HM-RC-4
Begonnen von stgeran, 10 November 2017, 22:52:47
stgeran
Wie bekomme ich es hin, dass auch ein long_press die gleiche Funktion hat wie der short_press.
Hier ein list Hand_1_1
   DEF        1DDF4E01
   NAME       Hand_1_1
   NOTIFYDEV  global
   NR         177
   STATE      Short 1_50 (to broadcast)
   TYPE       CUL_HM
   chanNo     01
   device     Hand_1
     2017-09-22 18:41:40   R-Roll_Garage_chn-01-expectAES set_off
     2017-09-22 18:41:40   R-Roll_Garage_chn-01-peerNeedsBurst set_off
     2017-09-21 19:06:11   R-sign          off
     2017-09-21 19:06:11   RegL_01.        04:10 08:00 09:00 00:00
     2017-11-09 06:14:35   state           Short 1_50 (to broadcast)
     2017-11-09 06:14:35   trigger         Short_50
     2017-11-09 06:14:35   trigger_cnt     50
   helper:
     BNO        50
     BNOCNT     1
     cfgChkResult No regs found for:
Hand_1_1 type:remote -
list:peer register         :value
   1:      dblPress         :0 s
   1:      longPress        :0.4 s
   1:      sign             :off
     expert:
       def        1
       det        0
       raw        1
       tpl        0
     role:
       chn        1
     shadowReg:
       RegL_04.Roll_Garage_chn-01  01:00
     tmpl:
   nb:
     cnt        1
   model      HM-RC-4
   peerIDs    00000000
Und wie peer ich den Taster mit dem Aktor?
Ein
set Hand_1_1 peerChan Roll_Garage
bringt ein
please enter peer
Hier noch ein list Roll_Garage
   DEF        2958C0
   HMLAN1_MSGCNT 99
   HMLAN1_RAWMSG E2958C0,0000,52ED3181,FF,FFB4,93A0102958C0123456030000
   HMLAN1_RSSI -76
   HMLAN1_TIME 2017-11-10 22:45:25
   IODev      HMLAN1
   LASTInputDev HMLAN1
   MAPLECUL868_2_MSGCNT 62
   MAPLECUL868_2_RAWMSG A1A92A0102958C01234560391C80000000000000000000000056800::-90.5:MAPLECUL868_2
   MAPLECUL868_2_RSSI -90.5
   MAPLECUL868_2_TIME 2017-11-10 22:45:25
   MAPLECUL868_MSGCNT 80
   MAPLECUL868_RAWMSG A1A92A0102958C01234560391C80000000000000000000000056800::-85.5:MAPLECUL868
   MAPLECUL868_RSSI -85.5
   MAPLECUL868_TIME 2017-11-10 22:45:25
   MSGCNT     333
   NAME       Roll_Garage
   NOTIFYDEV  global
   NR         54
   STATE      down
   TYPE       CUL_HM
   lastMsg    No:93 - t:10 s:2958C0 d:123456 030000
   myHmUART_MSGCNT 92
   myHmUART_RAWMSG 0500005193A0102958C0123456030000
   myHmUART_RSSI -81
   myHmUART_TIME 2017-11-10 22:45:25
   peerList   Hand_1_1,Hand_1_2,
   protLastRcv 2017-11-10 22:45:25
   protSnd    100 last_at:2017-11-10 22:45:25
   protState  CMDs_done
   rssi_at_HMLAN1 max:-75 min:-83 lst:-76 avg:-79.21 cnt:99
   rssi_at_MAPLECUL868 min:-102.5 max:-80 cnt:80 avg:-87.8 lst:-85.5
   rssi_at_MAPLECUL868_2 max:-82 min:-99 lst:-90.5 avg:-88.89 cnt:62
   rssi_at_myHmUART max:-68 min:-88 avg:-78.86 lst:-81 cnt:92
   rssi_myHmUART max:-99 min:-101 avg:-100 cnt:2 lst:-101
     2017-11-10 22:45:16   CommandAccepted yes
     2017-08-27 20:56:51   D-firmware      2.5
     2017-08-27 20:56:51   D-serialNr      LEQ0280298
     2017-11-10 22:45:21   PairedTo        0x123456
     2017-09-22 18:41:48   R-Hand_1_1-lgActionType jmpToTarget
     2017-09-22 18:41:48   R-Hand_1_1-lgOnLevel 100 %
     2017-09-22 18:41:48   R-Hand_1_1-shActionType jmpToTarget
     2017-09-22 18:41:48   R-Hand_1_1-shOnLevel 100 %
     2017-09-22 18:41:49   R-Hand_1_2-lgActionType jmpToTarget
     2017-09-22 18:41:49   R-Hand_1_2-lgOnLevel 100 %
     2017-09-22 18:41:49   R-Hand_1_2-shActionType jmpToTarget
     2017-09-22 18:41:49   R-Hand_1_2-shOnLevel 100 %
     2017-08-27 21:07:11   R-driveDown     50 s
     2017-08-27 21:07:11   R-driveTurn     0.5 s
     2017-08-27 21:07:11   R-driveUp       50 s
     2017-08-27 21:07:10   R-pairCentral   0x123456
     2017-08-27 21:07:11   R-sign          off
     2017-11-10 22:45:21   RegL_00.          02:01 0A:12 0B:34 0C:56 15:FF 18:00 00:00
     2017-11-10 22:45:22   RegL_01.         08:00 09:00 0A:00 0B:01 0C:F4 0D:01 0E:F4 0F:05 10:00  30:06 57:24 56:00 00:00
