Wandtaster HM-PB-2-WM55 die 2.
Begonnen von stgeran, 08 August 2017, 19:49:24
stgeran
Ich habe den 2. Taster gelötet. Soweit, sogut. Hier ein list.....
   CFGFN
   DEF        597F7C
   HMLAN1_MSGCNT 80
   HMLAN1_RAWMSG E597F7C,0000,0C852367,FF,FFB4,9A8440597F7C000000020F
   HMLAN1_RSSI -76
   HMLAN1_TIME 2017-08-08 19:37:00
   IODev      myHmUART
   LASTInputDev HMLAN1
   MSGCNT     161
   NAME       T_Nachttisch_li
   NOTIFYDEV  global
   NR         521
   STATE      HM_597F7C_Btn_02 Short
   TYPE       CUL_HM
   channel_01 HM_597F7C_Btn_01
   channel_02 HM_597F7C_Btn_02
   lastMsg    No:9A - t:40 s:597F7C d:000000 020F
   myHmUART_MSGCNT 81
   myHmUART_RAWMSG 0500002E9A8440597F7C000000020F
   myHmUART_RSSI -46
   myHmUART_TIME 2017-08-08 19:37:00
   protLastRcv 2017-08-08 19:37:00
   protState  Info_Cleared
   rssi_at_HMLAN1 avg:-76.91 max:-62 min:-96 cnt:80 lst:-76
   rssi_at_myHmUART min:-72 max:-35 cnt:81 lst:-46 avg:-48.53
     2017-08-08 18:59:18   D-firmware      1.4
     2017-08-08 18:59:18   D-serialNr      OEQ0486541
     2017-08-08 18:59:19   PairedTo        0x000000
     2017-08-08 18:59:19   R-pairCentral   0x000000
     2017-08-08 19:37:00   battery         ok
     2017-08-08 19:37:00   state           HM_597F7C_Btn_02 Short
   helper:
     HM_CMDNR   154
     cSnd       01123456597F7C02040000000001,01123456597F7C0203
     mId        006B
     rxType     28
     supp_Pair_Rep 0
     ack:
     expert:
       def        1
       det        0
       raw        1
       tpl        0
     io:
       newChn     +597F7C,00,00,00
       nextSend   1502213820.50115
       prefIO
       rxt        2
       vccu
       p:
         597F7C
         00
         00
         00
     mRssi:
       mNo        9A
       io:
         HMLAN1     -76
         myHmUART   -44
     prt:
       bErr       0
       sProc      0
     q:
       qReqConf
       qReqStat
     role:
       dev        1
     rssi:
       at_HMLAN1:
         avg        -76.9125
         cnt        80
         lst        -76
         max        -62
         min        -96
       at_myHmUART:
         avg        -48.5308641975308
         cnt        81
         lst        -46
         max        -35
         min        -72
     shadowReg:
     tmpl:
   IODev      myHmUART
   autoReadReg 4_reqStatus
   expert     2_raw
   firmware   1.4
   model      HM-PB-2-WM55
   room       CUL_HM,Schlafzimmer
   serialNr   OEQ0486541
   subType    pushButton
   webCmd     getConfig:clear msgEvents
Ich bekomme das verdammte Ding nicht mit einem Dimmer HM-LC-DIM2T-SM  zusammen.
Hier ein list.....
