fhem stops after couple minutes
Begonnen von Guest, 20 April 2012, 15:32:12
Guest
After a couple minutes, my fhem crashes. I dit an updatefhem today and
after that it is not stable.
I recieve this error
Can't use string ("fake") as a HASH ref while "strict refs" in use at /
usr/bin/fhem.pl line 2210.
and  fhem is stopped
logging doesn't say anything
2012.04.20 15:25:41 3: FHEM2FHEM opening Schuurtemp at
192.168.2.150:7072
2012.04.20 15:25:41 3: FHEM2FHEM device opened (Schuurtemp)
2012.04.20 15:25:41 3: RFXCOM opening RFXCOM device /dev/rfxcom
2012.04.20 15:25:41 1: RFXCOM: RFXCOM_OpenDev /dev/rfxcom done
2012.04.20 15:25:41 3: RFXCOM: device opened
2012.04.20 15:25:42 1: RFXCOM: Init OK
2012.04.20 15:25:42 2: FHEMWEB port 8083 opened
2012.04.20 15:25:42 2: FHEMWEB port 8084 opened
2012.04.20 15:25:42 2: FHEMWEB port 8085 opened
2012.04.20 15:25:43 0: Server started (version 5.2+SVN from 2012-04-18
($Id: fhem.pl 1462 2012-04-17 11:10:32Z rudolfkoenig $), pid 9798)
regards Richard
As you know, the info supplied is not enough to reproduce the problem, so all
we can do now is to feel sorry for you...
erwin
Same Problem here,
coming back after a week of vacation - fhem was running perfect....
i have not done any changes -
just updated fhem this afternoon with updatefhem...
SAME MESSAGE:
Use of implicit split to @_ is deprecated at /opt/lib/FHEM/95_FLOORPLAN.pm
line 411, <$fh> line 463.
*Can't use string ("fake") as a HASH ref while "strict refs" in use at
/opt/bin/fhem.pl line 2210.*
... and fhem terminates after the second message..., approx 15 seconds
after starting. - even when not doing any access thru WEB or Telnet.
i suspect something wrong with floorplan, but i did not get thru....
Log verbose 5 dos not show anything unusual, i post here just the last few
lines....
2012.04.20 17:55:10 5: Executing INSERT INTO current(TIMESTAMP, DEVICE,
TYPE, EVENT, READING, VALUE, UNIT) VALUES ('2012-04-20 17:55:10',
'Wohnzimmer_Thermostat', 'FHT', 'actuator: 0%', 'actuator', '0', '%')
2012.04.20 17:55:10 5: Wohnzimmer_Thermostat trigger: Checking
FileLog_AussenTempHum for notify
2012.04.20 17:55:15 5: FHEM2FHEM/RAW: /dummy WLANstatus ErwinatHome 0
2012.04.20 17:55:15 4: FB_FHEM: dummy WLANstatus ErwinatHome 0
the last line obviously causes fhem to crash.
thanks for yr. support.
Am Freitag, 20. April 2012 16:08:36 UTC+2 schrieb Rudolf Koenig:
> all
FHEM aktuell auf RaspberryPI Mdl 1-4
Maintainer: 00_KNXIO.pm 10_KNX.pm
User: CUNO2 (868 SLOWRF) - HMS100xx, FS20, FHT, 1-Wire  - 2401(iButton), 18x20, 2406, 2413 (AVR), 2450,..,MQTT2, KNX, SONOFF, mySENSORS,....
Hardware:  Busware ROT, Weinzierl IP731, 1-Wire GW,...
Guest
Am Freitag, 20. April 2012 18:18:31 UTC+2 schrieb Erwin:
> Don't think so. Line 411 is a regular split, nothing special about it:
 my $cols = ($cmdlist ? (split(":", $cmdlist)) : 0);
Especially, this line hasn't changed.
Maybe there is the same root cause for this effect?
https://groups.google.com/d/msg/fhem-users/UY3DgEl4D6I/E5EryqAFNnAJ
Cheers, Uli
erwin
Sorry Uli,
stimmt es liegt nicht an Floorplan,
hab jetzt mittlerweile "verdächtige Module" aus meiner Konfig entfernt,
... eins nach dem anderen, also nach der Ausschluß-Methode.....
schaut für mich so aus, als ob FHEM2FHEM der Bösewicht ist....
.... damit kann ich eine Zeitlang leben, das ist nicht soo dringend,
Hauptsache FHEM läuft wieder....
Am Freitag, 20. April 2012 18:26:59 UTC+2 schrieb UliM:
> Cheers, Uli
Welche Version haben die jeweiligen Installationen?
Kannst Du mir die beiden fhem.cfg Dateien perl PM zuschicken?
erwin
...email ist unterwegs...
danke
erwin
Am Freitag, 20. April 2012 19:38:26 UTC+2 schrieb Rudolf Koenig:
> > schaut f�r mich so aus, als ob FHEM2FHEM der B�sewicht ist....
