[gelöst] aesCommToDev fail bei sehr vielen HM-SEC-SCo bzw. Status unbekannt
Begonnen von Burny4600, 20 Juni 2017, 14:14:04
Burny4600
Seit ich den Raspberry neu aufgesetzt habe funktionieren viele Sensoren nicht mehr wie sie sollen.
Zudem ist bei den Sensoren HM-SEC-SCo der Status unbekannt bzw. dead und aesCommToDev mit fail deklariert.
configCheck
configCheck done:
missing register list
    AB_GAO_FS1_SSPPWT: RegL_00.,RegL_01.
    UESF1_EG_BA: RegL_00.,RegL_01.
    UESF1_EG_KUE: RegL_00.,RegL_01.
    UESF1_EG_STH: RegL_00.,RegL_01.
    UESF1_EG_WC: RegL_00.,RegL_01.
    UESF1_EG_WI: RegL_00.,RegL_01.
    UESF1_OG1_KI: RegL_00.,RegL_01.
    UESF1_OG1_KUE: RegL_00.,RegL_01.
    UESF1_OG1_SL: RegL_00.,RegL_01.
    UESF1_OG1_WC: RegL_00.,RegL_01.
    UESF1_OG2_BUE1_N: RegL_00.,RegL_01.
    UESF1_OG2_BUE2_W: RegL_00.,RegL_01.
    UESF1_OG2_DB: RegL_00.,RegL_01.
    UESF1_OG2_DBN: RegL_00.,RegL_01.
    UESF2_EG_SL: RegL_00.,RegL_01.
    UESF2_EG_STH: RegL_00.,RegL_01.
    UESF2_EG_WZ: RegL_00.,RegL_01.
    UESF2_OG2_BUE2_N: RegL_00.,RegL_01.
    UESF2_OG2_BUE2_W: RegL_00.,RegL_01.
    UESF2_OG2_DBN: RegL_00.,RegL_01.
    UESF3_OG2_BUE1_N: RegL_00.,RegL_01.
    UESF3_OG2_BUE2_W: RegL_00.,RegL_01.
    UESF3_OG2_DBN: RegL_00.,RegL_01.
    UEST1_AB_FR: RegL_00.,RegL_01.
    UEST1_EG_KUE: RegL_00.,RegL_01.
    UEST1_EG_STH: RegL_00.,RegL_01.
    UEST1_OG1_KUE: RegL_00.,RegL_01.
    UES_EG_STH_T1FB: RegL_00.
    UES_EG_STH_T1FB_light: RegL_01.
    UES_EG_STH_T1FB_lock: RegL_01.
    UES_EG_STH_T1FB_open: RegL_01.
    UES_EG_STH_T1FB_unlock: RegL_01.
PairedTo missing/unknown
    AB_GAO_FS1_SSPPWT
    UESF1_EG_BA
    UESF1_EG_KUE
    UESF1_EG_STH
    UESF1_EG_WC
    UESF1_EG_WI
    UESF1_OG1_KI
    UESF1_OG1_KUE
    UESF1_OG1_SL
    UESF1_OG1_WC
    UESF1_OG2_BUE1_N
    UESF1_OG2_BUE2_W
    UESF1_OG2_DB
    UESF1_OG2_DBN
    UESF2_EG_SL
    UESF2_EG_STH
    UESF2_EG_WZ
    UESF2_OG2_BUE2_N
    UESF2_OG2_BUE2_W
    UESF2_OG2_DBN
    UESF3_OG2_BUE1_N
    UESF3_OG2_BUE2_W
    UESF3_OG2_DBN
    UEST1_EG_KUE
    UEST1_EG_STH
    UEST1_OG1_KUE
    UES_EG_STH_T1FB
aesCommReq set, IO not compatibel
    UESF1_EG_BA
    UESF1_EG_KUE
    UESF1_EG_SL
    UESF1_EG_STH
    UESF1_EG_WC
    UESF1_EG_WI
    UESF1_EG_WZ
    UESF1_OG1_KI
    UESF1_OG1_KUE
    UESF1_OG1_SL
    UESF1_OG1_WC
    UESF1_OG2_BUE1_N
    UESF1_OG2_BUE2_W
    UESF1_OG2_DB
    UESF1_OG2_DBN
    UESF2_EG_SL
    UESF2_EG_STH
    UESF2_EG_WZ
    UESF2_OG2_BUE2_N
    UESF2_OG2_BUE2_W
    UESF2_OG2_DBN
    UESF3_OG2_BUE1_N
    UESF3_OG2_BUE2_W
    UESF3_OG2_DBN
    UEST1VG_EG_STH
    UEST1_AB_FR
    UEST1_EG_KUE
    UEST1_EG_STH
    UEST1_OG1_KUE
    UEST1_OG2_EDV
    UES_EG_STH_T1FB
    VCCU
Den großteil der Sensoren habe ich wieder neu angelernt. Trotzdem habe ich nach kurzer Zeit wieder das gleiche Problem. Warum geht das Paired verloren bzw. aesCommReq set, IO not compatibel.
An der Signalstärke kann es jedenfalls nicht liegen, denn über den gesamten Bereich sind vier HMUARTLGW verteilt.
