Wärmebedarfsrelais FHT 8W
Begonnen von Guest, 09 Januar 2012, 13:09:08
Guest
Hello everybody,
Does anyone know if it is possible to communicatie from fhem with the
FHT 8W? I don't see any reference in the devices section and neither
anything yet in this group.
I would like to monitor when the boiler is heating up and if possible
also read/write the settings of this device.
Alternatively I can problably create a script that analyzes all the
valve openings every few minutes but it would be nicer if there was a
module for it.
Thanks for any advice.
Alex
Guest
Hi
> FHT 8W?
It's possible so read the on/off status if the FS20 RF send module is
installed that would normally trigger a remote FS20 actor.
But I have not spend the money and read the gas meter instead :-)
It is not possible to read/write the settings or status of monitored
channels. The latter is not sensible anyway as you would then rather
monitor the status of the FHT actuator settings.
> module for it.
notify on FHT's actuators is your friend I guess...
Best
Zrrronggg!
> > module for it.
That has been done by others, check this group for "FHT8w" nd you'll
find some threads about that.
AFAIK there is even a module doing that, its in  99_PRIV.pm
Copy 99_PRIV.pm into FHEM's dir and use as:
define at_1 at +*00:05 { fhem "set heater " .
(sumactuator()?"on":"off") };
(copied from on of the threads here, don't know more about it.)
