[gelöst] aesCommToDev fail bei sehr vielen HM-SEC-SCo bzw. Status unbekannt
Begonnen von Burny4600, 20 Juni 2017, 14:14:04
Hi Chris,
mir fallen Unterschiede zu meinem auf, Ideen dazu habe ich aber nicht so richtig:
   DEF        4C1C11
   HMLAN1_MSGCNT 583
   HMLAN1_RAWMSG E4C1C11,0000,16C066A7,FF,FFD6,FEA6104C1C11200DB806010000
   HMLAN1_RSSI -42
   HMLAN1_TIME 2017-10-03 15:38:26
   HMUART1_MSGCNT 583
   HMUART1_RAWMSG 0501002CFEA6104C1C11200DB806010000
   HMUART1_RSSI -44
   HMUART1_TIME 2017-10-03 15:38:26
   IODev      HMUART1
   LASTInputDev HMLAN1
   MSGCNT     1166
   NAME       FensterAZL
   NOTIFYDEV  global
   NR         484
   STATE      closed
   TYPE       CUL_HM
   lastMsg    No:FE - t:10 s:4C1C11 d:200DB8 06010000
   protLastRcv 2017-10-03 15:38:26
   protSnd    583 last_at:2017-10-03 15:38:26
   protState  CMDs_done
   rssi_at_HMLAN1 avg:-42.69 cnt:583 lst:-42 min:-49 max:-40
   rssi_at_HMUART1 lst:-44 cnt:583 max:-39 min:-58 avg:-46.83
     2017-09-11 10:38:50   Activity        alive
     2016-11-06 16:52:53   CommandAccepted yes
     2016-11-06 17:09:31   D-firmware      1.0
     2016-11-06 17:09:31   D-serialNr      NEQ0630364
     2016-11-06 17:09:33   PairedTo        0x200DB8
     2016-11-06 17:09:33   R-cyclicInfoMsg on
     2016-11-06 17:09:33   R-eventDlyTime  0 s
     2016-11-06 17:09:33   R-pairCentral   0x200DB8
     2016-11-06 17:09:33   R-sabotageMsg   on
     2016-11-06 17:09:33   R-sign          on
     2016-11-06 17:09:33   RegL_00.        02:01 09:01 0A:20 0B:0D 0C:B8 10:01 14:06 00:00
     2016-11-06 17:09:33   RegL_01.        08:01 20:9C 21:00 30:06 00:00
     2016-11-06 16:52:53   aesCommToDev    ok
     2016-11-06 16:52:53   aesKeyNbr       00
     2017-10-03 15:38:26   alive           yes
     2017-10-03 15:38:26   battery         ok
     2017-10-03 15:38:26   contact         closed (to VCCU)
     2016-11-06 17:09:12   powerOn         2016-11-06 17:09:12
     2017-10-03 15:38:26   recentStateType info
     2017-10-03 15:38:26   sabotageError   off
     2017-10-03 15:38:26   state           closed
     2016-11-06 16:52:29   trigDst_broadcast noConfig
     2017-08-05 09:26:00   trigger_cnt     82
   helper:
     HM_CMDNR   254
     mId        00C7
     rxType     28
     supp_Pair_Rep 0
     ack:
     expert:
       def        1
       det        0
       raw        1
       tpl        0
     io:
       newChn     +4C1C11,00,00,00
       nextSend   1507037906.61213
       rxt        2
       vccu       VCCU
       p:
         4C1C11
         00
         00
         00
     mRssi:
       mNo        FE
       io:
         HMLAN1     -42
         HMUART1    -42
     prt:
       bErr       0
       sProc      0
       sleeping   0
       rspWait:
     q:
       qReqConf
       qReqStat
     role:
       chn        1
       dev        1
     rpt:
       IO         HMUART1
       flg        A
       ts         1507037906.51747
       ack:
         HASH(0x3669618)
         FE8002200DB84C1C1100
     rssi:
       at_HMLAN1:
         avg        -42.6946826758148
         cnt        583
         lst        -42
         max        -40
         min        -49
       at_HMUART1:
         avg        -46.8353344768439
         cnt        583
         lst        -44
         max        -39
         min        -58
     tmpl:
   IODev      HMUART1
   IOgrp      VCCU
   actCycle   002:50
   actStatus  alive
   autoReadReg 4_reqStatus
   expert     2_raw
   firmware   1.0
   model      HM-SEC-SCo
   peerIDs    00000000,
   room       Arbeitszimmer,CUL_HM
   serialNr   NEQ0630364
   subType    threeStateSensor
Bei Dir fehlen ein paar Readings, sowas habe ich bei mir nicht
Zitat2017-10-03 16:03:55   trig_aes_VCCU   fail:5
dies habe ich nicht gesetzt
ZitataesCommReq 1
Was sagt hmInfo? Kannst Du bittte ein getConfig absetzen und den configknopf drücken OHNE den Sensor auszulösen!?
Burny4600
#16
getConfig und kurzes betätigen des Tasters am Sensor hatte kein ersichtliche Änderung gebracht.
