dewpoint_notify: fan ON/OFF
Begonnen von laxmann, 10 Dezember 2017, 18:42:22
laxmann
seid meinem letzten Fhem-Update vom 9.12.2017
2017.12.09 13:03:34.991 1: UPD ./CHANGED
2017.12.09 13:03:35.063 1: UPD ./fhem.pl
2017.12.09 13:03:35.129 1: UPD FHEM/00_THZ.pm
2017.12.09 13:03:35.190 1: UPD FHEM/01_FHEMWEB.pm
2017.12.09 13:03:35.256 1: UPD FHEM/10_FBDECT.pm
2017.12.09 13:03:35.305 1: UPD FHEM/46_SmartPi.pm
2017.12.09 13:03:35.347 1: UPD FHEM/53_GHoma.pm
2017.12.09 13:03:35.394 1: UPD FHEM/92_FileLog.pm
2017.12.09 13:03:35.438 1: UPD FHEM/93_DbRep.pm
2017.12.09 13:03:35.567 1: UPD FHEM/95_YAAHM.pm
2017.12.09 13:03:35.640 1: UPD FHEM/98_DOIF.pm
2017.12.09 13:03:35.722 1: UPD FHEM/98_SVG.pm
2017.12.09 13:03:35.773 1: UPD FHEM/98_Siro.pm
2017.12.09 13:03:35.829 1: UPD FHEM/98_configdb.pm
2017.12.09 13:03:35.866 1: UPD FHEM/98_dewpoint.pm
2017.12.09 13:03:35.911 1: UPD FHEM/98_update.pm
2017.12.09 13:03:35.949 1: UPD FHEM/98_weekprofile.pm
2017.12.09 13:03:35.993 1: UPD FHEM/99_SUNRISE_EL.pm
2017.12.09 13:03:36.031 1: UPD FHEM/HttpUtils.pm
2017.12.09 13:03:36.086 1: UPD docs/commandref_frame.html
2017.12.09 13:03:36.135 1: UPD docs/commandref_frame_DE.html
2017.12.09 13:03:36.304 1: UPD www/pgm2/doif.js
2017.12.09 13:03:36.335 1: UPD www/pgm2/fhemweb.js
2017.12.09 13:03:36.391 1: UPD www/pgm2/yaahm.js
2017.12.09 13:03:36.426 1: saving fhem.cfg
2017.12.09 13:03:36.431 1: saving ./log/fhem.save
2017.12.09 13:03:36.439 1:
2017.12.09 13:03:36.444 1: New entries in the CHANGED file:
2017.12.09 13:03:36.446 1:   - feature: 99_weekprofile: add support for CCU2 (experimental)
2017.12.09 13:03:36.448 1:   - change:  93_DbRep: V6.3.2 ,changelist to last version:
2017.12.09 13:03:36.452 1:                        - new command delSeqDoublets
2017.12.09 13:03:36.454 1:                        - add last command option to internal LASTCMD
2017.12.09 13:03:36.456 1:                        - add format d:xx h:xx m:xx s:xx for attributes
2017.12.09 13:03:36.457 1:                          timeDiffToNow, timeOlderThan
2017.12.09 13:03:36.461 1:                        - new attribute fetchRoute to switch asc,desc datafetch
2017.12.09 13:03:36.463 1:   - change:  HttpUtils: compression activated
2017.12.09 13:03:36.464 1:              disable it with attr global httpcompress 0
2017.12.09 13:03:36.468 1:   - bugfix:  46_SmartPi: fix syntax error bug in Attribut Sub
2017.12.09 13:03:36.469 1:   - change:  98_dewpoint: Refactoring using API calls, verbose attribute added
2017.12.09 13:03:36.470 1:   - change:  FileLog removes newlines from the data (Forum #79684)
2017.12.09 13:03:36.704 1:   - bugfix:  98_Siro.pm: Support favorit for model ERB15LE
tritt in meinem Logfile jetzt folgendes auf
2017.12.09 13:07:33.606 3: dewpoint_notify: fan ON
2017.12.09 13:07:33.704 3: dewpoint_notify: fan ON
Diese Meldung tritt ca. alle 5 Minuten jetzt auf.