list VCCU
   CFGFN      /media/hdd/fhem/mycfg/HM/hm_rasp01.cfg
   DEF        Fxxxxxxxx
   HmUART_AB_MSGCNT 640
   HmUART_AB_RAWMSG 05000142CA943FFxxxxx000000020420DBD179
   HmUART_AB_RSSI -66
   HmUART_AB_TIME 2017-06-20 14:28:42
   HmUART_EG_MSGCNT 385
   HmUART_EG_RAWMSG 0500012DCA943FFxxxxx000000020420DBD179
   HmUART_EG_RSSI -45
   HmUART_EG_TIME 2017-06-20 14:28:42
   HmUART_OG1_MSGCNT 481
   HmUART_OG1_RAWMSG 0500003CE7A004Fxxxxx4EA895747922D9CE4F51AFA61EFAF53A765EF2
   HmUART_OG1_RSSI -60
   HmUART_OG1_TIME 2017-06-20 14:25:08
   HmUART_OG2_MSGCNT 399
   HmUART_OG2_RAWMSG 0500013ECA943FFxxxxx000000020420DBD179
   HmUART_OG2_RSSI -62
   HmUART_OG2_TIME 2017-06-20 14:28:42
   IODev      HmUART_AB
   LASTInputDev HmUART_OG2
   MSGCNT     1905
   NAME       VCCU
   NOTIFYDEV  global
   NR         743
   NTFY_ORDER 50-VCCU
   STATE      HmUART_AB:ok,HmUART_EG:ok,HmUART_OG1:ok,HmUART_OG2:ok,
   TYPE       CUL_HM
   assignedIOs HmUART_AB,HmUART_EG,HmUART_OG1,HmUART_OG2
   channel_01 VCCU_Btn1
   channel_02 VCCU_Btn2
   channel_03 VCCU_Btn3
   lastMsg    No:CA - t:3F s:Fxxxxxx d:000000 020420DBD179
   protLastRcv 2017-06-20 14:28:42
   rssi_at_HmUART_AB lst:-66 max:-26 cnt:495 min:-82 avg:-55.9
   rssi_at_HmUART_OG1 min:-68 cnt:114 max:-51 avg:-55.57 lst:-59
   Readings:
     2017-06-20 14:25:02   CommandAccepted yes
     2017-06-20 14:25:01   aesKeyNbr       02
     2017-06-20 14:02:19   aesReqTo        RGB_AB_FR
     2017-06-20 14:28:42   rssi_at_HmUART_AB -66
     2017-06-15 17:45:11   rssi_at_HmUART_EG -48
     2017-06-20 11:51:37   rssi_at_HmUART_OG1 -59
     2017-06-20 14:23:43   state           HmUART_AB:ok,HmUART_EG:ok,HmUART_OG1:ok,HmUART_OG2:ok,
   Helper:
     HM_CMDNR   202
     mId        FFF0
     rxType     1
     supp_Pair_Rep 0
     Ack:
     Expert:
       def        1
       det        0
       raw        0
       tpl        0
     Io:
       nextSend   1497961722.89345
       vccu       VCCU
       ioList:
         HmUART_AB
         HmUART_EG
         HmUART_OG1
         HmUART_OG2
     Mrssi:
       mNo        CA
       Io:
         HmUART_AB  -64
     Prt:
       bErr       0
       sProc      0
       Rspwait:
     Q:
       qReqConf
       qReqStat
     Role:
       dev        1
       vrt        1
     Rssi:
       At_hmuart_ab:
         avg        -55.9070707070707
         cnt        495
         lst        -66
         max        -26
         min        -82
       At_hmuart_og1:
         avg        -55.5701754385965
         cnt        114
         lst        -59
         max        -51
         min        -68
     Shadowreg:
     Tmpl:
   Role:
   IODev      HmUART_OG1
   IOList     HmUART_AB,HmUART_EG,HmUART_OG1,HmUART_OG2
   IOgrp      VCCU
   aesCommReq 1
   alias      HomeMatic Virtuelle CCU
   group      HomeMatic VCCU
   hmKey      01:e......................................................................
   icon       hm_ccu
   model      CCU-FHEM
   room       AB-Fitnessraum,EG-Bad,EG-Kueche,EG-Schlafzimmer,EG-Stiegenhaus,EG-WC,EG-Wirtschaftsraum,EG-Wohnzimmer,OG1-Balkon,OG1-Kinderzimmer,OG1-Kueche,OG1-Schlafzimmer,OG1-WC,OG1-Wohnzimmer,OG2-Buero1,OG2-Buero2,OG2-Dachboden,OG2-EDV-Raum,_HM,_Kontaktsensoren,_RxTx
   rssiLog    1
   subType    virtual
   webCmd     virtual:update
LG Chris
Devices: APC, Davis, Eastron, FS20, Homematic, IT, MQTT, PV-(DEYE, EPEVER, FRONIUS), Resol-VBUS, SkyWind, TEK603
das gehört da nicht hin -> IOgrp      VCCU !
Wenn das nichts behebt gib mal noch ein list von einem der Geräte.
Burny4600
#2
Danke für den Tipp.
Das muss irgendwann rein gerutscht sein.
Kann mich nicht erinnern das jemals definiert zu haben. Habe die IOgrp der VCCU entfernt.
Anbei noch ein Geräte List
   CFGFN      /media/hdd/fhem/mycfg/ueberwachung/sensoren_rasp01.cfg
   DEF        4.....
   HmUART_EG_MSGCNT 13
   HmUART_EG_RAWMSG 05030147F0A6104.....F.....06010000
   HmUART_EG_RSSI -71
   HmUART_EG_TIME 2017-06-20 18:07:16
   HmUART_OG1_MSGCNT 21
   HmUART_OG1_RAWMSG 0500003CF0A6034.....F.....A80288F206E43BA25C56AA6DDE0BE01D
   HmUART_OG1_RSSI -60
   HmUART_OG1_TIME 2017-06-20 18:07:16
   HmUART_OG2_MSGCNT 21
   HmUART_OG2_RAWMSG 05000152F0A6034.....F.....A80288F206E43BA25C56AA6DDE0BE01D
   HmUART_OG2_RSSI -82
   HmUART_OG2_TIME 2017-06-20 18:07:16
   IODev      HmUART_EG
   LASTInputDev HmUART_EG
   MSGCNT     55
   NAME       UESF1_EG_BA
   NOTIFYDEV  global
   NR         1536
   NTFY_ORDER 50-UESF1_EG_BA
   STATE      ZU
   TYPE       CUL_HM
   lastMsg    No:EB - t:10 s:4..... d:F..... 06010000
   protCmdPend 2 CMDs pending
   protLastRcv 2017-06-20 18:07:11
   protResnd  1 last_at:2017-06-20 18:07:16
   protSnd    2 last_at:2017-06-20 18:07:11
   protState  CMDs_pending
   rssi_at_HmUART_EG min:-71 avg:-71 max:-71 cnt:1 lst:-71
   Readings:
     2017-06-20 17:05:54   Activity        unknown
     2017-06-15 12:24:47   D-firmware      1.0
     2017-06-15 12:24:47   D-serialNr      NEQ.......
     2017-06-20 18:07:58   RegL_00.