   CFGFN      /media/hdd/fhem/mycfg/ueberwachung/sensoren_rasp01.cfg
   DEF        4C1E60
   HmUART_AB_MSGCNT 194
   HmUART_AB_RAWMSG 05000146CE84004C1E600000001000C74E45513036323635343280810101
   HmUART_AB_RSSI -70
   HmUART_AB_TIME 2017-10-03 17:16:58
   HmUART_EG_MSGCNT 190
   HmUART_EG_RAWMSG 05000155CE84004C1E600000001000C74E45513036323635343280810101
   HmUART_EG_RSSI -85
   HmUART_EG_TIME 2017-10-03 17:16:58
   HmUART_OG1_MSGCNT 354
   HmUART_OG1_RAWMSG 0500013DCE84004C1E600000001000C74E45513036323635343280810101
   HmUART_OG1_RSSI -61
   HmUART_OG1_TIME 2017-10-03 17:16:58
   HmUART_OG2_MSGCNT 194
   HmUART_OG2_RAWMSG 05000129CE84004C1E600000001000C74E45513036323635343280810101
   HmUART_OG2_RSSI -41
   HmUART_OG2_TIME 2017-10-03 17:16:58
   IODev      HmUART_OG1
   LASTInputDev HmUART_OG1
   MSGCNT     932
   NAME       UEST1_OG1_KUE
   NOTIFYDEV  global
   NR         2552
   NTFY_ORDER 50-UEST1_OG1_KUE
   STATE      ZU
   TYPE       CUL_HM
   lastMsg    No:CE - t:00 s:4C1E60 d:000000 1000C74E45513036323635343280810101
   protCmdPend 9 CMDs_pending
   protEvt_AESCom-ok 6 last_at:2017-10-03 16:02:55
   protLastRcv 2017-10-03 17:16:58
   protResnd  1 last_at:2017-10-03 16:00:25
   protSnd    19 last_at:2017-10-03 16:03:07
   protState  CMDs_pending
   rssi_at_HmUART_OG1 max:-57 lst:-61 cnt:19 avg:-59.68 min:-64
     2017-10-03 16:03:17   Activity        alive
     2017-10-03 16:02:55   CommandAccepted yes
     2017-10-03 16:03:17   D-firmware      1.0
     2017-10-03 16:03:17   D-serialNr      Nxxxxxxxxx
     2017-10-03 16:03:06   PairedTo        0xFxxxxx
     2017-10-03 16:00:41   R-cyclicInfoMsg on
     2017-10-03 16:00:41   R-eventDlyTime  0 s
     2017-10-03 16:03:06   R-pairCentral   0xFxxxxx
     2017-10-03 16:00:41   R-sabotageMsg   on
     2017-10-03 16:00:41   R-sign          on
     2017-10-03 16:50:05   aesCommToDev    fail
     2017-10-03 16:02:55   aesKeyNbr       00
     2017-10-03 17:16:58   rssi_at_HmUART_OG1 -61
   cmdStack:
     ++A001Fxxxxx4C1E6000040000000000
     ++A001Fxxxxx4C1E6001040000000001
     ++A001Fxxxxx4C1E600103
   helper:
     HM_CMDNR   206
     PONtest    0
     cSnd       01Fxxxxx4C1E6001040000000001,01Fxxxxx4C1E600103
     getCfgList all
     getCfgListNo ,4
     mId        00C7
     peerIDsRaw ,00000000
     rxType     28
     supp_Pair_Rep 0
     expert:
       def        1
       det        0
       raw        1
       tpl        0
     io:
       newChn     +4C1E60,03,01,02
       nextSend   1507043818.85282
       rxt        2
       vccu       VCCU
       p:
         4C1E60
         01
         01
         02
       prefIO:
         HmUART_OG1
     mRssi:
       mNo        CE
       io:
         HmUART_OG1 -59
     prt:
       bErr       0
       sProc      2
       try        1
       rspWait:
     q:
       qReqConf
       qReqStat
     role:
       chn        1
       dev        1
     rssi:
       at_HmUART_OG1:
         avg        -59.6842105263158
         cnt        19
         lst        -61
         max        -57
         min        -64
     shadowReg:
     tmpl:
   role:
   IODev      HmUART_OG1
   IOgrp      VCCU:HmUART_OG1
   actCycle   002:50
   actStatus  alive
   aesCommReq 1
   alias      OG1 Küche - Balkontüre - Öffnungssensor
   devStateIcon ZU:fts_door OFFEN:fts_door_open@red
   event-on-change-reading alive,battery,contact,sabotageError
   eventMap   closed:ZU open:OFFEN
   expert     2_defReg+raw
   firmware   1.0
   group      Sensoren
   icon       fts_door
   model      HM-SEC-SCo
   peerIDs    00000000,
   room       OG1,OG1-Balkon,OG1-Kueche,Rolllaeden,_HM,_Kontaktsensoren
   rssiLog    1
   serialNr   NEQ0626542
   userReadings rssi_dB:CUL_Master_RSSI.* {(ReadingsVal("$name","CUL_Master_RSSI",0))}
hmInfo gibt folgendes aus:
configCheck done:
missing register list
    AB_FR_AAM: RegL_00.
    AB_GAO_FS1_SSPPWT: RegL_00.,RegL_01.
    AB_SG_BW: RegL_00.
    AB_SG_BW_Sw_01: RegL_01.
    AB_SG_BW_Sw_02: RegL_01.
    AB_SG_BW_Sw_03: RegL_01.
    AB_SG_BW_Sw_04: RegL_01.
    OG2_BU1_HZG_RT: RegL_00.
    OG2_BU1_HZG_RT_ClimaTeam: RegL_01.
    OG2_BU1_HZG_RT_Climate: RegL_01.
    OG2_BU1_HZG_RT_Weather: RegL_01.
    OG2_BU1_HZG_RT_WindowRec: RegL_01.
    OG2_BU1_HZG_RT_remote: RegL_01.
    UESF1_EG_KUE: RegL_00.,RegL_01.
    UESF1_EG_WI: RegL_00.,RegL_01.
    UESF1_OG1_KUE: RegL_00.,RegL_01.
    UESF1_OG1_SL: RegL_00.,RegL_01.
    UESF1_OG2_BUE1_N: RegL_00.,RegL_01.
    UESF1_OG2_BUE2_W: RegL_00.,RegL_01.
    UESF1_OG2_DB: RegL_00.,RegL_01.
    UESF1_OG2_DBN: RegL_00.,RegL_01.
    UESF2_EG_WZ: RegL_00.,RegL_01.
    UESF2_OG2_BUE2_N: RegL_00.,RegL_01.
    UESF2_OG2_BUE2_W: RegL_00.,RegL_01.
    UESF2_OG2_DBN: RegL_00.,RegL_01.
    UESF3_OG2_BUE1_N: RegL_00.,RegL_01.
    UESF3_OG2_BUE2_W: RegL_00.,RegL_01.
    UESF3_OG2_DBN: RegL_00.,RegL_01.
    UEST1_AB_SA: RegL_00.,RegL_01.
    UEST1_OG1_KUE: RegL_00.,RegL_01.
    UES_EG_STH_T1FB: RegL_00.
    UES_EG_STH_T1FB_light: RegL_01.
    UES_EG_STH_T1FB_lock: RegL_01.
    UES_EG_STH_T1FB_open: RegL_01.
