Revision 15386: fhemweb_iconRadio.js: add a user defined class to svg icons by prefix ...
Begonnen von System, 03 November 2017, 21:01:09
System
fhemweb_iconRadio.js: add a user defined class to svg icons by prefix class<classname>@, improved matching for a numeric sequence of compare values, color numbers are now case insensitive, fhemweb_iconButtons.js, fhemweb_iconLabel.js, fhemweb_iconSwitch.js: add a user defined class to svg icons by prefix class<classname>@, color numbers are now case insensitive
Source: Revision 15386: fhemweb_iconRadio.js: add a user defined class to svg icons by prefix ...
