Dashboard as default page
Begonnen von Mario, 16 Mai 2017, 20:39:14
Mario
Hello,
I have problem can't set dashbord as defaultroom, I'm defined dashboard named Tablica
below displays almost empty "room" Tablica which only contains link to real Tablica
define Tablica dashboard
attr   Tablica room Tablica
attr    WEB defaultRoom Tablica
and below display blank page
attr   Tablica room ro_Tablica
attr    WEB defaultRoom ro_Tablica
is it possbile to set start/default page to dashboard page ?
FHEM since 2013, mixed FS20, HmIP, HM,
own modules for heater, garden & wheater station,
sun intensity, rain ratio & soil humidity sensors for inteligent watering.
moskito
the main problem is: Dashboard is not a room, and the attribute "defaultroom" won´t work.
Call the Dashboard/Tablica with your browser and if you see what you would like to see, bookmark the URL, and recall this one next time.
so  long
Danny
FHEM auf Intel NUC/Proxmox & Debian 12 + HM-CFG-USB + zigbee2mqtt + Zwave + Enocean
Mario
#2
thanks for answer => so it is imposible to set dashboard as starting/default page
yes, entering detailed url to dashboard or creating bookmark will of course workaround this but this is not real solution..
Wuppi68
just a thought ...
you can include a stylesheet with on load trigger an reload the dashboard
btw. never did it before :-)
FHEM unter Proxmox als VM
Mario
I'm not css coder so this is innovative idea for me :) but thanks maybe in future will css use this for something
BTW is there way/example/modification fhem default web page to to achieve functionality:
left web page panel (column with Rooms names, etc.), to be hidden by default after load.
Then would be expandable on user swipe "it" to left
(I like my current layout only left panel doesn't looks good on my mobile)
isy
Hi, on my iPhone for example, I set port 8084 to darksmallscreen
define WEBphone FHEMWEB 8084 global
attr WEBphone stylesheetPrefix darksmallscreen
Menu shows at the top of the screen.
Ein Weg wird erst zu einem Weg, wenn man ihn geht