    UES_EG_STH_T1FB_unlock: RegL_01.
peer list incomplete. Use getConfig to read it.
    incomplete: OG1_KI_HZG_RT_Clima:
    incomplete: OG2_BU2_HZG_RT1_Clima:
    incomplete: OG2_BU2_HZG_RT1_WindowRec:
PairedTo missing/unknown
    AB_GAO_FS1_SSPPWT
    UESF1_EG_WI
    UESF1_OG1_SL
    UESF1_OG2_BUE1_N
    UESF1_OG2_BUE2_W
    UESF1_OG2_DB
    UESF1_OG2_DBN
    UESF2_OG2_BUE2_N
    UESF2_OG2_BUE2_W
    UESF2_OG2_DBN
    UESF3_OG2_BUE1_N
    UESF3_OG2_BUE2_W
    UESF3_OG2_DBN
    UEST1_AB_SA
    UES_EG_STH_T1FB
aesCommReq set, IO not compatibel
    UESF1_EG_BA
    UESF1_EG_KUE
    UESF1_EG_SL
    UESF1_EG_STH
    UESF1_EG_WC
    UESF1_EG_WI
    UESF1_EG_WZ
    UESF1_OG1_KI
    UESF1_OG1_KUE
    UESF1_OG1_SL
    UESF1_OG1_WC
    UESF1_OG2_BUE1_N
    UESF1_OG2_BUE2_W
    UESF1_OG2_DB
    UESF1_OG2_DBN
    UESF2_EG_SL
    UESF2_EG_STH
    UESF2_EG_WZ
    UESF2_OG2_BUE2_N
    UESF2_OG2_BUE2_W
    UESF2_OG2_DBN
    UESF3_OG2_BUE1_N
    UESF3_OG2_BUE2_W
    UESF3_OG2_DBN
    UEST1VG_EG_STH
    UEST1_AB_FR
    UEST1_AB_SA
    UEST1_EG_KUE
    UEST1_EG_STH
    UEST1_OG1_KUE
    UEST1_OG2_EDV
    UES_EG_STH_T1FB
    VCCU
templist mismatch
    OG2_BU2_HZG_RT1_Clima: failed Entries:
     OG2_BU2_HZG_RT1_Clima :R_0_tempListSat mismatch 09:00 17.0 21:30 21.0 24:00 17.0 ne 06:00 17.0 22:00 21.0 24:00 17.0 ##
     OG2_BU2_HZG_RT1_Clima :R_1_tempListSun mismatch 09:00 17.0 21:30 21.0 24:00 17.0 ne 06:00 17.0 22:00 21.0 24:00 17.0 ##
     OG2_BU2_HZG_RT1_Clima :R_2_tempListMon mismatch 08:00 17.0 21:30 21.0 24:00 17.0 ne 06:00 17.0 09:00 21.0 17:00 17.0 22:00 21.0 24:00 17.0 ##
     OG2_BU2_HZG_RT1_Clima :R_3_tempListTue mismatch 08:00 17.0 21:30 21.0 24:00 17.0 ne 06:00 17.0 09:00 21.0 17:00 17.0 22:00 21.0 24:00 17.0 ##
     OG2_BU2_HZG_RT1_Clima :R_4_tempListWed mismatch 08:00 17.0 21:30 21.0 24:00 17.0 ne 06:00 17.0 09:00 21.0 17:00 17.0 22:00 21.0 24:00 17.0 ##
     OG2_BU2_HZG_RT1_Clima :R_5_tempListThu mismatch 08:00 17.0 21:30 21.0 24:00 17.0 ne 06:00 17.0 09:00 21.0 17:00 17.0 22:00 21.0 24:00 17.0 ##
     OG2_BU2_HZG_RT1_Clima :R_6_tempListFri mismatch 08:00 17.0 21:30 21.0 24:00 17.0 ne 06:00 17.0 09:00 21.0 17:00 17.0 22:00 21.0 24:00 17.0 ##
Vielleicht passt irgend etwas beider Konfiguration schon bei der VCCU und den UART Modulen nicht.
   CFGFN      /media/hdd/fhem/mycfg/HM/hm_rasp01.cfg
   DEF        Fxxxxx
   HmUART_AB_MSGCNT 1674
   HmUART_AB_RAWMSG 050001473FA001Fxxxxx568B7A0008A920AA45AB20AC45AD20AE45AF20
   HmUART_AB_RSSI -71
   HmUART_AB_TIME 2017-10-03 17:24:11
   HmUART_EG_MSGCNT 2110
   HmUART_EG_RAWMSG 050001323FA001Fxxxxx568B7A0008A920AA45AB20AC45AD20AE45AF20
   HmUART_EG_RSSI -50
   HmUART_EG_TIME 2017-10-03 17:24:11
   HmUART_OG1_MSGCNT 1437
   HmUART_OG1_RAWMSG 0500013F2DA001Fxxxxx568BBB000816551702184519201A451B201C45
   HmUART_OG1_RSSI -63
   HmUART_OG1_TIME 2017-10-03 17:23:08
   HmUART_OG2_MSGCNT 1488
   HmUART_OG2_RAWMSG 0500013E3FA001Fxxxxx568B7A0008A920AA45AB20AC45AD20AE45AF20
   HmUART_OG2_RSSI -62
   HmUART_OG2_TIME 2017-10-03 17:24:11
   IODev      HmUART_OG1
   LASTInputDev HmUART_EG
   MSGCNT     6709
   NAME       VCCU
   NOTIFYDEV  global
   NR         1181
   NTFY_ORDER 50-VCCU
   STATE      HmUART_AB:ok,HmUART_EG:ok,HmUART_OG1:ok,HmUART_OG2:ok,
   TYPE       CUL_HM
   assignedIOs HmUART_AB,HmUART_EG,HmUART_OG1,HmUART_OG2
   channel_01 VCCU_Btn1
   channel_02 VCCU_Btn2
   channel_03 VCCU_Btn3
   channel_04 VCCU_Btn4
   channel_05 VCCU_Btn5
   channel_06 VCCU_Btn6
   channel_07 VCCU_Btn7
   channel_08 VCCU_Btn8
   channel_09 VCCU_Btn9
   channel_0A VCCU_Btn10
   channel_0B VCCU_Btn11
   channel_0C VCCU_Btn12
   channel_0D VCCU_Btn13
   channel_0E VCCU_Btn14
   channel_0F VCCU_Btn15
   channel_10 VCCU_Btn16
   channel_11 VCCU_Btn17
   channel_12 VCCU_Btn18
   channel_13 VCCU_Btn19
   channel_14 VCCU_Btn20
   channel_15 VCCU_Btn21
   channel_16 VCCU_Btn22
   channel_17 VCCU_Btn23
   channel_18 VCCU_Btn24
   channel_19 VCCU_Btn25
   channel_1A VCCU_Btn26
   channel_1B VCCU_Btn27
   channel_1C VCCU_Btn28
   channel_1D VCCU_Btn29
   channel_1E VCCU_Btn30
   channel_1F VCCU_Btn31
   channel_20 VCCU_Btn32
   channel_21 VCCU_Btn33
   channel_22 VCCU_Btn34
   channel_23 VCCU_Btn35
   channel_24 VCCU_Btn36
   channel_25 VCCU_Btn37
   channel_26 VCCU_Btn38
   channel_27 VCCU_Btn39
   channel_28 VCCU_Btn40
   channel_29 VCCU_Btn41
   channel_2A VCCU_Btn42
   channel_2B VCCU_Btn43
   channel_2C VCCU_Btn44
   channel_2D VCCU_Btn45
   channel_2E VCCU_Btn46
