Hallo Stefan,
vielen Dank für die schnelle Antwort.
Hier das fhem-2017-12.log vom gleichen Zeitraum. Ein physikalisches Device habe dann also nicht, da ich ja TCP verwende.
2017.12.13 15:53:16 1: prg_brenner temp: temperature: 55.7
2017.12.13 15:53:33 3: 192.168.178.36:502 disconnected, waiting to reappear (KeSolarEdge)
2017.12.13 15:53:33 5: HttpUtils url=http://192.168.178.36:502/
2017.12.13 15:53:33 3: 192.168.178.36:502 reappeared (KeSolarEdge)
2017.12.13 15:53:34 5: KeSolarEdge: Get: Called with AC-Energy (h40093)
2017.12.13 15:53:34 4: KeSolarEdge: Send called with h40093, objLen 2 / reqLen - to id 1, op read, qlen 0
2017.12.13 15:53:34 4: KeSolarEdge: Send adds fc 3 to 1, tid 196, for h40093 (AC-Energy), reqLen 2 at beginning of queue for immediate sending
2017.12.13 15:53:34 5: KeSolarEdge: handle queue check commDelay (0.1) for KeSolarEdge: rest -119.937731981277
2017.12.13 15:53:34 5: KeSolarEdge: handle queue check sendDelay (0.1) for KeSolarEdge: rest -119.940572023392
2017.12.13 15:53:34 5: KeSolarEdge: HandleSendQueue: finished delay checking, proceed with sending
2017.12.13 15:53:34 4: KeSolarEdge: HandleSendQueue sends fc 3 to id 1, tid 196 for AC-Energy (h40093), len 2, device KeSolarEdge (TCP), pdu 039c9d0002, V 3.7.0 - 20.8.2017
2017.12.13 15:53:34 5: SW: 00c40000000601039c9d0002
2017.12.13 15:53:34 5: KeSolarEdge: ReadAnswer called and remaining timeout is 1.99962902069092 requested reading is AC-Energy
2017.12.13 15:53:35 5: KeSolarEdge: ReadAnswer got: 00c40000000701030400010266
2017.12.13 15:53:35 5: KeSolarEdge: ParseFrames got: 00c40000000701030400010266
2017.12.13 15:53:35 4: KeSolarEdge: ParseFrames got fcode 3 from 1, tid 196, values 00010266HeaderLen 4, ActualLen 4, request was for h40093 (AC-Energy), len 2 for module KeSolarEdge
2017.12.13 15:53:35 5: KeSolarEdge: ParseObj called with 00010266 and start 40093, op read
2017.12.13 15:53:35 5: KeSolarEdge: ParseObj ObjInfo for h40093: reading=AC-Energy, unpack=l>, expr=, format=, map=
2017.12.13 15:53:35 5: KeSolarEdge: ParseObj unpacked 00010266 with l> to hex 3636313530 (66150)
2017.12.13 15:53:35 4: KeSolarEdge: ParseObj for AC-Energy assigns 66150
2017.12.13 15:53:35 5: KeSolarEdge: ParseFrames got 1 readings from ParseObj
2017.12.13 15:53:35 5: KeSolarEdge: ReadAnswer done, reading is AC-Energy, value: 66150
2017.12.13 15:53:35 3: get KeSolarEdge AC-Energy : 66150
2017.12.13 15:53:35 5: KeSolarEdge: Get: Called with AC-Energy-Scale (h40095)
2017.12.13 15:53:35 4: KeSolarEdge: Send called with h40095, objLen 1 / reqLen - to id 1, op read, qlen 0
2017.12.13 15:53:35 4: KeSolarEdge: Send adds fc 3 to 1, tid 216, for h40095 (AC-Energy-Scale), reqLen 1 at beginning of queue for immediate sending
2017.12.13 15:53:35 5: KeSolarEdge: handle queue check commDelay (0.1) for KeSolarEdge: rest 0.0676119327545166
2017.12.13 15:53:35 4: KeSolarEdge: HandleSendQueue / CheckDelay commDelay (0.1) for KeSolarEdge not over, sleep 0.0676119327545166 forced
2017.12.13 15:53:35 5: KeSolarEdge: handle queue check sendDelay (0.1) for KeSolarEdge: rest -1.83849501609802
2017.12.13 15:53:35 5: KeSolarEdge: HandleSendQueue: finished delay checking, proceed with sending
2017.12.13 15:53:35 4: KeSolarEdge: HandleSendQueue sends fc 3 to id 1, tid 216 for AC-Energy-Scale (h40095), len 1, device KeSolarEdge (TCP), pdu 039c9f0001, V 3.7.0 - 20.8.2017
2017.12.13 15:53:35 5: SW: 00d80000000601039c9f0001
2017.12.13 15:53:35 5: KeSolarEdge: ReadAnswer called and remaining timeout is 1.99963212013245 requested reading is AC-Energy-Scale
2017.12.13 15:53:35 5: KeSolarEdge: ReadAnswer got: 00d8000000050103020000
2017.12.13 15:53:35 5: KeSolarEdge: ParseFrames got: 00d8000000050103020000
2017.12.13 15:53:35 4: KeSolarEdge: ParseFrames got fcode 3 from 1, tid 216, values 0000HeaderLen 2, ActualLen 2, request was for h40095 (AC-Energy-Scale), len 1 for module KeSolarEdge
2017.12.13 15:53:35 5: KeSolarEdge: ParseObj called with 0000 and start 40095, op read
2017.12.13 15:53:35 5: KeSolarEdge: ParseObj ObjInfo for h40095: reading=AC-Energy-Scale, unpack=n, expr=, format=, map=
2017.12.13 15:53:35 5: KeSolarEdge: ParseObj unpacked 0000 with n to hex 30 (0)
2017.12.13 15:53:35 4: KeSolarEdge: ParseObj for AC-Energy-Scale assigns 0
2017.12.13 15:53:36 5: KeSolarEdge: ParseFrames got 1 readings from ParseObj
2017.12.13 15:53:36 5: KeSolarEdge: ReadAnswer done, reading is AC-Energy-Scale, value: 0
2017.12.13 15:53:36 5: KeSolarEdge: Get: Called with AC-Power (h40083)
2017.12.13 15:53:36 4: KeSolarEdge: Send called with h40083, objLen 1 / reqLen - to id 1, op read, qlen 0
2017.12.13 15:53:36 4: KeSolarEdge: Send adds fc 3 to 1, tid 231, for h40083 (AC-Power), reqLen 1 at beginning of queue for immediate sending
2017.12.13 15:53:36 5: KeSolarEdge: handle queue check commDelay (0.1) for KeSolarEdge: rest 0.0445868968963623
2017.12.13 15:53:36 4: KeSolarEdge: HandleSendQueue / CheckDelay commDelay (0.1) for KeSolarEdge not over, sleep 0.0445868968963623 forced
2017.12.13 15:53:36 5: KeSolarEdge: handle queue check sendDelay (0.1) for KeSolarEdge: rest 0.0293118953704834
2017.12.13 15:53:36 4: KeSolarEdge: HandleSendQueue / CheckDelay sendDelay (0.1) for KeSolarEdge not over, sleep 0.0293118953704834 forced
2017.12.13 15:53:36 5: KeSolarEdge: HandleSendQueue: finished delay checking, proceed with sending
2017.12.13 15:53:36 4: KeSolarEdge: HandleSendQueue sends fc 3 to id 1, tid 231 for AC-Power (h40083), len 1, device KeSolarEdge (TCP), pdu 039c930001, V 3.7.0 - 20.8.2017
2017.12.13 15:53:36 5: SW: 00e70000000601039c930001
2017.12.13 15:53:36 5: KeSolarEdge: ReadAnswer called and remaining timeout is 1.99950289726257 requested reading is AC-Power
2017.12.13 15:53:36 5: KeSolarEdge: ReadAnswer got: 00e7000000050103025dc0
2017.12.13 15:53:36 5: KeSolarEdge: ParseFrames got: 00e7000000050103025dc0
2017.12.13 15:53:36 4: KeSolarEdge: ParseFrames got fcode 3 from 1, tid 231, values 5dc0HeaderLen 2, ActualLen 2, request was for h40083 (AC-Power), len 1 for module KeSolarEdge
2017.12.13 15:53:36 5: KeSolarEdge: ParseObj called with 5dc0 and start 40083, op read
2017.12.13 15:53:36 5: KeSolarEdge: ParseObj ObjInfo for h40083: reading=AC-Power, unpack=n, expr=, format=, map=
2017.12.13 15:53:36 5: KeSolarEdge: ParseObj unpacked 5dc0 with n to hex 3234303030 (24000)
2017.12.13 15:53:36 4: KeSolarEdge: ParseObj for AC-Power assigns 24000
2017.12.13 15:53:36 5: KeSolarEdge: ReadAnswer done, reading is AC-Power, value: 24000
2017.12.13 15:53:36 3: get KeSolarEdge AC-Power : 24000
2017.12.13 15:53:36 5: KeSolarEdge: Get: Called with AC-Power-Scale (h40084)
2017.12.13 15:53:36 4: KeSolarEdge: Send called with h40084, objLen 1 / reqLen - to id 1, op read, qlen 0
2017.12.13 15:53:36 4: KeSolarEdge: Send adds fc 3 to 1, tid 168, for h40084 (AC-Power-Scale), reqLen 1 at beginning of queue for immediate sending
2017.12.13 15:53:36 5: KeSolarEdge: handle queue check commDelay (0.1) for KeSolarEdge: rest 0.0678648948669434
2017.12.13 15:53:36 4: KeSolarEdge: HandleSendQueue / CheckDelay commDelay (0.1) for KeSolarEdge not over, sleep 0.0678648948669434 forced
2017.12.13 15:53:36 5: KeSolarEdge: handle queue check sendDelay (0.1) for KeSolarEdge: rest 0.0635199546813965
