Autor Thema: Can't find how to prevent access to detail view in FHEMWEB  (Gelesen 866 mal)
Offline oliv06
  • Full Member
    • Play with Free : FHEM
« am: 12 Dezember 2017, 08:22:26 »
Is is possible to remove link to detailed device view in FHEMWEB ? I thought it was but I cannot find how to. :(
Offline RaspiLED
  • Es begann alles so klein ;-)
Antw:Can't find how to prevent access to detail view in FHEMWEB
« Antwort #1 am: 12 Dezember 2017, 08:57:08 »
I'm not sure if I understood you correct, but try room hidden.
Warm regards, Arnd
Gesendet von meinem SM-G800F mit Tapatalk
Offline rudolfkoenig
  • Administrator
« Antwort #2 am: 12 Dezember 2017, 09:39:28 »
https://fhem.de/commandref.html#hiddenroom
hiddenroom
 Comma separated list of rooms to "hide", i.e. not to show. Special values are input, detail and save, in which case the input areas, link to the detailed views or save button is hidden (although each aspect still can be addressed through URL manipulation).
 The list can also contain values from the additional "Howto/Wiki/FAQ" block.
Offline oliv06
  • Full Member
« Antwort #3 am: 12 Dezember 2017, 10:09:09 »
Thanks a lot, will try it this evening !