   channel_2F VCCU_Btn47
   channel_30 VCCU_Btn48
   channel_31 VCCU_Btn49
   channel_32 VCCU_Btn50
   lastMsg    No:2D - t:01 s:Fxxxxx d:568BBB 000816551702184519201A451B201C45
   protLastRcv 2017-10-03 17:23:08
   rssi_at_HmUART_OG1 cnt:1437 avg:-63.43 min:-71 max:-52 lst:-63
     2017-10-03 17:22:26   CommandAccepted yes
     2017-10-03 17:21:49   aesKeyNbr       02
     2017-09-28 10:29:29   aesReqTo        OG1_KU_HZG_RT
     2017-10-03 17:23:08   rssi_at_HmUART_OG1 -63
     2017-10-03 15:41:53   state           HmUART_AB:ok,HmUART_EG:ok,HmUART_OG1:ok,HmUART_OG2:ok,
   helper:
     HM_CMDNR   45
     PONtest    1
     mId        FFF0
     rxType     1
     supp_Pair_Rep 0
     ack:
     expert:
       def        1
       det        0
       raw        0
       tpl        0
     io:
       nextSend   1507044251.56101
       prefIO
       vccu
       ioList:
         HmUART_AB
         HmUART_EG
         HmUART_OG1
         HmUART_OG2
     mRssi:
       mNo        2D
       io:
         HmUART_OG1 -61
     prt:
       bErr       0
       sProc      0
       rspWait:
     q:
       qReqConf
       qReqStat
     role:
       dev        1
       vrt        1
     rssi:
       at_HmUART_OG1:
         avg        -63.4377174669451
         cnt        1437
         lst        -63
         max        -52
         min        -71
     shadowReg:
     tmpl:
   role:
   IODev      HmUART_OG1
   IOList     HmUART_AB,HmUART_EG,HmUART_OG1,HmUART_OG2
   aesCommReq 1
   alias      HomeMatic Virtuelle CCU
   group      HomeMatic VCCU
   hmKey      01:e........................................................
   icon       hm_ccu
   model      CCU-FHEM
   room       AB-Fitnessraum,EG-Bad,EG-Kueche,EG-Schlafzimmer,EG-Stiegenhaus,EG-WC,EG-Wirtschaftsraum,EG-Wohnzimmer,OG1-Balkon,OG1-Kinderzimmer,OG1-Kueche,OG1-Schlafzimmer,OG1-WC,OG1-Wohnzimmer,OG2-Buero1,OG2-Buero2,OG2-Dachboden,OG2-EDV-Raum,_HM,_Kontaktsensoren,_RxTx
   rssiLog    1
   subType    virtual
   verbose    0
   webCmd     virtual:update
   AssignedPeerCnt 17
   CFGFN      /media/hdd/fhem/mycfg/schnittstellen_rasp01.cfg
   CNT        191
   DEF        /dev/ttyAMA0
   DEVCNT     191
   DevState   99
   DevType    UART
   DeviceName /dev/ttyAMA0@115200
   FD         16
   LastOpen   1507034417.84569
   NAME       HmUART_OG2
   NR         369
   PARTIAL
   RAWMSG     0404
   RSSI       -53
   STATE      opened
   TYPE       HMUARTLGW
   XmitOpen   1
   model      HM-MOD-UART
   msgLoadCurrent 31
   msgLoadHistory 1/4/-5/1/1/0/0/8/-6/-1/2/1
   msgLoadHistoryAbs 31/30/26/31/30/29/29/29/21/27/28/26/25
   owner      Fxxxxx
   owner_CCU  VCCU
   Helper:
     CreditTimer 626
     FW         66561
     Initialized 1
     SendCnt    313
     AckPending:
     LastSendLen:
       15
       31
     Log:
       IDs:
         sys
         all
     PeerQueue:
     PendingCMD:
     RoundTrip:
       Delay      0.0099492073059082
     loadLvl:
       lastHistory 1507044133.67685
   Peers:
     4B52E7     +4B52E7,00,01,00
     4C1DAB     +4C1DAB,01,01,02
     4C21C5     +4C21C5,01,01,02
     4C23A3     +4C23A3,01,01,02
     4C23BC     +4C23BC,01,01,02
     4C2428     +4C2428,01,01,02
     4C242E     +4C242E,01,01,02
     4C2433     +4C2433,00,01,00
     4C2435     +4C2435,01,01,02
     4C2440     +4C2440,01,01,02
     4C2456     +4C2456,01,01,02
     4DEBC0     +4DEBC0,01,01,02
     4EA895     +4EA895,01,01,02
     545002     +545002,00,01,00
     568BB9     +568BB9,00,01,00
     568BBB     +568BBB,02,01,00
     577508     +577508,03,01,02
     2017-10-03 14:42:05   D-HMIdAssigned  Fxxxxx
     2017-10-03 14:42:06   D-HMIdOriginal  584868
     2017-10-03 14:42:06   D-firmware      1.4.1
     2017-10-03 14:42:12   D-serialNr      Oxxxxxxxx
     2017-10-03 14:40:17   D-type          HM-MOD-UART
     2017-10-03 14:42:13   cond            ok
     2017-10-03 17:25:55   load            31
     2017-10-03 14:42:13   loadLvl         low
     2017-10-03 14:40:17   state           opened
   helper:
   alias      HomeMatic Gateway - OG2 EDV Raum
   devStateIcon init:hm_lan@orange opened:hm_lan@lightgreen
   dutyCycle  1
   group      Schnittstellen HomeMatic
   hmId       Fxxxxx
   icon       hm_lan
   logIDs     sys,all
   qLen       60
   room       _HM,_RxTx
   verbose    0
LG Chris
Devices: APC, Eastron, FS20, IT, Homematic, MQTT, PV-(DEYE, EPEVER, FRONIUS), Resol-VBUS, S.USV, TEK603, WMR200, YouLess
Was mir auf die Schnelle bei der VCCU auffällt ->   hmKey      01:e1....