     2017-11-10 22:45:24   RegL_03.Hand_1_1  01:00 02:00 03:00 04:32 05:64 06:00 07:FF 08:00 09:FF 0A:01 0B:44 0C:54 0D:93 0E:00 0F:00 11:C8 12:00 13:00 14:00 15:00 16:00 17:00 18:00 19:00 1A:00 1B:00 1C:00 1D:FF 1E:93 1F:00 81:00 82:00 83:00 84:32 85:64 86:00 87:FF 88:00 89:FF 8A:21 8B:44 8C:54 8D:93 8E:00 8F:00 91:C8 92:00 93:00 94:00 95:00 96:00 97:00 98:00 99:00 9A:00 9B:00 9C:00 9D:05 9E:93 9F:00 00:00
     2017-11-10 22:45:25   RegL_03.Hand_1_2  01:00 02:00 03:00 04:32 05:64 06:00 07:FF 08:00 09:FF 0A:01 0B:11 0C:12 0D:68 0E:00 0F:00 11:C8 12:00 13:00 14:00 15:00 16:00 17:00 18:00 19:00 1A:00 1B:00 1C:00 1D:FF 1E:68 1F:00 81:00 82:00 83:00 84:32 85:64 86:00 87:FF 88:00 89:FF 8A:21 8B:11 8C:12 8D:68 8E:00 8F:00 91:C8 92:00 93:00 94:00 95:00 96:00 97:00 98:00 99:00 9A:00 9B:00 9C:00 9D:05 9E:68 9F:00 00:00
     2017-11-10 15:44:37   deviceMsg       off (to VCCU)
     2017-11-10 15:44:37   level           0
     2017-11-10 15:44:37   motor           stop:off
     2017-11-10 15:44:37   pct             0
     2017-11-10 22:45:22   peerList        Hand_1_1,Hand_1_2,
     2017-09-21 18:39:41   powerOn         2017-09-21 18:39:41
     2017-11-10 15:44:37   recentStateType info
     2017-11-10 15:44:37   state           off
     2017-11-10 15:44:37   timedOn         off
   helper:
     HM_CMDNR   147
     cSnd       011234562958C001041DDF4E0103,011234562958C001041DDF4E0203
     mId        0005
     peerIDsRaw ,1DDF4E02,1DDF4E01,00000000
     rxType     1
     supp_Pair_Rep 0
     ack:
     dir:
       cur        stop
       rct        down
     expert:
       def        1
       det        0
       raw        1
       tpl        0
     io:
       newChn     +2958C0,00,00,00
       nextSend   1510350325.83094
       rxt        0
       vccu       VCCU
       p:
         2958C0
         00
         00
         00
     mRssi:
       mNo        93
       io:
         HMLAN1     -74
         myHmUART   -81
     prt:
       bErr       0
       sProc      0
       rspWait:
     q:
       qReqConf
       qReqStat
     role:
       chn        1
       dev        1
       prs        1
     rpt:
       IO         myHmUART
       flg        A
       ts         1510350325.75571
       ack:
         HASH(0x246b840)
         9380021234562958C000
     rssi:
       at_HMLAN1:
         avg        -79.2121212121212
         cnt        99
         lst        -76
         max        -75
         min        -83
       at_MAPLECUL868:
         avg        -87.80625
         cnt        80
         lst        -85.5
         max        -80
         min        -102.5
       at_MAPLECUL868_2:
         avg        -88.8951612903226
         cnt        62
         lst        -90.5
         max        -82
         min        -99
       at_myHmUART:
         avg        -78.8695652173913
         cnt        92
         lst        -81
         max        -68
         min        -88
       myHmUART:
         avg        -100
         cnt        2
         lst        -101
         max        -99
         min        -101
     shadowReg:
     tmpl:
   IODev      VCCU
   IOgrp      VCCU
   autoReadReg 4_reqStatus
   devStateIcon up:fts_shutter_10@green down:fts_shutter_100@black 9\d.*:fts_shutter_10 8\d.*:fts_shutter_20 7\d.*:fts_shutter_30 6\d.*:fts_shutter_40 5\d.*:fts_shutter_50 4\d.*:fts_shutter_60 3\d.*:fts_shutter_70 2\d.*:fts_shutter_80 1\d.*:fts_shutter_90 0\d.*:fts_shutter_100
   eventMap   on:up off:down
   expert     2_raw
   firmware   2.5
   model      HM-LC-BL1-FM
   peerIDs    00000000,1DDF4E01,1DDF4E02,
   room       Garage,CUL_HM
   serialNr   LEQ0280298
   subType    blindActuator
   webCmd     pct
FHEM auf Raspberry
CSM 866MHz für EM1010 mit Strom und Gaszähler
CUL 866MHz für MAX! Radiator Thermostat
CUL 433MHz für Innen und Aussen Temp
HMLAN für HM-LC-Sw1-PI-2
Pfriemler
#1
Es fehlt der "Kanalplatzhalter" und ggf.  die Anzahl der zu peerenden Kanäle:
dual setzt den aktuellen und folgenden Kanal für den Aktor auf "aus" und "an". Roll_Garage ist ein Rolladenaktor, also passt
set Hand_1_1 peerChan 0 Roll_Garage dual set
Achte auf die etwas krude Tastenzuordnung der RC-4!
