Fehlerprotokoll beim pairen von MAX Zwischenstecker (Medion)
Begonnen von JoWiemann, 04 September 2017, 10:18:33
JoWiemann
weil etwas umfangreichen anbei das Protokoll als txt-Datei. Hier ein Auszug:
2017.09.04 09:30:32 1: readingsUpdate(,boostDuration,25) missed to call readingsBeginUpdate first.
2017.09.04 09:30:32 1:     main::CallFn                        called by /usr/share/fhem/fhem.pl (686)
2017.09.04 09:30:32 1:     main::CUL_Read                      called by /usr/share/fhem/fhem.pl (3411)
2017.09.04 09:30:32 1:     main::CUL_Parse                     called by /usr/share/fhem/FHEM/00_CUL.pm (831)
2017.09.04 09:30:32 1:     main::Dispatch                      called by /usr/share/fhem/FHEM/00_CUL.pm (947)
2017.09.04 09:30:32 1:     main::CUL_MAX_Parse                 called by /usr/share/fhem/fhem.pl (3607)
2017.09.04 09:30:32 1:     main::Dispatch                      called by /usr/share/fhem/FHEM/14_CUL_MAX.pm (374)
2017.09.04 09:30:32 1:     main::MAX_Parse                     called by /usr/share/fhem/fhem.pl (3607)
2017.09.04 09:30:32 1:     main::readingsBulkUpdate            called by /usr/share/fhem/FHEM/10_MAX.pm (782)
2017.09.04 09:30:32 1: stacktrace:
2017.09.04 09:30:32 1: readingsUpdate(,boostValveposition,80) missed to call readingsBeginUpdate first.
2017.09.04 09:30:32 1:     main::readingsBulkUpdate            called by /usr/share/fhem/FHEM/10_MAX.pm (780)
2017.09.04 09:30:32 1: readingsUpdate(,.weekProfile,444855084520452045204520452045204520452045204520452044485508452045204520452045204520452045204520452045204448546c44cc55144520452045204520452045204520452045204448546c44cc55144520452045204520452045204520452045204448546c44cc55144520452045204520452045204520452045204448546c44cc55144520452045204520452045204520452045204448546c44cc5514452045204520452045204520452045204520) missed to call readingsBeginUpdate first.
2017.09.04 09:30:32 1:     main::readingsBulkUpdate            called by /usr/share/fhem/FHEM/10_MAX.pm (779)
2017.09.04 09:30:32 1: readingsUpdate(,minimumTemperature,off) missed to call readingsBeginUpdate first.
2017.09.04 09:30:32 1:     main::readingsBulkUpdate            called by /usr/share/fhem/FHEM/10_MAX.pm (778)
2017.09.04 09:30:32 1: readingsUpdate(,maximumTemperature,on) missed to call readingsBeginUpdate first.
2017.09.04 09:30:32 1:     main::readingsBulkUpdate            called by /usr/share/fhem/FHEM/10_MAX.pm (777)
2017.09.04 09:30:32 1: readingsUpdate(,comfortTemperature,21.0) missed to call readingsBeginUpdate first.
2017.09.04 09:30:32 1:     main::readingsBulkUpdate            called by /usr/share/fhem/FHEM/10_MAX.pm (776)
2017.09.04 09:30:32 1: readingsUpdate(,ecoTemperature,17.0) missed to call readingsBeginUpdate first.
2017.09.04 09:30:32 1: PERL WARNING: Use of uninitialized value $name in concatenation (.) or string at /usr/share/fhem/fhem.pl line 4335.
2017.09.04 09:30:32 1:     main::readingsBeginUpdate           called by /usr/share/fhem/FHEM/10_MAX.pm (642)
2017.09.04 09:30:32 1: ERROR: empty name in readingsBeginUpdate
2017.09.04 09:30:32 3: CUL_MAX_Parse: Pairing device 0929ff of type HeatingThermostat with serial KEQ9008970
Über eine Fehlerkorrektur würde ich mich freuen.
Grüße Jörg
Jörg Wiemann
