Autor Thema: fhem logfile temp/hum highcharts  (Gelesen 1606 mal)
Offline kroonen
  • Full Member
    • http://www.kroonen.eu/mobile
« am: 15 Juni 2017, 21:48:42 »
Is there anybody who create an standalone highcharts script that reads the fhem log file and creates an highcharts graph.
the log looks like this of a temp/hum sensor
2017-06-15_21:44:35 Isakamertemp Temperature: 24.5
2017-06-15_21:44:35 Isakamertemp Humidity: 54
2017-06-15_21:44:35 Isakamertemp Hum: 54 Tem: 24.5
2017-06-15_21:45:35 Isakamertemp Humidity: 54
2017-06-15_21:45:35 Isakamertemp Temperature: 24.4
2017-06-15_21:45:35 Isakamertemp Hum: 54 Tem: 24.4
2017-06-15_21:46:35 Isakamertemp Temperature: 24.4
2017-06-15_21:46:35 Isakamertemp Humidity: 54
2017-06-15_21:46:35 Isakamertemp Hum: 54 Tem: 24.4
« Letzte Änderung: 15 Juni 2017, 22:17:10 von kroonen »
Offline fruit
  • Full Member
Antw:fhem logfile temp/hum highcharts
« Antwort #1 am: 15 Juni 2017, 22:47:31 »
I use the average module for several readings, this provides daily minimum, maximum as well as average values - hoping this is what you mean.
It is fairly easy to extract these and graph them
Feel free to follow up in German if you prefer
Offline kroonen
  • Full Member
« Antwort #2 am: 17 Juni 2017, 21:50:14 »
No that is not what I mean, I just want to graph with highcharts, with reading the logfile
Offline amenomade
« Antwort #3 am: 17 Juni 2017, 23:05:15 »
In whoch frontend do you want to graph? In TabletUI there is a widget highcharts. Otherwise there is this: https://wiki.fhem.de/wiki/Neues_Charting_Frontend
In a complete external frontend, you should be able to get the data from fhem using html requests with Get from the Logfile https://fhem.de/commandref_DE.html#FileLog
FHEM 5.8 Pi 3, EchoDot, CUL868+Selbstbau 1/2λ-Dipol-Antenne, USB Optolink / Vitotronic, und HM Komponenten, Rademacher Duofern Jalousien, Fritz!Dect Thermostaten
Offline kroonen
  • Full Member
« Antwort #4 am: 20 Juni 2017, 22:14:45 »
I want a standalone php script or whatever, that reads the fhem log en creates an highchart from it to integrate on a website
regards Richard
Offline supernova1963
  • Full Member
« Antwort #5 am: 21 Juni 2017, 04:54:31 »
Hi Richard,
if you want to use data outside from fhem, try Dblog (https://wiki.fhem.de/wiki/DbLog).
After that you can use every highchart, that support SQLlite or MySQL.
Regards,
Gernot
Fhemserver: Mac Mini - Parallels Desktop mit Ubuntu Server 18.04,
Module: Harmony, fakeRoku, FBAHA, Fritzbox, MQTT + espBridge + TASMOTA_DEVICE, HMCCU, Nmap, ...