     2017-06-20 18:07:16   aesCommToDev    fail
     2017-06-20 12:21:06   aesReqTo        VCCU
     2017-06-20 18:07:11   alive           yes
     2017-06-20 18:07:11   battery         ok
     2017-06-20 18:07:11   contact         closed (to VCCU)
     2017-06-20 18:07:11   recentStateType info
     2017-06-20 12:21:08   rssi_at_HmUART_AB -86
     2017-06-20 18:07:11   rssi_at_HmUART_EG -71
     2017-06-20 18:07:11   sabotageError   off
     2017-06-20 18:07:11   state           closed
   cmdStack:
     ++A001F..........00040000000000
     ++A001F..........01040000000001
     ++A001F..........0103
   Helper:
     HM_CMDNR   236
     cSnd       ,01F..........00040000000000
     getCfgList all
     getCfgListNo ,4
     mId        00C7
     rxType     28
     supp_Pair_Rep 0
     Expert:
       def        1
       det        0
       raw        1
       tpl        0
     Io:
       newChn     +4.....,03,01,02
       nextSend   1497974836.86972
       rxt        2
       vccu       VCCU
       p:
         4.....
         01
         01
         02
       prefIO:
         HmUART_EG
     Mrssi:
       mNo        EB
       Io:
         HmUART_EG  -69
     Prt:
       bErr       0
       sProc      2
       sleeping   0
       wuReSent   2
     Q:
       qReqConf
       qReqStat
     Role:
       chn        1
       dev        1
     Rpt:
       IO         HmUART_EG
       flg        A
       ts         1497974831.7111
       ack:
         HASH(0x27fb4c8)
         EB8002F..........00
     Rssi:
       At_hmuart_eg:
         avg        -71
         cnt        1
         lst        -71
         max        -71
         min        -71
     Tmpl:
   Role:
   IODev      HmUART_EG
   IOgrp      VCCU:HmUART_EG
   actCycle   002:50
   actStatus  unknown
   aesCommReq 1
   alias      EG Bad - Fenster - Öffnungssensor
   autoReadReg 4_reqStatus
   devStateIcon ZU:fts_window_1w OFFEN:fts_window_1w_tilt@red
   eventMap   closed:ZU open:OFFEN
   expert     2_defReg+raw
   firmware   1.0
   group      Sensoren
   icon       fts_window_1w
   model      HM-SEC-SCo
   peerIDs    00000000,
   room       EG-Bad,Rolllaeden,_HM,_Kontaktsensoren
   rssiLog    1
   serialNr   NEQ.......
   subType    threeStateSensor
   userReadings rssi_dB:CUL_Master_RSSI.* {(ReadingsVal("$name","CUL_Master_RSSI",0))}
   DEF        4.....
   HmUART_AB_MSGCNT 155
   HmUART_AB_RAWMSG 0500013F21A6034.....F......8819E59D58A5A0A1ADEF70CDB5938800
   HmUART_AB_RSSI -63
   HmUART_AB_TIME 2017-06-20 18:14:54
   HmUART_EG_MSGCNT 131
   HmUART_EG_RAWMSG 0500014E21A6034.....F......8819E59D58A5A0A1ADEF70CDB5938800
   HmUART_EG_RSSI -78
   HmUART_EG_TIME 2017-06-20 18:14:54
   HmUART_OG1_MSGCNT 288
   HmUART_OG1_RAWMSG 0503013921A6104.....F......06010000
   HmUART_OG1_RSSI -57
   HmUART_OG1_TIME 2017-06-20 18:14:54
   HmUART_OG2_MSGCNT 155
   HmUART_OG2_RAWMSG 0500013A21A6034.....F......8819E59D58A5A0A1ADEF70CDB5938800
   HmUART_OG2_RSSI -58
   HmUART_OG2_TIME 2017-06-20 18:14:54
   IODev      HmUART_OG1
   LASTInputDev HmUART_OG1
   MSGCNT     729
   NAME       UEST1_OG1_KUE
   NOTIFYDEV  global
   NR         1656
   NTFY_ORDER 50-UEST1_OG1_KUE
   STATE      OFFEN
   TYPE       CUL_HM
   protCmdPend 9 CMDs_pending
   Readings:
     2017-06-20 16:15:52   Activity        unknown
     2017-06-15 12:24:50   D-firmware      1.0
     2017-06-15 12:24:50   D-serialNr      NEQ........
     2017-06-20 18:14:54   aesCommToDev    fail
     2017-06-20 10:14:08   aesReqTo        VCCU
     2017-06-19 23:41:16   alive           yes
     2017-06-20 10:20:07   battery         ok
     2017-06-20 10:20:07   contact         open (to VCCU)
     2017-06-19 23:41:16   recentStateType info
     2017-06-20 10:14:08   rssi_at_HmUART_AB -55
     2017-06-20 10:20:07   rssi_at_HmUART_OG1 -70
     2017-06-19 23:41:16   sabotageError   off
     2017-06-20 10:20:07   state           open
     2017-06-20 17:24:29   trig_aes_VCCU   fail:152
     2017-06-20 10:20:07   trigger_cnt     133
   cmdStack:
     ++A001F......4.....00040000000000
     ++A001F......4.....01040000000001
     ++A001F......4.....0103
   Helper:
     HM_CMDNR   169
     getCfgList all
     getCfgListNo ,4
     mId        00C7
     rxType     28
     Expert:
       def        1
       det        0
       raw        1
       tpl        0
     Io:
       nextSend   1497975294.95732
       rxt        2
       vccu       VCCU
       p:
         4.....
         01
         01
         02
       prefIO:
         HmUART_OG1
     Mrssi:
       mNo
       Io:
     Prt:
       bErr       0
       sProc      2
     Q:
       qReqConf
       qReqStat
     Role:
       chn        1
       dev        1
     Rssi:
     Shadowreg:
     Tmpl:
   Role:
   IODev      HmUART_OG1
   IOgrp      VCCU:HmUART_OG1
   actCycle   002:50
   actStatus  unknown
   aesCommReq 1
   alias      OG1 Küche - Balkontüre - Öffnungssensor
   devStateIcon ZU:fts_door OFFEN:fts_door_open@red
   expert     2_defReg+raw
   firmware   1.0
   group      Sensoren
   icon       fts_door
   model      HM-SEC-SCo
   peerIDs    00000000,
   room       OG1,OG1-Balkon,OG1-Kueche,Rolllaeden,_HM,_Kontaktsensoren
   rssiLog    1
LG Chris
sorry aber die Sensoren sind nicht angelernt (gepairt) die sind lediglich mit autocreate (wahrscheinlich) angelegt.