Aber Deine Sensoren wissen davon nix -<      2017-10-03 16:02:55   aesKeyNbr       00
Das gefällt mir nicht -> aesCommReq set, IO not compatibel
Macht das attr aesCommReq wirklich Sinn bei der VCCU oder deinen HMUARTs? ->
ZitataesCommReq wenn gesetzt wird HMLAN/USB AES signature anfordern bevor ACK zum Device gesendet wird.
Die Funktion abeitet aktuell nur mit HMLAN/USB.
Ich denke irgendwas ist mit Deiner AES Landschaft durcheinander. Ich habe mein AES noch auf Standard, ich kann Dir da nicht direkt weiterhelfen.
Burny4600
#18
Ich bin mir da nicht wirklich sicher was ich laut Letztstand hierfür wirklich für das AES wirklich benötige.
AES ist jedenfalls nötig um externe Manipulationen zu verhindern was zumindest den Zutritt betrifft.
Das aesKeyNbr sollte von der VCCU beim Pairing gespeißt werden. Manuell gibt es wahrscheinlich keine Möglichkeit.
ZitatMacht das attr aesCommReq wirklich Sinn bei der VCCU oder deinen HMUARTs? ->
Das ist schon mal etwas. Wenn ich das richtig verstehe können die HMUARTs damit nichts verarbeiten.
Dann kann ich mir diesen Parameter jedenfalls sparen.
Ich habe jetzt das attr aesCommReq 0 definiert.
LG Chris
pc1246
Moin
Kurz mal meinen Senf auch noch dazu. Ich habe zwar auch kein AES aktiviert, genau aus diesem Grund, aber wenn ich mir das so ansehe, dann meine ich, dass es Key01 gibt. (Ich hoffe der ist gekuerzt!?)
   hmKey      01:e1fa95c5613ea3c257a6862a2fdc6bf9
Es taucht auch Key02 auf
Und die Geraete kennen wohl nur den Key00.
Aber das musst Du am Besten wissen, was Du da mal gemacht hattest! Ansonsten weiss Martin eventuell noch etwas schlaues?
Gruss Christoph
HP T610
mgernoth
Nein, wieso sollte die VCCU das tun?
Doch, und das ist auch die einzige. Wenn Du ein Gerät resettest/unpairst wir der Schlüssel auf Standard zurückgesetzt und du musst ihn neu übertragen.
Siehe dazu den Wiki-Artikel: https://wiki.fhem.de/wiki/AES_Encryption
Und die "IO is not compatible"-Meldung bitte einfach ignorieren, dieser Test im ConfigCheck ist überholt, es gibt keine IOs mehr, die kein AES können.
  Michael
Burny4600
@pc1246
Zitat....dann meine ich, dass es Key01 gibt. (Ich hoffe der ist gekuerzt!?)
Was meinst du mit gekürzt!?
ZitatUnd die Geraete kennen wohl nur den Key00.
Wie kann ich den Geräten das beibringen das sie einen bestimmten Key verwenden müssen?
LG Chris
pc1246
#22
Hallo Chris
Mit gekuerzt meinte ich, dass du Deinen Key hier hoffentlich nicht vollstaendig postest. Anfaenglich hast du alles unkenntlich gemacht, und jetzt genau das Gegenteil.
Ich kann es Dir nicht sagen, da ich AES nicht benutze. Aber Mgernoth hat Dir denke ich den richtigen Tipp gegeben!
Gruss Christoph
HP T610
Burny4600
#24
Im Endeffekt war nur dieses Attribut aesCommReq 1 das den Fehler hervorgerufen hat den ich bei den Sensoren und der VCCU eingetragen hatte.
Mit einer VCCU und den 4 Stk. HM-MOD-UART Modulen wird dies für AES nicht benötigt?
Ist noch etwas zu berücksichtigen damit die Performance mit einer VCCU und 4 Stk. HM-MOD-UART Modulen passt?
Eines was mir noch nicht ganz klar ist ob ich alles bei der VCCU richtig definiert habe.
Dort ist ein IODev eingetragen das sich von selbst einträgt wenn nichts definiert ist, und in der IOList sind alle vier HM-MOD-UART Module eingetragen.
Unter IOgrp ist nichts definiert.
IOgrp ist nur bei den Sensoren mit VCCU definiert.
LG Chris
#25
das ist eigentlich so ok. das attr IOgrp hat bei der VCCU nix zu suchen. Bei Einsatz der VCCU  wird IODev selbst verwaltet bzw. ignoriert.
IOgrp sollte aber bei allen HM Geräten definiert sein, sonst werden sie von der VCCU nicht verwaltet.
Man muss mit der Zuordnung von mobilen Geräten etwas aufpassen.
Burny4600
Gut.
Dann passt jetzt alles soweit.
Danke für die Tipps.
LG Chris
JM2012
Hallo Burny4600,
war das setzen von Attribut "aesCommReq 0" Deine Lösung?
Ich habe genau das gleiche Problem und werde wahnsinng.
Am Anfang funktioniert immer alles und nach einer Weile verliere ich die Kommunikation mit dem Sensor. (aesCommToDev = fail)
Mit Attribut "aesCommReq 0" funktioniert es bei mir auch, nur habe ich dabei das Problem, dass nach meiner Meinung die Zentrale bei einem Trigger nicht mehr nach der Signatur beim Sensor anfragt. Mit anderenWorte, könnte mir jeder ein Signal zuschicken....grrrr
Gruss
JM2012
Fhem 5.8, last 16838
Hardware: Intel-Core-i7
OS: Docker 18.03.1 Container, debian:jessie
CUL_HM, DbLog, FBAHA, FBDECT, FileLog, HMLAN, HMUARTLGW,
Weather, SYSMON, TELNET
Hi JM2012,
beschreibe dein Problem mal näher. wann verlierst Du die Kommunikation genau?
