Verständnisfrage: event-on-change-reading im DOIF mit userReadings
Begonnen von hopgeq, 09 November 2017, 18:17:58
hopgeq
ich habe ein DOIF, das einfach Daten von anderen Devices zusammensammelt, damit alles was zusammengehört auch an einem Ort ist.
   DEF        (["ESPEasy_Werkstatt"])
   NAME       a_ESP_Werkstatt
   NR         161
   NTFY_ORDER 50-a_ESP_Werkstatt
   STATE      low
   TYPE       DOIF
     2017-11-09 18:09:15   Device          ESPEasy_Werkstatt_SystemInfo
     2017-11-09 18:09:15   RSSI            -65
     2017-11-09 18:09:15   Relais_A        on
     2017-11-09 18:09:15   Relais_B        off
     2017-11-09 18:09:15   cmd             1
     2017-11-09 18:09:15   cmd_event       ESPEasy_Werkstatt_SystemInfo
     2017-11-09 18:09:15   cmd_nr          1
     2017-11-09 18:09:15   dewpoint        9.9
     2017-11-08 22:56:09   fan             on
     2017-11-09 18:09:15   humidity        60
     2017-11-09 18:09:15   matched_event_c1_1 RSSI: -65,RSS: -65
     2017-11-09 18:09:15   presence        present
     2017-11-09 18:09:15   presence2       present
     2017-11-09 18:09:15   state           cmd_1
     2017-11-09 18:09:15   temperature     17.8
     2017-11-09 18:09:15   ventilator      low
   condition:
     0          EventDoIf('ESPEasy_Werkstatt',$hash,'',0)
   devices:
   do:
     0:
       0
     1:
   helper:
     event      RSSI: -65,RSS: -65
     globalinit 1
     last_timer 0
     sleeptimer -1
     timerdev   ESPEasy_Werkstatt_SystemInfo
     timerevent RSSI: -65,RSS: -65
     triggerDev ESPEasy_Werkstatt_SystemInfo
     timerevents:
       RSSI: -65
       RSS: -65
     timereventsState:
       RSSI: -65
       state: RSS: -65
     triggerEvents:
       RSSI: -65
       RSS: -65
     triggerEventsState:
       RSSI: -65
       state: RSS: -65
   internals:
   itimer:
   readings:
   regexp:
     0:
       0          ESPEasy_Werkstatt
     all:
       0          ESPEasy_Werkstatt
   state:
     STATE:
   trigger:
   adminlink  192.168.0.31
   devStateIcon off:off low:half high:on
   do         always
   room       Abstracts
   stateFormat ventilator
   userReadings presence    { ReadingsVal("Pres_ESPEasy_Werkstatt",       "presence",   "null")  },
presence2   { ReadingsVal("ESPEasy_Werkstatt_SystemInfo", "presence",   "null")  },
RSSI        { ReadingsVal("ESPEasy_Werkstatt_SystemInfo", "RSSI",       "null")  },
temperature { ReadingsVal("ESPEasy_Werkstatt_DHT_innen",  "temperature","null")  },
humidity    { ReadingsVal("ESPEasy_Werkstatt_DHT_innen",  "humidity",   "null")  },
Relais_A    { ReadingsVal("ESPEasy_Werkstatt_Relais_A",   "Relais_A",   "null")  },
Relais_B    { ReadingsVal("ESPEasy_Werkstatt_Relais_B",   "Relais_B",   "null")  },
ventilator  { ReadingsVal("ESPEasy_Werkstatt_Fan",        "state",      "null")  }
Jetzt will ich die Daten loggen, und zwar alle userReadings. Es entstehen aber viel zu viele Zeilen im Log. Daher möchte ich event-on-change-reading einsetzen.
attr a_ESP_Werkstatt event-on-change-reading Relais_A,Relais_B
Bei anderen Devices funktioniert das auch gut, aber hier nicht. In der obigen Form entstehen überhaupt gar keine Logzeilen mehr.
1) Woran hakt es? Hängt das mit den Events zusammen, die das DOIF triggern? Die heißen ja anders als die userReadings (die dann auch in event-on-change-reading aufgeführt werden).
2) Zur Architektur. Ich hatte das gleiche Ziel -- Zusammenfassen aller Daten in einem Device -- auch mal mit einem dummy erreicht. Der dummy wurde mittels notify und setreading mit Daten versorgt. Also ein "Push"-Ansatz im Gegensatz zu den userReadings, die sich die Daten selbst holen ("Pull"). Ist das womöglich der bessere Ansatz?
viegener
Ohne mir jetzt Dein ganzes DOIF angeschaut zu haben vermute ich erstmal folgendes:
userreadings werden nur neu berechnet, wenn andere Readings einen Event auslösen - Dein event-on-change enthält nur userreadings, damit werden alle anderen reading änderungen keinen event mehr auslösen - ergo werden die user readings nie upgedated da es nie einen event gibt
hopgeq
verstehe. Ich habe mal testweise folgendes eingestellt:
attr a_ESP_Waesche event-on-change-reading fan,Relais_A,Relais_B
fan ist kein userReadings, Relais_A und Relais_B aber schon.
fan ändert sich grad nicht.