Ohne pairing funktionieren die Zustandsmeldungen zwar, aber die Fehler im configCheck bleiben.
Also alles hübsch pairen und dann wird es funktionieren.
Burny4600
#4
Das kann aber nicht sein.
Alle HM Geräte wurden gepairt.
set VCCU hmPairForSec 20 und am Sensor Taste zum Anlernen gedrückt.
Sensor blinket schnell, und im Anschluß standen die Attribute R-pairCentral und PairedTo mit 0xF..... in den Readings.
Und das ist ja das eigenartige, das die Sensor bzw. Geräte Definitionen mit AES auf einmal nicht mehr funktionieren.
Ich habe mittlerweile ein duzend Mal die Sensor bzw. Geräte unpaired sowohl über FHEM als auch direkt am Sensor, und nach dem alle Sensoren unpaired waren wieder alle gepairt.
   DEF        4.....
   HmUART_AB_MSGCNT 95
   HmUART_AB_RAWMSG 050201522AA6104.....F.....06010000
   HmUART_AB_RSSI -82
   HmUART_AB_TIME 2017-06-21 06:48:38
   HmUART_EG_MSGCNT 112
   HmUART_EG_RAWMSG 050000524EA6104.....F.....06010000
   HmUART_EG_RSSI -82
   HmUART_EG_TIME 2017-06-21 12:32:19
   HmUART_OG1_MSGCNT 108
   HmUART_OG1_RAWMSG 0500014B4EA6104.....F.....06010000
   HmUART_OG1_RSSI -75
   HmUART_OG1_TIME 2017-06-21 12:32:19
   HmUART_OG2_MSGCNT 120
   HmUART_OG2_RAWMSG 0500014E4EA6104.....F.....06010000
   HmUART_OG2_RSSI -78
   HmUART_OG2_TIME 2017-06-21 12:32:19
   IODev      HmUART_AB
   MSGCNT     435
   NAME       UEST1_AB_FR
   NOTIFYDEV  global
   NR         1505
   NTFY_ORDER 50-UEST1_AB_FR
   STATE      ZU
   TYPE       CUL_HM
   lastMsg    No:2A - t:10 s:4..... d:F..... 06010000
   protEvt_AESCom-ok 8 last_at:2017-06-21 06:48:38
   protLastRcv 2017-06-21 06:48:38
   protResnd  2 last_at:2017-06-20 18:50:29
   protSnd    18 last_at:2017-06-21 06:48:38
   protState  CMDs_done
   rssi_at_HmUART_AB avg:-83.66 max:-80 min:-85 cnt:15 lst:-82
   Readings:
     2017-06-21 09:46:16   Activity        dead
     2017-06-15 12:24:50   D-serialNr      NEQ0......
     2017-06-20 19:41:57   PairedTo        0xF.....
     2017-06-15 22:13:12   R-cyclicInfoMsg on
     2017-06-15 22:13:12   R-eventDlyTime  0 s
     2017-06-15 22:13:12   R-pairCentral   0xF.....
     2017-06-15 22:13:12   R-sabotageMsg   on
     2017-06-15 22:13:12   R-sign          on
     2017-06-20 19:41:57   RegL_00.          02:01 09:01 0A:F1 0B:23 0C:47 10:01 14:06 00:00
     2017-06-20 19:41:58   RegL_01.          08:01 20:9C 21:00 30:06 00:00
     2017-06-21 06:48:38   aesCommToDev    ok
     2017-06-21 06:48:38   alive           yes
     2017-06-21 06:48:38   battery         ok
     2017-06-21 06:48:38   contact         closed (to VCCU)
     2017-06-21 06:48:38   recentStateType info
     2017-06-21 06:48:38   rssi_at_HmUART_AB -82
     2017-06-21 06:48:38   sabotageError   off
     2017-06-21 06:48:38   state           closed
     2017-06-16 19:49:23   trig_aes_VCCU   ok:245
     2017-06-16 19:49:23   trigger_cnt     245
   Helper:
     HM_CMDNR   42
     cSnd       01F.....4.....01040000000001,01F.....4.....0103
     mId        00C7
     peerIDsRaw ,00000000
     rxType     28
     supp_Pair_Rep 0
     Ack:
     Expert:
       def        1
       det        0
       raw        1
       tpl        0
     Io:
       newCh      1
       newChn     +4.....,01,01,02
       nextSend   1498041139.55909
       rxt        2
       vccu       VCCU
       p:
         4.....
         01
         01
         02
       prefIO:
         HmUART_AB
     Mrssi:
       mNo        2A
       Io:
         HmUART_AB  -80
     Prt:
       bErr       0
       sProc      0
       sleeping   0
       Rspwait:
     Q:
       qReqConf
       qReqStat
     Role:
       chn        1
       dev        1
     Rpt:
       IO         HmUART_AB
       flg        A
       ts         1498020518.31881
       ack:
         HASH(0x27f9c50)
         2A8002F.....4.....00
     Rssi:
       At_hmuart_ab:
         avg        -83.6666666666667
         cnt        15
         lst        -82
         max        -80
         min        -85
     Shadowreg:
     Tmpl:
   Role:
   IODev      HmUART_AB
   IOgrp      VCCU:HmUART_AB
   actCycle   002:50
   actStatus  dead
   aesCommReq 1
   alias      AB Fitnessraum - Türe - Öffnungssensor
   expert     2_defReg+raw
   firmware   1.0
   group      Sensoren
   icon       fts_door
   model      HM-SEC-SCo
   peerIDs    00000000,
   room       AB,AB-Fitnessraum,_HM,_Kontaktsensoren
   rssiLog    1
   serialNr   NEQ0......
LG Chris
aber genau das fehlt oben in deinem list!
In dem list jetzt ist alles korrekt.
Manchmal save vergessen?
LuckyDay
das problem ist, dass er alte Readings zeigt, und jedes mal einen anderen Sensor
und wenn ich den jetzt mal als Beispiel nehme , ist denn wirklich R-cyclicInfoMsg on , weil er sollte eigentlich nicht 2017-06-21 09:46:16   Activity        dead sein.
bei den anderen 2 lists sind sogar noch command pendings drin, Ich sag mal knöpfchen drücken.
ihm zu helfen ist für mich extrem schwierig
Burny4600
Wie kann ich überprüfen ob R-cyclicInfoMsg on ist bzw. wie aktiviere ich das?
