Autor Thema: Unknown module ESPEasy  (Gelesen 3193 mal)
dumbme
  • Gast
« am: 22 Juni 2017, 12:29:05 »
Hi There,
I have been building my setup
and after trying multiple solutions i choose fhem to run the home
Sadly it seems to be 1 of my intended uses seem to fail
the idea is to use an ESP8266 this works fine connecting it up to fHEM with the define gives me
Unknown module ESPEasy tried the search but nothing showed up
Anybody have an idea ?
Offline Otto123
  • Tester
    • Otto's Technik Blog
Antw:Unknown module ESPEasy
« Antwort #1 am: 22 Juni 2017, 12:38:27 »
may be your FHEM is an old version? Since march 2017 the modul ESPEasy ist official content, earlier it was experimental.
regards Otto
« Letzte Änderung: 22 Juni 2017, 12:46:54 von Otto123 »
Viele Grüße aus Leipzig
Offline Fixel2012
« Antwort #2 am: 22 Juni 2017, 12:42:00 »
To update fhem, type "update" in the Fhem Commandline at the upper of the GUI.
Fhem 5.8 auf Raspi 3, HMLAN und 868MHz CUL mit einigen Komponenten, Z-Wave Rollladenaktoren, Tablet UI, 433 MHz CUL mit Baumarktsteckdosen und Temp Sensoren, Amazon Echo, Echo Dot, 2x SONOS  play1, 1x SONOS Connect AMP,  presence, HUE, Lightify
dumbme
  • Gast
« Antwort #3 am: 22 Juni 2017, 12:50:23 »
2017.06.22 10:48:24 1 : nothing to do...
define espBridge ESPEasy bridge 8383
dumbme
  • Gast
« Antwort #4 am: 22 Juni 2017, 12:53:14 »
Hmzzz just reflashed the sdcard ran update again and tried again and now seem to work no clue why there first time it didint accept
Whoei Thanks for the help
Offline Otto123
  • Tester
« Antwort #5 am: 22 Juni 2017, 12:54:18 »
what say version to you?
btw. the modul needs the debian Paket libjson-perl.
to late ...  ;)
Offline Benni
  • FHEMinist
« Antwort #6 am: 22 Juni 2017, 14:14:30 »
update usually requires to restart fhem (shutdown restart) after completion.
Maybe you missed that?
decade-submarginal