Das setzen des attr <> aesCommReq 1  am Gerät (nur dort!) funktioniert bei mir ohne Probleme.
Zitat Wiki
ZitatDie Zentrale kann ebenfalls eine AES-Signatur von einem Gerät anfordern, so sie einen Trigger empfängt. Hierzu ist im Device (und evtl. entsprechendem Kanal) eines Geräts das Attribut aesCommReq auf 1 zu setzen. Damit die Signatur angefordert wird, muss das Attribut auf jeden Fall auch im Gerät gesetzt werden, auch wenn nur ein einzelner Kanal betroffen ist. Hiermit kann die Überprüfung für ein Gerät sehr schnell deaktiviert werden, indem nur das Geräteattribut wieder entfernt wird (z.B. nach Factory-Reset nötig, wenn das Gerät den eigenen Schlüssel noch nicht kennt). Sollte die Signaturüberprüfung fehlschlagen, verarbeitet FHEM den Befehl nicht.
attr Geraet aesCommReq 1
attr Schalter aesCommReq 1
attr Schalter_Btn_01 aesCommReq 1
JM2012
Tja, ich habe gestern den ganzen Tag gebastelt und bin zu diesem Ergebnis gekommen:
Ich habe eine VCCU mit 1 x HMLAN und 2 x  HMUARTLGW.
Ich versuche gerade einen HM-SEC-SCo in Betrieb zu nehmen, mit folgenden Settings:
   DEF        6042FB
   HMLAN_BA_MSGCNT 3
   HMLAN_BA_RAWMSG E6042FB,0000,010D09EA,FF,FFB7,BFA6416042FBAABB00011200
   HMLAN_BA_RSSI -73
   HMLAN_BA_TIME 2018-06-10 13:32:39
   HMLAN_EG_MSGCNT 6
   HMLAN_EG_RAWMSG 05020144BFA6416042FBAABB00011200
   HMLAN_EG_RSSI -68
   HMLAN_EG_TIME 2018-06-10 13:32:39
   HMLAN_OG_MSGCNT 2
   HMLAN_OG_RAWMSG 05000059BFA6036042FBAABB00C61543328CF4B4EEE182F70CFBB63FE0
   HMLAN_OG_RSSI -89
   HMLAN_OG_TIME 2018-06-10 13:32:39
   IODev      HMLAN_EG
   LASTInputDev HMLAN_OG
   MSGCNT     11
   NAME       EG_gar_tu_TuerGarten_if_is_d_hm
   NOTIFYDEV  global
   NR         1813
   NTFY_ORDER 50-EG_gar_tu_TuerGarten_if_is_d_hm
   STATE      closed
   TYPE       CUL_HM
   lastMsg    No:BF - t:41 s:6042FB d:AABB00 011200
   protEvt_AESCom-ok 2 last_at:2018-06-10 13:32:39
   protLastRcv 2018-06-10 13:32:39
   protSnd    2 last_at:2018-06-10 13:32:39
   protState  CMDs_done
   rssi_at_HMLAN_BA cnt:3 min:-73 max:-70 avg:-71 lst:-73
   rssi_at_HMLAN_EG cnt:4 min:-71 max:-68 avg:-69.5 lst:-68
   rssi_at_HMLAN_OG cnt:2 min:-89 max:-86 avg:-87.5 lst:-89
   Helper:
     DBLOG:
       battery:
         logdb:
           TIME       1528630359.98308
           VALUE      ok
       contact:
         logdb:
           VALUE      closed (to vccu)
     2018-06-10 13:32:30   Activity        alive
     2018-06-09 21:40:58   CommandAccepted yes
     2018-06-09 21:40:57   D-firmware      1.0
     2018-06-09 21:40:57   D-serialNr      OEQ1195653
     2018-06-09 21:40:35   PairedTo        0xAABB00
     2018-06-09 12:29:23   R-cyclicInfoMsg on
     2018-06-09 12:32:04   R-eventDlyTime  0 s
     2018-06-09 12:32:04   R-msgScPosA     open
     2018-06-09 12:32:04   R-msgScPosB     closed
     2018-06-09 21:40:57   R-pairCentral   set_0xAABB00
     2018-06-09 12:29:23   R-sabotageMsg   on
     2018-06-09 12:32:04   R-sign          on
     2018-06-09 12:29:23   R-transmDevTryMax 6
     2018-06-09 12:32:04   R-transmitTryMax 6
     2018-06-09 21:40:36   RegL_01.        08:01 20:9C 21:00 30:06 00:00
     2018-06-10 13:32:39   aesCommToDev    ok
     2018-06-09 21:40:58   aesKeyNbr       02
     2018-06-10 08:39:49   aesReqTo        vccu
     2018-06-10 12:44:58   alive           yes
     2018-06-10 13:32:39   battery         ok
     2018-06-10 13:32:39   contact         closed (to vccu)
     2018-06-09 16:23:46   powerOn         2018-06-09 16:23:46
     2018-06-10 12:44:58   recentStateType info
     2018-06-10 12:44:58   sabotageError   off
     2018-06-10 13:32:39   state           closed
     2018-06-10 13:32:39   trig_aes_vccu   ok:18
     2018-06-10 13:32:39   trigger_cnt     18
   helper:
     HM_CMDNR   191
     mId        00C7
     regLst     ,0,1,4p
     rxType     28
     supp_Pair_Rep 0
     ack:
     expert:
       def        1
       det        1
       raw        1
       tpl        0
     io:
       newChn     +6042FB,01,01,02
       nextSend   1528630360.1932
       rxt        2
       vccu       vccu
       p:
         6042FB
         01
         01
         02
       prefIO:
         HMLAN_EG
         none
     mRssi:
       mNo        BF
       io:
         HMLAN_BA:
           -73
           -73
         HMLAN_EG:
           -64
           -64
         HMLAN_OG:
           -89
           -89
     prt:
       bErr       0
       sProc      0
       sleeping   0
       rspWait:
     q:
       qReqConf
       qReqStat
     role:
       chn        1
       dev        1
     rpt:
       IO         HMLAN_EG
       flg        A
       ts         1528630359.97897
       ack:
         HASH(0x588af08)
         BF8002AABB006042FB0101C800
     rssi:
       at_HMLAN_BA:
         avg        -71
         cnt        3
         lst        -73
         max        -70
         min        -73
       at_HMLAN_EG:
         avg        -69.5
         cnt        4
         lst        -68
         max        -68
         min        -71
       at_HMLAN_OG:
         avg        -87.5
         cnt        2
         lst        -89
         max        -86
         min        -89
     tmpl:
   role:
   IODev      HMLAN_EG
   IOgrp      vccu:HMLAN_EG,none
   actCycle   002:50
   actStatus  alive
   aesCommReq 1
   autoReadReg 0_off
   expert     3_allReg+raw
   firmware   1.0
   model      HM-SEC-SCo
   peerIDs    00000000,
   room       HomeMatic,Garage
   serialNr   OEQ1195653
Super! Funktioniert! Auch länger. Erstmal alles in Ordnung!  :)
ABER: Ab und zu kam die Meldung "aesCommToDev fail".