LG Chris
Burny4600
#8
Zitatund wenn ich den jetzt mal als Beispiel nehme , ist denn wirklich R-cyclicInfoMsg on , weil er sollte eigentlich nicht 2017-06-21 09:46:16   Activity        dead sein.
All das wurde gemacht und dennoch verabschieden sich die Komponeten wieder.
Ich weis schön langsam nicht mehr was mit diesen HM Komponeten los ist.
Alle Geräte wurden mit unpair und am Sensor mit zweimal Knöpfchen lange gedrückt (rot langs und rot schnell blinken) getrennt und im mit set VCCU hmPairForSec 20 wieder neu gepeert und gespeichert und dennoch steht wieder in der Geräteübersicht nach ca. einem Tag
alive:4 dead:0 unkn:27 off:0
Was noch dazu kommt ist das aesCommReq set, IO not compatibel für alle Komponenten eingetragen ist.
configCheck done:
    AB_GAO_FS1_SSPPWT
    UESF1_EG_BA
    UESF1_EG_KUE
    UESF1_EG_SL
    UESF1_EG_STH
    UESF1_EG_STH
    UESF1_EG_WI
    UESF1_EG_WC
    UESF1_EG_WI
    UESF1_EG_WZ
    UESF1_OG1_KI
    UESF1_OG1_KUE
    UESF1_OG1_SL
    UESF1_OG1_WC
    UESF1_OG2_BUE1_N
    UESF1_OG2_BUE2_W
    UESF1_OG2_DB
    UESF1_OG2_DBN
    UESF2_EG_SL
    UESF2_EG_STH
    UESF2_EG_WZ
    UESF2_OG2_BUE2_N
    UESF2_OG2_BUE2_W
    UESF2_OG2_DBN
    UESF3_OG2_BUE1_N
    UESF3_OG2_BUE2_W
    UESF3_OG2_DBN
    UEST1VG_EG_STH
    UEST1_AB_FR
    UEST1_EG_KUE
    UEST1_EG_STH
    UEST1_OG1_KUE
    UEST1_OG2_EDV
    UES_EG_STH_T1FB
    VCCU
LG Chris
Ich rate Dir einfach zur Ruhe. Ich habe den Eindruck Du machst zu viel, zu schnell und zu sehr alles durcheinander.
Zitatset VCCU hmPairForSec 20
Schon das halte ich für sportlich, da bekommt man bei manchen HM Geräten nicht mal den configTaster aktiviert.
Burny4600
#10
Wenn die Aktivierung abgeschlossen ist und alle Sensoren mit alive vorhanden sind müsste das doch reichen.
Zudem sind die Readings ja passend, oder nicht?
ZB ein Sensor der jetzt wieder mit dead sich zurückmeldet nachdem die Parameter PairedTo R-pairCentral   mit 0xF......
Activity dead 03.07.2017 15:55
D-firmware 1.0        15.06.2017 12:24
D-serialNr NEQ.......        15.06.2017 12:24
PairedTo 0xF.....        23.06.2017 01:53
R-cyclicInfoMsg on        23.06.2017 01:53
R-eventDlyTime 0 s 23.06.2017 01:53
R-pairCentral 0xF..... 23.06.2017 01:53
R-sabotageMsg on 23.06.2017 01:53
R-sign on                 23.06.2017 01:53
RegL_00. 02:01 09:01 0A:F1 0B:23 0C:47 10:01 14:06 00:00 23.06.2017 01:53
RegL_01. 08:01 20:9C 21:00 30:06 00:00 23.06.2017 01:53
aesCommToDev fail 04.07.2017 08:40
aesReqTo VCCU 02.07.2017 03:55
alive yes 02.07.2017 12:17
battery ok 02.07.2017 12:17
contact closed (to VCCU) 02.07.2017 12:17
recentStateType info 02.07.2017 12:17
rssi_at_HmUART_AB -82 02.07.2017 03:01
rssi_at_HmUART_EG -69 02.07.2017 12:17
sabotageError off 02.07.2017 12:17
state closed 02.07.2017 12:17
Was mich nur stutzig macht sind die Zeitstempel wo dies passiert sein soll, die nicht stimmen können.
Da dürfte mehr faul sein, und ich denke das hängt eventuell mit dem eingerichteten https und SSL zusammen.
Beim Pairing meldeten sich zudem die Sensoren am Ende mit dem einmaligen Auflauchten der LED in grün. Während des Pairing blinken die Sensoren sehr rasch in Orange.
Ich denke wir gehen zum Anfang. Vielleicht passt auch etwas in der Konfiguration nicht.
Es gibt einen zentralen Raspberry mit FHEM der die VCCU und einen HM Schnittstelle mit einem HMUARTLGW besitzt.
Zudem gibt es drei exponierte HMUARTLGW Schnittstellen die via ser2net an dem zentralen Raspberry angebunden sind.
Config VCCU
###        HomeMatic VCCU         ###
define VCCU CUL_HM F.....