DEF        27A7B1
   HMLAN1_MSGCNT 28
   HMLAN1_RAWMSG RC2DB5F63,0001,0C74B183,FF,FFC4,8CA41027A7B11234560601000040
   HMLAN1_RSSI -60
   HMLAN1_TIME 2017-08-08 19:19:02
   IODev      HMLAN1
   LASTInputDev HMLAN1
   MSGCNT     45
   NAME       Bett_li
   NOTIFYDEV  global
   NR         158
   STATE      CMDs_done
   TYPE       CUL_HM
   channel_01 Nachttisch_li
   channel_02 Deckenlampe
   hmPairSerial LEQ0176739
   lastMsg    No:8C - t:10 s:27A7B1 d:123456 0601000040
   myHmUART_MSGCNT 17
   myHmUART_RAWMSG 050000428CA41027A7B11234560601000040
   myHmUART_RSSI -66
   myHmUART_TIME 2017-08-08 19:19:02
   protLastRcv 2017-08-08 19:19:02
   protSnd    30 last_at:2017-08-08 19:19:02
   protState  CMDs_done
   rssi_HMLAN1 min:-69 max:-64 lst:-64 cnt:5 avg:-65.2
   rssi_at_HMLAN1 avg:-62.14 max:-60 min:-65 lst:-60 cnt:28
   rssi_at_myHmUART avg:-67 cnt:17 lst:-66 max:-66 min:-70
     2017-07-09 22:06:54   CommandAccepted yes
     2017-07-09 22:06:53   D-firmware      2.7
     2017-07-09 22:06:53   D-serialNr      LEQ0176739
     2017-07-09 22:07:17   PairedTo        0x123456
     2017-07-09 22:06:57   R-pairCentral   0x123456
     2017-07-09 22:07:17   RegL_00.        02:01 0A:12 0B:34 0C:56 15:FF 16:00 00:00
     2017-07-10 21:31:02   level           set_35
     2017-08-08 19:19:02   state           CMDs_done
   helper:
     HM_CMDNR   140
     cSnd       0112345627A7B10103,0112345627A7B1010E
     mId        005A
     rxType     1
     supp_Pair_Rep 0
     ack:
     expert:
       def        1
       det        0
       raw        1
       tpl        0
     io:
       newChn     +27A7B1,00,00,00
       nextSend   1502212742.92021
       rxt        0
       vccu       VCCU
       p:
         27A7B1
         00
         00
         00
       prefIO:
         HMLAN1
     mRssi:
       mNo        8C
       io:
         HMLAN1     -58
         myHmUART   -66
     prt:
       bErr       0
       sProc      0
       rspWait:
     q:
       qReqConf
       qReqStat
     role:
       dev        1
       prs        1
     rpt:
       IO         myHmUART
       flg        A
       ts         1502212742.83845
       ack:
         HASH(0x3887538)
         8C800212345627A7B100
     rssi:
       HMLAN1:
         avg        -65.2
         cnt        5
         lst        -64
         max        -64
         min        -69
       at_HMLAN1:
         avg        -62.1428571428571
         cnt        28
         lst        -60
         max        -60
         min        -65
       at_myHmUART:
         avg        -67
         cnt        17
         lst        -66
         max        -66
         min        -70
     tmpl:
   IODev      HMLAN1
   IOgrp      VCCU:HMLAN1
   expert     2_raw
   firmware   2.7
   model      HM-LC-DIM2T-SM
   room       Schlafzimmer,CUL_HM
   serialNr   LEQ0176739
   subType    dimmer
   webCmd     off:35:50:75:on
Ich möchte den Dimmer mit dem Taster betätigen. Erst mal egal ob ein oder zwei Tasten Bedienung.
Ich bekomme es nicht geregelt, weder mit pair serial oder ähnlichem.
FHEM auf Raspberry
CSM 866MHz für EM1010 mit Strom und Gaszähler
CUL 866MHz für MAX! Radiator Thermostat
CUL 433MHz für Innen und Aussen Temp
HMLAN für HM-LC-Sw1-PI-2
rvideobaer
der Taster ist mit FHEM noch nicht richtig gepairt, das muss erst durch dann kannst Du versuchen zu peeren.
Gruß Rolf
Raspberry Pi 2, HM-Uart,1x HM-LC-Sw1PBU-FM, 1x HM-RC-2-PBU-FM,1x HM-LC-SW4-DR,1x HM-LC-Sw1-Pl-DN-R1,1x HM-TC-IT-WM-W-EU, 5x HM-CC-RT-DN und noch mehr
#2
Ergänzung: Das Pairing ist offenbar begonnen aber nicht fertig. So oft den ConfigTaster drücken bis die Datenübertragung abgeschlossen ist. Eventuell auch noch ein getConfig absetzen und dann wieder configTaster.
Wenn das Pairing des Tasters ok ist kannst Du mit peerChan die beiden zusammenbringen. Oder Du nutzt ein Template in hmInfo.
herrmannj
Ein Zufall, habe das gestern auch gemacht. Musste das auch einige Male wiederholen, gern danach auch mal abwarten. Channel 2 zb wollte erst gar nicht, kam aber nach ca 30 min dann doch noch rein (peer).
So richtig warm geworden bin ich aber noch nicht mit dem Ding. Scheint mir fast etwas nutzlos ... ;) Oder ich muss noch lernen ..
Kann man mit den Channel 2..8 eigentlich aktiv was anfangen ?
