New attribute group
Begonnen von Dr. Boris Neubert, 01 Mai 2012, 12:45:08
Dr. Boris Neubert
Rudi and me implemented a new attribute /group/.
group
Group devices. Recognized by web-pgm2 (module
FHEMWEB), it makes devices
in the same group appear in the same box. This is used to further group
devices together. A device can appear in more than one group, in this
case the groups have to be specified comma-separated. If this attribute
is not set then the device type is used as the grouping attribute.
Example:
        attr MyFunnyDevice1 group Lighting
      attr MyFunnyDevice2 group Switches,BathRoom
Kind regards
Boris
Guest
Hi!
Use of uninitialized value in concatenation (.) or string at
/usr/bin/fhem.pl line 1534, <$fh> line 5.
Am Dienstag, 1. Mai 2012 12:45:08 UTC+2 schrieb Boris:
>  Hi,
> Rudi and me implemented a new attribute *group*.
> group
> Group devices. Recognized by web-pgm2 (module FHEMWEB),
> it makes devices in the same group appear in the same box. This is used to
> further group devices together. A device can appear in more than one group,
> in this case the groups have to be specified comma-separated. If this
> attribute is not set then the device type is used as the grouping
> attribute.
> Example:
> Kind regards
> Boris
Dr. Boris Neubert
Am 01.05.2012 14:58, schrieb ilmtuelp0815:
aha.
bn
Guest
Am Dienstag, 1. Mai 2012 16:03:43 UTC+2 schrieb Boris:
> aha.
> bn
> Hi,
habe eben ein shutdown restar gemacht.
Auch bei mir diese Meldung dutzendfach im Log.
Gruß, Uli
2012.05.01 18:39:54 0: Server started (version 5.2+SVN from 2012-04-27
($Id: fhem.pl 1488 2012-04-26 16:47:12Z borisneubert $), pid 4838)
Use of uninitialized value $_ in pattern match (m//) at
/var/InternerSpeicher/fhem/FHEM/01_FHEMWEB.pm line 940.
Dr. Boris Neubert
wer soll denn etwas mit diesen Meldungen anfangen. Bitte meeeeehr Input, am besten die fragliche Stelle mit Logs pflastern und die Ursache ergründen.
Boris
>> aha.
>> bn
>> Hi,
>Gruß, Uli
Diese Nachricht wurde von meinem WePad mit K-9 Mail gesendet.
LuckyDay
2012.05.01 13:29:13 0: Server started (version 5.2+SVN from 2012-05-01
($Id: fhem.pl 1508 2012-04-30 07:23:43Z rudolfkoenig $), pid 8390)
vielleicht hilft das
alte fhem.pl
On 1 Mai, 19:31, Boris Neubert wrote:
> Hallo,
> Viele Grüße
> Boris
> >> aha.
> >> bn
> >> Hi,
> >Gruß, Uli