2017.12.13 15:53:36 4: KeSolarEdge: HandleSendQueue / CheckDelay sendDelay (0.1) for KeSolarEdge not over, sleep 0.0635199546813965 forced
2017.12.13 15:53:36 4: KeSolarEdge: HandleSendQueue sends fc 3 to id 1, tid 168 for AC-Power-Scale (h40084), len 1, device KeSolarEdge (TCP), pdu 039c940001, V 3.7.0 - 20.8.2017
2017.12.13 15:53:36 5: SW: 00a80000000601039c940001
2017.12.13 15:53:36 5: KeSolarEdge: ReadAnswer called and remaining timeout is 1.99963593482971 requested reading is AC-Power-Scale
2017.12.13 15:53:36 5: KeSolarEdge: ReadAnswer got: 00a800000005010302fffd
2017.12.13 15:53:36 5: KeSolarEdge: ParseFrames got: 00a800000005010302fffd
2017.12.13 15:53:36 4: KeSolarEdge: ParseFrames got fcode 3 from 1, tid 168, values fffdHeaderLen 2, ActualLen 2, request was for h40084 (AC-Power-Scale), len 1 for module KeSolarEdge
2017.12.13 15:53:36 5: KeSolarEdge: ParseObj called with fffd and start 40084, op read
2017.12.13 15:53:36 5: KeSolarEdge: ParseObj ObjInfo for h40084: reading=AC-Power-Scale, unpack=s>, expr=, format=, map=
2017.12.13 15:53:36 5: KeSolarEdge: ParseObj unpacked fffd with s> to hex 2d33 (-3)
2017.12.13 15:53:36 4: KeSolarEdge: ParseObj for AC-Power-Scale assigns -3
2017.12.13 15:53:36 5: KeSolarEdge: ReadAnswer done, reading is AC-Power-Scale, value: -3
2017.12.13 15:53:36 3: get KeSolarEdge AC-Power-Scale : -3
2017.12.13 15:53:36 5: KeSolarEdge: Get: Called with DC-Power (h40100)
2017.12.13 15:53:36 4: KeSolarEdge: Send called with h40100, objLen 1 / reqLen - to id 1, op read, qlen 0
2017.12.13 15:53:36 4: KeSolarEdge: Send adds fc 3 to 1, tid 124, for h40100 (DC-Power), reqLen 1 at beginning of queue for immediate sending
2017.12.13 15:53:36 5: KeSolarEdge: handle queue check commDelay (0.1) for KeSolarEdge: rest 0.0471358299255371
2017.12.13 15:53:36 4: KeSolarEdge: HandleSendQueue / CheckDelay commDelay (0.1) for KeSolarEdge not over, sleep 0.0471358299255371 forced
2017.12.13 15:53:36 5: KeSolarEdge: handle queue check sendDelay (0.1) for KeSolarEdge: rest 0.0420279502868652
2017.12.13 15:53:36 4: KeSolarEdge: HandleSendQueue / CheckDelay sendDelay (0.1) for KeSolarEdge not over, sleep 0.0420279502868652 forced
2017.12.13 15:53:36 4: KeSolarEdge: HandleSendQueue sends fc 3 to id 1, tid 124 for DC-Power (h40100), len 1, device KeSolarEdge (TCP), pdu 039ca40001, V 3.7.0 - 20.8.2017
2017.12.13 15:53:36 5: SW: 007c0000000601039ca40001
2017.12.13 15:53:36 5: KeSolarEdge: ReadAnswer called and remaining timeout is 1.99956893920898 requested reading is DC-Power
2017.12.13 15:53:36 5: KeSolarEdge: ReadAnswer got: 007c000000050103025f2d
2017.12.13 15:53:36 5: KeSolarEdge: ParseFrames got: 007c000000050103025f2d
2017.12.13 15:53:36 4: KeSolarEdge: ParseFrames got fcode 3 from 1, tid 124, values 5f2dHeaderLen 2, ActualLen 2, request was for h40100 (DC-Power), len 1 for module KeSolarEdge
2017.12.13 15:53:36 5: KeSolarEdge: ParseObj called with 5f2d and start 40100, op read
2017.12.13 15:53:36 5: KeSolarEdge: ParseObj ObjInfo for h40100: reading=DC-Power, unpack=n, expr=, format=, map=
2017.12.13 15:53:36 5: KeSolarEdge: ParseObj unpacked 5f2d with n to hex 3234333635 (24365)
2017.12.13 15:53:36 4: KeSolarEdge: ParseObj for DC-Power assigns 24365
2017.12.13 15:53:36 5: KeSolarEdge: ReadAnswer done, reading is DC-Power, value: 24365
2017.12.13 15:53:36 3: get KeSolarEdge DC-Power : 24365
2017.12.13 15:53:36 5: KeSolarEdge: Get: Called with DC-Power-Scale (h40101)
2017.12.13 15:53:36 4: KeSolarEdge: Send called with h40101, objLen 1 / reqLen - to id 1, op read, qlen 0
2017.12.13 15:53:36 4: KeSolarEdge: Send adds fc 3 to 1, tid 212, for h40101 (DC-Power-Scale), reqLen 1 at beginning of queue for immediate sending
2017.12.13 15:53:36 5: KeSolarEdge: handle queue check commDelay (0.1) for KeSolarEdge: rest 0.0678768157958984
2017.12.13 15:53:36 4: KeSolarEdge: HandleSendQueue / CheckDelay commDelay (0.1) for KeSolarEdge not over, sleep 0.0678768157958984 forced
2017.12.13 15:53:36 5: KeSolarEdge: handle queue check sendDelay (0.1) for KeSolarEdge: rest 0.0573928356170654
2017.12.13 15:53:36 4: KeSolarEdge: HandleSendQueue / CheckDelay sendDelay (0.1) for KeSolarEdge not over, sleep 0.0573928356170654 forced
2017.12.13 15:53:36 4: KeSolarEdge: HandleSendQueue sends fc 3 to id 1, tid 212 for DC-Power-Scale (h40101), len 1, device KeSolarEdge (TCP), pdu 039ca50001, V 3.7.0 - 20.8.2017
2017.12.13 15:53:36 5: SW: 00d40000000601039ca50001
2017.12.13 15:53:36 5: KeSolarEdge: ReadAnswer called and remaining timeout is 1.99959897994995 requested reading is DC-Power-Scale
2017.12.13 15:53:36 5: KeSolarEdge: ReadAnswer got: 00d400000005010302fffd
2017.12.13 15:53:36 5: KeSolarEdge: ParseFrames got: 00d400000005010302fffd
2017.12.13 15:53:36 4: KeSolarEdge: ParseFrames got fcode 3 from 1, tid 212, values fffdHeaderLen 2, ActualLen 2, request was for h40101 (DC-Power-Scale), len 1 for module KeSolarEdge
2017.12.13 15:53:36 5: KeSolarEdge: ParseObj called with fffd and start 40101, op read
2017.12.13 15:53:36 5: KeSolarEdge: ParseObj ObjInfo for h40101: reading=DC-Power-Scale, unpack=s>, expr=, format=, map=
2017.12.13 15:53:36 4: KeSolarEdge: ParseObj for DC-Power-Scale assigns -3
2017.12.13 15:53:36 5: KeSolarEdge: ReadAnswer done, reading is DC-Power-Scale, value: -3
2017.12.13 15:53:36 3: get KeSolarEdge DC-Power-Scale : -3
2017.12.13 15:53:36 5: KeSolarEdge: Get: Called with DC-Voltage (h40098)
2017.12.13 15:53:36 4: KeSolarEdge: Send called with h40098, objLen 1 / reqLen - to id 1, op read, qlen 0
2017.12.13 15:53:36 4: KeSolarEdge: Send adds fc 3 to 1, tid 157, for h40098 (DC-Voltage), reqLen 1 at beginning of queue for immediate sending
2017.12.13 15:53:36 5: KeSolarEdge: handle queue check commDelay (0.1) for KeSolarEdge: rest 0.0467789173126221
2017.12.13 15:53:36 4: KeSolarEdge: HandleSendQueue / CheckDelay commDelay (0.1) for KeSolarEdge not over, sleep 0.0467789173126221 forced
2017.12.13 15:53:36 5: KeSolarEdge: handle queue check sendDelay (0.1) for KeSolarEdge: rest 0.0305407047271729
2017.12.13 15:53:36 4: KeSolarEdge: HandleSendQueue / CheckDelay sendDelay (0.1) for KeSolarEdge not over, sleep 0.0305407047271729 forced
2017.12.13 15:53:36 4: KeSolarEdge: HandleSendQueue sends fc 3 to id 1, tid 157 for DC-Voltage (h40098), len 1, device KeSolarEdge (TCP), pdu 039ca20001, V 3.7.0 - 20.8.2017
2017.12.13 15:53:36 5: SW: 009d0000000601039ca20001
2017.12.13 15:53:36 5: KeSolarEdge: ReadAnswer called and remaining timeout is 1.99949216842651 requested reading is DC-Voltage
2017.12.13 15:53:36 5: KeSolarEdge: ReadAnswer got: 009d000000050103021d3a
2017.12.13 15:53:36 5: KeSolarEdge: ParseFrames got: 009d000000050103021d3a
2017.12.13 15:53:36 4: KeSolarEdge: ParseFrames got fcode 3 from 1, tid 157, values 1d3aHeaderLen 2, ActualLen 2, request was for h40098 (DC-Voltage), len 1 for module KeSolarEdge
2017.12.13 15:53:36 5: KeSolarEdge: ParseObj called with 1d3a and start 40098, op read
2017.12.13 15:53:36 5: KeSolarEdge: ParseObj ObjInfo for h40098: reading=DC-Voltage, unpack=n, expr=, format=, map=
2017.12.13 15:53:36 5: KeSolarEdge: ParseObj unpacked 1d3a with n to hex 37343832 (7482)
2017.12.13 15:53:36 4: KeSolarEdge: ParseObj for DC-Voltage assigns 7482
2017.12.13 15:53:36 5: KeSolarEdge: ReadAnswer done, reading is DC-Voltage, value: 7482
2017.12.13 15:53:36 3: get KeSolarEdge DC-Voltage : 7482
