[gelöst]Pairing HM-LC-Dim1L-Pl-2 bleibt bei "R-pairCentral set_0xF10001" stecken
Begonnen von Frank_Huber, 07 November 2017, 22:17:46
Frank_Huber
Nabend,
auch nach dem 10ten pairing des Dimmers steckt er noch bei "R-pairCentral set_0xF10001" fest.
Ich weis von anderen HM Geräten dass man das Pairing mehrfach anstossen muss,
hilft bei diesem diesmal aber leider nicht.
Woran kann es denn noch liegen?
List:
   CFGFN
   CUL868_WIFI_164_MSGCNT 54
   CUL868_WIFI_164_RAWMSG A0A29800220847DF1000100::-75:CUL868_WIFI_164
   CUL868_WIFI_164_RSSI -75
   CUL868_WIFI_164_TIME 2017-11-07 22:11:31
   DEF        20847D
   IODev      CUL868_WIFI_164
   LASTInputDev CUL868_WIFI_164
   MSGCNT     54
   NAME       HM_20847D
   NOTIFYDEV  global
   NR         45198
   STATE      off
   TYPE       CUL_HM
   lastMsg    No:29 - t:02 s:20847D d:F10001 00
   protLastRcv 2017-11-07 22:11:31
   protSnd    42 last_at:2017-11-07 22:11:31
   protState  CMDs_done
   rssi_CUL868_WIFI_164 avg:-74.33 min:-78 max:-67 cnt:15 lst:-71
   rssi_at_CUL868_WIFI_164 min:-91.5 lst:-75 cnt:54 max:-70.5 avg:-77.95
   Helper:
     DBLOG:
       D-firmware:
         logdb:
           TIME       1510089090.39992
           VALUE      2.3
       D-serialNr:
         logdb:
           VALUE      KEQ0201038
       deviceMsg:
         logdb:
           TIME       1510088912.47986
           VALUE      off (to VCCU)
       dim:
         logdb:
           VALUE      stop:off
       level:
         logdb:
           VALUE      0
       levelMissed:
         logdb:
           TIME       1510088387.55297
           VALUE      desired:100
       loadFail:
         logdb:
           VALUE      on
       pct:
         logdb:
           VALUE      0
       powerOn:
         logdb:
           TIME       1510088912.07819
           VALUE      2017-11-07 22:08:31
       state:
         logdb:
           VALUE      off
       timedOn:
         logdb:
           VALUE      off
     2017-11-07 22:11:31   CommandAccepted yes
     2017-11-07 22:11:30   D-firmware      2.3
     2017-11-07 22:11:30   D-serialNr      KEQ0201038
     2017-11-07 21:53:44   R-pairCentral   set_0xF10001
     2017-11-07 22:08:32   deviceMsg       off (to VCCU)
     2017-11-07 22:08:32   dim             stop:off
     2017-11-07 22:08:32   level           0
     2017-11-07 21:59:47   levelMissed     desired:100
     2017-11-07 22:08:32   loadFail        on
     2017-11-07 22:08:32   pct             0
     2017-11-07 22:08:32   powerOn         2017-11-07 22:08:31
     2017-11-07 22:08:32   recentStateType info
     2017-11-07 22:08:32   state           off
     2017-11-07 22:08:32   timedOn         off
   helper:
     HM_CMDNR   41
     PONtest    0
     cSnd       01F1000120847D000802010AF10B000C01,01F1000120847D0006
     dlvlCmd    ++A011F1000120847D0201000000
     mId        00A3
     rxType     1
     supp_Pair_Rep 0
     dir:
       cur        stop
     expert:
       def        1
       det        0
       raw        1
       tpl        0
     io:
       newChn     +20847D,00,00,00
       nextSend   1510089091.33427
       rxt        0
       vccu       VCCU
       p:
         20847D
         00
         00
         00
     mRssi:
       mNo        29
       io:
         CUL868_WIFI_164 -73
     prt:
       bErr       0
       sProc      0
       rspWait:
     q:
       qReqConf   00
       qReqStat
     role:
       chn        1
       dev        1
       prs        1
     rssi:
       CUL868_WIFI_164:
         avg        -74.3333333333333
         cnt        15
         lst        -71
         max        -67
         min        -78
       at_CUL868_WIFI_164:
         avg        -77.9537037037037
         cnt        54
         lst        -75
         max        -70.5
         min        -91.5
     shadowReg:
       RegL_00.    02:01 0A:F1 0B:00 0C:01
     tmpl:
   IOgrp      VCCU:CUL868_WIFI_164
   autoReadReg 4_reqStatus
   expert     2_raw
   firmware   2.3
   model      HM-LC-Dim1L-Pl-2
   room       HM
   serialNr   KEQ0201038
   subType    dimmer
   webCmd     statusRequest:toggle:on:off:up:down
RegTable:
No regs found for:
HM_20847D type:dimmer -
list:peer register         :value
   0:      intKeyVisib      :set_invisib
   0:      pairCentral      :set_0xF10001
LuckyDay
dein Device ist bereits gepairt, getConfig gemacht?
beim Cul bin ich aber raus, und die TS Firmware probiert, ich habe nur orginale HM-IOs
Frank_Huber
Danke, das war es.
Hab paarmal den StausRequest gedrückt, aber kein getConfig.
manches ist sooo einfach. :-)
Danke nochmal!
