leidiges Thema, Batterieüberwachung
Begonnen von satprofi, 11 August 2017, 15:22:15
satprofi
Hallo.
habe durch Zufall, und nicht durch DOIF, erfahren das einer meiner Batterien "low" ist.
Warum bekomme ich aber keine Meldung?
Habe mal ein list angehängt
   DEF        (([":^battery:.*low"] or [":^battery:.*0"]) and [?$SELF:$DEVICE] eq "0") ( {set Telegram message @xxxxxxxxxx send 'Battery warnung "$DEVICE: $EVENT"}, {Log 3,"$DEVICE: Batteriewarnung $EVENT"}, setreading $SELF $DEVICE low)
DOELSEIF (([":^battery:.*low"] or [":^battery:.*0"]) and ([?$SELF:$DEVICE] eq "ok" or [?$SELF:$DEVICE] eq "novalue")) (setreading $SELF $DEVICE [$SELF:delayCounter])
DOELSEIF (([":^battery:.*low"] or [":^battery:.*0"]) and [?$SELF:$DEVICE] > "0" and [?$SELF:$DEVICE] <= [?$SELF:delayCounter]) (setreading $SELF $DEVICE {([$SELF:$DEVICE])-1})
DOELSEIF (([":^battery:.*ok"] or [":^battery:.*1"]) and [?$SELF:$DEVICE] ne "ok") (setreading $SELF $DEVICE ok)
   NAME       Batteriewarnung
   NR         882
   NTFY_ORDER 50-Batteriewarnung
   STATE      initialized
   TYPE       DOIF
   Readings:
     2017-07-02 13:09:03   AURIOL_9        2
     2017-04-12 19:31:32   Alarmanlage     ok
     2017-08-11 15:18:42   Device          HZ_Hobbyraum
     2017-04-12 18:51:43   HZ_Bad          ok
     2017-04-12 18:52:40   HZ_Buero        ok
     2017-04-12 18:51:23   HZ_Hobbyraum    ok
     2017-04-12 18:53:21   HZ_Schlafzimmer ok
     2017-04-12 18:51:36   HZ_Vorzimmer    ok
     2017-04-12 18:48:46   HZ_Wohnzimmer   ok
     2017-04-12 19:42:59   Hideki_30_1     ok
     2017-04-12 18:52:22   Pooltemperatur  ok
     2017-05-03 05:49:44   SD_WS07_TH_1    ok
     2017-04-12 18:46:34   TH_Sensor       ok
     2017-08-11 15:18:06   cmd             0
     2017-08-11 15:18:42   delayCounter    2
     2017-08-11 15:18:42   matched_event_c4_1 battery: ok
     2017-08-11 15:18:06   state           initialized
   Condition:
     0          (EventDoIf('',$hash,'^battery:.*low',0) or EventDoIf('',$hash,'^battery:.*0',0)) and ReadingValDoIf($hash,'Batteriewarnung','$DEVICE') eq "0"
     1          (EventDoIf('',$hash,'^battery:.*low',0) or EventDoIf('',$hash,'^battery:.*0',0)) and (ReadingValDoIf($hash,'Batteriewarnung','$DEVICE') eq "ok" or ReadingValDoIf($hash,'Batteriewarnung','$DEVICE') eq "novalue")
     2          (EventDoIf('',$hash,'^battery:.*low',0) or EventDoIf('',$hash,'^battery:.*0',0)) and ReadingValDoIf($hash,'Batteriewarnung','$DEVICE') > "0" and ReadingValDoIf($hash,'Batteriewarnung','$DEVICE') <= ReadingValDoIf($hash,'Batteriewarnung','delayCounter')
     3          (EventDoIf('',$hash,'^battery:.*ok',0) or EventDoIf('',$hash,'^battery:.*1',0)) and ReadingValDoIf($hash,'Batteriewarnung','$DEVICE') ne "ok"
   Devices:
   Do:
     0:
       0           {set Telegram message @xxxxxxxxx send 'Battery warnung "$DEVICE: $EVENT"}, {Log 3,"$DEVICE: Batteriewarnung $EVENT"}, setreading Batteriewarnung $DEVICE low
     1:
       0          setreading Batteriewarnung $DEVICE [Batteriewarnung:delayCounter]
     2:
       0          setreading Batteriewarnung $DEVICE {([Batteriewarnung:$DEVICE])-1}
     3:
       0          setreading Batteriewarnung $DEVICE ok
     4:
   Helper:
     event      battery: ok
     globalinit 1
     last_timer 0
     sleeptimer -1
     triggerDev HZ_Hobbyraum
     triggerEvents:
       actuator: 100
       battery: ok
       batteryLevel: 2.6
       desired-temp: on
       measured-temp: 24.9
       motorErr: ok
     triggerEventsState:
       actuator: 100
       battery: ok
       batteryLevel: 2.6
       desired-temp: on
       measured-temp: 24.9
       motorErr: ok
   Itimer:
   Readings:
     0           Batteriewarnung:$DEVICE
     1           Batteriewarnung:$DEVICE Batteriewarnung:$DEVICE
     2           Batteriewarnung:$DEVICE Batteriewarnung:$DEVICE Batteriewarnung:delayCounter
     3           Batteriewarnung:$DEVICE
     all         Batteriewarnung:$DEVICE Batteriewarnung:$DEVICE Batteriewarnung:$DEVICE Batteriewarnung:$DEVICE Batteriewarnung:$DEVICE Batteriewarnung:delayCounter Batteriewarnung:$DEVICE
   Regexp:
     0:
       0          :^battery:.*low
       1          :^battery:.*0
     1:
       0          :^battery:.*low
       1          :^battery:.*0
     2:
       0          :^battery:.*low
       1          :^battery:.*0
     3:
       0          :^battery:.*ok
       1          :^battery:.*1
     All:
       0          :^battery:.*low
       1          :^battery:.*0
       2          :^battery:.*ok
       3          :^battery:.*1
   State:
   Trigger:
   delayCounter 2
   do         always
   notexist   "novalue"
   room       DOIF
   userReadings delayCounter { AttrVal($name,"delayCounter",0);; }
   userattr   delayCounter
Was mich auch stutzig macht, meine ganzen Fenstersensoren FHT80 fehlen auch. vielleicht hat wer einen tipp für mich.
lg
Tasmota,LD382A,Telegram
Per
Ich sehe nicht, dass cmdState definiert wurde und
ergibt bestimmt auch nicht das Erwünschte. ne statt > wäre da angebrachter.
satprofi
das beispiel habe ich aus den firum hier übernommen, weil einfachere erst recht nicht funktionierte. danke trotzdem
Gesendet von meinem ONEPLUS A5000 mit Tapatalk
