CUL unknown code P12#....
Begonnen von Shadow3561, 05 Mai 2017, 12:18:05
Shadow3561
Hallo allerseits,
ich habe seit gestern folgende Meldungen im Log.
2017.05.05 11:50:09.771 3: Cul_Slow_Rf_433: Unknown code P12#751346B5BF1B07B6, help me!
2017.05.05 11:55:10.613 3: Cul_Slow_Rf_433: Unknown code P12#751346358240A2165B, help me!
2017.05.05 11:56:36.582 3: Cul_Slow_Rf_433: Unknown code P12#7513463582F01DB6, help me!
2017.05.05 11:57:19.458 3: Cul_Slow_Rf_433: Unknown code P12#751346358240A2165B, help me!
2017.05.05 11:57:19.687 3: Cul_Slow_Rf_433: Unknown code P12#751346B58240226EBB, help me!
2017.05.05 11:58:45.652 3: Cul_Slow_Rf_433: Unknown code P12#7513910D201028055B, help me!
2017.05.05 11:58:45.899 3: Cul_Slow_Rf_433: Unknown code P12#751346D5FF1337B6, help me!
2017.05.05 12:00:11.621 3: Cul_Slow_Rf_433: Unknown code P12#75134635FAFF07B6, help me!
2017.05.05 12:03:03.549 3: Cul_Slow_Rf_433: Unknown code P12#75134635C2FF0E6D, help me!
2017.05.05 12:03:03.799 3: Cul_Slow_Rf_433: Unknown code P12#755B9A514A2BB6, help me!
2017.05.05 12:04:29.518 3: Cul_Slow_Rf_433: Unknown code P12#75DFFE41A216EC01, help me!
2017.05.05 12:04:29.764 3: Cul_Slow_Rf_433: Unknown code P12#751346B58240226E3B, help me!
2017.05.05 12:05:12.637 3: Cul_Slow_Rf_433: Unknown code P12#751346358240A2165B, help me!
2017.05.05 12:05:55.481 3: Cul_Slow_Rf_433: Unknown code P12#751346358240A216DB, help me!
2017.05.05 12:06:38.753 3: Cul_Slow_Rf_433: Unknown code P12#751346358240A2163B, help me!
2017.05.05 12:06:38.837 3: Cul_Slow_Rf_433: Unknown code P12#751346B58240A2085B, help me!
2017.05.05 12:09:30.524 3: Cul_Slow_Rf_433: Unknown code P12#75278C6A0480442CDB, help me!
2017.05.05 12:10:13.627 3: Cul_Slow_Rf_433: Unknown code P12#751346358240A216DB, help me!
2017.05.05 12:10:56.488 3: Cul_Slow_Rf_433: Unknown code P12#751346358240A216DB, help me!
2017.05.05 12:11:39.593 3: Cul_Slow_Rf_433: Unknown code P12#751346358240A2165B, help me!
Ich habe bereits im Forum gesucht und herausgefunden, dass es sich um das Hideki Protokoll handeln müsste.
Jedoch wird das Signal wohl nicht verarbeitet.
Gibt es eine Möglichkeit die ständigen Log-Einträge zu unterbinden?
FHEM ist up to date.
MfG
Thorsten Pferdekaemper
womöglich mit dem Attribut verbose im entsprechenden Device.
   Thorsten
FUIP
Ralf9
Die Meldungen kommen von einem Temperatursensor der von dem bei Dir verwendeten Hideki-Modul noch nicht unterstützt wird.
Mit dem aktuellen Hideki-Modul passt es.