2017.12.13 15:53:36 5: KeSolarEdge: Get: Called with DC-Voltage-Scale (h40099)
2017.12.13 15:53:36 4: KeSolarEdge: Send called with h40099, objLen 1 / reqLen - to id 1, op read, qlen 0
2017.12.13 15:53:36 4: KeSolarEdge: Send adds fc 3 to 1, tid 15, for h40099 (DC-Voltage-Scale), reqLen 1 at beginning of queue for immediate sending
2017.12.13 15:53:36 5: KeSolarEdge: handle queue check commDelay (0.1) for KeSolarEdge: rest 0.0675590038299561
2017.12.13 15:53:36 4: KeSolarEdge: HandleSendQueue / CheckDelay commDelay (0.1) for KeSolarEdge not over, sleep 0.0675590038299561 forced
2017.12.13 15:53:36 5: KeSolarEdge: handle queue check sendDelay (0.1) for KeSolarEdge: rest 0.0603690147399902
2017.12.13 15:53:36 4: KeSolarEdge: HandleSendQueue / CheckDelay sendDelay (0.1) for KeSolarEdge not over, sleep 0.0603690147399902 forced
2017.12.13 15:53:36 4: KeSolarEdge: HandleSendQueue sends fc 3 to id 1, tid 15 for DC-Voltage-Scale (h40099), len 1, device KeSolarEdge (TCP), pdu 039ca30001, V 3.7.0 - 20.8.2017
2017.12.13 15:53:36 5: SW: 000f0000000601039ca30001
2017.12.13 15:53:36 5: KeSolarEdge: ReadAnswer called and remaining timeout is 1.99963402748108 requested reading is DC-Voltage-Scale
2017.12.13 15:53:36 5: KeSolarEdge: ReadAnswer got: 000f00000005010302ffff
2017.12.13 15:53:36 5: KeSolarEdge: ParseFrames got: 000f00000005010302ffff
2017.12.13 15:53:36 4: KeSolarEdge: ParseFrames got fcode 3 from 1, tid 15, values ffffHeaderLen 2, ActualLen 2, request was for h40099 (DC-Voltage-Scale), len 1 for module KeSolarEdge
2017.12.13 15:53:36 5: KeSolarEdge: ParseObj called with ffff and start 40099, op read
2017.12.13 15:53:36 5: KeSolarEdge: ParseObj ObjInfo for h40099: reading=DC-Voltage-Scale, unpack=s>, expr=, format=, map=
2017.12.13 15:53:36 5: KeSolarEdge: ParseObj unpacked ffff with s> to hex 2d31 (-1)
2017.12.13 15:53:36 4: KeSolarEdge: ParseObj for DC-Voltage-Scale assigns -1
2017.12.13 15:53:36 5: KeSolarEdge: ReadAnswer done, reading is DC-Voltage-Scale, value: -1
2017.12.13 15:53:36 3: get KeSolarEdge DC-Voltage-Scale : -1
2017.12.13 15:53:36 5: KeSolarEdge: Get: Called with Status (h40107)
2017.12.13 15:53:36 4: KeSolarEdge: Send called with h40107, objLen 1 / reqLen - to id 1, op read, qlen 0
2017.12.13 15:53:36 4: KeSolarEdge: Send adds fc 3 to 1, tid 36, for h40107 (Status), reqLen 1 at beginning of queue for immediate sending
2017.12.13 15:53:36 5: KeSolarEdge: handle queue check commDelay (0.1) for KeSolarEdge: rest 0.0472097396850586
2017.12.13 15:53:36 4: KeSolarEdge: HandleSendQueue / CheckDelay commDelay (0.1) for KeSolarEdge not over, sleep 0.0472097396850586 forced
2017.12.13 15:53:36 5: KeSolarEdge: handle queue check sendDelay (0.1) for KeSolarEdge: rest 0.0430431365966797
2017.12.13 15:53:36 4: KeSolarEdge: HandleSendQueue / CheckDelay sendDelay (0.1) for KeSolarEdge not over, sleep 0.0430431365966797 forced
2017.12.13 15:53:36 4: KeSolarEdge: HandleSendQueue sends fc 3 to id 1, tid 36 for Status (h40107), len 1, device KeSolarEdge (TCP), pdu 039cab0001, V 3.7.0 - 20.8.2017
2017.12.13 15:53:36 5: SW: 00240000000601039cab0001
2017.12.13 15:53:36 5: KeSolarEdge: ReadAnswer called and remaining timeout is 1.99961113929749 requested reading is Status
2017.12.13 15:53:36 5: KeSolarEdge: ReadAnswer got: 0024000000050103020004
2017.12.13 15:53:36 5: KeSolarEdge: ParseFrames got: 0024000000050103020004
2017.12.13 15:53:36 4: KeSolarEdge: ParseFrames got fcode 3 from 1, tid 36, values 0004HeaderLen 2, ActualLen 2, request was for h40107 (Status), len 1 for module KeSolarEdge
2017.12.13 15:53:36 5: KeSolarEdge: ParseObj called with 0004 and start 40107, op read
2017.12.13 15:53:36 5: KeSolarEdge: ParseObj ObjInfo for h40107: reading=Status, unpack=n, expr=, format=, map=
2017.12.13 15:53:36 5: KeSolarEdge: ParseObj unpacked 0004 with n to hex 34 (4)
2017.12.13 15:53:36 4: KeSolarEdge: ParseObj for Status assigns 4
2017.12.13 15:53:36 5: KeSolarEdge: ReadAnswer done, reading is Status, value: 4
2017.12.13 15:53:36 3: get KeSolarEdge Status : 4
2017.12.13 15:55:36 3: 192.168.178.36:502 disconnected, waiting to reappear (KeSolarEdge)
2017.12.13 15:55:36 5: HttpUtils url=http://192.168.178.36:502/
2017.12.13 15:55:36 1: disconnected
2017.12.13 15:55:36 3: 192.168.178.36:502 reappeared (KeSolarEdge)
2017.12.13 15:56:02 1: prg_brenner temp: temperature: 54.6
2017.12.13 15:56:36 5: KeSolarEdge: Get: Called with AC-Energy (h40093)
2017.12.13 15:56:36 4: KeSolarEdge: Send called with h40093, objLen 2 / reqLen - to id 1, op read, qlen 0
2017.12.13 15:56:36 4: KeSolarEdge: Send adds fc 3 to 1, tid 218, for h40093 (AC-Energy), reqLen 2 at beginning of queue for immediate sending
2017.12.13 15:56:36 5: KeSolarEdge: handle queue check commDelay (0.1) for KeSolarEdge: rest -179.941762208939
2017.12.13 15:56:36 5: KeSolarEdge: handle queue check sendDelay (0.1) for KeSolarEdge: rest -179.949740886688
2017.12.13 15:56:36 5: KeSolarEdge: HandleSendQueue: finished delay checking, proceed with sending
2017.12.13 15:56:36 4: KeSolarEdge: HandleSendQueue sends fc 3 to id 1, tid 218 for AC-Energy (h40093), len 2, device KeSolarEdge (TCP), pdu 039c9d0002, V 3.7.0 - 20.8.2017
2017.12.13 15:56:36 5: SW: 00da0000000601039c9d0002
2017.12.13 15:56:36 5: KeSolarEdge: ReadAnswer called and remaining timeout is 1.99959397315979 requested reading is AC-Energy
2017.12.13 15:56:36 5: KeSolarEdge: ReadAnswer got: 00da0000000701030400010267
2017.12.13 15:56:36 5: KeSolarEdge: ParseFrames got: 00da0000000701030400010267
2017.12.13 15:56:36 4: KeSolarEdge: ParseFrames got fcode 3 from 1, tid 218, values 00010267HeaderLen 4, ActualLen 4, request was for h40093 (AC-Energy), len 2 for module KeSolarEdge
2017.12.13 15:56:36 5: KeSolarEdge: ParseObj called with 00010267 and start 40093, op read
2017.12.13 15:56:36 5: KeSolarEdge: ParseObj ObjInfo for h40093: reading=AC-Energy, unpack=l>, expr=, format=, map=
2017.12.13 15:56:36 5: KeSolarEdge: ParseObj unpacked 00010267 with l> to hex 3636313531 (66151)
2017.12.13 15:56:36 4: KeSolarEdge: ParseObj for AC-Energy assigns 66151
2017.12.13 15:56:36 5: KeSolarEdge: ParseFrames got 1 readings from ParseObj
2017.12.13 15:56:36 5: KeSolarEdge: ReadAnswer done, reading is AC-Energy, value: 66151
2017.12.13 15:56:36 3: get KeSolarEdge AC-Energy : 66151
2017.12.13 15:56:36 5: KeSolarEdge: Get: Called with AC-Energy-Scale (h40095)
2017.12.13 15:56:36 4: KeSolarEdge: Send called with h40095, objLen 1 / reqLen - to id 1, op read, qlen 0
2017.12.13 15:56:36 4: KeSolarEdge: Send adds fc 3 to 1, tid 155, for h40095 (AC-Energy-Scale), reqLen 1 at beginning of queue for immediate sending
2017.12.13 15:56:36 5: KeSolarEdge: handle queue check commDelay (0.1) for KeSolarEdge: rest 0.066267728805542
2017.12.13 15:56:36 4: KeSolarEdge: HandleSendQueue / CheckDelay commDelay (0.1) for KeSolarEdge not over, sleep 0.066267728805542 forced
2017.12.13 15:56:36 5: KeSolarEdge: handle queue check sendDelay (0.1) for KeSolarEdge: rest 0.0619838237762451
2017.12.13 15:56:36 4: KeSolarEdge: HandleSendQueue / CheckDelay sendDelay (0.1) for KeSolarEdge not over, sleep 0.0619838237762451 forced
2017.12.13 15:56:36 4: KeSolarEdge: HandleSendQueue sends fc 3 to id 1, tid 155 for AC-Energy-Scale (h40095), len 1, device KeSolarEdge (TCP), pdu 039c9f0001, V 3.7.0 - 20.8.2017