Guest
Rudolf,
It looks like when I try to use fhem2fhem, the errors happens
when I do
define Buitentemp FHEM2FHEM 192.168.2.5:7072 LOG:.*
I get this error
when I do
define Buitentemp FHEM2FHEM 192.168.2.5:7072 RAW:CUL
I get
 telUse of uninitialized value $rname in string ne at /usr/share/fhem/
FHEM/93_FHEM2FHEM.pm line 153.
Use of uninitialized value $rname in string ne at /usr/share/fhem/FHEM/
neUse of uninitialized value $rname in string ne at /usr/share/fhem/
regards RIchard
Occured if a LOG type FHEM2FHEM device received a message, and it was caused by
the recent STATE -> state change. It was buggy before the change too, but due
to the wrong spelling nobody noticed it :)
I fixed it, tested it, and put it into to the SVN. Available via updatefhem
tomomorrow, as usual.
This should be fixed.
You have to define the CUL on both instances (possibly with device none on the
receiver), although the define should check for this problem.
I've get no errors right now with my FHEM2FHEM RAW setup here, so I wonder what
went wrong there.
Guest
Rudolf ,
I want messages from an rfxcom device
Is it possible to recieve messages on an remote fhem, with fhem
without having an rfxcom reciever on the other side??
Should I define a rfxcom as kind of dummy? Or an the network rfxcom
with noinit????
I have this
define RFXCOM RFXCOM 127.0.0.1:10001 noinit
define Buitentemp FHEM2FHEM 192.168.2.5:7072 RAW:RFXCOM
define Buitentemp OREGON THGR228N_bb
still this error
regards Richard
> went wrong there.
Guest
Sorry, found a little bit but still errors. I defined this
define RFXCOM RFXCOM none
I get many new devices in the log
2012.04.20 22:34:52 3: RFXCOM: Unknown OREGON device detected, define
one to get detailed information.
2012.04.20 22:34:55 3: RFXCOM: Unknown OREGON device detected, define
2012.04.20 22:34:56 3: RFXCOM: Unknown OREGON device detected, define
2012.04.20 22:34:57 3: RFXCOM: Unknown OREGON device detected, define
2012.04.20 22:34:58 3: RFXCOM: Unknown OREGON device detected, define
I don't get temperatur ehumidity readings, as on the local fhem?
fhem> l Buitentemp
   Clients    :RFXMETER:OREGON:RFXX10REC:RFXELSE:
   DEF        192.168.2.5:7072 RAW:RFXCOM
   FD         9
   Host       192.168.2.5:7072
   NAME       Buitentemp
   NR         8
   PARTIAL
   STATE      connected
   TYPE       FHEM2FHEM
   informType RAW
   rawDevice  RFXCOM
Local fhem with real rfxcom
fhem> l Buitentemp
   CODE       THGR228N_bb
   DEF        THGR228N_bb
   IODev      RFXCOM
   NAME       Buitentemp
   NR         51
   STATE      T: 7.7  H: 65
   TIME       2012-04-20 22:37:39
   TYPE       OREGON
   CHANGETIME:
   Readings:
     2012-04-20 22:37:39   battery         10
     2012-04-20 22:37:39   humidity        65
     2012-04-20 22:37:39   temperature     7.7
On 20 apr, 22:07, kroonen wrote:
> Rudolf ,
> with noinit????
> I have this
> still this error
> regards Richard
> > went wrong there.
I'm afraid you have to ask the RFXCOM author about this.
In general it is like documented in commandref.html:
- you can use FHEM2FHEM in LOG mode with each device
- using it in RAW mode is supported right now with the 2-tier modules only, as
  some logic is handled by the Dispatch function.
erwin
Hi Rudi,
i can confirm that FHEM2FHEM is working after applying the fix.
Thx. again for yr. support.
erwin
Am Freitag, 20. April 2012 21:21:14 UTC+2 schrieb Rudolf Koenig:
> the
> what
> went wrong there.
Guest
Hello Richard,
the new TRX module for RFXtrx433 transmitter (new protocol) works with
FHEM2FHEM raw. I use it daily and without any stability problems.
The old RFXCOM receiver module currently does not work with
FHEM2FHEM:raw. Reason is that the receiver transmits binary data that can
not be handled by FHEM2FHEM:raw. FHEM2FHEM only allows to transfer
Ascii-Data.
Fixing this is easy. I just have to convert to Ascii HEX for this as I
already use for the TRX module.
I will hopefully change this, test is and put this to FHEM SVN next week.
After I have done the changes, do an updatefhem and you may use is as
follows.
In order to get it run, use dummy. Also you can not use the name Buitentemp
as FHEM2FHEM definition and OREGON device. Use different names
define RFXCOM RFXCOM none noninit
attr RFXCOM dummy 1
define ds3 FHEM2FHEM 192.168.169.196:7072 RAW:RFXCOM
If you enable autocreate you will see all devices as expected.
Regards
Willi
Am Freitag, 20. April 2012 22:07:44 UTC+2 schrieb kroonen:
> Rudolf ,
> with noinit????
> I have this
> still this error
> regards Richard