2017.05.05 18:20:55.139 4: sduinoD/msg get dispatch: P12#751346358240A2165B
2017.05.05 18:20:55.155 4: Hideki_Parse sduinoD incomming P12#751346358240A2165B
2017.05.05 18:20:55.155 4: Hideki_Parse SensorTyp = 31 decodedString = 7535ca5f86c0e63aed
2017.05.05 18:20:55.155 4: sduinoD decoded Hideki protocol model=Hideki_31, sensor id=35, channel=1, bat=ok, temp=8.6
2017.05.05 18:20:55.155 1: sduinoD Hideki: UNDEFINED sensor 31 detected, code Hideki_31_1
2017.05.05 18:22:01.161 4: sduinoD/msg get dispatch: P12#751346358240A2165B
2017.05.05 18:22:01.161 4: Hideki_Parse sduinoD incomming P12#751346358240A2165B
2017.05.05 18:22:01.162 4: Hideki_Parse SensorTyp = 31 decodedString = 7535ca5f86c0e63aed
2017.05.05 18:22:01.162 4: sduinoD decoded Hideki protocol model=Hideki_31, sensor id=35, channel=1, bat=ok, temp=8.6
2017.05.05 18:22:01.162 1: sduinoD Hideki: UNDEFINED sensor 31 detected, code Hideki_31_1
2017.05.05 18:22:01.165 2: autocreate: define Hideki_31_1 Hideki Hideki_31_1
Du kannst entweder das aktuelle Hideki-Modul ins FHEM Verzeichnis kopieren:
https://raw.githubusercontent.com/RFD-FHEM/RFFHEM/dev-r33/FHEM/14_Hideki.pm
oder ein update durchführen:
update add https://raw.githubusercontent.com/RFD-FHEM/RFFHEM/dev-r33/controls_signalduino.txt
Gruß Ralf
Shadow3561
Danke erstmal bis hierhin.
Komisch ist nur, dass ich den Sensor nur empfange wenn es regnet.
Jetzt, wo es nicht mehr regnet, kommen auch keine Log-Einträge mehr.
Dieses Verhalten konnte ich seit gestern beobachten.
Habe jetzt das Hideki Modul auf den neuesten Stand gebracht und warte auf den nächsten Regen.
PS: Die dekodieren Temperaturen passen allerdings zu meinem Aussensensor.
MfG
Shadow3561
Heute war es wieder so weit,
der Log-Eintrag mit dem Sensor ist wieder da.
Das Hideki-Modul ist auf dem neuesten Stand.
Kann evtl. der CUL nichts mot dem Hideki-Modul anfangen?
CUL ist mit der aculfw geflasht. V 1.21.00 Build:70
MfG
KernSani
@Shadow3561 Könntest du den Beitrag ins "Sonstige Systeme" Forum verschieben (Button ganz links unten), wo das Hideki-Modul laut maintainer.txt supported wird? Da lesen vielleicht auch mehr kundige User mit...
Shadow3561
KölnSolar
ZitatKomisch ist nur, dass ich den Sensor nur empfange wenn es regnet.
Einfach ein Sender bzgl. Reichweite in der Grauzone. geht, geht nicht.
ZitatCUL ist mit der aculfw geflasht. V 1.21.00 Build:70
Flash mal die aktuellste Version der aculfw. Ist denkbar, dass die aculfw 1.21 noch nicht so weit war.
Grüße Markus
Fixel2012
ich finde bei mir auch täglich die oben genannten Log Einträge.
2017.06.05 18:48:52 3: CUL1: Unknown code P12#75EC7A143A9F41B6, help me!
2017.06.05 18:51:01 3: CUL1: Unknown code P12#75ECCAE835EE04B6, help me!
2017.06.05 18:53:10 3: CUL1: Unknown code P12#75ECBACAEDBE2652EA, help me!
2017.06.05 18:54:36 3: CUL1: Unknown code P12#75ECBACA12BED3BFBB, help me!
2017.06.05 19:02:29 3: CUL1: Unknown code P12#75ECBACA13BE260757, help me!
2017.06.05 19:03:55 3: CUL1: Unknown code P12#75ECBA8A13BE92233B, help me!
Mein Fhem ist Software technisch auf dem aktuellen Stand.
Mein Cul ist auf folgendem Stand:
CUL1 version => V 1.23.02 a-culfw Build: private build (unknown) nanoCUL433 (F-Band: 433MHz
Weiß jemand zufällig ob hier auch eine neuere Version der a-culfw helfen würde?
Habe noch keine Erfahrung mit dem flashen des Culs gemacht.
Danke und Gruß,
Fixel
Fhem 5.8 auf Raspi 3, HMLAN und 868MHz CUL mit einigen Komponenten, Z-Wave Rollladenaktoren, Tablet UI, 433 MHz CUL mit Baumarktsteckdosen und Temp Sensoren, Amazon Echo, Echo Dot, 2x SONOS  play1, 1x SONOS Connect AMP,  presence, HUE, Lightify