Wenn sich jetzt Relais_A ändert, gibt es keinen Logeintrag. Weil sich fan nicht geändert hat, richtig?
Wenn das so ist, dann würde das aber bedeuten, dass event-on-change-reading für userReadings in einem DOIF prinzipiell nicht funktioniert, oder sehe ich das falsch?
D.h. ich müsste dann einen dummy nehmen statt des DOIF?
amenomade
Richtig
Aktualisierung eines Readings, das nicht durch event-on-change ausgefiltert ist => Event => Aktualisierung des userReadings
Kein Event, oder durch event-on-change ausgefiltertes Event => Kein Event => keine Aktualisierung
ZitatWenn das so ist, dann würde das aber bedeuten, dass event-on-change-reading für userReadings in einem DOIF prinzipiell nicht funktioniert, oder sehe ich das falsch?
Naja
event-on-change-reading NUR auf userReadings => nix passiert. Siehe oben.
Aber probier mal mit
event-on-update-reading cmd
hopgeq
schade, das klang gut, aber es erzeugt im Logging
2017-11-09_21:15:09 a_ESP_Werkstatt cmd: 1
2017-11-09_21:15:20 a_ESP_Werkstatt cmd: 1
2017-11-09_21:15:47 a_ESP_Werkstatt cmd: 1
2017-11-09_21:16:09 a_ESP_Werkstatt cmd: 1
2017-11-09_21:16:20 a_ESP_Werkstatt cmd: 1
2017-11-09_21:16:47 a_ESP_Werkstatt cmd: 1
2017-11-09_21:17:09 a_ESP_Werkstatt cmd: 1
Und mit
event-on-update-reading Relais_A,Relais_B
erzeuge ich zwar ein Logging, aber event-on-change-reading greift nicht:
2017-11-09_21:17:20 a_ESP_Werkstatt Relais_A: off
2017-11-09_21:17:20 a_ESP_Werkstatt Relais_B: off
2017-11-09_21:17:47 a_ESP_Werkstatt Relais_A: off
2017-11-09_21:17:47 a_ESP_Werkstatt Relais_B: off
2017-11-09_21:17:49 a_ESP_Werkstatt Relais_A: off
2017-11-09_21:17:49 a_ESP_Werkstatt Relais_B: off
Ich hab auch noch mit checkReadingEvent und timestamp-on-change-reading herumexperimentiert, aber ich bekomme das Logging der userReadings entweder alle paar Sekunden oder gar nicht, aber nicht on-change.
amenomade
Mach mal ein "list ESPEasy_Werkstatt_Relais_A" und ein "list ESPEasy_Werkstatt_Relais_B" bitte.
hopgeq
   DEF        192.168.0.31 80 EspBridge Werkstatt_Relais_A
   ESP_BUILD  20000
   ESP_BUILD_GIT v2.0.0-dev12
   ESP_BUILD_NOTES  - Mega
   ESP_NODE_TYPE_ID 17: ESP Easy Mega
   ESP_SLEEP  0
   ESP_UNIT   1
   ESP_VERSION 2
   EspBridge_MSGCNT 297
   EspBridge_TIME 2017-11-09 22:28:19
   HOST       192.168.0.31
   IDENT      Werkstatt_Relais_A
   INTERVAL   300
   IODev      EspBridge
   LASTInputDev EspBridge
   MSGCNT     297
   NAME       ESPEasy_Werkstatt_Relais_A
   NOTIFYDEV  global
   NR         91
   NTFY_ORDER 50-ESPEasy_Werkstatt_Relais_A
   PORT       80
   STATE      off
   SUBTYPE    device
   TYPE       ESPEasy
   VERSION    1.33
     2017-11-09 22:28:19   Relais_A        off
     2017-11-09 22:28:08   presence        present
     2017-11-09 22:28:19   state           Rel: off
   helper:
     fpc        1510245343
     pm:
       Encode     1
       JSON       1
     received:
       Relais_A   1510262899
   IODev      EspBridge
   Interval   300
   eventMap   /gpio 16 on:off/gpio 16 off:on/
   group      ESPEasy Device
   presenceCheck 1
   readingSwitchText 1
   room       Basisdaten
   setState   3
   stateFormat Relais_A
   DEF        192.168.0.31 80 EspBridge Werkstatt_Relais_B
   ESP_BUILD  20000
   ESP_SLEEP  0
   ESP_UNIT   1
   ESP_VERSION 2
   EspBridge_MSGCNT 296
   EspBridge_TIME 2017-11-09 22:29:37
   HOST       192.168.0.31
   IDENT      Werkstatt_Relais_B
   INTERVAL   300
   IODev      EspBridge
   MSGCNT     296
   NAME       ESPEasy_Werkstatt_Relais_B
   NOTIFYDEV  global
   NR         92
   NTFY_ORDER 50-ESPEasy_Werkstatt_Relais_B
   PORT       80
   STATE      off
   SUBTYPE    device
   TYPE       ESPEasy
   VERSION    1.33
     2017-11-09 22:29:37   Relais_B        off
     2017-10-23 23:50:28   Switch          off
     2017-11-09 22:28:20   presence        present
     2017-11-09 22:29:37   state           Rel: off
   helper:
     fpc        1510245343
     pm:
       Encode     1
       JSON       1
     received:
       Relais_B   1510262977
   IODev      EspBridge
   Interval   300
   eventMap   /gpio 5 on:off/gpio 5 off:on/
   presenceCheck 1
   readingSwitchText 1
   room       Basisdaten
   setState   3
   stateFormat Relais_B
amenomade
Hat sich zwischen 21:15 und 21:17 Werkstatt_Relais_A:Relais_A oder Werkstatt_Relais_B:Relais_B geändert (von "off" auf "on")?