2017.12.13 15:56:36 5: SW: 009b0000000601039c9f0001
2017.12.13 15:56:36 5: KeSolarEdge: ReadAnswer called and remaining timeout is 1.99952793121338 requested reading is AC-Energy-Scale
2017.12.13 15:56:36 5: KeSolarEdge: ReadAnswer got: 009b000000050103020000
2017.12.13 15:56:36 5: KeSolarEdge: ParseFrames got: 009b000000050103020000
2017.12.13 15:56:36 4: KeSolarEdge: ParseFrames got fcode 3 from 1, tid 155, values 0000HeaderLen 2, ActualLen 2, request was for h40095 (AC-Energy-Scale), len 1 for module KeSolarEdge
2017.12.13 15:56:36 5: KeSolarEdge: ParseObj called with 0000 and start 40095, op read
2017.12.13 15:56:36 5: KeSolarEdge: ParseObj ObjInfo for h40095: reading=AC-Energy-Scale, unpack=n, expr=, format=, map=
2017.12.13 15:56:36 5: KeSolarEdge: ParseObj unpacked 0000 with n to hex 30 (0)
2017.12.13 15:56:36 4: KeSolarEdge: ParseObj for AC-Energy-Scale assigns 0
2017.12.13 15:56:36 5: KeSolarEdge: ReadAnswer done, reading is AC-Energy-Scale, value: 0
2017.12.13 15:56:36 5: KeSolarEdge: Get: Called with AC-Power (h40083)
2017.12.13 15:56:36 4: KeSolarEdge: Send called with h40083, objLen 1 / reqLen - to id 1, op read, qlen 0
2017.12.13 15:56:36 4: KeSolarEdge: Send adds fc 3 to 1, tid 41, for h40083 (AC-Power), reqLen 1 at beginning of queue for immediate sending
2017.12.13 15:56:36 5: KeSolarEdge: handle queue check commDelay (0.1) for KeSolarEdge: rest 0.045637845993042
2017.12.13 15:56:36 4: KeSolarEdge: HandleSendQueue / CheckDelay commDelay (0.1) for KeSolarEdge not over, sleep 0.045637845993042 forced
2017.12.13 15:56:36 5: KeSolarEdge: handle queue check sendDelay (0.1) for KeSolarEdge: rest 0.0423038005828857
2017.12.13 15:56:36 4: KeSolarEdge: HandleSendQueue / CheckDelay sendDelay (0.1) for KeSolarEdge not over, sleep 0.0423038005828857 forced
2017.12.13 15:56:36 4: KeSolarEdge: HandleSendQueue sends fc 3 to id 1, tid 41 for AC-Power (h40083), len 1, device KeSolarEdge (TCP), pdu 039c930001, V 3.7.0 - 20.8.2017
2017.12.13 15:56:36 5: SW: 00290000000601039c930001
2017.12.13 15:56:36 5: KeSolarEdge: ReadAnswer called and remaining timeout is 1.99960780143738 requested reading is AC-Power
2017.12.13 15:56:36 5: KeSolarEdge: ReadAnswer got: 0029000000050103020c1c
2017.12.13 15:56:36 5: KeSolarEdge: ParseFrames got: 0029000000050103020c1c
2017.12.13 15:56:36 4: KeSolarEdge: ParseFrames got fcode 3 from 1, tid 41, values 0c1cHeaderLen 2, ActualLen 2, request was for h40083 (AC-Power), len 1 for module KeSolarEdge
2017.12.13 15:56:36 5: KeSolarEdge: ParseObj called with 0c1c and start 40083, op read
2017.12.13 15:56:36 5: KeSolarEdge: ParseObj ObjInfo for h40083: reading=AC-Power, unpack=n, expr=, format=, map=
2017.12.13 15:56:36 5: KeSolarEdge: ParseObj unpacked 0c1c with n to hex 33313030 (3100)
2017.12.13 15:56:36 4: KeSolarEdge: ParseObj for AC-Power assigns 3100
2017.12.13 15:56:36 5: KeSolarEdge: ReadAnswer done, reading is AC-Power, value: 3100
2017.12.13 15:56:36 3: get KeSolarEdge AC-Power : 3100
2017.12.13 15:56:36 5: KeSolarEdge: Get: Called with AC-Power-Scale (h40084)
2017.12.13 15:56:36 4: KeSolarEdge: Send called with h40084, objLen 1 / reqLen - to id 1, op read, qlen 0
2017.12.13 15:56:36 4: KeSolarEdge: Send adds fc 3 to 1, tid 240, for h40084 (AC-Power-Scale), reqLen 1 at beginning of queue for immediate sending
2017.12.13 15:56:36 5: KeSolarEdge: handle queue check commDelay (0.1) for KeSolarEdge: rest 0.0674428939819336
2017.12.13 15:56:36 4: KeSolarEdge: HandleSendQueue / CheckDelay commDelay (0.1) for KeSolarEdge not over, sleep 0.0674428939819336 forced
2017.12.13 15:56:36 5: KeSolarEdge: handle queue check sendDelay (0.1) for KeSolarEdge: rest 0.06036376953125
2017.12.13 15:56:36 4: KeSolarEdge: HandleSendQueue / CheckDelay sendDelay (0.1) for KeSolarEdge not over, sleep 0.06036376953125 forced
2017.12.13 15:56:36 4: KeSolarEdge: HandleSendQueue sends fc 3 to id 1, tid 240 for AC-Power-Scale (h40084), len 1, device KeSolarEdge (TCP), pdu 039c940001, V 3.7.0 - 20.8.2017
2017.12.13 15:56:36 5: SW: 00f00000000601039c940001
2017.12.13 15:56:36 5: KeSolarEdge: ReadAnswer called and remaining timeout is 1.9996018409729 requested reading is AC-Power-Scale
2017.12.13 15:56:36 5: KeSolarEdge: ReadAnswer got: 00f000000005010302fffe
2017.12.13 15:56:36 5: KeSolarEdge: ParseFrames got: 00f000000005010302fffe
2017.12.13 15:56:36 4: KeSolarEdge: ParseFrames got fcode 3 from 1, tid 240, values fffeHeaderLen 2, ActualLen 2, request was for h40084 (AC-Power-Scale), len 1 for module KeSolarEdge
2017.12.13 15:56:36 5: KeSolarEdge: ParseObj called with fffe and start 40084, op read
2017.12.13 15:56:36 5: KeSolarEdge: ParseObj ObjInfo for h40084: reading=AC-Power-Scale, unpack=s>, expr=, format=, map=
2017.12.13 15:56:36 5: KeSolarEdge: ParseObj unpacked fffe with s> to hex 2d32 (-2)
2017.12.13 15:56:36 4: KeSolarEdge: ParseObj for AC-Power-Scale assigns -2
2017.12.13 15:56:36 5: KeSolarEdge: ReadAnswer done, reading is AC-Power-Scale, value: -2
2017.12.13 15:56:36 3: get KeSolarEdge AC-Power-Scale : -2
2017.12.13 15:56:36 5: KeSolarEdge: Get: Called with DC-Power (h40100)
2017.12.13 15:56:36 4: KeSolarEdge: Send called with h40100, objLen 1 / reqLen - to id 1, op read, qlen 0
2017.12.13 15:56:36 4: KeSolarEdge: Send adds fc 3 to 1, tid 24, for h40100 (DC-Power), reqLen 1 at beginning of queue for immediate sending
2017.12.13 15:56:36 5: KeSolarEdge: handle queue check commDelay (0.1) for KeSolarEdge: rest 0.0473949909210205
2017.12.13 15:56:36 4: KeSolarEdge: HandleSendQueue / CheckDelay commDelay (0.1) for KeSolarEdge not over, sleep 0.0473949909210205 forced
2017.12.13 15:56:36 5: KeSolarEdge: handle queue check sendDelay (0.1) for KeSolarEdge: rest 0.0428109169006348
2017.12.13 15:56:36 4: KeSolarEdge: HandleSendQueue / CheckDelay sendDelay (0.1) for KeSolarEdge not over, sleep 0.0428109169006348 forced
2017.12.13 15:56:36 4: KeSolarEdge: HandleSendQueue sends fc 3 to id 1, tid 24 for DC-Power (h40100), len 1, device KeSolarEdge (TCP), pdu 039ca40001, V 3.7.0 - 20.8.2017
2017.12.13 15:56:36 5: SW: 00180000000601039ca40001
2017.12.13 15:56:36 5: KeSolarEdge: ReadAnswer called and remaining timeout is 1.99958896636963 requested reading is DC-Power
2017.12.13 15:56:36 5: KeSolarEdge: ReadAnswer got: 0018000000050103026f0a
2017.12.13 15:56:36 5: KeSolarEdge: ParseFrames got: 0018000000050103026f0a
2017.12.13 15:56:36 4: KeSolarEdge: ParseFrames got fcode 3 from 1, tid 24, values 6f0aHeaderLen 2, ActualLen 2, request was for h40100 (DC-Power), len 1 for module KeSolarEdge
2017.12.13 15:56:36 5: KeSolarEdge: ParseObj called with 6f0a and start 40100, op read
2017.12.13 15:56:36 5: KeSolarEdge: ParseObj ObjInfo for h40100: reading=DC-Power, unpack=n, expr=, format=, map=
2017.12.13 15:56:36 5: KeSolarEdge: ParseObj unpacked 6f0a with n to hex 3238343236 (28426)
2017.12.13 15:56:36 4: KeSolarEdge: ParseObj for DC-Power assigns 28426
2017.12.13 15:56:36 5: KeSolarEdge: ReadAnswer done, reading is DC-Power, value: 28426
2017.12.13 15:56:36 3: get KeSolarEdge DC-Power : 28426
2017.12.13 15:56:36 5: KeSolarEdge: Get: Called with DC-Power-Scale (h40101)
2017.12.13 15:56:36 4: KeSolarEdge: Send called with h40101, objLen 1 / reqLen - to id 1, op read, qlen 0
2017.12.13 15:56:36 4: KeSolarEdge: Send adds fc 3 to 1, tid 109, for h40101 (DC-Power-Scale), reqLen 1 at beginning of queue for immediate sending