Nach vielen Versuchen habe ich folgendes herausbekommen:  :'(
Das Problem habe ich "nur", wenn der HM-SEC-SCo an einem HMUARTLGW (NICHT HMLAN) per IOgrp angebunden ist und ich über das GUI die Config im Editor editiere und save "config" durchführe.
FHEM scheint dann alle Definitionen zu loeschen und neu anzulegen. Dabei geht irgendetwas schief, da ich danach auch mit mehreren Open/Closed Aktionen Folgendes sehe:
   DEF        6042FB
   HMLAN_BA_MSGCNT 13
   HMLAN_BA_RAWMSG E6042FB,0000,011216A9,FF,FFB2,CCA6416042FBAABB000115C8
   HMLAN_BA_RSSI -78
   HMLAN_BA_TIME 2018-06-10 13:38:10
   HMLAN_EG_MSGCNT 32
   HMLAN_EG_RAWMSG 0503004ACCA6416042FBAABB000115C8
   HMLAN_EG_RSSI -74
   HMLAN_EG_TIME 2018-06-10 13:38:10
   HMLAN_OG_MSGCNT 13
   HMLAN_OG_RAWMSG 05000049CCA6036042FBAABB00FEBF9F43DE65EB43BE45E2EA91670B3C
   HMLAN_OG_RSSI -73
   HMLAN_OG_TIME 2018-06-10 13:38:10
   IODev      HMLAN_EG
   MSGCNT     58
   NOTIFYDEV  global
   NR         1813
   STATE      closed
   TYPE       CUL_HM
   rssi_at_HMLAN_BA cnt:13 min:-85 max:-70 avg:-75.76 lst:-78
   rssi_at_HMLAN_EG cnt:16 min:-79 max:-73 avg:-76.25 lst:-74
   rssi_at_HMLAN_OG cnt:13 min:-87 max:-72 avg:-74.15 lst:-73
     2018-06-10 13:37:56   Activity        alive
     2018-06-10 13:38:10   [b]aesCommToDev    fail[/b]
     2018-06-10 13:38:10   [b]trig_aes_vccu   fail:21[/b]
   helper:
     HM_CMDNR   160
     mId        00C7
     regLst     ,0,1,4p
     rxType     28
     ack:
     expert:
       def        1
       det        1
       raw        1
       tpl        0
     io:
       newChn     +6042FB,01,00,02
       nextSend   1528630691.18362
       rxt        2
       vccu       vccu
       p:
         6042FB
         01
         00
         02
       prefIO:
         HMLAN_EG
         none
     mRssi:
       mNo        CC
       io:
         HMLAN_BA:
           -78
           -78
         HMLAN_EG:
           -72
           -72
         HMLAN_OG:
           -73
           -73
     prt:
       bErr       0
       sProc      0
     q:
       qReqConf
       qReqStat
     role:
       chn        1
       dev        1
     rssi:
       at_HMLAN_BA:
         avg        -75.7692307692308
         cnt        13
         lst        -78
         max        -70
         min        -85
       at_HMLAN_EG:
         avg        -76.25
         cnt        16
         lst        -74
         max        -73
         min        -79
       at_HMLAN_OG:
         avg        -74.1538461538462
         cnt        13
         lst        -73
         max        -72
         min        -87
     tmpl:
   role:
   IODev      HMLAN_EG
   actCycle   002:50
   actStatus  alive
   aesCommReq 1
   autoReadReg 0_off
   expert     3_allReg+raw
   firmware   1.0
   model      HM-SEC-SCo
   peerIDs    00000000,
   serialNr   OEQ1195653
Die VCCU zeigt dann:
   DEF        AABB00
   HMLAN_BA_MSGCNT 53
   HMLAN_BA_RAWMSG EAABB00,0000,01185AF7,FF,FFBE,8C8002AABB00338D2900
   HMLAN_BA_RSSI -66
   HMLAN_BA_TIME 2018-06-10 13:45:01
   HMLAN_EG_MSGCNT 44
   HMLAN_EG_RAWMSG 05000034B2A001AABB00339375010E
   HMLAN_EG_RSSI -52
   HMLAN_EG_TIME 2018-06-10 13:45:01
   HMLAN_OG_MSGCNT 62
   HMLAN_OG_RAWMSG 05000034D1A001AABB002E0BAB010E
   HMLAN_OG_RSSI -52
   HMLAN_OG_TIME 2018-06-10 13:45:01
   IODev      HMLAN_BA
   MSGCNT     159
   NAME       vccu
   NOTIFYDEV  global
   NR         203
   STATE      HMLAN_BA:ok,HMLAN_EG:ok,HMLAN_OG:ok,
   TYPE       CUL_HM
   assignedIOs HMLAN_BA,HMLAN_EG,HMLAN_OG
   lastMsg    No:D1 - t:01 s:AABB00 d:2E0BAB 010E
   protLastRcv 2018-06-10 13:45:01
   rssi_at_HMLAN_BA cnt:53 min:-87 max:-65 avg:-69.92 lst:-66
   rssi_at_HMLAN_EG cnt:42 min:-66 max:-51 avg:-57.88 lst:-52
   rssi_at_HMLAN_OG cnt:60 min:-87 max:-51 avg:-62.95 lst:-52
     2018-06-10 13:45:01   CommandAccepted yes
    [b] 2018-06-10 13:39:08   aesKeyNbr       00[/b]
     2018-06-09 21:40:58   aesReqTo        EG_gar_tu_TuerGarten_if_is_d_hm
     2018-06-10 13:32:40   recentStateType ack
     2018-06-10 13:37:59   state           HMLAN_BA:ok,HMLAN_EG:ok,HMLAN_OG:ok,
     2018-06-02 22:29:56   unknown_167878  received
     2018-06-07 18:45:46   unknown_1BEE74  received
     2018-04-25 20:16:03   unknown_1BF177  received
     2018-05-31 22:43:20   unknown_2A35C7  received
     2018-05-03 21:01:16   unknown_2B1CA1  received
     2018-05-18 08:51:43   unknown_2B39AC  received
     2018-06-09 13:28:17   unknown_2D4891  received
     2018-06-10 13:39:26   unknown_35C9D5  received
     2018-05-08 06:57:04   unknown_3A1722  received
     2018-06-09 09:04:35   unknown_3BA4F3  received
     2018-06-09 22:04:32   unknown_41F65E  received
