fhem stops after couple minutes
Begonnen von Guest, 20 April 2012, 15:32:12
Guest
Willi,
That works I think only get one error, I think RFXMeter something? I
get no values of my water
 Use of uninitialized value $_[0] in bitwise and (&) at /usr/share/
fhem/FHEM/41_OREGON.pm line 99.
Use of uninitialized value $_[0] in bitwise and (&) at /usr/share/fhem/
FHEM/41_OREGON.pm line 102.
Use of uninitialized value $rname in string ne at /usr/share/fhem/FHEM/
93_FHEM2FHEM.pm line 152.
   CODE       00
   DEF        00 0.5 ltr
   NAME       RFXWater
   NR         11
   STATE      ???
   TYPE       RFXMETER
   scalefactor 0.5
   unitname   ltr
   room       Meterkast
 define RFXWater RFXMETER 00 0.5 ltr
On 21 apr, 11:28, Willi wrote:
> Hello Richard,
> the new TRX module for RFXtrx433 transmitter (new protocol) works with
> FHEM2FHEM raw. I use it daily and without any stability problems.
> The old RFXCOM receiver module currently does not work with
> FHEM2FHEM:raw. Reason is that the receiver transmits binary data that can
> not be handled by FHEM2FHEM:raw. FHEM2FHEM only allows to transfer
> Ascii-Data.
> Fixing this is easy. I just have to convert to Ascii HEX for this as I
> already use for the TRX module.
> I will hopefully change this, test is and put this to FHEM SVN next week.
> After I have done the changes, do an updatefhem and you may use is as
> follows.
> In order to get it run, use dummy. Also you can not use the name Buitentemp
> as FHEM2FHEM definition and OREGON device. Use different names
> define RFXCOM RFXCOM none noninit
> attr RFXCOM dummy 1
> define ds3 FHEM2FHEM 192.168.169.196:7072 RAW:RFXCOM
> If you enable autocreate you will see all devices as expected.
> Regards
> Willi
> Am Freitag, 20. April 2012 22:07:44 UTC+2 schrieb kroonen:
> > Rudolf ,
> > I want messages from an rfxcom device
> > Is it possible to recieve messages on an remote fhem, with fhem
> > without having an rfxcom reciever on the other side??
> > Should I define a rfxcom as kind of dummy? Or an the network rfxcom
> > with noinit????
> > I have this
> > define RFXCOM RFXCOM 127.0.0.1:10001 noinit
> > define Buitentemp FHEM2FHEM 192.168.2.5:7072 RAW:RFXCOM
> > define Buitentemp OREGON THGR228N_bb
> > still this error
> > 93_FHEM2FHEM.pm line 153.
> > regards Richard
Guest
Hello Richard,
FHEM2FHEM:raw does not pass all binary data.
As I stated I have to change my modules for the old RFXCOM driver to pass a
hexstring instead of binary.
I did the changes some minutes ago and I am currently doing the tests.
I will send you the modules as a PM if you want to test.
Regards Willi
Am Samstag, 21. April 2012 22:19:49 UTC+2 schrieb kroonen:
> Willi,
> Internals:
>    CODE       00
>    DEF        00 0.5 ltr
>    NAME       RFXWater
>    NR         11
>    STATE      ???
>    TYPE       RFXMETER
>    scalefactor 0.5
>    unitname   ltr
> Attributes:
>    room       Meterkast
> > Hello Richard,
> can
> > Ascii-Data.
> week.
> > follows.
> Buitentemp
> > attr RFXCOM dummy 1
> > Regards
> > Willi
> > > Rudolf ,
> > > with noinit????
> > > I have this
> > > still this error
> > > regards Richard
Guest
Changes for the RFXCOM modules to work with FHEM2FHEM has been done and
tested. RFXCOM has been also changed to use DevIO.pm.
I have checked it into FHEMs SVN some minutes ago.
You may use it tomorrow via updatefhem.
