Crash FHEM nach Anlernen eines HM-LC-SW2-FM
Begonnen von Hausautomat, 28 Januar 2012, 23:21:19
Hausautomat
Moinsen.
FHEM ist mir vorhin abgeranzt, als ich einen 2fach-Homematic UP-Schalter.
FHEM meldete
fhem main process (20157) terminated with status 25
Im Log stand folgendes:
2012.01.28 22:38:16 4: HTTP FHEMWEB:192.168.178.27:36459 GET /fhem?detail=Cuno&detail=Cuno&dev.setCuno=Cuno&cmd.setCuno=set&arg.s
etCuno=hmPairForSec&val.setCuno=600
2012.01.28 22:38:16 4: /fhem?detail=Cuno&detail=Cuno&dev.setCuno=Cuno&cmd.setCuno=set&arg.setCuno=hmPairForSec&val.setCuno=600 /
RL: 1666 / text/html; charset=UTF-8 / Content-Encoding: gzip
2012.01.28 22:38:25 4: RCV L:0D N:0F CMD:A010 SRC:180D9C DST:000000 06010000 (INFO_ACTUATOR_STATUS CHANNEL:01 STATUS:00 UNKNOWN:0
0)
2012.01.28 22:38:31 4: RCV L:0D N:11 CMD:A010 SRC:180D9C DST:000000 0601C800 (INFO_ACTUATOR_STATUS CHANNEL:01 STATUS:C8 UNKNOWN:0
0)
2012.01.28 22:39:03 4: RCV L:1A N:12 CMD:8000 SRC:180D9C DST:000000 1900094945513033343134383210020100 (DEVICE_INFO FIRMWARE:19 TYPE:0009 SERIALNO:IEQ0341482 CLASS:10 PEER_CHANNEL_A:02 PEER_CHANNEL_B:01 UNKNOWN:00)
2012.01.28 22:39:03 3: CUL_HM Unknown device CUL_HM_switch_180D9C, please define it
2012.01.28 22:39:03 2: autocreate: define CUL_HM_switch_180D9C CUL_HM 180D9C A1A128400180D9C0000001900094945513033343134383210020100
2012.01.28 22:39:03 2: CUL_HM pair: CUL_HM_switch_180D9C is a switch, model HM-LC-SW2-FM serialNr IEQ0341482
2012.01.28 22:39:03 2: autocreate: define CUL_HM_switch_180D9C_CHN_2 CUL_HM 180D9C02
2012.01.28 22:39:03 2: autocreate: define FileLog_CUL_HM_switch_180D9C_CHN_2 FileLog /var/log/fhem/CUL_HM_switch_180D9C_CHN_2-%Y.log CUL_HM_switch_180D9C_CHN_2
2012.01.28 22:39:04 2: Cuno pairing (hmPairForSec) not enabled
2012.01.28 22:39:04 2: autocreate: define FileLog_CUL_HM_switch_180D9C FileLog /var/log/fhem/CUL_HM_switch_180D9C-%Y.log CUL_HM_switch_180D9C
2012.01.28 22:39:09 2: Telnet port 7072 opened
Als der telnetport geöffnet wurde, hat FHEM neu gestartet. Interessanterweise hatte ich in der Tat hmpairforsec einige sekunden vorher eingegeben - trotzdem meckert er. Autocreate lief aber trotzdem durch.
Weiter Details nötig?
Ich habe die Schalter dann nochmal angelernt, ging einwandfrei.