attr VCCU IODev HmUART_OG1
attr VCCU IOList HmUART_AB,HmUART_EG,HmUART_OG1,HmUART_OG2
attr VCCU aesCommReq 1
attr VCCU alias HomeMatic Virtuelle CCU
attr VCCU group HomeMatic VCCU
attr VCCU hmKey 01:e...............................................................9
attr VCCU icon hm_ccu
attr VCCU model CCU-FHEM
attr VCCU room AB-Fitnessraum,EG-Bad,EG-Kueche,EG-Schlafzimmer,EG-Stiegenhaus,EG-WC,EG-Wirtschaftsraum,EG-Wohnzimmer,OG1-Balkon,OG1-Kinderzimmer,OG1-Kueche,OG1-Schlafzimmer,OG1-WC,OG1-Wohnzimmer,OG2-Buero1,OG2-Buero2,OG2-Dachboden,OG2-EDV-Raum,_HM,_Kontaktsensoren,_RxTx
attr VCCU rssiLog 1
attr VCCU subType virtual
attr VCCU webCmd virtual:update
define VCCU_Btn1 CUL_HM F.....01
attr VCCU_Btn1 alias HomeMatic Virtuelle CCU - Taste 1
attr VCCU_Btn1 group HomeMatic VCCU
attr VCCU_Btn1 icon hm_ccu
attr VCCU_Btn1 model CCU-FHEM
attr VCCU_Btn1 peerIDs 00000000,
attr VCCU_Btn1 room _HM,_Kontaktsensoren
attr VCCU_Btn1 webCmd press short:press long
define VCCU_Btn2 CUL_HM F.....02
attr VCCU_Btn2 alias HomeMatic Virtuelle CCU - Taste 2
attr VCCU_Btn2 group HomeMatic VCCU
attr VCCU_Btn2 icon hm_ccu
attr VCCU_Btn2 model CCU-FHEM
attr VCCU_Btn2 peerIDs 00000000,
attr VCCU_Btn2 room _HM
attr VCCU_Btn2 webCmd press short:press long
define VCCU_Btn3 CUL_HM F.....03
attr VCCU_Btn3 alias HomeMatic Virtuelle CCU - Taste 3
attr VCCU_Btn3 group HomeMatic VCCU
attr VCCU_Btn3 icon hm_ccu
attr VCCU_Btn3 model CCU-FHEM
attr VCCU_Btn3 peerIDs 00000000,
attr VCCU_Btn3 room _HM
attr VCCU_Btn3 webCmd press short:press long
###        HomeMatic Info         ###
define HM HMinfo
attr HM alias HomeMatic Info
attr HM icon edit_paste
attr HM room _HM,_Kontaktsensoren
attr HM sumERROR battery:ok,sabotageError:off,powerError:ok,overload:off,overheat:off,reduced:off,motorError:no,error:none,uncertain:yes,smoke_detect:none,cover:closed
attr HM sumStatus battery,sabotageError,powerError,motor
attr HM webCmd update:protoEvents short:rssi:peerXref:configCheck:models
lokale Schnittstelle
###       INPUT HomeMatic         ###
define HmUART_OG2 HMUARTLGW /dev/ttyAMA0
attr HmUART_OG2 alias HomeMatic Gateway - OG2 EDV Raum
attr HmUART_OG2 devStateIcon init:hm_lan@orange opened:hm_lan@lightgreen
attr HmUART_OG2 group Schnittstellen HomeMatic
attr HmUART_OG2 hmId F.....
attr HmUART_OG2 icon hm_lan
attr HmUART_OG2 logIDs sys,all
attr HmUART_OG2 qLen 60
attr HmUART_OG2 room _HM,_RxTx
attr HmUART_OG2 verbose 0
ser2net Schnittstellen
###     ser2net Schnittstellen    ###
### HomeMatic AB
define HmUART_AB HMUARTLGW uart://192.xxx.xxx.xx6:40541
attr HmUART_AB alias HomeMatic Gateway - AB Fitnessraum
attr HmUART_AB devStateIcon init:it_network@orange opened:it_network@lightgreen disconnected:it_network@red
attr HmUART_AB dutyCycle 1
attr HmUART_AB group Schnittstellen ser2net
attr HmUART_AB hmId F.....
attr HmUART_AB icon hm_lan
attr HmUART_AB qLen 60
attr HmUART_AB room _HM,_RxTx
attr HmUART_AB verbose 0
### HomeMatic EG
define HmUART_EG HMUARTLGW uart://192.xxx.xxx.xx5:40541
attr HmUART_EG alias HomeMatic Gateway - EG Vorraum HV
attr HmUART_EG devStateIcon init:it_network@orange opened:it_network@lightgreen disconnected:it_network@red
attr HmUART_EG dutyCycle 1
attr HmUART_EG group Schnittstellen ser2net
attr HmUART_EG hmId F.....
attr HmUART_EG icon hm_lan
attr HmUART_EG qLen 60
attr HmUART_EG room _HM,_RxTx
attr HmUART_EG verbose 0
### HomeMatic OG1
define HmUART_OG1 HMUARTLGW uart://192.xxx.xxx.xx7:40541
attr HmUART_OG1 alias HomeMatic Gateway - OG1 Vorraum UV
attr HmUART_OG1 devStateIcon init:it_network@orange opened:it_network@lightgreen disconnected:it_network@red
attr HmUART_OG1 dutyCycle 1
attr HmUART_OG1 group Schnittstellen ser2net
attr HmUART_OG1 hmId F.....
attr HmUART_OG1 icon hm_lan
attr HmUART_OG1 qLen 60
attr HmUART_OG1 room _HM,_RxTx
attr HmUART_OG1 verbose 0
###           RSSI Geräte         ###
define culRSSI readingsGroup <Gerät>,<Signal>,<Zeit>,<hr>\
nanoCUL433_RSSI=.*:+nanoCUL433_RSSI,+nanoCUL433_TIME\
nanoCUL868_RSSI=.*:+nanoCUL868_RSSI,+nanoCUL868_TIME\
HmUART_AB_RSSI=.*:+HmUART_AB_RSSI,+HmUART_AB_TIME\
HmUART_EG_RSSI=.*:+HmUART_EG_RSSI,+HmUART_EG_TIME\
HmUART_OG1_RSSI=.*:+HmUART_OG1_RSSI,+HmUART_OG1_TIME\
HmUART_OG2_RSSI=.*:+HmUART_OG2_RSSI,+HmUART_OG2_TIME
attr culRSSI alias Signalstärke Geräte & Sensoren
attr culRSSI room _Signalstärke Geräte
attr culRSSI sortDevices 1
attr culRSSI valueFormat {nanoCUL433_RSSI => "%0.1f db",\
nanoCUL868_RSSI => "%0.1f db",\
nanoCUL868_HM_RSSI => "%0.1f db",\
HmUART_AB_RSSI => "%0.1f db",\
HmUART_EG_RSSI => "%0.1f db",\
HmUART_OG1_RSSI => "%0.1f db",\
HmUART_OG2_RSSI => "%0.1f db"}
attr culRSSI valueStyle {return undef if($READING =~ m/TIME/);; ($VALUE <= -85)?'style="color:red"':($VALUE <= -80)?'style="color:yellow"':undef}
###         RSSI Sensoren         ###
define SenRSSI readingsGroup <Gerät>,<Signal>,<Zeit>,<hr> .*:rssi_dB
attr SenRSSI alias Signalstärke Sensoren
attr SenRSSI room _Signalstärke Geräte
attr SenRSSI valueFormat {rssi_dB => "%1.f db"}
attr SenRSSI valueStyle {return undef if($READING =~ m/TIME/);; ($VALUE <= -85)?'style="color:red"':($VALUE <= -80)?'style="color:yellow"':undef}
###    Batteriezustände Sensor    ###
define battStatus readingsGroup <Sensor>,<Zustand>,<Zeitstempel> <hr> .*:[Bb]attery
attr battStatus alias Sensor Batteriezustände
attr battStatus commands {"battery.low" => "set %DEVICE replaceBatteryForSec 600"}
attr battStatus room _Sensor Batteriezustände
attr battStatus sortDevices 1
attr battStatus valueIcon {'battery.ok' => \
'measure_battery_100@green',\
'battery.ok 100%' =>\
'battery.bad' =>\
'measure_battery_25@red',\
'battery.low' =>\
'battery.low 10%' =>\
'measure_battery_25@red'}
LG Chris
frank
ZitatWas mich nur stutzig macht sind die Zeitstempel wo dies passiert sein soll, die nicht stimmen können.
