Nicht identifizierbare Einträge in der LOG Datei
Begonnen von Guest, 06 Juli 2012, 21:26:02
Guest
Seit geraumer Zeit finde ich folgende Einträge in der LOG Datei.
Was hat es damit auf sich? Habe ich etwas verpasst?
Gruß Klaus
FHEM Neustart
2012.07.06 20:32:17 0: Server shutdown
2012.07.06 20:32:19 1: Including /etc/fhem.cfg
2012.07.06 20:32:20 3: WEB: port 8083 opened
2012.07.06 20:32:20 3: WEBS: port 8084 opened
2012.07.06 20:32:20 3: Opening CUL device /dev/ttyACM0
2012.07.06 20:32:20 3: CUL device opened
Use of implicit split to @_ is deprecated at /usr/share/fhem/FHEM/95_FLOORPLAN.pm line 410, <$fh> line 76.
2012.07.06 20:32:22 1: OWX: Serial device /dev/ttyUSB0 defined
2012.07.06 20:32:22 1: OWX: 1-Wire bus master DS2480 detected for the first time
2012.07.06 20:32:22 3: OWID:   Device OWXID defined.
2012.07.06 20:32:22 3: OWTEMP: Device 1W.T_Gartenhaus defined.
2012.07.06 20:32:22 3: OWTEMP: Device 1W.T_Dach defined.
2012.07.06 20:32:22 3: OWTEMP: Device 1W.T_Garage defined.
2012.07.06 20:32:22 3: OWTEMP: Device 1W.T_Wasser defined.
2012.07.06 20:32:22 3: OWTEMP: Device 1W.T_Zirko defined.
2012.07.06 20:32:22 3: OWTEMP: Device 1W.T_F_Heizung_.V defined.
2012.07.06 20:32:22 3: OWTEMP: Device 1W.T_F_Heizung_R defined.
2012.07.06 20:32:22 3: OWTEMP: Device 1W.T_K_Heizung_.V defined.
2012.07.06 20:32:22 3: OWTEMP: Device 1W.T_K_Heizung_R defined.
2012.07.06 20:32:22 3: OWCOUNT:   Device Zaehler defined.
2012.07.06 20:32:22 3: OWSWITCH:   Device IO defined.
2012.07.06 20:32:25 3: telnetPort: port 7072 opened
2012.07.06 20:32:25 1: Including /var/log/fhem/fhem.save
Use of uninitialized value in concatenation (.) or string at /usr/bin/fhem.pl line 389.
2012.07.06 20:32:25 0: Server started (version , pid 9749)
2012.07.06 20:32:42 1: OWX: Warning, IO is defined with improper family id 1D, correcting to 3A
2012.07.06 20:32:42 1: OWX: 1-Wire devices found (1W.T_F_Heizung_R,1W.T_Zirko,1W.T_Garage,1W.T_Gartenhaus,1W.T_Dach,1W.T_K_Heizung_.V,1W.T_F_Heizung_.V,1W.T_Wasser,1W.T_K_Heizung_R,IO,OWXID,Zaehler)
2012.07.06 20:33:17 2: dummy set D_Kaffeemaschine off
Use of uninitialized value in numeric ne (!=) at (eval 25) line 1.
Aufruf von Floorplan
Invalid conversion in sprintf: "%<" at /usr/share/fhem/FHEM/99_Utils.pm line 140.
Use of uninitialized value $_ in split at /usr/share/fhem/FHEM/99_myFloorplanList.pm line 68.
Use of uninitialized value $cssTitle in substitution (s///) at /usr/share/fhem/FHEM/99_myFloorplanList.pm line 70.
Use of uninitialized value $cssTitle in concatenation (.) or string at /usr/share/fhem/FHEM/99_myFloorplanList.pm line 71.
Use of uninitialized value $title in concatenation (.) or string at /usr/share/fhem/FHEM/99_myFloorplanList.pm line 71.
Use of uninitialized value $value in concatenation (.) or string at /usr/share/fhem/FHEM/99_myFloorplanList.pm line 71.
