[Gelöst]Fehler DbRep bei get svrinfo im Log
Begonnen von Deckoffizier, 17 September 2017, 18:15:00
Deckoffizier
Hallo in die Runde,
wie oben beschrieben bekomme ich folgende Fehlermeldung
Can't locate object method "sqlite_db_filename" via package "DBI::db" at ./FHEM/93_DbRep.pm line 3946.
konnte bisher hierzu leider nichts finden was eventuell schief läuft.
Hat von Euch hierzu jemand eine Idee?
hierzu mal ein List
   DATABASE   /opt/fhem/fhem.db
   DEF        myDbLog
   LASTCMD    svrinfo
   NAME       repmyDB
   NOTIFYDEV  global,repmyDB
   NR         291
   NTFY_ORDER 50-repmyDB
   ROLE       Client
   STATE      running
   TYPE       DbRep
   UTF8       0
   VERSION    5.6.2
   HELPER:
     DBLOGDEVICE myDbLog
     RUNNING_PID:
       abortFn    ParseAborted
       arg        repmyDB|svrinfo
       bc_pid     28228
       finishFn   dbmeta_ParseDone
       fn         dbmeta_DoParse
       pid        DEAD:28252
       timeout    86400
       abortArg:
   Helper:
     DBLOG:
       SizeDbBegin_MB:
         myDbLog:
           TIME       1505651799.23155
           VALUE      43
       SizeDbEnd_MB:
         myDbLog:
           VALUE      43
       state:
         myDbLog:
           TIME       1505663644.70345
           VALUE      running
     2017-09-17 17:54:04   state           running
   dbloghash:
     CFGFN
     COLUMNS    field length used for Device: 64, Type: 64, Event: 512, Reading: 64, Value: 128, Unit: 32
     CONFIGURATION ./db.conf
     DEF        ./db.conf .*:.*
     MODE       asynchronous
     MODEL      SQLITE
     NAME       myDbLog
     NR         375
     NTFY_ORDER 50-myDbLog
     PID        2093
     REGEXP     .*:.*
     STATE      connected
     TYPE       DbLog
     VERSION    2.22.3
     dbconn     SQLite:dbname=/opt/fhem/fhem.db
     dbuser
     HELPER:
       COLSET     1
       DELDAYS    2
       DEVICECOL  64
       EVENTCOL   512
       OLDSTATE   connected
       READINGCOL 64
       TYPECOL    64
       UNITCOL    32
       VALUECOL   128
       REDUCELOG:
         myDbLog
         reduceLogNbl
         2
     Helper:
       DBLOG:
         CacheUsage:
           myDbLog:
             TIME       1505506583.50332
             VALUE      18
         DbFileSize:
           myDbLog:
             TIME       1505455385.51789
             VALUE      68
         lastRowsDeleted:
           myDbLog:
             TIME       1505455297.53376
             VALUE      0
         reduceLogState:
           myDbLog:
             VALUE      DBD::SQLite::st execute failed
         state:
           myDbLog:
             TIME       1505506462.96038
             VALUE      connected
       2017-09-17 18:12:33   CacheUsage      0
       2017-09-17 14:33:29   DbFileSize      96
       2017-09-17 18:12:33   NextSync        2017-09-17 18:13:03 or if CacheUsage 50 reached
       2017-09-17 14:35:35   lastRowsDeleted 22270
       2017-09-17 14:33:29   reduceLogState  Rows processed: 309634, deleted: 287829, time: 129.73sec
       2017-09-17 18:12:33   state           connected
     cache:
       index      53704
       memcache:
   allowDeletion 1
   room       Entwicklung
Hans-Jürgen
FHEM 5.8 auf "yakkaroo Emu A1FL.1" mit CUL 868MHz, SIGNALduino,2 1Wire USB Busmaster, diverse 1 Wire Sensoren,Landroid,Aeotec USB Dongle Z-Wave Plus
DS_Starter
Hallo Hans-Jürgen,
das könnte an einer zu niedrigen Treiber-Version liegen.
Es ist zumindest in der 1.54 enthalten -> http://search.cpan.org/~ishigaki/DBD-SQLite-1.54/lib/DBD/SQLite.pm
Die DBD für SQLite wird installiert mit :
sudo apt-get install libdbd-sqlite3-perl
Heiko
Deckoffizier
Hallo DS_Starter,
tut mir leid aber bekomme bei mir nur nach
wie ist schon die neuste Version.
Dann update und upgrade auf dem pi gemacht und noch mal von vorne  selbe Meldung.
Bin jetzt erstmal ratlos :-).
Hans-Jürgen
DS_Starter
Prüfe mal welche DBD::SQLite Version du hast.
Kannst du machen mit:
perl -MDBD::SQLite -le "print(DBD::SQLite->VERSION)"
Bei mir wird diese Version angezeigt:
heiko@fhemtest:~$ perl -MDBD::SQLite -le "print(DBD::SQLite->VERSION)"
1.44
Und jetzt noch die DBI Version:
heiko@fhemtest:~$ perl -MDBI -le "print(DBI->VERSION)"
1.631
Falls die Versionen niedriger sind als meine, könntest du versuchen sie mit CPAN upzudaten.
Wie die genaue Syntax dazu ist müsste ich aber auch erst googlen, ich verwende CPAN nicht damit alle Module mit apt-get upgedatet werden.
Heiko
Deckoffizier
Hallo Heiko,
stark ! Du bist ja noch am Ball.
Die Perl Version ist bei mir 1.37.
Die DBI Version ist 1.622.
Hans-Jürgen
DS_Starter
#5
ZitatDu bist ja noch am Ball.
War nur etwas abgelenkt weil ich gesetrn wieder mal an meinem SSCam-Modul geschraubt habe  ;)
ZitatDie Perl Version ist bei mir 1.37
Du meinst sicher die DBD-Version. Das würde meine Vermutung bestätigen dass die Version zu niedrig ist weil die besagte Methode fehlt.
Schau mal ob du mit CPAN zurecht kommst (falls du es machen willst). Musst du ein bisschen googeln ...
EDIT: Vielleicht reicht schon ein cpan -i DBD::SQLite
Heiko
Deckoffizier
Hallo Heiko,
Wunderbar hat auf Anhieb mit Deinem Tipp
cpan -i DBD::SQLite auf meinem Raspberry geklappt.
DANKE!
Grüße von
Hans-Jürgen