2017.12.13 15:56:36 5: KeSolarEdge: handle queue check commDelay (0.1) for KeSolarEdge: rest 0.0524137020111084
2017.12.13 15:56:36 4: KeSolarEdge: HandleSendQueue / CheckDelay commDelay (0.1) for KeSolarEdge not over, sleep 0.0524137020111084 forced
2017.12.13 15:56:36 5: KeSolarEdge: handle queue check sendDelay (0.1) for KeSolarEdge: rest 0.00745582580566406
2017.12.13 15:56:36 4: KeSolarEdge: HandleSendQueue / CheckDelay sendDelay (0.1) for KeSolarEdge not over, sleep 0.00745582580566406 forced
2017.12.13 15:56:36 4: KeSolarEdge: HandleSendQueue sends fc 3 to id 1, tid 109 for DC-Power-Scale (h40101), len 1, device KeSolarEdge (TCP), pdu 039ca50001, V 3.7.0 - 20.8.2017
2017.12.13 15:56:36 5: SW: 006d0000000601039ca50001
2017.12.13 15:56:36 5: KeSolarEdge: ReadAnswer called and remaining timeout is 1.99940896034241 requested reading is DC-Power-Scale
2017.12.13 15:56:36 5: KeSolarEdge: ReadAnswer got: 006d00000005010302fffd
2017.12.13 15:56:36 5: KeSolarEdge: ParseFrames got: 006d00000005010302fffd
2017.12.13 15:56:36 4: KeSolarEdge: ParseFrames got fcode 3 from 1, tid 109, values fffdHeaderLen 2, ActualLen 2, request was for h40101 (DC-Power-Scale), len 1 for module KeSolarEdge
2017.12.13 15:56:36 5: KeSolarEdge: ParseObj called with fffd and start 40101, op read
2017.12.13 15:56:36 5: KeSolarEdge: ParseObj ObjInfo for h40101: reading=DC-Power-Scale, unpack=s>, expr=, format=, map=
2017.12.13 15:56:36 5: KeSolarEdge: ParseObj unpacked fffd with s> to hex 2d33 (-3)
2017.12.13 15:56:36 4: KeSolarEdge: ParseObj for DC-Power-Scale assigns -3
2017.12.13 15:56:36 5: KeSolarEdge: ReadAnswer done, reading is DC-Power-Scale, value: -3
2017.12.13 15:56:36 3: get KeSolarEdge DC-Power-Scale : -3
2017.12.13 15:56:36 5: KeSolarEdge: Get: Called with DC-Voltage (h40098)
2017.12.13 15:56:36 4: KeSolarEdge: Send called with h40098, objLen 1 / reqLen - to id 1, op read, qlen 0
2017.12.13 15:56:36 4: KeSolarEdge: Send adds fc 3 to 1, tid 71, for h40098 (DC-Voltage), reqLen 1 at beginning of queue for immediate sending
2017.12.13 15:56:36 5: KeSolarEdge: handle queue check commDelay (0.1) for KeSolarEdge: rest 0.0320219993591309
2017.12.13 15:56:36 4: KeSolarEdge: HandleSendQueue / CheckDelay commDelay (0.1) for KeSolarEdge not over, sleep 0.0320219993591309 forced
2017.12.13 15:56:36 5: KeSolarEdge: handle queue check sendDelay (0.1) for KeSolarEdge: rest 0.0281867980957031
2017.12.13 15:56:36 4: KeSolarEdge: HandleSendQueue / CheckDelay sendDelay (0.1) for KeSolarEdge not over, sleep 0.0281867980957031 forced
2017.12.13 15:56:36 4: KeSolarEdge: HandleSendQueue sends fc 3 to id 1, tid 71 for DC-Voltage (h40098), len 1, device KeSolarEdge (TCP), pdu 039ca20001, V 3.7.0 - 20.8.2017
2017.12.13 15:56:36 5: SW: 00470000000601039ca20001
2017.12.13 15:56:36 5: KeSolarEdge: ReadAnswer called and remaining timeout is 1.99961686134338 requested reading is DC-Voltage
2017.12.13 15:56:36 5: KeSolarEdge: ReadAnswer got: 0047000000050103021d38
2017.12.13 15:56:36 5: KeSolarEdge: ParseFrames got: 0047000000050103021d38
2017.12.13 15:56:36 4: KeSolarEdge: ParseFrames got fcode 3 from 1, tid 71, values 1d38HeaderLen 2, ActualLen 2, request was for h40098 (DC-Voltage), len 1 for module KeSolarEdge
2017.12.13 15:56:36 5: KeSolarEdge: ParseObj called with 1d38 and start 40098, op read
2017.12.13 15:56:36 5: KeSolarEdge: ParseObj ObjInfo for h40098: reading=DC-Voltage, unpack=n, expr=, format=, map=
2017.12.13 15:56:36 5: KeSolarEdge: ParseObj unpacked 1d38 with n to hex 37343830 (7480)
2017.12.13 15:56:36 4: KeSolarEdge: ParseObj for DC-Voltage assigns 7480
2017.12.13 15:56:36 5: KeSolarEdge: ReadAnswer done, reading is DC-Voltage, value: 7480
2017.12.13 15:56:36 3: get KeSolarEdge DC-Voltage : 7480
2017.12.13 15:56:36 5: KeSolarEdge: Get: Called with DC-Voltage-Scale (h40099)
2017.12.13 15:56:36 4: KeSolarEdge: Send called with h40099, objLen 1 / reqLen - to id 1, op read, qlen 0
2017.12.13 15:56:36 4: KeSolarEdge: Send adds fc 3 to 1, tid 211, for h40099 (DC-Voltage-Scale), reqLen 1 at beginning of queue for immediate sending
2017.12.13 15:56:36 5: KeSolarEdge: handle queue check commDelay (0.1) for KeSolarEdge: rest 0.0678548812866211
2017.12.13 15:56:36 4: KeSolarEdge: HandleSendQueue / CheckDelay commDelay (0.1) for KeSolarEdge not over, sleep 0.0678548812866211 forced
2017.12.13 15:56:36 5: KeSolarEdge: handle queue check sendDelay (0.1) for KeSolarEdge: rest 0.0644629001617432
2017.12.13 15:56:36 4: KeSolarEdge: HandleSendQueue / CheckDelay sendDelay (0.1) for KeSolarEdge not over, sleep 0.0644629001617432 forced
2017.12.13 15:56:36 4: KeSolarEdge: HandleSendQueue sends fc 3 to id 1, tid 211 for DC-Voltage-Scale (h40099), len 1, device KeSolarEdge (TCP), pdu 039ca30001, V 3.7.0 - 20.8.2017
2017.12.13 15:56:36 5: SW: 00d30000000601039ca30001
2017.12.13 15:56:36 5: KeSolarEdge: ReadAnswer called and remaining timeout is 1.99955105781555 requested reading is DC-Voltage-Scale
2017.12.13 15:56:36 5: KeSolarEdge: ReadAnswer got: 00d300000005010302ffff
2017.12.13 15:56:36 5: KeSolarEdge: ParseFrames got: 00d300000005010302ffff
2017.12.13 15:56:36 4: KeSolarEdge: ParseFrames got fcode 3 from 1, tid 211, values ffffHeaderLen 2, ActualLen 2, request was for h40099 (DC-Voltage-Scale), len 1 for module KeSolarEdge
2017.12.13 15:56:36 5: KeSolarEdge: ParseObj called with ffff and start 40099, op read
2017.12.13 15:56:36 5: KeSolarEdge: ParseObj ObjInfo for h40099: reading=DC-Voltage-Scale, unpack=s>, expr=, format=, map=
2017.12.13 15:56:36 5: KeSolarEdge: ParseObj unpacked ffff with s> to hex 2d31 (-1)
2017.12.13 15:56:36 4: KeSolarEdge: ParseObj for DC-Voltage-Scale assigns -1
2017.12.13 15:56:36 5: KeSolarEdge: ReadAnswer done, reading is DC-Voltage-Scale, value: -1
2017.12.13 15:56:36 3: get KeSolarEdge DC-Voltage-Scale : -1
2017.12.13 15:56:36 5: KeSolarEdge: Get: Called with Status (h40107)
2017.12.13 15:56:36 4: KeSolarEdge: Send called with h40107, objLen 1 / reqLen - to id 1, op read, qlen 0
2017.12.13 15:56:36 4: KeSolarEdge: Send adds fc 3 to 1, tid 107, for h40107 (Status), reqLen 1 at beginning of queue for immediate sending
2017.12.13 15:56:36 5: KeSolarEdge: handle queue check commDelay (0.1) for KeSolarEdge: rest 0.0471670627593994
2017.12.13 15:56:36 4: KeSolarEdge: HandleSendQueue / CheckDelay commDelay (0.1) for KeSolarEdge not over, sleep 0.0471670627593994 forced
2017.12.13 15:56:36 5: KeSolarEdge: handle queue check sendDelay (0.1) for KeSolarEdge: rest 0.0390989780426025
2017.12.13 15:56:36 4: KeSolarEdge: HandleSendQueue / CheckDelay sendDelay (0.1) for KeSolarEdge not over, sleep 0.0390989780426025 forced
2017.12.13 15:56:36 4: KeSolarEdge: HandleSendQueue sends fc 3 to id 1, tid 107 for Status (h40107), len 1, device KeSolarEdge (TCP), pdu 039cab0001, V 3.7.0 - 20.8.2017
2017.12.13 15:56:36 5: SW: 006b0000000601039cab0001
2017.12.13 15:56:36 5: KeSolarEdge: ReadAnswer called and remaining timeout is 1.99943900108337 requested reading is Status
2017.12.13 15:56:36 5: KeSolarEdge: ReadAnswer got: 006b000000050103020004
2017.12.13 15:56:36 5: KeSolarEdge: ParseFrames got: 006b000000050103020004
2017.12.13 15:56:36 4: KeSolarEdge: ParseFrames got fcode 3 from 1, tid 107, values 0004HeaderLen 2, ActualLen 2, request was for h40107 (Status), len 1 for module KeSolarEdge