hopgeq
nein.  (EDIT:doch, s.u.)
amenomade
Dann klar hast Du nix anderes in der Log als "cmd1"
event-on-change-reading = er wird ein Event generiert, wenn sich der Wert ändert
bedeutet:
a_ESP_Werkstatt:Relais_A = ESPEasy_Werkstatt_Relais_A:Relais_A
Wenn ESPEasy_Werkstatt_Relais_A:Relais_A sich nicht ändert, ändert sich a_ESP_Werkstatt:Relais_A auch nicht => es wird kein Event generiert, wenn event-on-change-reading gesetzt.
hopgeq
ja, schon klar. Das bedeutet dann aber auch: event-on-change-reading ist nicht für userReadings verwendbar, sondern nur für Readings, die von außen über einen Event hereinkommen.
Ich hab jetzt ein notify, das genau das macht:
defmod n_copy_to_esp_waesche notify ESPEasy_Waesche.*:(RSSI|Relais_A|Relais_B|humidity|temperature|ventilator).*|ESPEasy_Waesche_DHT.*:presence.* {\
fhem(  copyreading_command("a_ESP_Waesche", $EVENT)       );; \
und in 99_myUtils.pm:
sub copyreading_command($$){
my $ziel = $_[0];
my $eventstring = $_[1];
$eventstring =~ tr/://d;  # Doppelpunkt streichen
'setreading '.$ziel.' '.$eventstring;
hopgeq
Ich wundere mich nur, warum das so kompliziert ist und warum ich im jahrelangem Forum-Wissensschatz auch nichts darüber finde. Es scheint eine total exotische Idee zu sein, Readings zusammenzufassen, zu kopieren und damit umzustrukturieren. Dabei habe ich das an gleich mehreren Stellen:
- obiges DOIF fasst verschiedene Devices wieder zusammen, die eigentlich auch ein physikalisches Gerät sind
- Es gibt noch ein a_Internet-Device, das Auskunft über den Status der Internet-Konnektivität gibt, derzeit bestehend aus ping-Test und Speedtest
- und es gibt ein a_Umwelt-Device, das für einige Werte jeweils den Mittelwert von Yahoo-Wetter und einer Wunderground-Wetterstation liefert und außerdem statt 100 Readings nur die 5 Readings liefert, die ich brauche
Ist dieses Bündeln und Filtern von Readings wirklich ein so ungewöhnlicher, exotischer Usecase? Oder wenn nicht, wie macht man das als FHEM-Profi?
hopgeq
@amenomade: Sorry, ich hatte dir eine falsche Information gegeben und deine Antwort auch erst falsch verstanden.
Doch, der Zustand des Relais hat sich geändert.
Ich habe es nochmal ausprobiert.
Also folgendes eingestellt:
attr a_ESP_Werkstatt event-on-update-reading cmd
Jetzt das Relais geschaltet (mit einem anderen Device).
Der Zustand des Relais hat sich geändert.
Logging ist:
2017-11-09_23:33:55 a_ESP_Werkstatt cmd: 1
2017-11-09_23:33:57 a_ESP_Werkstatt cmd: 1
2017-11-09_23:34:06 a_ESP_Werkstatt cmd: 1
2017-11-09_23:34:25 a_ESP_Werkstatt cmd: 1
2017-11-09_23:34:42 a_ESP_Werkstatt cmd: 1
2017-11-09_23:35:06 a_ESP_Werkstatt cmd: 1
2017-11-09_23:35:25 a_ESP_Werkstatt cmd: 1
2017-11-09_23:35:44 a_ESP_Werkstatt cmd: 1
2017-11-09_23:36:06 a_ESP_Werkstatt cmd: 1
D.h. die Relais wurden nicht geloggt. Aber wenn es seinen Wert verändert, wird cmd geloggt.
amenomade
Wenn dein Ziel ist, verschiedene Readings von verschiedene Devices zusammenzufassen, probier mal https://wiki.fhem.de/wiki/ReadingsGroup
amenomade
