Sonos läuft nicht mehr
Begonnen von fini, 06 November 2017, 08:27:18
fini
Das Sonos Device ist aus Fhem verschwunden.
keine Ahnung wie lange Sonos nicht mehr läuft.
Habe auch nicht neues eingerichtet...
Das steht im Log nach den Fhem Neustart:
2017.11.06 08:17:52 0: Server shutdown
2017.11.06 08:17:52 1: HMCCU: Deregistering RPC server http://192.168.178.41:7411/fh2001 at http://192.168.178.116:2001/
2017.11.06 08:17:52 0: HMCCU: Stopping RPC server CB2001 with PID 3997
2017.11.06 08:17:52 0: CCURPC: CB2001 Server loop terminated
2017.11.06 08:17:52 2: CCURPC: Eventcount DD = 0
2017.11.06 08:17:52 2: CCURPC: Eventcount EV = 318
2017.11.06 08:17:52 2: CCURPC: Eventcount EX = 1
2017.11.06 08:17:52 2: CCURPC: Eventcount IN = 1
2017.11.06 08:17:52 2: CCURPC: Eventcount ND = 102
2017.11.06 08:17:52 2: CCURPC: Eventcount RA = 0
2017.11.06 08:17:52 2: CCURPC: Eventcount RD = 0
2017.11.06 08:17:52 2: CCURPC: Eventcount SL = 1
2017.11.06 08:17:52 2: CCURPC: Eventcount UD = 0
2017.11.06 08:17:52 2: CCURPC: Eventcount total = 423
2017.11.06 08:17:52 2: CCURPC: Eventcount writeerror = 0
2017.11.06 08:17:58 1: reload: Error:Modul 99_myutils deactivated:
2017.11.06 08:17:58 1: Including fhem.cfg
2017.11.06 08:17:58 3: telnetPort: port 7072 opened
2017.11.06 08:17:59 3: WEB: port 8083 opened
2017.11.06 08:17:59 3: WEBphone: port 8084 opened
2017.11.06 08:17:59 3: WEBtablet: port 8085 opened
2017.11.06 08:17:59 2: eventTypes: loaded 2200 events from ./log/eventTypes.txt
2017.11.06 08:17:59 3: HUEDevice4: I/O device is hueBridge1
2017.11.06 08:17:59 3: HUEDevice5: I/O device is hueBridge1
2017.11.06 08:17:59 3: HUEDevice2: I/O device is hueBridge1
2017.11.06 08:17:59 3: HUEDevice1: I/O device is hueBridge1
2017.11.06 08:17:59 3: HUEDevice3: I/O device is hueBridge1
2017.11.06 08:17:59 3: HUEGroup2: I/O device is hueBridge1
2017.11.06 08:17:59 3: HUEGroup1: I/O device is hueBridge1
2017.11.06 08:17:59 3: HUEGroup0: I/O device is hueBridge1
2017.11.06 08:17:59 3: TABLETUI: new ext defined infix:ftui/: dir:./www/tablet:
2017.11.06 08:17:59 3: Registering HTTPSRV TABLETUI for URL /ftui   and assigned link ftui/ ...
2017.11.06 08:18:00 3: Opening Fritz_Box_Monitor device 192.168.178.1:1012
2017.11.06 08:18:02 1: HMCCU: Device d_ccu. Initialized version 4.1
2017.11.06 08:18:02 2: HMCCU: Duplicate name for device/channel Sromz�hler1 address=MEQ1125981:1 in CCU.
2017.11.06 08:18:02 2: HMCCU: Duplicate name for device/channel Heizung Wohnzimmer address=NEQ0414827:4 in CCU.
2017.11.06 08:18:02 2: HMCCU: Duplicate name for device/channel Rolladen_K�che_Fenster address=NEQ1367309 in CCU.
2017.11.06 08:18:02 2: HMCCU: Duplicate name for device/channel Wandthermostat address=MEQ1842790 in CCU.
2017.11.06 08:18:02 2: HMCCU: Duplicate name for device/channel Rolladen_K�che_T�r address=NEQ1367209:1 in CCU.
