Seit update kein zugriff auf weboberfläche
Begonnen von Badflex, 19 August 2017, 15:06:35
Badflex
Im log finde ich das.
Stimmt da was nicht mit der 01_fhemweb.pm oder Pearl?
2017.08.19 09:21:05 1: update finished, "shutdown restart" is needed to activate the changes.
2017.08.19 09:21:05 1: Please consider using the global attribute sendStatistics
2017.08.19 09:21:45 0: Server shutdown
2017.08.19 09:21:46 1: Timeout for MPD_IdleStart reached, terminated process 1086
2017.08.19 09:21:48 1: Including fhem.cfg
2017.08.19 09:21:48 1: reload: Error:Modul 01_FHEMWEB deactivated:
Too many arguments for main::TcpServer_Close at ./FHEM/01_FHEMWEB.pm line 583, near "1)"
Too many arguments for main::TcpServer_Close at ./FHEM/01_FHEMWEB.pm line 708, near "1)"
BEGIN not safe after errors--compilation aborted at ./FHEM/01_FHEMWEB.pm line 886, <$fh> line 35.
2017.08.19 09:21:48 0: Too many arguments for main::TcpServer_Close at ./FHEM/01_FHEMWEB.pm line 583, near "1)"
2017.08.19 09:21:48 1: PERL WARNING: Subroutine FHEMWEB_Initialize redefined at ./FHEM/01_FHEMWEB.pm line 125, <$fh> line 48.
2017.08.19 09:21:48 1: PERL WARNING: Subroutine FW_SecurityCheck redefined at ./FHEM/01_FHEMWEB.pm line 231, <$fh> line 48.
2017.08.19 09:21:48 1: PERL WARNING: Subroutine FW_Define redefined at ./FHEM/01_FHEMWEB.pm line 262, <$fh> line 48.
2017.08.19 09:21:48 1: PERL WARNING: Subroutine FW_Undef redefined at ./FHEM/01_FHEMWEB.pm line 297, <$fh> line 48.
BEGIN not safe after errors--compilation aborted at ./FHEM/01_FHEMWEB.pm line 886, <$fh> line 48.
2017.08.19 09:21:49 1: PERL WARNING: Subroutine FHEMWEB_Initialize redefined at ./FHEM/01_FHEMWEB.pm line 125, <$fh> line 59.
2017.08.19 09:21:49 1: PERL WARNING: Subroutine FW_SecurityCheck redefined at ./FHEM/01_FHEMWEB.pm line 231, <$fh> line 59.
2017.08.19 09:21:49 1: PERL WARNING: Subroutine FW_Define redefined at ./FHEM/01_FHEMWEB.pm line 262, <$fh> line 59.
2017.08.19 09:21:49 1: PERL WARNING: Subroutine FW_Undef redefined at ./FHEM/01_FHEMWEB.pm line 297, <$fh> line 59.
2017.08.19 09:21:49 1: reload: Error:Modul 01_FHEMWEB deactivated:
BEGIN not safe after errors--compilation aborted at ./FHEM/01_FHEMWEB.pm line 886, <$fh> line 59.
2017.08.19 09:21:49 0: Too many arguments for main::TcpServer_Close at ./FHEM/01_FHEMWEB.pm line 583, near "1)"
2017.08.19 09:21:54 1: PERL WARNING: Prototype mismatch: sub main::deg2rad ($;$) vs none at /usr/share/perl/5.20/Exporter.pm line 66, <DATA> line 129.
2017.08.19 09:21:54 1: PERL WARNING: "my" variable $host masks earlier declaration in same scope at ./FHEM/30_MilightBridge.pm line 72, <$fh> line 1204.
2017.08.19 09:21:55 1: PERL WARNING: Use of uninitialized value $port in lc at ./FHEM/42_SYSMON.pm line 192, <$fh> line 1322.
2017.08.19 09:21:57 1: PERL WARNING: Use of uninitialized value $d in hash element at fhem.pl line 4096, <$fh> line 1534.
2017.08.19 09:21:57 1: PERL WARNING: Use of uninitialized value $FW_wname in concatenation (.) or string at ./FHEM/55_GDS.pm line 662, <$fh> line 1534.
2017.08.19 09:21:58 1: Including ./log/fhem.save
2017.08.19 09:21:59 1: configfile: Cannot load module FHEMWEB
2017.08.19 09:22:02 1: usb create starting
2017.08.19 09:22:03 1: define CUL_1 CUL /dev/ttyACM1@9600 1134
2017.08.19 09:22:09 1: usb create end
Use of uninitialized value in concatenation (.) or string at ./FHEM/38_netatmo.pm line 1625.
Raspberry Pi, CUL868(SlowRF), FB 7490, SmartVisu, fast nur HomeMatic wenig FS20, Netatmo
CoolTux
Dein Update ist nicht sauber durchgelaufen. Es gab einen Abbruch. Du musst nun sehen das du irgendwie ein. Sau erwähnt Update hinbekommst.
/usr/bin/perl fhem.pl 7072 "update"
Könnte helfen.
Das TuxNet Wiki:
https://www.cooltux.net
Badflex
Hab nochmal ein update gemacht, aber leider ohne erfolg.
Im log steht jetzt:
BlockingInformParent (BlockingStart): Can't connect to localhost:40905: IO::Socket::INET: connect: Verbindungsaufbau abgelehnt
2017.08.19 17:42:37 1: BlockingInformParent (FRITZBOX_Readout_Done): Can't connect to localhost:40905: IO::Socket::INET: connect: Verbindungsaufbau abgelehnt
2017.08.19 17:42:39 1: Including fhem.cfg
woran kann das liegen?
amenomade
Badflex
Hat sich erledigt, ich habe die vorherige cfg eingespielt. Jetzt geht's wieder.