     2018-06-08 15:00:00   unknown_4B0C82  received
     2018-06-08 13:54:50   unknown_604066  received
     2018-06-08 13:30:11   unknown_6042FB  received
     2018-06-10 09:00:46   unknown_F10000  received
   helper:
     HM_CMDNR   209
     PONtest    1
     mId        FFF0
     regLst     ,0
     rxType     1
     supp_Pair_Rep 0
     ack:
     expert:
       def        1
       det        0
       raw        0
       tpl        0
     io:
       nextSend   1528631101.57002
       prefIO
       vccu
       ioList:
         HMLAN_BA
         HMLAN_EG
         HMLAN_OG
     mRssi:
       mNo        D1
       io:
         HMLAN_BA:
           -62
         HMLAN_EG:
         HMLAN_OG:
           -52
           -52
     prt:
       bErr       0
       sProc      0
       rspWait:
     q:
       qReqConf
       qReqStat
     role:
       chn        1
       dev        1
       vrt        1
     rssi:
       at_HMLAN_BA:
         avg        -69.9245283018868
         cnt        53
         lst        -66
         max        -65
         min        -87
       at_HMLAN_EG:
         avg        -57.8809523809524
         cnt        42
         lst        -52
         max        -51
         min        -66
       at_HMLAN_OG:
         avg        -62.95
         cnt        60
         lst        -52
         max        -51
         min        -87
   IODev      HMLAN_BA
   IOList     HMLAN_BA,HMLAN_EG,HMLAN_OG
   hmKey      01:xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
   model      CCU-FHEM
   room       HomeMatic
   subType    virtual
   verbose    1
Hier noch HMLAN:
   AssignedPeerCnt 17
   CNT        202
   Clients    :CUL_HM:
   DEF        10.18.1.72
   DEVCNT     202
   DevState   99
   DevType    LGW
   DeviceName 10.18.1.72:2000
   FD         13
   LastOpen   1528630670.61766
   NAME       HMLAN_EG
   NR         181
   PARTIAL
   RAWMSG     040208
   RSSI       -59
   STATE      opened
   TYPE       HMUARTLGW
   XmitOpen   1
   model      eQ3-HM-LGW
   msgLoadCurrent 4
   msgLoadHistory 0/1/3/-/-/-/-/-/-/-/-/-
   msgLoadHistoryAbs 4/4/3/0/-/-/-/-/-/-/-/-/-
   owner      AABB00
   owner_CCU  vccu
   Helper:
     CreditTimer 76
     FW         66561
     Initialized 1
     SendCnt    33
     AckPending:
     LastSendLen:
       3
       3
     Log:
       IDs:
         1
     PeerQueue:
     PendingCMD:
     RoundTrip:
       Delay      0.0038909912109375
     loadLvl:
       lastHistory 1528631579.43254
   MatchList:
     1:CUL_HM   ^A......................
   Peers:
     1BE766     +1BE766,00,00,00
     1BEE5B     +1BEE5B,00,00,00
     1BEEE5     +1BEEE5,00,00,00
     1BF17C     +1BF17C,00,00,00
     1BF188     +1BF188,00,00,00
     1BF194     +1BF194,00,00,00
     2CD526     +2CD526,00,00,00
     2E0BAB     +2E0BAB,00,00,00
     338D19     +338D19,00,00,00
     338D29     +338D29,00,00,00
     338D35     +338D35,00,00,00
     338D55     +338D55,00,00,00
     339403     +339403,00,00,00
     39CCCE     +39CCCE,00,00,00
     5A0D65     +5A0D65,00,00,00
     604066     +604066,01,00,02
     6042FB     +6042FB,01,00,02
     2018-06-10 13:37:59   D-HMIdAssigned  AABB00
     2018-06-10 13:37:59   D-HMIdOriginal  FFFFFF
     2018-06-10 13:37:50   D-LANfirmware   1.1.5
     2018-06-10 13:37:59   D-firmware      1.4.1
     2018-06-10 13:37:50   D-serialNr      OEQ0795803
     2018-06-10 13:37:50   D-type          eQ3-HM-LGW
     2018-06-10 13:37:59   cond            ok
     2018-06-10 13:45:03   load            4
     2018-06-10 13:37:59   loadLvl         low
     2018-06-10 13:37:50   state           opened
   helper:
   keepAlive:
     CNT        93
     DEVCNT     92
     DevState   99
     DevType    LGW-KeepAlive
     DeviceName 10.18.1.72:2001
     FD         23
     LastOpen   1528630670.62766
     NAME       HMLAN_EG:keepAlive
     NR         1827
     PARTIAL
     STATE      opened
     TEMPORARY  1
     TYPE       HMUARTLGW
     XmitOpen   0
     Helper:
       NextKeepAlive 1528631824.02963
       Log:
         Resolve    1
         IDs:
   comment    PW=exxxxxxxx,MAC=00:1a:22:0a:7f:b4
   hmId       AABB00
   logIDs     1
   room       HomeMatic
   verbose    1
Das Problem kann ich nur lösen, wenn ich einen "shutdown restart" mache.
Ich weiß, dass das Arbeiten mit dem Editor hier im Forum gar nicht so gerne gesehen wird....Trotzdem nutze ich es ab und zu.... ;)
Mir würde ja schon reichen, wenn jemand das gleiche Problem hat, oder Interesse an einer Lösung hat. Die Logs würde ich gerne zur Verfügung stellen....Ich für meinen Teil bin im Moment verloren.... :'( :'( :'( :'(
Gruss
JM