2017.11.06 08:18:02 1: HMCCU: Read 11 devices with 109 channels from CCU 192.168.178.116
2017.11.06 08:18:03 3: HUEDevice6: I/O device is hueBridge1
2017.11.06 08:18:03 3: HUEDevice7: I/O device is hueBridge1
2017.11.06 08:18:03 3: HUEDevice8: I/O device is hueBridge1
2017.11.06 08:18:03 3: HUEGroup3: I/O device is hueBridge1
2017.11.06 08:18:03 3: bewegungsmelder_1: I/O device is hueBridge1
2017.11.06 08:18:03 3: licht_hue: I/O device is hueBridge1
2017.11.06 08:18:03 3: hue_2: I/O device is hueBridge1
2017.11.06 08:18:03 3: hue_3: I/O device is hueBridge1
2017.11.06 08:18:03 3: hue_4: I/O device is hueBridge1
2017.11.06 08:18:03 3: hue_5: I/O device is hueBridge1
2017.11.06 08:18:03 3: hue_6: I/O device is hueBridge1
2017.11.06 08:18:03 3: hue_bewegungsmelder1_temp: I/O device is hueBridge1
2017.11.06 08:18:03 3: hue_bewegungsmelder1: I/O device is hueBridge1
2017.11.06 08:18:03 3: hue_bewegungsmelder1_helligkeit: I/O device is hueBridge1
2017.11.06 08:18:03 1: termo1: no I/O device
2017.11.06 08:18:03 1: temp_dachboden: no I/O device
2017.11.06 08:18:03 1: temp_kueche: no I/O device
2017.11.06 08:18:03 1: temp_hw: no I/O device
2017.11.06 08:18:03 1: temp_schlaf: no I/O device
2017.11.06 08:18:03 1: temp_arbeit: no I/O device
2017.11.06 08:18:03 3: HUEGroup4: I/O device is hueBridge1
2017.11.06 08:18:03 3: HUEDevice9: I/O device is hueBridge1
2017.11.06 08:18:03 3: Tanken_Team: Defined with URL http://www.clever-tanken.de/tankstelle_details/43329 and interval 600
2017.11.06 08:18:04 3: HUEDevice10: I/O device is hueBridge1
2017.11.06 08:18:04 3: HUEGroup5: I/O device is hueBridge1
2017.11.06 08:18:04 1: Including ./log/fhem.save
2017.11.06 08:18:04 3: No I/O device found for temp_arbeit
2017.11.06 08:18:04 3: No I/O device found for Steckdose1
2017.11.06 08:18:04 3: No I/O device found for temp_kueche
2017.11.06 08:18:04 3: No I/O device found for temp_schlaf
2017.11.06 08:18:04 3: No I/O device found for temp_hw
2017.11.06 08:18:04 3: No I/O device found for termo1
2017.11.06 08:18:04 3: No I/O device found for temp_dachboden
2017.11.06 08:18:04 3: aussen: I/O device is Netatmo
2017.11.06 08:18:05 0: HMCCU: Start of RPC server after FHEM initialization in 12 seconds
2017.11.06 08:18:06 1: usb create starting
2017.11.06 08:18:06 3: Probing CUL device /dev/ttyAMA0
2017.11.06 08:18:06 1: PERL WARNING: Bareword found where operator expected at /usr/lib/arm-linux-gnueabihf/perl5/5.20/Device/SerialPort.pm line 133, near ""cfg_param_! CVG]2 5> "cfg_param_2"
2017.11.06 08:18:06 1: PERL WARNING: (Missing operator before cfg_param_2?)
2017.11.06 08:18:06 1: Unrecognized character \x02; marked by <-- HERE after "C^CFLAG",<-- HERE near column 18 at /usr/lib/arm-linux-gnueabihf/perl5/5.20/Device/SerialPort.pm line 138.
Compilation failed in require at ./FHEM/DevIo.pm line 391.
2017.11.06 08:18:06 3: Can't connect to /dev/ttyAMA0: Unrecognized character \x02; marked by <-- HERE after "C^CFLAG",<-- HERE near column 18 at /usr/lib/arm-linux-gnueabihf/perl5/5.20/Device/SerialPort.pm line 138.
2017.11.06 08:18:06 1: usb create end
2017.11.06 08:18:06 3: innen: I/O device is Netatmo
2017.11.06 08:18:06 3: netatmo_C70_ee_50_21_d9_fc pingCamera (cameraping)
2017.11.06 08:18:06 3: netatmo_C70_ee_50_2a_1f_ba pingCamera (cameraping)
2017.11.06 08:18:06 3: netatmo_H598793fafb7ecf00668b4b62 initHome (gethomedata)
2017.11.06 08:18:06 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/38_netatmo.pm line 1655.
2017.11.06 08:18:06 3: netatmo_M05_00_00_03_9c_9e: I/O device is Netatmo
2017.11.06 08:18:06 3: wetter_duchschnitt: poll (PUBLIC)
2017.11.06 08:18:06 3: wetter_duchschnitt getPublicDevices (53.6261395,12.8107535 / 53.4661395,12.6507535)
2017.11.06 08:18:06 0: Featurelevel: 5.8
2017.11.06 08:18:06 0: Server started with 121 defined entities (fhem.pl:14834/2017-08-02 perl:5.020002 os:linux user:fhem pid:4346)
2017.11.06 08:18:06 3: telnetForBlockingFn_1509952686: port 44101 opened
Can't locate Encode/Locale.pm in @INC (you may need to install the Encode::Locale module) (@INC contains: . /etc/perl /usr/local/lib/arm-linux-gnueabihf/perl/5.20.2 /usr/local/share/perl/5.20.2 /usr/lib/arm-linux-gnueabihf/perl5/5.20 /usr/share/perl5 /usr/lib/arm-linux-gnueabihf/perl/5.20 /usr/share/perl/5.20 /usr/local/lib/site_perl ./FHEM) at /usr/share/perl5/LWP/UserAgent.pm line 1002.