2017.12.13 15:56:36 5: KeSolarEdge: ParseObj called with 0004 and start 40107, op read
2017.12.13 15:56:36 5: KeSolarEdge: ParseObj ObjInfo for h40107: reading=Status, unpack=n, expr=, format=, map=
2017.12.13 15:56:36 5: KeSolarEdge: ParseObj unpacked 0004 with n to hex 34 (4)
2017.12.13 15:56:36 4: KeSolarEdge: ParseObj for Status assigns 4
2017.12.13 15:56:36 5: KeSolarEdge: ReadAnswer done, reading is Status, value: 4
2017.12.13 15:56:36 3: get KeSolarEdge Status : 4
2017.12.13 15:57:11 5: KeSolarEdge: GetUpdate called
2017.12.13 15:57:11 4: KeSolarEdge: update timer modified: will call GetUpdate in 900.0 seconds at 2017-12-13 16:12:11 - Interval 900
2017.12.13 15:57:11 5: KeSolarEdge: GetUpdate objects from attributes: h40103 h40098 h40101 h40084 h40096 h40107 h40095 h40097 h40099 h40083 h40100 h40082 h40079 h40093
2017.12.13 15:57:11 5: KeSolarEdge: GetUpdate full object list: h40079 h40082 h40083 h40084 h40093 h40095 h40096 h40097 h40098 h40099 h40100 h40101 h40103 h40107
2017.12.13 15:57:11 5: KeSolarEdge: GetUpdate check h40079 => AC-Volt-A, poll = 1, last = 1513176132.92639
2017.12.13 15:57:11 4: KeSolarEdge: GetUpdate will request AC-Volt-A
2017.12.13 15:57:11 5: KeSolarEdge: GetUpdate check h40082 => AC-Volt-Scale, poll = 1, last = 1513176131.50495
2017.12.13 15:57:11 4: KeSolarEdge: GetUpdate will request AC-Volt-Scale
2017.12.13 15:57:11 5: KeSolarEdge: GetUpdate check h40083 => AC-Power, poll = 1, last = 1513176996.52662
2017.12.13 15:57:11 4: KeSolarEdge: GetUpdate will request AC-Power
2017.12.13 15:57:11 5: KeSolarEdge: GetUpdate check h40084 => AC-Power-Scale, poll = 1, last = 1513176996.56613
2017.12.13 15:57:11 4: KeSolarEdge: GetUpdate will request AC-Power-Scale
2017.12.13 15:57:11 5: KeSolarEdge: GetUpdate check h40093 => AC-Energy, poll = 1, last = 1513176996.42373
2017.12.13 15:57:11 4: KeSolarEdge: GetUpdate will request AC-Energy
2017.12.13 15:57:11 5: KeSolarEdge: GetUpdate check h40095 => AC-Energy-Scale, poll = 1, last = 1513176996.46258
2017.12.13 15:57:11 4: KeSolarEdge: GetUpdate will request AC-Energy-Scale
2017.12.13 15:57:11 5: KeSolarEdge: GetUpdate check h40096 => DC-Current, poll = 1, last = 1513176131.71948
2017.12.13 15:57:11 4: KeSolarEdge: GetUpdate will request DC-Current
2017.12.13 15:57:11 5: KeSolarEdge: GetUpdate check h40097 => DC-Current-Scale, poll = 1, last = 1513176131.61059
2017.12.13 15:57:11 4: KeSolarEdge: GetUpdate will request DC-Current-Scale
2017.12.13 15:57:11 5: KeSolarEdge: GetUpdate check h40098 => DC-Voltage, poll = 1, last = 1513176996.79503
2017.12.13 15:57:11 4: KeSolarEdge: GetUpdate will request DC-Voltage
2017.12.13 15:57:11 5: KeSolarEdge: GetUpdate check h40099 => DC-Voltage-Scale, poll = 1, last = 1513176996.83781
2017.12.13 15:57:11 4: KeSolarEdge: GetUpdate will request DC-Voltage-Scale
2017.12.13 15:57:11 5: KeSolarEdge: GetUpdate check h40100 => DC-Power, poll = 1, last = 1513176996.66803
2017.12.13 15:57:11 4: KeSolarEdge: GetUpdate will request DC-Power
2017.12.13 15:57:11 5: KeSolarEdge: GetUpdate check h40101 => DC-Power-Scale, poll = 1, last = 1513176996.72279
2017.12.13 15:57:11 4: KeSolarEdge: GetUpdate will request DC-Power-Scale
2017.12.13 15:57:11 5: KeSolarEdge: GetUpdate check h40103 => HeatSinkTemp, poll = 1, last = 1513176132.59902
2017.12.13 15:57:11 4: KeSolarEdge: GetUpdate will request HeatSinkTemp
2017.12.13 15:57:11 5: KeSolarEdge: GetUpdate check h40107 => Status, poll = 1, last = 1513176996.89762
2017.12.13 15:57:11 4: KeSolarEdge: GetUpdate will request Status
2017.12.13 15:57:11 5: KeSolarEdge: GetUpdate tries to combine read commands
2017.12.13 15:57:11 5: KeSolarEdge: No Combine AC-Volt-A / h40079 with AC-Volt-Scale / h40082, span 4 > max 1
2017.12.13 15:57:11 5: KeSolarEdge: No Combine AC-Volt-Scale / h40082 with AC-Power / h40083, span 2 > max 1
2017.12.13 15:57:11 5: KeSolarEdge: No Combine AC-Power / h40083 with AC-Power-Scale / h40084, span 2 > max 1
2017.12.13 15:57:11 5: KeSolarEdge: No Combine AC-Power-Scale / h40084 with AC-Energy / h40093, span 11 > max 1
2017.12.13 15:57:11 5: KeSolarEdge: No Combine AC-Energy / h40093 with AC-Energy-Scale / h40095, span 3 > max 1
2017.12.13 15:57:11 5: KeSolarEdge: No Combine AC-Energy-Scale / h40095 with DC-Current / h40096, span 2 > max 1
2017.12.13 15:57:11 5: KeSolarEdge: No Combine DC-Current / h40096 with DC-Current-Scale / h40097, span 2 > max 1
2017.12.13 15:57:11 5: KeSolarEdge: No Combine DC-Current-Scale / h40097 with DC-Voltage / h40098, span 2 > max 1
2017.12.13 15:57:11 5: KeSolarEdge: No Combine DC-Voltage / h40098 with DC-Voltage-Scale / h40099, span 2 > max 1
2017.12.13 15:57:11 5: KeSolarEdge: No Combine DC-Voltage-Scale / h40099 with DC-Power / h40100, span 2 > max 1
2017.12.13 15:57:11 5: KeSolarEdge: No Combine DC-Power / h40100 with DC-Power-Scale / h40101, span 2 > max 1
2017.12.13 15:57:11 5: KeSolarEdge: No Combine DC-Power-Scale / h40101 with HeatSinkTemp / h40103, span 3 > max 1
2017.12.13 15:57:11 5: KeSolarEdge: No Combine HeatSinkTemp / h40103 with Status / h40107, span 5 > max 1
2017.12.13 15:57:11 5: KeSolarEdge: don't sort objList before sending requests
2017.12.13 15:57:11 4: KeSolarEdge: Send called with h40082, objLen 1 / reqLen 1 to id 1, op read, qlen 0
2017.12.13 15:57:11 4: KeSolarEdge: Send queues fc 3 to 1, tid 199, for h40082 (AC-Volt-Scale), reqLen 1
2017.12.13 15:57:11 5: KeSolarEdge: handle queue check commDelay (0.1) for KeSolarEdge: rest -34.4885032176971
2017.12.13 15:57:11 5: KeSolarEdge: handle queue check sendDelay (0.1) for KeSolarEdge: rest -34.4925169944763
2017.12.13 15:57:11 5: KeSolarEdge: HandleSendQueue: finished delay checking, proceed with sending
2017.12.13 15:57:11 4: KeSolarEdge: HandleSendQueue sends fc 3 to id 1, tid 199 for AC-Volt-Scale (h40082), len 1, device KeSolarEdge (TCP), pdu 039c920001, V 3.7.0 - 20.8.2017
2017.12.13 15:57:11 5: SW: 00c70000000601039c920001
2017.12.13 15:57:11 4: KeSolarEdge: Send called with h40097, objLen 1 / reqLen 1 to id 1, op read, qlen 0
2017.12.13 15:57:11 4: KeSolarEdge: Send queues fc 3 to 1, tid 9, for h40097 (DC-Current-Scale), reqLen 1
2017.12.13 15:57:11 4: KeSolarEdge: Send called with h40096, objLen 1 / reqLen 1 to id 1, op read, qlen 1
2017.12.13 15:57:11 4: KeSolarEdge: Send queues fc 3 to 1, tid 226, for h40096 (DC-Current), reqLen 1
2017.12.13 15:57:11 4: KeSolarEdge: Send called with h40099, objLen 1 / reqLen 1 to id 1, op read, qlen 2
2017.12.13 15:57:11 4: KeSolarEdge: Send queues fc 3 to 1, tid 4, for h40099 (DC-Voltage-Scale), reqLen 1
2017.12.13 15:57:11 4: KeSolarEdge: Send called with h40083, objLen 1 / reqLen 1 to id 1, op read, qlen 3
2017.12.13 15:57:11 4: KeSolarEdge: Send queues fc 3 to 1, tid 192, for h40083 (AC-Power), reqLen 1
2017.12.13 15:57:11 4: KeSolarEdge: Send called with h40107, objLen 1 / reqLen 1 to id 1, op read, qlen 4
2017.12.13 15:57:11 4: KeSolarEdge: Send queues fc 3 to 1, tid 212, for h40107 (Status), reqLen 1
2017.12.13 15:57:11 4: KeSolarEdge: Send called with h40095, objLen 1 / reqLen 1 to id 1, op read, qlen 5
2017.12.13 15:57:11 4: KeSolarEdge: Send queues fc 3 to 1, tid 45, for h40095 (AC-Energy-Scale), reqLen 1
2017.12.13 15:57:11 4: KeSolarEdge: Send called with h40084, objLen 1 / reqLen 1 to id 1, op read, qlen 6
