail happens when deleting the attribute HomeMatic from
CUL_0
958.
00_CUL.pm li
ne 975.
Setting the attribute causes no error message.
> > > & log filled with:
> please define it
> CUL_HM 14764502
> CUL_HM 14764503
> CUL_HM 14764504
> for switch 1
> and
> please define it
> CUL_HM 14760602
> CUL_HM 14760603
> CUL_HM 14760604
> for switch 2
> CUL_0
Thanks for the report, fixed this one.
I'm sorry, I do not have a HM-LC-SW4-SM to test it.  After trying to inject
your code with:
  { Dispatch($defs{CUL}, "A1A0A84001476450000001900034845513033363538353210040100", undef) }
I've also got a single error message (fixed it now), but I think this is not
what you get. For the repeated messages: all of them are pointing to an
improperly created device ($defs is lacking necessary attributes like NR), but
I have no idea where the error is.
Btw.: it would be nice if you could send the error messages through uniq,
mentioning it once is enough for me.
Guest
What do you mean by "... send the error messages through uniq..." ?
If there is anything I can try out here, just let me know.
Btw the switches are configured properly ( TYPE  CUL_HM ) after restart and
work as expected.
ignisquivir
Auftrag von Rudolf Koenig
Gesendet: Freitag, 6. Januar 2012 19:12
An: fhem-users@googlegroups.com
your code with:
but I have no idea where the error is.
I do not want to read the same line over and over again, making the posting
huge. The unix tool uniq will throw away duplicate lines.
Repeat the whole procedure with the current SVN version, by starting fhem from
the command line with "attr global logfile -", in order to see why it crashes.
Guest
from the command line with "attr global logfile -", in order to see why it
crashes.
1)    rm -R  /var/InternerSpeicher/fhem
2)   extract folder fhem from fhem.tar.gz ( fhem-5.2-7390.image) to
/var/InternerSpeicher/fhem (is configured as external drive un my Linux VM
thus saving me to reboot the Fritz!Box)
3)   updatefhem  (causes: "use of uninitialized value $commandchain[0] in
uc at .FHEM/99_updatefhem.pm line 44" in Telnetsession)
4)    modify fhem.cfg attr global logfile to "-"
5)   start fhem via telnet
6)     define CUL
7)   flash CUL (same error as before)
9)   remove and reattach CUL (CUL is detected properly)
10)   set CUL to HomeMatic
11)   Initiate learning mode on switch 1
12)    crash
Hope that helps :-)
ignisquivir
> Hope that helps :-)
Not really, I need hints (== fhem/perl/os error messages) to get an idea what
the problem is. I cannot repeat your setup, as I don't have the HM device.
Guest
what the problem is. I cannot repeat your setup, as I don't have the HM
device.
Did you notice the attachment to my previous message ?
ignisquivir
Nope. Sorry for that. I changed a line in 91_notify.pm, so this error should
not hapen any more. I hope that there are no further bugs hidden by this one.