2017.11.06 08:18:06 3: Fritz_Box_Monitor device opened
2017.11.06 08:18:07 2: netatmo_C70_ee_50_21_d9_fc: invalid json detected
2017.11.06 08:18:07 2: netatmo_C70_ee_50_2a_1f_ba: invalid json detected
Wenn ich Sonos neu anlegen möchte, kommt "Cannot load module SONOS"
Fini
was sagt den ls -l /opt/fhem/FHEM/*SONO*
Im Terminal?
Abgesehen davon, das Du ziemlich viele andere Fehler ? Meldungen im Log hast  :o
DeeSPe
Wie in anderen Forenbeiträgen schon berichtet ist wohl der RPC-Server dran Schuld.
Danach gibt es Probleme mit perl-json. Steht auch so im Wiki.
Dan
fini
Im Terminal?
-rwxrwxrwx 1 fhem dialout 493218 Jul 16 09:55 /opt/fhem/FHEM/00_SONOS.pm
-rwxrwxrwx 1 fhem dialout 116041 Jul 16 09:55 /opt/fhem/FHEM/21_SONOSPLAYER.pm
fini
Dan
in welcher Wiki?
Komisch, es lief ja mal, jetzt nicht mehr und ich habe nichts gemacht.
DeeSPe
Zitat von: fini am 06 November 2017, 11:43:29
in welcher Wiki?
Ich vermute Du verwendest HMCCU!?
Dan
fini
DeeSPe
Zitat von: fini am 06 November 2017, 11:46:17
ja
Dann sollte Dir der verlinkte Wiki-Eintrag Erleuchtung bringen.
Dan
Sorry ich kann nicht weiterhelfen. Sonos Module sind zumindest da.
Ich denke auch nicht das es primar an SONOS liegt wird wohl was mit HMCCU sein - das verwende ich nicht.
Viel Erfolg
Otto
fini
Dan
hmmm... verstehe nur nicht, warum sonos schon lief
also solte ich das machen:
Beim externen RPC-Server kann es zu Inkompatibilitäten mit Modulen kommen, die JSON verwenden (z.B. HUEBridge). Falls im Log von FHEM JSON Fehlermeldungen auftauchen, muss entweder der interne RPC-Server verwendet oder das Perl Modul JSON::XS deinstalliert werden. Für die Nutzung von JSON ist es nicht zwingend erforderlich. Unter Raspbian kann das Modul mit folgendem Befehl entfernt werden:
sudo dpkg --purge libjson-xs-perl
Für CPAN lautet der Befehl:
sudo cpan --uninstall JSON::XS
fini
keiner eine Ahnung was ich machen kann?
DeeSPe
Deaktiviere doch einfach mal testweise den externen RPC-Server in HMCCU.
Dan
fini
Dan
geht immer noch nicht:
2017.11.06 14:15:31 0: HMCCU: All RPC servers stopped
2017.11.06 14:15:56 1: reload: Error:Modul 00_SONOS deactivated:
Compilation failed in require at ./FHEM/00_SONOS.pm line 102.
BEGIN failed--compilation aborted at ./FHEM/00_SONOS.pm line 102.
2017.11.06 14:15:56 0: Can't locate Encode/Locale.pm in @INC (you may need to install the Encode::Locale module) (@INC contains: . /etc/perl /usr/local/lib/arm-linux-gnueabihf/perl/5.20.2 /usr/local/share/perl/5.20.2 /usr/lib/arm-linux-gnueabihf/perl5/5.20 /usr/share/perl5 /usr/lib/arm-linux-gnueabihf/perl/5.20 /usr/share/perl/5.20 /usr/local/lib/site_perl ./FHEM) at /usr/share/perl5/LWP/UserAgent.pm line 1002.
DeeSPe
sudo apt-get install libencode-locale-perl
Dan
fini
Dan
da kommt:
Paketlisten werden gelesen... Fertig
Abhängigkeitsbaum wird aufgebaut.
Statusinformationen werden eingelesen.... Fertig
libencode-locale-perl ist schon die neueste Version.
libencode-locale-perl wurde als manuell installiert festgelegt.
0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