Hat sich etwas verändert?
Wird "dewpoint" jetzt alle 5 Minuten aktualisiert? Ich übergebe "dewpoint" in meiner Schaltung einem Dummy, damit ich den Wert von "dewpoint jederzeit abrufen kann.
Ich finde in meiner FHEM-Installation auch den Verursacher von
nicht.
laxmann
helmut
CHANGED:   - change:  98_dewpoint: Refactoring using API calls, verbose attribute added
98_dewpoint.pm:
            if (($dewpoint_out + $diff_temp) < $dewpoint && $temperature_out >= $min_temp) {
                $current = "on";
                Log3($hashName, 3, "dewpoint_notify: fan ON");
            } else {
                $current = "off";
                Log3($hashName, 3, "dewpoint_notify: fan OFF");
Das ist wohl Absicht so. Du kannst ja den verbosity level heruntersetzen.
Gruss Helmut
Intelligenz ist die Fähigkeit, Arbeit zu vermeiden, aber dafür zu sorgen, daß die Arbeit gemacht wird.
(Linus Torvalds)
CoolTux
Das wird ich beim Maintainer als zu diskutieren ansprechen. Ich wäre der Meinung das dies als verbose 3 falsch ist. Wenn dann höchstens ab verbose 4. Ruhig Mal ansprechen.
Das TuxNet Wiki:
https://www.cooltux.net
laxmann
Hallo Helmut und CoolTux,
ich habe den verbose-Wert verändert. Einmal 4, dann 2 und dann wieder auf 3.
Das letztemal
2017.12.11 18:15:55.252 3: dewpoint_notify: fan ON
2017.12.11 18:16:09.067 3: dewpoint_notify: fan ON
war vor den Änderungen des verbose-Wertes.
Nach mehreren FHEM-Neustarts gibt es keine Meldungen mehr.
Ich warte mal zu.
Gruss laxmann
hotbso
Aus der command ref
Set the verbosity level. Possible values:
0 - server start/stop
1 - error messages or unknown packets
2 - major events/alarms.
3 - commands sent out will be logged.
4 - you'll see whats received by the different devices.
5 - debugging.
Ich habe Ein- Ausschalten eines Fan mal als "commands sent out" interpretiert und deshalb Loglevel 3 genommen.
Wenn das zu größeren Problemen führt, kann ich das ggf. auch ändern.
CoolTux
Zitat von: hotbso am 12 Dezember 2017, 16:15:53
Aus der command ref
5 - debugging.
Persönlich denke ich das es an der Praxis vorbei geht wenn alle 5 min so ein Eintrag im Log steht. verbose 3 ist ja default
Das TuxNet Wiki:
hotbso
Da die 3 inzwischen nicht mehr der Lebenspraxis entspricht, werde ich das Loglevel bei der nächsten Überarbeitung auf 4 setzen.
Gesendet von meinem Nexus 5X mit Tapatalk
mi.ke
Moin.
Wollte mal nachfragen . . .
Die aktuelle Version steht immer noch auf Loglevel 3
Id: 98_dewpoint.pm 16949 2018-07-06 14:06:51Z hotbso $
cheers
mi.ke
FHEM 31310 | Mini PC N100, RPi4 + 5 x RPi(Z) + FB7590 + FB 6890 LTE via LAN / WAN (VPN).
2 x CUL868 + 3 x RFXTRX(e) + 6 x HMwLanGW + 5 x z2tGw + 5 x LGW + 2 x IRBlast + CO2 +++
FS20, FHT, FMS, Elro(mod), CM160, Revolt, LGTV, STV, AVR, withings, HM-*, MQTT2, ZigBee, AMAD, PCA301, arlo, Aqara,
CoolTux
Jep und das schon seit 2 neuen Versionen. Ich stelle das dann jedesmal auf 4
Das TuxNet Wiki:
hotbso
Das war mir wohl durch die Lappen gegangen, ist jetzt behoben.