Nun solltest Du ein default-Verhalten bekommen: kurz drücken erzeugt eine Fahrt in die Endlage, lang fährt das Tor solange gedrückt wird.
Ist das nicht sogar wünschenswert?
Wenn Du erreichen möchtest, dass die Unterscheidung short-long nicht schon nach 0,4 Sekunden, sondern nach bspw. zwei Sekunden so spät wie möglich erfolgt (dann wird alles bis 1.8 s als short interpretiert), ändere das Register "longPress" in den Kanälen der Fernbedienung entsprechent:
set Hand_1_1 regSet longPress 1.8
set Hand_1_2 regSet longPress 1.8
Hilft das weiter?
edit: Korrektur der maximalen longPress-Zeit auf 1.8, danke für den Hinweis.
stgeran
Danke, ich bin erst jetzt dazu gekommen. Gesetzt habe ich es so wie Du geschrieben hast. Ich werde es morgen bei Tag ausprobieren. Das Register für longPress lies nur Zeiten zwischen 0,3 und 1,8 zu.
FHEM auf Raspberry
stgeran
Funktioniert so weit. :-) Frage: Ich bekomme kein "grünes" Feedback nach dem Sendebefehl. Fehlt da noch etwas?
FHEM auf Raspberry
Pfriemler
Also beim direkten Peeren mit einem HM-Aktor sollte dieser die Quittung liefern. Allerdings ist die Empfangsleistung einer RC-4 außerordentlich besch...eiden, d.h. schon ab 15-20 m bekommt man den Aktor noch gut erreicht, aber das ACK erreicht die RC-4 nicht mehr und diese leuchtet nach gelb dann rot. Das wäre dann leider normal.
Wenn die RC-4 aber nur kurz gelb leuchtet, ist sie vermutlich nicht gepeert. Das Eintragen beim Aktor hat dann funktioniert und dieser reagiert dann auf die RC-4, wenn diese aber nicht weiß an wen sie sendet, erwartet sie auch keine Quittung und macht nach gelb weder rot noch grün.
Nicht alle RC-4 untersützen lazyConfig (automatisches Nachholen von Programmierungen und Abfragen bei einer Tastenbetätigung), zum Konfigurieren empfiehlt sich also immer der Konfig-Button (Unterseite, mit einem spitzen Gegenstand).
Schaue also bitte, ob in Hand_1_1 der Roll_Garage als peer eingetragen ist. Wenn nicht, setze ein getConfig und drücke den Konfigbutton. Schaue dann nochmal. Fehlt es noch immer, wiederhole das Peering. Mit Konfigbutton. Es genügt, wenn Du an den peer-Befehl " remote" anhängst, dann wird nur die Fernbedienung programmiert. Ein "Drüberpeeren" schadet aber dem Aktor auch nicht. Bestehende Register werden nicht gelöscht oder verändert.
stgeran
War nicht gepeert, getConfig und der Button haben geholfen, jetzt steht da auch eine Adresse drin.
Andere Frage: Könnte ich auch an Stelle der zwei Tasten auch ein "toggle" verwenden? Mit kurz drücken auf oder zu bis zur Endlage und lang drücken Fahren so lange man drückt. Hintergrund: ich möchte im Auto einen Taster einbauen den ich betätigen kann ohne groß die Tasten auszuwählen.
FHEM auf Raspberry
Pfriemler
Natürlich. Fernbedienung entpeeren und erneut mit der gewünschten Taste, aber dann ".... single set" statt "dual set".  Taste toggelt dann (inkl. Stop wenn Tor noch fährt), langer Druck = fahren solange gedrückt ist.
Für den Einbau eines Tasters empfiehlt sich evtl ein HM-Mod-Re-8. Oder das HM-PB4-Dingens. Ich habe statt eines Tasters einen Hebeltaster (Kippschalter mit selbsttätigen Mittelstellung). Das ist auch blind zu betätigen und man gibt die Richtung vor. Nur als Anregung...