2017.12.13 15:57:11 4: KeSolarEdge: Send queues fc 3 to 1, tid 125, for h40084 (AC-Power-Scale), reqLen 1
2017.12.13 15:57:11 4: KeSolarEdge: Send called with h40093, objLen 2 / reqLen 2 to id 1, op read, qlen 7
2017.12.13 15:57:11 4: KeSolarEdge: Send queues fc 3 to 1, tid 121, for h40093 (AC-Energy), reqLen 2
2017.12.13 15:57:11 4: KeSolarEdge: Send called with h40101, objLen 1 / reqLen 1 to id 1, op read, qlen 8
2017.12.13 15:57:11 4: KeSolarEdge: Send queues fc 3 to 1, tid 92, for h40101 (DC-Power-Scale), reqLen 1
2017.12.13 15:57:11 4: KeSolarEdge: Send called with h40103, objLen 1 / reqLen 1 to id 1, op read, qlen 9
2017.12.13 15:57:11 4: KeSolarEdge: Send queues fc 3 to 1, tid 189, for h40103 (HeatSinkTemp), reqLen 1
2017.12.13 15:57:11 4: KeSolarEdge: Send called with h40100, objLen 1 / reqLen 1 to id 1, op read, qlen 10
2017.12.13 15:57:11 4: KeSolarEdge: Send queues fc 3 to 1, tid 114, for h40100 (DC-Power), reqLen 1
2017.12.13 15:57:11 4: KeSolarEdge: Send called with h40098, objLen 1 / reqLen 1 to id 1, op read, qlen 11
2017.12.13 15:57:11 4: KeSolarEdge: Send queues fc 3 to 1, tid 81, for h40098 (DC-Voltage), reqLen 1
2017.12.13 15:57:11 4: KeSolarEdge: Send called with h40079, objLen 1 / reqLen 1 to id 1, op read, qlen 12
2017.12.13 15:57:11 4: KeSolarEdge: Send queues fc 3 to 1, tid 209, for h40079 (AC-Volt-A), reqLen 1
2017.12.13 15:57:11 5: KeSolarEdge: raw read: 00c700000005010302ffff
2017.12.13 15:57:11 5: KeSolarEdge: ParseFrames got: 00c700000005010302ffff
2017.12.13 15:57:11 4: KeSolarEdge: ParseFrames got fcode 3 from 1, tid 199, values ffffHeaderLen 2, ActualLen 2, request was for h40082 (AC-Volt-Scale), len 1 for module KeSolarEdge
2017.12.13 15:57:11 5: KeSolarEdge: ParseObj called with ffff and start 40082, op read
2017.12.13 15:57:11 5: KeSolarEdge: ParseObj ObjInfo for h40082: reading=AC-Volt-Scale, unpack=s>, expr=, format=, map=
2017.12.13 15:57:11 5: KeSolarEdge: ParseObj unpacked ffff with s> to hex 2d31 (-1)
2017.12.13 15:57:11 4: KeSolarEdge: ParseObj for AC-Volt-Scale assigns -1
2017.12.13 15:57:11 5: KeSolarEdge: ParseFrames got 1 readings from ParseObj
2017.12.13 15:57:11 5: KeSolarEdge: handle queue check commDelay (0.1) for KeSolarEdge: rest 0.0708389282226562
2017.12.13 15:57:11 4: KeSolarEdge: HandleSendQueue / CheckDelay commDelay (0.1) for KeSolarEdge not over, try again in 0.0708389282226562
2017.12.13 15:57:11 5: KeSolarEdge: handle queue check commDelay (0.1) for KeSolarEdge: rest -0.00173425674438477
2017.12.13 15:57:11 5: KeSolarEdge: handle queue check sendDelay (0.1) for KeSolarEdge: rest -0.0245509147644043
2017.12.13 15:57:11 4: KeSolarEdge: HandleSendQueue sends fc 3 to id 1, tid 9 for DC-Current-Scale (h40097), len 1, device KeSolarEdge (TCP), pdu 039ca10001, V 3.7.0 - 20.8.2017
2017.12.13 15:57:11 5: SW: 00090000000601039ca10001
2017.12.13 15:57:11 5: KeSolarEdge: raw read: 000900000005010302fffb
2017.12.13 15:57:11 5: KeSolarEdge: ParseFrames got: 000900000005010302fffb
2017.12.13 15:57:11 4: KeSolarEdge: ParseFrames got fcode 3 from 1, tid 9, values fffbHeaderLen 2, ActualLen 2, request was for h40097 (DC-Current-Scale), len 1 for module KeSolarEdge
2017.12.13 15:57:11 5: KeSolarEdge: ParseObj called with fffb and start 40097, op read
2017.12.13 15:57:11 5: KeSolarEdge: ParseObj ObjInfo for h40097: reading=DC-Current-Scale, unpack=s>, expr=, format=, map=
2017.12.13 15:57:11 5: KeSolarEdge: ParseObj unpacked fffb with s> to hex 2d35 (-5)
2017.12.13 15:57:11 4: KeSolarEdge: ParseObj for DC-Current-Scale assigns -5
2017.12.13 15:57:11 5: KeSolarEdge: handle queue check commDelay (0.1) for KeSolarEdge: rest 0.0707628726959229
2017.12.13 15:57:11 4: KeSolarEdge: HandleSendQueue / CheckDelay commDelay (0.1) for KeSolarEdge not over, try again in 0.0707628726959229
2017.12.13 15:57:11 5: KeSolarEdge: handle queue check commDelay (0.1) for KeSolarEdge: rest -0.00237607955932617
2017.12.13 15:57:11 5: KeSolarEdge: handle queue check sendDelay (0.1) for KeSolarEdge: rest -0.00801301002502441
2017.12.13 15:57:11 4: KeSolarEdge: HandleSendQueue sends fc 3 to id 1, tid 226 for DC-Current (h40096), len 1, device KeSolarEdge (TCP), pdu 039ca00001, V 3.7.0 - 20.8.2017
2017.12.13 15:57:11 5: SW: 00e20000000601039ca00001
2017.12.13 15:57:11 5: KeSolarEdge: raw read: 00e2000000050103020fe6
2017.12.13 15:57:11 5: KeSolarEdge: ParseFrames got: 00e2000000050103020fe6
2017.12.13 15:57:11 4: KeSolarEdge: ParseFrames got fcode 3 from 1, tid 226, values 0fe6HeaderLen 2, ActualLen 2, request was for h40096 (DC-Current), len 1 for module KeSolarEdge
2017.12.13 15:57:11 5: KeSolarEdge: ParseObj called with 0fe6 and start 40096, op read
2017.12.13 15:57:11 5: KeSolarEdge: ParseObj ObjInfo for h40096: reading=DC-Current, unpack=n, expr=, format=, map=
2017.12.13 15:57:11 5: KeSolarEdge: ParseObj unpacked 0fe6 with n to hex 34303730 (4070)
2017.12.13 15:57:11 4: KeSolarEdge: ParseObj for DC-Current assigns 4070
2017.12.13 15:57:11 5: KeSolarEdge: handle queue check commDelay (0.1) for KeSolarEdge: rest 0.0562348365783691
2017.12.13 15:57:11 4: KeSolarEdge: HandleSendQueue / CheckDelay commDelay (0.1) for KeSolarEdge not over, try again in 0.0562348365783691
2017.12.13 15:57:11 5: KeSolarEdge: handle queue check commDelay (0.1) for KeSolarEdge: rest -0.0024261474609375
2017.12.13 15:57:11 5: KeSolarEdge: handle queue check sendDelay (0.1) for KeSolarEdge: rest -0.00670814514160156
2017.12.13 15:57:11 4: KeSolarEdge: HandleSendQueue sends fc 3 to id 1, tid 4 for DC-Voltage-Scale (h40099), len 1, device KeSolarEdge (TCP), pdu 039ca30001, V 3.7.0 - 20.8.2017
2017.12.13 15:57:11 5: SW: 00040000000601039ca30001
2017.12.13 15:57:11 5: KeSolarEdge: raw read: 000400000005010302ffff
2017.12.13 15:57:11 5: KeSolarEdge: ParseFrames got: 000400000005010302ffff
2017.12.13 15:57:11 4: KeSolarEdge: ParseFrames got fcode 3 from 1, tid 4, values ffffHeaderLen 2, ActualLen 2, request was for h40099 (DC-Voltage-Scale), len 1 for module KeSolarEdge
2017.12.13 15:57:11 5: KeSolarEdge: ParseObj called with ffff and start 40099, op read
2017.12.13 15:57:11 5: KeSolarEdge: ParseObj ObjInfo for h40099: reading=DC-Voltage-Scale, unpack=s>, expr=, format=, map=
2017.12.13 15:57:11 4: KeSolarEdge: ParseObj for DC-Voltage-Scale assigns -1
2017.12.13 15:57:11 5: KeSolarEdge: handle queue check commDelay (0.1) for KeSolarEdge: rest 0.0618929862976074
2017.12.13 15:57:11 4: KeSolarEdge: HandleSendQueue / CheckDelay commDelay (0.1) for KeSolarEdge not over, try again in 0.0618929862976074
2017.12.13 15:57:11 5: KeSolarEdge: handle queue check commDelay (0.1) for KeSolarEdge: rest -0.00171709060668945
2017.12.13 15:57:11 5: KeSolarEdge: handle queue check sendDelay (0.1) for KeSolarEdge: rest -0.0062410831451416
2017.12.13 15:57:11 4: KeSolarEdge: HandleSendQueue sends fc 3 to id 1, tid 192 for AC-Power (h40083), len 1, device KeSolarEdge (TCP), pdu 039c930001, V 3.7.0 - 20.8.2017
2017.12.13 15:57:11 5: SW: 00c00000000601039c930001
2017.12.13 15:57:11 5: KeSolarEdge: raw read: 00c0000000050103026978
2017.12.13 15:57:11 5: KeSolarEdge: ParseFrames got: 00c0000000050103026978
2017.12.13 15:57:11 4: KeSolarEdge: ParseFrames got fcode 3 from 1, tid 192, values 6978HeaderLen 2, ActualLen 2, request was for h40083 (AC-Power), len 1 for module KeSolarEdge
