fhem2fhem connection lost, not sending commands with fs20 devices
Begonnen von Guest, 04 Juli 2012, 20:42:33
Guest
My fhem2fhem connection was down, and I also had problems with my fs20
devices. When the connection is down you can't send fs20 commands to
these devices.
Anybody also have these problems?
regards Richard
> When the connection is down you can't send fs20 commands to these devices.
If the conection is down, the fhem2fhem client tries to connect once a minute
to the server, blocking fhem for up to X seconds, where X is the default OS
timeout for a connect call, usually around 3 secods.
It may be that the default connect timeout on your architecture is more than
that, causing a larger delay. Can you pleae confirm this?
