Raspberry and Reboot from fhem
Begonnen von HarryT, 13 Juli 2017, 23:06:03
HarryT
Hi I am trying to start a reboot of the rapsberry from  fhem with:
  system("sudo reboot &");
I tried this:
  http://ueberueck.com/index.php/fhem-hausautomatisierung/fhem-how-to-s/raspberry-aus-fhem-neu-starten
In my password file I have:
  fhem:x:999:20::/opt/fhem:/bin/bash
In groups I have:
  sudo:x:27:pi,fhem
In the fhem logging I get:
We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
    #1) Respect the privacy of others.
    #2) Think before you type.
    #3) With great power comes great responsibility.
sudo: no tty present and no askpass program specified
Has anybody succeeded in getting this to work? If so, how?
Thanks
FHEM 6.4 auf Raspberry Pi3  (1,2 Ghz)
RFXTRX433XL, ZWave, KFL200 and ConBeeIII
Raspberry Pi1 (0,7 Ghz), Raspberry Pi4 and RaspberryPi 5 for testing
German reading skills are good.
amenomade
What do you have in /etc/sudoers ?
HarryT
Hi
my /etc/sudoers: ( it is the standard version. as far as I see, it is sufficient to add fhem to the group sudoers)
# This file MUST be edited with the 'visudo' command as root.
# Please consider adding local content in /etc/sudoers.d/ instead of
# directly modifying this file.
# See the man page for details on how to write a sudoers file.
Defaults        env_reset
Defaults        mail_badpass
Defaults        secure_path="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin"
# Host alias specification
# User alias specification
# Cmnd alias specification
# User privilege specification
root    ALL=(ALL:ALL) ALL
# Allow members of group sudo to execute any command
%sudo   ALL=(ALL:ALL) ALL
# See sudoers(5) for more information on "#include" directives:
#includedir /etc/sudoers.d
Manul
That would need to be
%sudo   ALL=(ALL:ALL) NOPASSWD: ALL
or better still
fhem ALL=(root) NOPASSWD: /sbin/shutdown
HarryT
Cool
worked.
BTW I guess adding fhem to the sudoers group is not necessary when this line is add to the sudoers file?
Thanks
Manul
Right.