2017.12.13 15:57:11 5: KeSolarEdge: ParseObj called with 6978 and start 40083, op read
2017.12.13 15:57:11 5: KeSolarEdge: ParseObj ObjInfo for h40083: reading=AC-Power, unpack=n, expr=, format=, map=
2017.12.13 15:57:11 5: KeSolarEdge: ParseObj unpacked 6978 with n to hex 3237303030 (27000)
2017.12.13 15:57:11 4: KeSolarEdge: ParseObj for AC-Power assigns 27000
2017.12.13 15:57:11 5: KeSolarEdge: handle queue check commDelay (0.1) for KeSolarEdge: rest 0.0634677410125732
2017.12.13 15:57:11 4: KeSolarEdge: HandleSendQueue / CheckDelay commDelay (0.1) for KeSolarEdge not over, try again in 0.0634677410125732
2017.12.13 15:57:12 5: KeSolarEdge: handle queue check commDelay (0.1) for KeSolarEdge: rest -0.00258421897888184
2017.12.13 15:57:12 5: KeSolarEdge: handle queue check sendDelay (0.1) for KeSolarEdge: rest -0.0070033073425293
2017.12.13 15:57:12 5: KeSolarEdge: HandleSendQueue: finished delay checking, proceed with sending
2017.12.13 15:57:12 4: KeSolarEdge: HandleSendQueue sends fc 3 to id 1, tid 212 for Status (h40107), len 1, device KeSolarEdge (TCP), pdu 039cab0001, V 3.7.0 - 20.8.2017
2017.12.13 15:57:12 5: SW: 00d40000000601039cab0001
2017.12.13 15:57:12 5: KeSolarEdge: raw read: 00d4000000050103020004
2017.12.13 15:57:12 5: KeSolarEdge: ParseFrames got: 00d4000000050103020004
2017.12.13 15:57:12 4: KeSolarEdge: ParseFrames got fcode 3 from 1, tid 212, values 0004HeaderLen 2, ActualLen 2, request was for h40107 (Status), len 1 for module KeSolarEdge
2017.12.13 15:57:12 5: KeSolarEdge: ParseObj called with 0004 and start 40107, op read
2017.12.13 15:57:12 5: KeSolarEdge: ParseObj ObjInfo for h40107: reading=Status, unpack=n, expr=, format=, map=
2017.12.13 15:57:12 5: KeSolarEdge: ParseObj unpacked 0004 with n to hex 34 (4)
2017.12.13 15:57:12 4: KeSolarEdge: ParseObj for Status assigns 4
2017.12.13 15:57:12 5: KeSolarEdge: ParseFrames got 1 readings from ParseObj
2017.12.13 15:57:12 5: KeSolarEdge: handle queue check commDelay (0.1) for KeSolarEdge: rest 0.0562198162078857
2017.12.13 15:57:12 4: KeSolarEdge: HandleSendQueue / CheckDelay commDelay (0.1) for KeSolarEdge not over, try again in 0.0562198162078857
2017.12.13 15:57:12 5: KeSolarEdge: handle queue check commDelay (0.1) for KeSolarEdge: rest -0.0022730827331543
2017.12.13 15:57:12 5: KeSolarEdge: handle queue check sendDelay (0.1) for KeSolarEdge: rest -0.00712800025939941
2017.12.13 15:57:12 4: KeSolarEdge: HandleSendQueue sends fc 3 to id 1, tid 45 for AC-Energy-Scale (h40095), len 1, device KeSolarEdge (TCP), pdu 039c9f0001, V 3.7.0 - 20.8.2017
2017.12.13 15:57:12 5: SW: 002d0000000601039c9f0001
2017.12.13 15:57:12 5: KeSolarEdge: raw read: 002d000000050103020000
2017.12.13 15:57:12 5: KeSolarEdge: ParseFrames got: 002d000000050103020000
2017.12.13 15:57:12 4: KeSolarEdge: ParseFrames got fcode 3 from 1, tid 45, values 0000HeaderLen 2, ActualLen 2, request was for h40095 (AC-Energy-Scale), len 1 for module KeSolarEdge
2017.12.13 15:57:12 5: KeSolarEdge: ParseObj called with 0000 and start 40095, op read
2017.12.13 15:57:12 5: KeSolarEdge: ParseObj ObjInfo for h40095: reading=AC-Energy-Scale, unpack=n, expr=, format=, map=
2017.12.13 15:57:12 5: KeSolarEdge: ParseObj unpacked 0000 with n to hex 30 (0)
2017.12.13 15:57:12 4: KeSolarEdge: ParseObj for AC-Energy-Scale assigns 0
2017.12.13 15:57:12 5: KeSolarEdge: handle queue check commDelay (0.1) for KeSolarEdge: rest 0.0704658031463623
2017.12.13 15:57:12 4: KeSolarEdge: HandleSendQueue / CheckDelay commDelay (0.1) for KeSolarEdge not over, try again in 0.0704658031463623
2017.12.13 15:57:12 5: KeSolarEdge: handle queue check commDelay (0.1) for KeSolarEdge: rest -0.00171422958374023
2017.12.13 15:57:12 5: KeSolarEdge: handle queue check sendDelay (0.1) for KeSolarEdge: rest -0.0050661563873291
2017.12.13 15:57:12 4: KeSolarEdge: HandleSendQueue sends fc 3 to id 1, tid 125 for AC-Power-Scale (h40084), len 1, device KeSolarEdge (TCP), pdu 039c940001, V 3.7.0 - 20.8.2017
2017.12.13 15:57:12 5: SW: 007d0000000601039c940001
2017.12.13 15:57:12 5: KeSolarEdge: raw read: 007d00000005010302fffe
2017.12.13 15:57:12 5: KeSolarEdge: ParseFrames got: 007d00000005010302fffe
2017.12.13 15:57:12 4: KeSolarEdge: ParseFrames got fcode 3 from 1, tid 125, values fffeHeaderLen 2, ActualLen 2, request was for h40084 (AC-Power-Scale), len 1 for module KeSolarEdge
2017.12.13 15:57:12 5: KeSolarEdge: ParseObj called with fffe and start 40084, op read
2017.12.13 15:57:12 5: KeSolarEdge: ParseObj ObjInfo for h40084: reading=AC-Power-Scale, unpack=s>, expr=, format=, map=
2017.12.13 15:57:12 5: KeSolarEdge: ParseObj unpacked fffe with s> to hex 2d32 (-2)
2017.12.13 15:57:12 4: KeSolarEdge: ParseObj for AC-Power-Scale assigns -2
2017.12.13 15:57:12 5: KeSolarEdge: handle queue check commDelay (0.1) for KeSolarEdge: rest 0.0694448947906494
2017.12.13 15:57:12 4: KeSolarEdge: HandleSendQueue / CheckDelay commDelay (0.1) for KeSolarEdge not over, try again in 0.0694448947906494
2017.12.13 15:57:12 5: KeSolarEdge: handle queue check commDelay (0.1) for KeSolarEdge: rest -0.00162005424499512
2017.12.13 15:57:12 5: KeSolarEdge: handle queue check sendDelay (0.1) for KeSolarEdge: rest -0.00555109977722168
2017.12.13 15:57:12 4: KeSolarEdge: HandleSendQueue sends fc 3 to id 1, tid 121 for AC-Energy (h40093), len 2, device KeSolarEdge (TCP), pdu 039c9d0002, V 3.7.0 - 20.8.2017
2017.12.13 15:57:12 5: SW: 00790000000601039c9d0002
2017.12.13 15:57:12 5: KeSolarEdge: raw read: 00790000000701030400010268
2017.12.13 15:57:12 5: KeSolarEdge: ParseFrames got: 00790000000701030400010268
2017.12.13 15:57:12 4: KeSolarEdge: ParseFrames got fcode 3 from 1, tid 121, values 00010268HeaderLen 4, ActualLen 4, request was for h40093 (AC-Energy), len 2 for module KeSolarEdge
2017.12.13 15:57:12 5: KeSolarEdge: ParseObj called with 00010268 and start 40093, op read
2017.12.13 15:57:12 5: KeSolarEdge: ParseObj ObjInfo for h40093: reading=AC-Energy, unpack=l>, expr=, format=, map=
2017.12.13 15:57:12 5: KeSolarEdge: ParseObj unpacked 00010268 with l> to hex 3636313532 (66152)
2017.12.13 15:57:12 4: KeSolarEdge: ParseObj for AC-Energy assigns 66152
2017.12.13 15:57:12 5: KeSolarEdge: handle queue check commDelay (0.1) for KeSolarEdge: rest 0.070537805557251
2017.12.13 15:57:12 4: KeSolarEdge: HandleSendQueue / CheckDelay commDelay (0.1) for KeSolarEdge not over, try again in 0.070537805557251
2017.12.13 15:57:12 5: KeSolarEdge: handle queue check commDelay (0.1) for KeSolarEdge: rest -0.00167107582092285
2017.12.13 15:57:12 5: KeSolarEdge: handle queue check sendDelay (0.1) for KeSolarEdge: rest -0.00990128517150879
2017.12.13 15:57:12 4: KeSolarEdge: HandleSendQueue sends fc 3 to id 1, tid 92 for DC-Power-Scale (h40101), len 1, device KeSolarEdge (TCP), pdu 039ca50001, V 3.7.0 - 20.8.2017
2017.12.13 15:57:12 5: SW: 005c0000000601039ca50001
2017.12.13 15:57:12 5: KeSolarEdge: raw read: 005c00000005010302fffd
2017.12.13 15:57:12 5: KeSolarEdge: ParseFrames got: 005c00000005010302fffd
2017.12.13 15:57:12 4: KeSolarEdge: ParseFrames got fcode 3 from 1, tid 92, values fffdHeaderLen 2, ActualLen 2, request was for h40101 (DC-Power-Scale), len 1 for module KeSolarEdge
2017.12.13 15:57:12 5: KeSolarEdge: ParseObj called with fffd and start 40101, op read
