problem with curl http://192.168.0.4:8083/fhem?cmd.PorteSms=attr%20PorteSms%20di
Begonnen von bend94, 28 März 2017, 20:59:18
bend94
Hi
I was using this command through curl to enable or disable attribute
enable:
curl "http://192.168.0.4:8083/fhem?cmd.PorteSms=attr%20PorteSms%20disable%200"
disable:
curl "http://192.168.0.4:8083/fhem?cmd.PorteSms=attr%20PorteSms%20disable%201"
I did an upgrade of fhem and reboot
now it doesn't work anymore
Please advise
regards
MadMax-FHEM
Now fhem uses a random token csrfToken in order to be safe against cross side resource forgery:
https://forum.fhem.de/index.php/topic,67419.0.html
sorry is in german but here is a short description in the commandref:
https://fhem.de/commandref.html#FHEMWEB
Regards, Joachim
FHEM PI3 Buster (Test)
roedert
MadMax-FHEM
Zitat von: roedert am 28 März 2017, 22:48:05
attr <FHEMWEB-device> csrfToken none
That was NOT the intention of "inventing" that token!
Doing so is UNSAFE!!
Everyone is responsible for his own installation...
...and so can do whatever he wants...
...I just wanted to mention that!
Regards, Joachim
Zitatnow it doesn't work anymore
Please advise
If you take a look into your FHEM Log, you'll see a message like
FHEMWEB WEB CSRF error:  ne csrf_500476365397455. For detals see the csrfToken FHEMWEB attribute
If you follow the instruction, and check https://fhem.de/commandref.html#csrfToken, you get a short explanation:
ZitatIf set, FHEMWEB requires the value of this attribute as fwcsrf Parameter for each command. It is used as countermeasure for Cross Site Resource Forgery attacks. If the value is random, then a random number will be generated on each FHEMWEB start. If it is set to the literal string none, no token is expected. Default is random for featurelevel 5.8 and greater, and none for featurelevel below 5.8
