FHZ1000 on OpenWRT
Begonnen von Guest, 15 April 2012, 15:29:52
Guest
Hi Everybody,
I'm trying to run FHZ1000 on OpenWRT, but I'm facing well know problem
of missing SerialPort module in Perl.
I'm using Backfire 10.3.1
I see that problem has been fixed for CUL, but can I do with FHZ?
Any solutions?
Greetings
Guest
Am Sonntag, 15. April 2012 15:29:52 UTC+2 schrieb Kissiel:
> Any solutions?
Why do you think there is a problem and that this is or was broken?
CUL and new modules now uses DevIo.pm which itself also uses SerialPort:
"require Device::SerialPort;"
Some modules like 00_FHZ.pm have not been changed but this does not make
any difference on the requirement of SerialPort.
You need the serial port module in perl. See http://fhem.de/HOWTO.html for
further help.
Guest
For a CUL Device the perl module Device::SerialPort is not always required.
The FHEM Wiki describes the use of ser2net to avoid this requirement:
http://fhemwiki.de/wiki/OpenWRT
However this does not work for FHZ, as far as I know.
But you can build the perl module Device::SerialPort following this guide:
http://www.he1ix.org/tag/openwrt/
Take the Makefile from here:
http://tcb.udarknet.com/dokuwiki/doku.php/projects/securouter/openwrt
I was able to build the module for a TP-LINK TL-WR1043ND:
http://wiki.openwrt.org/toh/tp-link/tl-wr1043nd
So if your router is also ar71xx based, I could also provide you the
binaries.
Just let me know.
Am Sonntag, 15. April 2012 16:38:26 UTC+2 schrieb Willi:
>> Any solutions?
> further help.
Guest
PanTau,
Could you please send me the compiled binaries made by you?
My email address is: hodosiszabolcs@gmail.com
Thank you very much in advance,
Szabi
Guest
Good time of day!
Can you please put this ipk somewhere on the net or in attach to this group
reply?
It will be great help not only for me, but also for others, starving to
have this module available on their ar71xx based devices ;))
Thanks a lot!
Ivan
воскресенье, 15 апреля 2012 г., 23:15:03 UTC+3 пользователь PanTau написал:
> binaries.
> Just let me know.
>>> Any solutions?
>> further help.
Guest
Just in case, I'll put this IPK here.
Compiled for ar71xx, target WR703N.
If opkg complains, you can extract stuff from IPK by these steps:
tar xvzf package.ipk
tar xvzf data.tar.gz
then you will have usr/ dir extracted (.pm and .so are there, copy to
appropriate locations)
Good luck!
Best,
Ivan
>>> further help.
Guest
Sorry, can't attach... Bad Google, no cookie!!! :)))
So, here we go:
https://www.dropbox.com/s/a3xpbl8cu7hkmw5/perl-device-serialport_1.04-2_ar71xx.ipk
f40f7b9974431426e6fa1b9079093240  perl-device-serialport_1.04-2_ar71xx.ipk
Thank you,
Ivan
пятница, 28 декабря 2012 г., 21:50:43 UTC+2 пользователь Ivan написал:
> Good luck!
> Best,
> Ivan
>>>> further help.