dann würde ich "set clear all" machen und anschliessend getconfig. danach müssen alle timestamps aktuell sein.
wenn, dann poste komplette list's und keine auszüge.
"schwärzen" ist auch sinnlos, ausser beim eigenen homematic schlüssel.
wie otto schon sagt, nimm dir immer nur ein device vor, und teste es, bis alles funktioniert. eventuell sniffen, um kommunikationsprobleme zu erkennen.
FHEM: 6.0(SVN) => Pi3(buster)
Das würde mich beunruhigen:
Die Readings mit dead und alive kann ich irgendwie nicht richtig deuten. Kann es sein, das Du den Sensoren zusätzlich mit Abfragen Stress bereitest?
Kannst Du für Sensoren bevorzugte IOs definieren, ich meine sich immer zwischen mehreren IOs zu entscheiden birgt vielleicht auch Probleme.
Mein Sensor sieht z.B. so aus:
   DEF        4C1C11
   HMLAN1_MSGCNT 136
   HMLAN1_RAWMSG E4C1C11,0000,3ABCF8D6,FF,FFD3,7FA6104C1C11200DB806010000
   HMLAN1_RSSI -45
   HMLAN1_TIME 2017-07-04 12:31:17
   HMUART1_MSGCNT 130
   HMUART1_RAWMSG 0501002B7FA6104C1C11200DB806010000
   HMUART1_RSSI -43
   HMUART1_TIME 2017-07-04 12:31:17
   IODev      HMUART1
   LASTInputDev HMLAN1
   MSGCNT     266
   NAME       FensterAZL
   NOTIFYDEV  global
   NR         528
   NTFY_ORDER 50-FensterAZL
   STATE      closed
   TYPE       CUL_HM
   lastMsg    No:7F - t:10 s:4C1C11 d:200DB8 06010000
   protLastRcv 2017-07-04 12:31:17
   protSnd    136 last_at:2017-07-04 12:31:17
   protState  CMDs_done
   rssi_at_HMLAN1 cnt:136 lst:-45 avg:-41.83 max:-40 min:-49
   rssi_at_HMUART1 max:-41 avg:-50.28 min:-72 cnt:130 lst:-43
   Readings:
     2017-06-29 12:01:05   Activity        alive
     2016-11-06 16:52:53   CommandAccepted yes
     2016-11-06 17:09:31   D-firmware      1.0
     2016-11-06 17:09:31   D-serialNr      NEQ0630364
     2016-11-06 17:09:33   PairedTo        0x200DB8
     2016-11-06 17:09:33   R-cyclicInfoMsg on
     2016-11-06 17:09:33   R-eventDlyTime  0 s
     2016-11-06 17:09:33   R-pairCentral   0x200DB8
     2016-11-06 17:09:33   R-sabotageMsg   on
     2016-11-06 17:09:33   R-sign          on
     2016-11-06 17:09:33   RegL_00.        02:01 09:01 0A:20 0B:0D 0C:B8 10:01 14:06 00:00
     2016-11-06 17:09:33   RegL_01.        08:01 20:9C 21:00 30:06 00:00
     2016-11-06 16:52:53   aesCommToDev    ok
     2016-11-06 16:52:53   aesKeyNbr       00
     2017-07-04 12:31:17   alive           yes
     2017-07-04 12:31:17   battery         ok
     2017-07-04 12:31:17   contact         closed (to VCCU)
     2016-11-06 17:09:12   powerOn         2016-11-06 17:09:12
     2017-07-04 12:31:17   recentStateType info
     2017-07-04 12:31:17   sabotageError   off
     2017-07-04 12:31:17   state           closed
     2016-11-06 16:52:29   trigDst_broadcast noConfig
     2017-06-26 10:38:26   trigger_cnt     46
   Helper:
     HM_CMDNR   127
     mId        00C7
     rxType     28
     supp_Pair_Rep 0
     Ack:
     Expert:
       def        1
       det        0
       raw        1
       tpl        0
     Io:
       newChn     +4C1C11,00,00,00
       nextSend   1499164277.45722
       rxt        2
       vccu       VCCU
       p:
         4C1C11
         00
         00
         00
     Mrssi:
       mNo        7F
       Io:
         HMLAN1     -45
         HMUART1    -41
     Prt:
       bErr       0
       sProc      0
       sleeping   0
       Rspwait:
     Q:
       qReqConf
       qReqStat
     Role:
       chn        1
       dev        1
     Rpt:
       IO         HMUART1
       flg        A
       ts         1499164277.36906
       ack:
         HASH(0x312ee38)
         7F8002200DB84C1C1100
     Rssi:
       At_hmlan1:
         avg        -41.8382352941176
         cnt        136
         lst        -45
         max        -40
         min        -49
       At_hmuart1:
         avg        -50.2846153846154
         cnt        130
         lst        -43
         max        -41
         min        -72
     Tmpl:
   IODev      HMUART1
   IOgrp      VCCU
   actCycle   002:50
   actStatus  alive
   expert     2_raw
   firmware   1.0
   model      HM-SEC-SCo
   peerIDs    00000000,
   room       Arbeitszimmer,CUL_HM
   serialNr   NEQ0630364
Da sind durchaus auch einige Readings alt ...
Burny4600
#13
@frank
Zitatdann würde ich "set clear all" machen und anschliessend getconfig. danach müssen alle timestamps aktuell sein.
Das ist einmal etwas mit dem ich etwas anfangen kann.
Was meinst du mit schwärzen?
Von welchen Geräten soll ich ein List machen?
@Otto123
ZitataesCommToDev   fail   04.07.2017 08:40
und auch die Menge an geräten die unter
ZitataesCommReq set, IO not compatibel
aufschein irritiert mich.
ZitatDie Readings mit dead und alive kann ich irgendwie nicht richtig deuten. Kann es sein, das Du den Sensoren zusätzlich mit Abfragen Stress bereitest?
Die HM Sensoren werden wie alle anderen Sensoren behandelt. Da erfolgt nur ein Trigger wenn der Sensor etwas liefert.
LG Chris
Burny4600
#14
Ich bin wieder einmal bei dem leidigem Thema nachdem ich wieder ein wenig Zeit habe.
Folgender Teststand:
Ich habe die Sensoren unpaired.
Vorher wurden wegen des besseren Überblicks ein  clear ausgeführt.
set UEST1_OG1_KUE clear all
Jeder Sensor ist einer entsprechenden IODev zugeortnet der in seiner Nähe liegt. in diesem Tesfall dem IODev HmUART_OG1.
Nach einer längeren Zeit wurder das Pairing gestartet.
set VCCU hmPairForSec 90
Alles sieht sauber gepairt aus.
Nach dem Pairing stand sogar das aesCommToDev mit ok an.
Nach kurzer Zeit aber wieder nicht.
list UEST1_OG1_KUE
   DEF        4C1E60
   HmUART_AB_MSGCNT 181
   HmUART_AB_RAWMSG 05000143C7A6034C1E60FxxxxxA73FC099EEA38B4D266C10D5A2C7404E
   HmUART_AB_RSSI -67
   HmUART_AB_TIME 2017-10-03 16:03:55
   HmUART_EG_MSGCNT 177
   HmUART_EG_RAWMSG 05000150C7A6034C1E60FxxxxxA73FC099EEA38B4D266C10D5A2C7404E
   HmUART_EG_RSSI -80
   HmUART_EG_TIME 2017-10-03 16:03:55
   HmUART_OG1_MSGCNT 329
   HmUART_OG1_RAWMSG 0503013BC7A6414C1E60Fxxxxx010500
   HmUART_OG1_RSSI -59
   HmUART_OG1_TIME 2017-10-03 16:03:55
   HmUART_OG2_MSGCNT 181
   HmUART_OG2_RAWMSG 05000128C7A6034C1E60FxxxxxA73FC099EEA38B4D266C10D5A2C7404E
   HmUART_OG2_RSSI -40
   HmUART_OG2_TIME 2017-10-03 16:03:55
   IODev      HmUART_OG1
   MSGCNT     868
   NAME       UEST1_OG1_KUE
   NOTIFYDEV  global
   NR         2552
   STATE      ZU
   TYPE       CUL_HM
   lastMsg    No:BB - t:00 s:4C1E60 d:000000 1000C74E45513036323635343280810101
   protEvt_AESCom-ok 6 last_at:2017-10-03 16:02:55
   protLastRcv 2017-10-03 16:03:17
   protResnd  1 last_at:2017-10-03 16:00:25
   protSnd    19 last_at:2017-10-03 16:03:07
   protState  CMDs_done
   rssi_at_HmUART_OG1 avg:-59.61 min:-64 cnt:18 max:-57 lst:-59
     2017-10-03 16:03:17   Activity        alive
     2017-10-03 16:02:55   CommandAccepted yes
     2017-10-03 16:03:17   D-firmware      1.0
     2017-10-03 16:03:17   D-serialNr      Nxxxxxxxxx
     2017-10-03 16:03:06   PairedTo        0xFxxxxx
     2017-10-03 16:00:41   R-cyclicInfoMsg on
     2017-10-03 16:00:41   R-eventDlyTime  0 s
     2017-10-03 16:03:06   R-pairCentral   0xFxxxxx
     2017-10-03 16:00:41   R-sabotageMsg   on
     2017-10-03 16:00:41   R-sign          on
     2017-10-03 16:03:06   RegL_00.          02:01 09:01 0A:F1 0B:23 0C:47 10:01 14:06 00:00
     2017-10-03 16:03:07   RegL_01.          08:01 20:9C 21:00 30:06 00:00
     2017-10-03 16:03:55   aesCommToDev    fail
     2017-10-03 16:02:55   aesKeyNbr       00
     2017-10-03 16:03:17   rssi_at_HmUART_OG1 -59
     2017-10-03 16:03:55   trig_aes_VCCU   fail:5
   helper:
     HM_CMDNR   226
     PONtest    0
     cSnd       01Fxxxxx4C1E6001040000000001,01Fxxxxx4C1E600103
     mId        00C7
     rxType     28
     supp_Pair_Rep 1
     expert:
       def        1
       det        0
       raw        1
       tpl        0
     io:
       newChn     +4C1E60,01,01,02
       nextSend   1507039435.63487
       rxt        2
       vccu       VCCU
       p:
         4C1E60
         01
         01
         02
       prefIO:
         HmUART_OG1
     mRssi:
       mNo        BB
       io:
         HmUART_OG1 -57
     prt:
       bErr       0
       sProc      0
       try        1
       rspWait:
     q:
       qReqConf
       qReqStat
     role:
       chn        1
       dev        1
     rssi:
       at_HmUART_OG1:
         avg        -59.6111111111111
         cnt        18
         lst        -59
         max        -57
         min        -64
     shadowReg:
     tmpl:
   role:
   IODev      HmUART_OG1
   actCycle   002:50
   actStatus  alive
   aesCommReq 1
   event-on-change-reading alive,battery,contact,sabotageError
   expert     2_defReg+raw
   firmware   1.0
   group      Sensoren
   icon       fts_door
   model      HM-SEC-SCo
   peerIDs    00000000,
   rssiLog    1
   serialNr   NEQ0626542
Zudem ist es jetzt der Fall das Statusänderungen bei zb. diesem Sensor nicht mehr an FHEM übermittelt werden.
Ich weiß wirklich hier nicht mehr wo ich noch ansetzten kann.
LG Chris
